View Full Version : Honda Civic / Del Sol (1992 - 2000)
- right hand drive EK impounded! help!
- Single Wiper Conversion
- Engine rebuild tools. Where?
- JDM ps sensortorx screw size?
- D16z6: CEL at top of 3rd gear @ WOT.... ?
- B16 wont turn over, other problems that lead to this. Please help.
- how restrictive do u think this will be?
- i need some ecu info!!!
- idle/ gas milage problems please look
- b16a build up
- Whats easier to swap?
- important question!!!
- ATS LSD for my 2001 b18c swap 94 eg.
- tein hood damper for eg
- a fair deal
- EF Si civic seats into an EG hatch
- Oil light blip while turning with new moroso oil pan and stock pan.
- Radiator Hose pressure extremly high,what can cause this headgasket?
- 92 si, Air conditioning + swap question
- help testing the vtec solenoid
- condensation water in spark plug valve cover misfire help
- Quick question how long is the endlink bolt for a del sol front sway bar
- GSR Intake Manny swap
- snapped timing belt!!!some ?'s on this
- Looking for some very quiet exhausts for me 99 EK coupe.........help
- Getting ready to swap my self built b18b.
- Carbon hatch fitment
- B16a2 question
- advance timing
- SEAFOAM.... now its blowing blue smoke!!!!!!! is this normal?
- chicago doHc
- Front bumper removal.
- b16a sir1 axle question
- chipped ecu?
- coupe w/gsr wont go into gear????
- si cluster
- Is this a good turbo for my del sol?
- Smoke coming through vents, shifter area?
- boost or swap
- NOS on a d16y8
- question on camshafts for my b16a
- Boosting D16
- Parts list diagrams..?
- Civic exhaust hangers? 92-95 same as 96-00?
- B16a injector trouble
- GSR front strut bar into an EG
- sounds like shots of compressed air
- Wont Start...
- today
- headlight bulb
- Left front lower by 3/4"
- what shift linkage to use
- My B20VTEC Build
- -~Chipped ECU question--
- dropping the car
- zc sohc vtec swap into EG, help
- B16 Fuel Rail Installation
- Help With Arospeed Coil-springs!
- T1R Exhaust?
- pic request or quesiton.
- Auto to manual gearbox mount for conversion in EJ
- HELP...crank no start weird speedo/vss
- need some help with swap...
- Painting Mud Flaps??
- does any body know if this will help any
- testing and diagnostics for any honda
- s2000 seats in a civic?
- pls help =)
- Axle & CV joint out of place...
- PLS POST YOUR EG HATCH PICS....
- which turbo should I get????
- Jdm EG console pics?????
- 96 civic engine blown
- [Question] B16A2 O2 Sensor
- Stock timing on 93 1.6 hatchback
- MOtor Blown?????HELP
- clutch upgrade
- Will it sound bad?
- I live in North Dakota and my heat doesnt work
- Ground Control/ KYB GR-2
- No check engine light
- OEM Fog lights vs. Password JDM Replica Fog Lights
- help running retarded
- A mass murder scene, with a twist of lazy
- Cluster lights flicker once Ignition placed in ON position
- power steering conversion. help.
- simple o2 sensor question
- Question about stock 96 hatch motor
- aftermarket Front LCA for sway bar install?
- ARP Extended wheel studs + Rays Lugs
- JDM headlight adjustment???
- Replaceing the clutch/flywheel. Swaped EK
- final drive ratio
- This is crazy (chk this ebay auction that ended)
- V-afc
- Need help lowering
- HELP!! ANY DIAGRAM FOR A OBD1 GSR VALVE ADJUSTMENT
- D16Z6 CAM IN D16Y8?
- What i need for this EG
- integra rear spindles on ek real trailing arm
- Will an OBD1 H22 harness fit a D16z6 OBD1
- mugen strut bar..
- SI Seats
- oil pressure
- JDM Si-R II Gauge Cluster Problems
- How do i fix this?
- Whats this tube for?
- just SEAFOAMED..... should i change my oil? HELP!!!!!!!!!!
- oem spoiler ( 3 led's burnt out )
- 93 civic h/b with 95 acura integra GSR front end ???
- Started my b18c without oil, did i damage it????????
- loss of power?
- tps question???
- GSR cams?
- MOTOR MOUNT HELP! ASAP
- Wind Noise
- holes for side skirt...
- purge kit???
- 2 VERY Important questions
- Exhaust question....Quick Help!!!!
- brake pad question...
- Does anyone know what this is????
- fuel pump fuse?
- Question about Civic SI oem suspension...
- DEL SOL WONT START Please help
- DIY EVAP removal, Look inside.
- diagrams for wire harness for power windows?
- Question about Intake ...please HELP
- looking for a computer
- OEM Tachometer
- Relay neccesary in hid retrofit?
- A/C question. '95 Civic
- advancing the timing on a stock engine... any cons?
- Write Up: How to wire up a Horn on a Non SRS EG Civic
- misfire and shuttering. irregular problem
- What size tires do I need for 17" going on a 1996 civic dx 2dr coupe?
- Got skunk2 full coilover kit with LCA...slammed the civic but really bumpy
- hasport or spoon motor mounts
- projectors
- can advancing the timing from spec. affect anything? gas mileage, power etc.
- RACERAMPS
- does a k20 fit into 1993 civic hatchback? or can a type s fit into it ?
- Car Was Running Fine Now wont start. No Crank and Barely any power even with new battery
- 2000 Turbo Civic Si
- Problems after tune was done
- Car smokes like crazy when PCV valve is in....
- 92 civic question
- Looking for input on manual trans problem
- Newbie from Singapore
- Quick question on clutch and pressure plate
- Idle problem
- CEL 16
- head lights killing my radio and also turn signals???
- HELP!!!
- coolant leak.. missing hose??
- what SPRING i should get for my TOKICO To setup a GOOD RIDE?? SMOOTH RIDE
- Obd1 code 8
- driveshaft problem
- Trunk Leak.......... (searched)
- ek mudguards with rear lip
- EG rear tailight housing help!
- 96 Foglight Question
- new guy needs some help
- Quick question for a swap about throttle cable
- i put a j. rac. sup. charger on my civic now i blow smoke!! i can't figure out why!!
- Rear lca bolt broke, another frozen. HELP
- Pic request of 99 civic dash
- 1998 Acura 1.6 EL/Honda civic EX
- engine harness help for 96 dx hatch
- vtec is being lame... help!
- Dizzy Question???
- Fuel Rail question
- what parts should I buy to get more hp out of my d-series?
- 5zigen
- need help pleaseee!!! thanks
- Need some help car died tonight
- thermostat question
- where to buy flex pipe?
- fuse box swap
- Alot of Debri Appearing on Bumper
- Interchangeable ECU!!!!!!
- From power steering to manuel steering.
- painting bumper with gun (2)
- Good Trade ? My 95 del sol Si vs 95 Integra LS Coupe
- need info on these spark plugs please
- 92 civic vx overheating when cold outside (40°F) after 20 minutes driving at 75 mph
- Need Wiring Help!!!
- Need link to rebuild b16a2(searched)
- 98 dx CLIMATE CONTROL want to put 99-00 CLIMATE CONTROL. Well it work????
- D15A6 Block
- NEED HELP ... del Sol trailing arm bushings need replacing
- Manual transmission
- Key in Ignition And Open Door Chime
- determining a aftermarket fuel pump
- Help: which ps belt to use on b16a2!
- Front bumper/ Grill question....
- del Sol S build updates .. let me know what you think
- HELPPP CLIMATE CONTROLL!!!!
- modified itr header???
- skunk2 intake manifold
- ek or ej?
- Adjusting valves, i need a write up for a d- series.
- EG/EJ 94-95 Air conditioning
- Wheel Hub Centric Rings with sportmax 002? nessesary?
- Block sleeving
- Rim and tire offset problem....HELP !!!
- jdm itr upper heatshield??
- disk brake bolts... can't find em??
- blown head gasket help
- How do you make soild mounts
- Wiring harness, radio, clock...need help
- b16 guide
- why is my car not staying on
- radiator hoses???? b18c into 00 ex...any factor hoses that are direct fit??
- benen tow hooks
- determining swapped JDM engine year.
- ****I NEED HELP IN FIXN UP MY SOHC V-TEC D16Z ENGINE!!!***
- Problem adjusting throttle cable
- Main Relay Location-EK
- tranny s20
- BADLY NEED OF HELP.....TPS!!!!!!!!!!!!!!!!!!!!!!!!!!
- Which H2B kit is complete?
- vtec question on b16/b18
- popping gauge fuses
- NEED HELP FAST.. CANT GET 93 CIVIC DX GUAGE BEZEL OR CLUSTER OUT
- p75 ecu code??..
- HX and EX ???????????
- Injen cai for itr fits Eg?
- Friends Distributor Removed and Reinstalled Back Now car Shakes
- Leaky Valve Cover! Tried Everything
- ECU list
- what is the honda junkyard website?
- Exhaust Question
- Standard Tranny
- Noob to 92+ civics...few questions on auto to manual b series swap?
- P28
- what does my EAV canister do??? do i need it???
- does this seem resonable : ngk spark plugs and wires
- installed new in. manifold & TB, idle is way high. help???
- Xenon relay burned out? =-(
- car vibrates when accelerating
- EK compression test?
- 98 civic engine swap
- B16 wont rev past 3500 rpm, and almost bogs when I tap the gas.....
- Piping Size on 99-00 Si
- Doing some checks on my b16 after blowing a head gasket
- Engine Torque Damper
- how to replace window track
- Help ASAP, Car wont start after obd2- obd1 conversion,
- ek and eg seats
