View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 5th gen honda auto tranny question
- 5th gear grind outta nowhere!!! WTF??? :( need some help
- ASR Subframe brace question and pics
- new foglight bulbs
- will EJ coupe axle back fit on a del sol
- 2000 rhd em1 project has come to an end! tragic :(
- I NEED MONEY4 CAR lol
- heat, but not hot
- not really new, but heres my project D/D
- mugen racing 2 steering wheel
- Cooling fan issues
- Stuck Rotors.
- 94 Civic VX CEL 41 Low Voltage
- norman guage temp
- D16y8 rebuild.
- foglights
- b18a1 swap in 94 civic dx
- d16 runs hotter than normal
- iat relocation?
- Effects from defective IAT
- oil swap question
- Parking Brake Cable Stuck??
- motor cooling
- Skunk2 IM
- hesistation when cold
- B18 swap PROBLEMS!!!!
- fuse keep popping problem please help help!
- Should I get a ZC SOHC engine to replace old engine?????
- Axle problems
- fender flares
- Would you trade head up?
- Car dies on 30deg. or below also.............
- Wtf?? What spark plug is this?
- OBD2 Integra engine harness HELP
- Steering wheel pics? Need an idea
- 93 hatch front bumper hanging off from one side
- Civic Speed Sensor Problem Automatic 98
- need to pass nj inspection
- How to: Gut a 92 EG6 w/ sunroof and then put a cage for a non sunroof car into it.
- Crank Case Pressure Question?
- Need Help with codes please
- Stock steering wheel
- hesitation/idle problem...help!
- AHH HELP ...cant pass jersey inspectionn!!ls swap in ek hatch help??
- My car won't turn on - 94 civic ex
- Help with headlight conversion from 96,97,98 to 99,00
- what rim size do i get for 00 civic??
- Sell my 92 Si or trade for a 94 Del Sol S
- socketed p28 question
- 94 Civic Coupe No Heat!!!!
- are nsx calipers worth it??
- LS motor into 97 civic What drivers side mount/bracket to use???????
- noise from my passenger side
- d16z6 help
- Help needed for h22a swap in a EG8
- springs
- signs of a junk dizzy
- suspension for eg
- Does anyone know if the 96-98 sohc engine is an iterference head?
- OBX ITB's
- b16 mods question
- Buddy Club or Skunk2: Which camber kit do you trust more?
- 1999 Si-R W/ JDM K20
- OBD1 check code 5
- will d16y8 rods fit d16z6?
- boosted d16y7
- Rear calipers shot! Suggestions on replacement!
- gsr suspension
- Possible messed up motor
- subharness / floor harness swap?
- how to get rid of the beeping noise
- d16y7 question
- New Guy saying hello
- Very odd B series axle problem...
- Head studs question on a b18c block with b16a head
- CF Hood - Washer Fluid Nozzles
- good or bad to run cold air intake in winter?
- how long does a 92 EG tranny last?
- OBDII dizzy to OBDI harness wiring?
- Suspension
- I got some questions bout the 94 ex I just picked up
- Help identifying EX exhaust manifold?? ( WHICH YEAR IT CAME FROm?? )
- 96 Civic Ex Engine Dieing need to replace but confused and not sure what to get
- Best ad trying to sell an EK ever
- difference between a cable trans and a hydro
- help fast! axle wont come out of trans
- p30 or p28
- Intake manifold coolant leak
- I need to know what size my motor mount bolts are Civic W/LS swap.
- automatic b18 swap
- Wiring Help!
- Car goes into gear but dosent move?
- new battery and new altenator and still pulsing headlights
- battery light...
- Does aftermarket gauges need fuses?
- what to do
- How to do a resistor box on a 94 Civic coupe
- timing gun
- Low idle when cold...like 100 rpm
- Oil Leak. help
- 99-00 Si cd player into 96-98 civic
- Worth rebuilding a B20?
- what rethread / tap size to use for o2 bung?
- Steering wheel from '96-'00 Civic into '92-'95 civic?
- 2 eg6's one big problem
- installing a clutch in my d16a need help
- engine scretches
- need help, which ecu is better for my setup ?
- hard to get into 1st
- rotora brakes
- need help car idles high then dies out...
- Need Rota Slips Gunmetal paint. + Story
- fuel pressure quick question
- What is limp mode??? HELP
- HELP Installing Airbag
- rpm's is going crazy!
- any1 know how to fix this common problem?
- need advice port n polish b20 vtec or b20 vtec turbo
- weird idle problem when vtec pops
- massive oil leak cam shaft seal
- part list ?
- Help me find 2 honda parts on this website.
- '92 Civics have ABS?
- Integra Seats???
- URGENT!!! WINDOW WONT ROLL UP!!
- 98 civic hx vafc 2
- Trannys Making A weird noise some1 help?
- Rear Lip??
- Wire tuck: Where to put the power steering reservoir?
- Need help with my rotors
- Throwin OBD1 code 45
- Hey Anyone mechanics in stamford, Connecticut
- electrical issue...
- 4 Door sedan civics, rear seat head rests?
- So the cluster lights went out again... this time the fuse diddnt blow?
- Type R B18 C ????
- Integra 5 Speed Swap into EG Body
- Hondata heatshield...... question.
- The Honda K series engine full thread
- fog light trick gone bad.
- NS0600's b16 n/a build!
- ---- are all OEM ek side skirts the same?
- EK fog lights...your experiences...
- Help? Gsr brake conversion on a 98 civic dx
- dizzy cap problems
- Ek Hatch Sunroof option overseas?
- Parking/Tail Lights Issue (Help!)
- ASAP: Better in performance with d16y8 block..
- Will WIRE TUCK CAli state refee inspection in CA legal?
- injector advice
- Car losing power on track? Help!
- noob to turbo got some question to maintain
- weird idle problem help peoples idles @ 2k
- Automatic block, manual tranny?
- ej6 ctr rear lip???
- 1999 4 door civic, error 41, any assistance?
- question about gasket
- WTF removed oem stereo now no light ?
- skunk2 cam gears and california inspection
- bseries head weight
- part numbers for bulbs?
- Del SOl Front Bumper
- were to start
- Trying to get off of trial user status :)
- a/c pulley(tensioner)
- New Front End. Ej1. WHat kind of Lights to get?
- ep3 cluster in an eg
- 93/94 Del Sol Si Wont Start
- DASH LIGHTS
- Help!! I backed into my door and [freak]ed it up!!
- FENDER BENDER!!!!!!!! need help....
- What does it mean when my exhaust drip water?
- whats ur input???
- Modding a b20
- Clock Spring question
- Re-wiring grounds and replacing stock battery terminals, thoughts?
- STOLEN EG (Honda Civic Hatch) please READ this! (Las Vegas)
- Fairly New to Site and Honda's- N00b Questions
- need advice
- radio wiring diagram
- idle jumps to 1500rpms at random, poor driveability
- fastest civic in the world
- How to ADD cruise control in 00 EK w/ type R motor and JDM ECU
- 96 civic ignition kill switch?
- P1362 99 Civic EX
- motor mounts r scrood!
- CRVtec
- coupe sunroof problems
- smokes bad in vtec?
- Blox Endlinks
- Opening hood with a screwdriver? (broken cable)
- b16 engine
- Hasport B series
- Brake Pads Whats good
- help engine codes
- November 22nd Civic MEET!!!!
- Improving suspension
- MSD boots
- Low compression? why?
- Tail Lights Si Saloon
- on board diagnostic doesnt work, help
- Resistor bypass on civic harness HELP!!!!!!!!!!!!!!
- EJ8 sideskirts on my EJ1 fitment woes any ideas?
- Python alarm transmitter problems
- Problem with 1998 Honda Civic EX (Video inside)
- Top Hat Mod
- SPINDLE PROBLEM
- I have a very simple brake question for you guys
- Are they trustworthy
- HELP! EG charcoal canister removal
- 99-00 Mugen lip question
- 92-95 coupe red/clear jdm tail lights general question
- Apex'i N1 99spec Coilovers
- Looking for a loud exhaust.
- Need photo of hood stickers for 93 del sol si
- How do you ship a motor?
- Misfire in cold weather
- benen front lower tie bar
- Idle Problem!! could it be o2 sensor?
- WANT QUITE EXHAUST!!!! HELP
- No power to wheels
- LAUNCHING CONTROL.. and red-line
- Adjusting coilovers dont have the tool help!
- tire size question eg hatch.
- 95 Coupe Wire Tuck
- Steering: Hard to turn steering wheel?
- 92 Civic LX hard starting when its wet........??
- So im new on the forums and i need
- Cam Seal Install
- Burning ~1 Qt a fillup due to valve stem/seal leaking, can I replace just the one or all four?
- Photo Shop Help please.
- Thin side molding for EG coupe??? Do they make them or why wont Hatch fit on the coupe?
- Suspension Question
- b18c1
- 1992-1995 civic hatchback b18 swap questions
- TAPPING REALLY LOUD
- pillay gauge install ?? post pictures,
- Tin Can rattling sound in my exhaust? Help please!
- D16Y8 timing belt
- Civci shifter threading broke ???
- upgrade auto to manual
- DASH/CLUSTER LIGHTS
- turn signal help
- 96 civic ex..looking for a lowkey exhaust..
- two questions for you guys about axles and brakes.
- Dashboard Fuse Box: What is This Plug-in?
- RPM low at idle WHY? Help please!
- valve springs for 92 b18a1
- suspension sqeak?
