View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Fender liner came loose...
- ctr b16b stroke
- What kind of bulb does the trunk light use on an EG Civic?
- fuel pump wont prime - 98 ex gsr bottom/built itr head/Hondata
- 92 civic vibrates while accelerating on firts gear please help!!!!!
- h2b dizzy + msd help
- CKP sensor error code?..
- 93 civic with vtec swap which wire harness to use?
- Skunk2’s Biggest Sale Ever is Coming!
- foglight wire
- upgrades available for 98 civic alternator
- Civic eg steering problem
- trouble with axles
- 2000 Civic Si Spoiler Break Light Not Working?
- Valve adjustment Tuning
- Where to find crank pully holder?
- 92 Civic sputters when cold but runs fine when warm.. PLEASE HELP
- how to install 00 si spoiler on 97 hx trunk?
- 98 Civic coupe -- Outer tailights don't work
- Can you hang any muffler on a 95 civic?
- Has anyone tried to pass CA smog with an ebay cat?
- 96 EK Wires missing?? HELP :[
- 95 Civic CX Motor Swap Final Touches - What to check before start up?
- Cassette player connection
- rough idleing
- Does my exhaust set up affect my backpressure?
- Electric-powered 1994 Honda Civic
- Threads for cam cap all stripped, dont know what to do
- Wheel spin sticking
- How do I connect the ECUbox so I have VTEC?
- d16 tranny issues - hard shifting and car won't move
- rear end conversion? 98lx to 96dx
- Throttle body gasket dor D15B
- EG/EK Owners: Koni NA presents their "Prepare to be Shocked" Promotion
- comp ratio
- Eg 4 Door Questions...
- Ignitor from different model/year. Compatibility question
- Is eg coupe back seat fit on eg hatch?
- 98 civic hatch exhaust HELP
- d16z6 with a dx trans?!
- Need wiring help with a 92 JDM DelSol SIR
- ---nrg short hub--
- Why are Del Sol's so unpopular?
- 1996 Civic LX -- Brake Lights stay on
- Weird idle on my 99 1.6EL (D16y8)
- 92 Civic LX would not start.
- Trans for b20
- 98 Civic EX - DIY header replacement, brake repair, and wheel alignment questions
- 98 evap canister on 99-00 with orvr question
- spoon mirrors
- weatherstripping help
- Bled the front brakes
- 00 DX blower motor noise
- civic ac problem
- K SERIES QUESTION
- New headlights needed.
- Recommend code reader please. Year 2000
- NEED HELP with B18A swap into eg write up
- D16z6 Sputtering Through All RPMs And All Gears
- 92 civic Hatch b16A upper coolent line
- Issue with starting. Possible Alternator?
- 93 civic rough start and idling issue
- name that part
- What is the way to replace hose under the distributor
- TICKET FOR "ADEQUATE MUFFLER REQUIRED". Questions Please Help.
- EVO 9 Recaros on a 98 ej?
- b16b w/ gsr crankshaft and rods
- Separated Engine From Trans But Gears Stayed On Engine
- need help with making a wiring harness for the speedometer
- B16 timing belt tension
- Apexi WS2 from EK on EG
- What brand axle shaft to go with?
- 92 civic crank pulley
- Disc Swap- Bleeding Question
- auto wiring harness in manual
- EM1 Type R Swap or K20a2/z1 HELP!!!
- wipers wont stop
- d16z6 w/ d15b7 tranny. what starter?
- 99 Civic front wheel stud
- 93 Del Sol OverHeating and Smoking Problem
- Wire tuck question
- Dimmer switch and Idle help
- Need help finding this manifold to cat converter gasket, 97 LX
- Swap from auto to stick
- Eg b20b starter problems
- 2000 SI grinding sound no clue
- Help, no spark
- Basic tune-up Q's for '94 civic
- need advice HT!!!!
- TDC a skunk2 camgear on D16y8 Civic (1997)
- Mystery plug
- Turbo b16 hp numbers
- 92 civic dx power steering delete
- honda civic dx coupe 1995...where should i begin???
- Differences between a 95 Del Sol and a 97 Del Sol?
- 93 civic ashtray light????
- Noise from head after dyno pulls
- B16 del sol mounts for b20b swap into ej1
- 1998 d16y7 reading P0420 after replacing cat & exhaust manifold. O2 sensor problem?
- Please help with the codes my car is throwing (2000 d16y7 civic)
- 93 EJ1 SRS and CEL jumpers both missing?
- 92 Civic DX with CEL code 0 won't start
- ac compatibility
- obd2a vtec harness on obd2a d16y7 with y8 intake
- Gas lid/cover problem
- EJ civic -Stalled on takeoff and wont start again- Troubleshooting Video Included !
- VSS help!
- Gasoline leak :(
- Faded rough window trim?
- EK COUPE D to B conversion a/c questions
- b16a2 3500rpm fuel cut
- My New Del Sol Build Thread
- D16y7 AC bracket on D16Z6 block
- First Post: odd noise when engine is cold
- Car Occasionally Won't Start, no check engine light.
- CV Shaft Mount Bolt Size
- 98 civic wont start!!!
- should i trade my car for this
- temperature gauge help
- 1999 Honda Civic DX acting sluggishly. Details inside.
- hp gain on upgraded throttle body
- My EG coupe build thread/ progress
- piston ring gap???
- 93 CX Hatch no start.
- 93 Civic/Y8 swap -- Will Z6 dizzy work/fit on the Y8 engine?
- civic transmission problem, no 2nd gear?
- 3wire IACV QUESTION![SEARCHED] OBD2b ECU PINOUT? HELP ASAP PLZ
- Aftermarket mounts -vs- stock mounts
- 93 honda civic o2 sensor
- replace '98 D16Y7 and keep auto/ac/ps
- bulkhead bolt holes in hatch area?????
- my car turns over starts then choaks and dies
- seized caliper rear discs
- Bushings 97 Civic EX
- Steering Rack Jumping Teeth?
- mirror install
- 1994 Honda Civic DX,Starter no crank
- Default Minime swap and burned the ECU box.. Why?
- Wiring up resistor box
- interior and exterior parts, where's the best place to buy?
- Wiper stalk problem
- ls Vtec on my 99 civic dx(dizzy and alternator) wiring problem
- Worn out window molding
- 3rd Gear Grind. :O, 1996 Civic Ex d16y8
- "d" light blinks
- Slight hesitation while starting cold
- Header questions
- 93 del sol suspension makes creaking noise - dont know what it could be
- 1997 Honda Civic EX
- slight idle problem...vid uploaded
- symptoms of a bad dizzy?
- What mirrors are these?
- CEL p0135 o2 sensor
- 1996 Honda Del Sol VIN number locations
- Subtle duckbill wing?
- ECU question
- JDM B16 CEL 14 IAVC -- Low Idle Speed
- Front shock install, what other parts to install while I'm at it????
- SRS light fades in and out while driving ......
- Guages not working
- del sol map lights?
- sticking throttle
- GM Syncromesh or GM Syncromesh Friction modified?
- vip style si with 235s
- 2000 Honda Civic LX CEL:67 Bad Cat
- Brake lights wont shut off. HELP
- Styrofoam Bumper Absorber
- Fuel rail question
- Are VX injectors less than 240cc?
- 2000 civic AC control knob lights NOT working!
- HELP! Broken oil dipstick
- which camber kit for 99 EK hatch
- Ok I give up...need cat-back install help!
- need help... upgraded brakes and now theres no pressure on the brake pedal
- 92 hatch b18 swap keeps blowing the main relay & CEL on but no codes retrieved
- 2000 Civic Hatch or 2001 Civic EX??? Help!
- ac not working
- 97 Civic LX -- no check engine and cant pass smog?
- d16y8 or b18b1
- dimmer switch
- 95 civic: horn blows a fuse
- 1999 civic si engine belt(s) replacement DIY?
- Engine Swap Advice
- stalling and blowing white smoke
- Gsr EG exhaust gap
- Professional fuel injector cleaning
- d16y7 cranks but no start
- Alternator Wiring
- questions and problems.. HELP eg6_b18cT
- Interior lights not working now!
- Manual Transmission Noise 96 ex
- Energy suspension bushing kit
- Hids turn on by them selves
- Random Power Loss
- monster tach off
- identify this part
- Intro from Civic owner in Australia
- torque_spec_question
- how do you install cwest spoiler?
- selling my del sol
- 2005 Evo seats in 96 ej6 sedan
- Proportioning valve for a non ABS set up
- Can I use a rear wheel hub from a non ABS car
- 94 ex coupe/d15b -- No power to ECU
- 99 civic jdm b20b swap w/ CRV ecu problems
- WHAT HEAD STUDS DO I NEED FOR my hybrid engine?
- car will not start please - timing problem (solved)
- B18C5 What fitting is this?? Help!!!
- H22 Del Sol Swap: Cable Linkage Question
- Hazards turning car to "ACC" and keeps car running!?!?!
- 92 civic heat issue. Second opinion needed
- How much electrical power does a 94 civic use >
- b18b1 rebuild advice
- LS bogs at high rpms?
- 99 EM1 - need info on throttle body issues and MAP sensor code
- How to tell the difference between OBD2 and OBD1 injectors
- '97 EK Trunk wont lock
- OBD2b VBU color rywire/factory
- Will d16y8 water pump bolts and timing belt tensioner spring work on a b16a2??
- B18B1 fully buit and boosted del sol !!! what kind of numbers ?
- Help with random plug I didn't label
- ABS Delete in EK
- My 95 Hatch build
- new cams -- now distributor won't fit
- 120psi cold comp on all 4cyld
- 95 Del Sol Si with a D16Z6 -- NO SPARK!!!
- p28 ECU in EG.. shouldn't O2 sensor be hooked up?
- what harness plug is this...for..?
- 94 civic ex auto trans issue
- 93 civic lx redline
- Door locks wont work when open but works fine when closed
- B16 failed Calif. smog test. Need suggestions.
- EG GSR Throwing Three Codes, Only After Up To Temp
- Rear shock bolt stuck inside Function 7 LCA bushing...
- P0335/CKP sensor - Fried My ECU, Pls Help!!!
- Trans trouble
- vtec is not working on my jdm d15b wit p28 ecu
- HELP with EK gauge temp not working.
- 96 hatch/B swap. Carefully hardwired jumper harness, now wont rev over 2.5k.
- What tells your car, that it is in Park?
- burning oil and spark plug analysis
- No start when hot. Starts good cold, drives great.
- lca & asr subrame install ?
- vtec and xtd clutch are good?
- Need help d15b
- EG Windshield
- D16Y7 sounds choppy..
- engine harness needed for fuel pump to prime?
- b-series swap into ek
- 92 hatch w/ gsr swap overheats and stalls -- need help asap.
