View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Does anyone know what lip this?
- Want to put some S2000 seats in my 93 Del Sol
- EBC slotted rotors
- lood at this video!!
- anyone know about RS-R springs?
- anyone know what u need to put an EL front end on an EK civic?
- Chech them out
- tranny question
- OT: should i paint my eg olive drab green?
- cant find a swap down here so imthinking of selling out!!!!!!!!!
- where can I get some type r lip/mugen for a good price?
- Amber gauge and dash lights in EK
- Swaybar identity
- Civic Factory Performance??
- H23/H22 in a Del Sol?
- Si doors on EJ6 hatch
- How-to 92-95 foglight install
- Does everyone still have the stock Splashguard on?
- jdm teg type r front clip?.......conversion?
- add power steering to a 92-95 cx/vx/ or dx.
- How much paint needed to for a 97 hatch?
- Tires for SI Rims
- 92-95 2/4 DR H&R Sport Springs Vs. 92-95 4DR EX H&R Sport Springs
- Pics of Project Egg Go Boom !
- I have stupid question
- exhaust noise
- Hid conversion help....
- Curious how everyone feels. Black primered Coupe
- why are my lights dimming in my 97 ex ?
- crap-o spark
- Foglight wiring? Horn Doesn't Work? SRS Light on? 92 Si
- question about headers on a hatch . . . . .
- hondata gasket
- ** i need pics of EG hatches with LOWERING springs & drop rate**
- My corner lamp fell out while driving!!!
- 99-00 Si door, how to install them?
- 43 ecu code
- throttle body spacers?
- 99 center console in a 98??
- brakes needed repaired, cost me $600 :(
- specs on D16y8 vs. D17A1?
- jdm engines not passing visual and smog.......wtf?
- pray for me...
- OBD 0 block into 97 EX, wiring ideas, need feedback
- D16y7 into vtec???????
- whats the cheapest price i can find a b18c1 with an lsd tranny?
- wtf happened? Mods and Administrators
- Engine year ?
- exhaust piping and carsound cat question
- your experiences with importautosalvage.com
- Sedan and Couple rear bumpers the same?
- Where did you go to get your car weighed?
- del sol rookie needs help
- ASAP axle swap Q for D16 TYIA
- help!
- Chassis codes
- Can someone help me. CARFAX
- WHY does my driver side axle sound like a super charger!
- 4750 to much for b61a2 swap in 97 civic ex
- Do it yourself projects?
- florida delsol meet and anyone else for dyno...
- Wander/tracking/"poor" handling with fatter tires?
- 90-93 accord leather seats
- h22 in EJ3??? in the works need some help!
- Review of suspension techniques Sway bar kit
- Rear bumper question...
- Those with engine assembling experience.....
- Almost Finished!
- Annoying sounds coming from the suspension
- Spoon damper kit
- tein type flex
- Civic EX? (valve cover problem need help asap!!!
- Part number for EG6/9 folding mirror relay.
- Joined the Broken INTO car club last night
- to those who have a B16a and VAFC
- B18b, turbo question
- CARB EO#'s Follow the link inside for what has it and what doesn't.
- 92 civic w/ABS - Grinding noise but discs are good
- What clutch should I use?
- ITR Muffler? install??
- Almost got a thief 2!!!
- help wit tokico springs . . . . ?
- Spoon n1 and Apex n1 review for "eg" hatch
- 96 obd2 alternator in 90 civic hatch.
- how hard is it to do a trans top conversion on a usdm del sol?
- What is the easiest way to get 300whp out of a 2nd gen JDM B16a?
- is it necessary?
- what seats will work in a 94 cx?
- almost got a theif!
- SoCal Fudruckers Jan 25 meet caravan from SD
- making a del sol fast?
- Integra Seats in a 97 hatch
- LS swap in the process
- ek9 meet at hooters in SD
- need help on installing 99 civic si gauge cluster into 95 civic
- check engine light
- ES Oval?
- 94 hatch w/gsr swap idles fluctuates,chipped ecu maybe???
- Boost or not boost?
- Rear lower tie bar with Suspension Tech sway bars...which tie bar?
- Hey Guys.. Plz. Post Pics Of Your EG CIVICS THANKS!!
- 5 lug conversion e brake question
- 96-97 integra type r 4x114.3 conversion pics
- Which quiet and straight through exhaust?
- sohc vtec
- Flucuating idle after Swap
- n000000b question......compression ratio?
- northern california ht members meet
- ITR pistons= Skunk2 stage 1 cams or Toda Spec B's help me decide
- anyone have any suggestions to where i can find a grs with an lsd tranny for under 3 Gs?
- Can someone please tell me what this is?
- Need some tech advice...
- setup question
- Pic request: 92-95 HB w/16s and/or 15s
- Would colder plugs hurt performance?
- squeaking noise when i turn sharply
- what the difference between REAL spoon mirrors and replicas
- San Antonio Area H-Ters.... Track night!!!!
- Good Rear control arms???
- Finally!! The Tein S. tech review....
- kph speedo opinions
- CTR lsd
- tires for 16s?
- some exhaust questions..
- Will this mount work??
- The budget Minded Catback.
- Easiest and Cheapest Way to Put On Disc Brakes
- car died on me last night....HELP please
- a picture for you to dwell on....
- turbo civic si's
- What the hell, my HX rims don't fit on my EX. Help
- Pic Request or a good diy source to install sidemarker
- I figured EVERYONE should get to see this!
- Pic request: B18s with boost
- Pix'z Of My Ride, Ek99!
- civic cat and integra cat same?
- Check out what came in today!
- Field SFC or Apex SAFC for modified EX
- need help with brake lines!!!
- what does an axle back thermal exhaust go for?
- Some pics of my alignment 56k--good luck!
- Who is rockin high ass insurance on their hatch?
- Alinment
- Suspenion bars - NOOB question.
- 2000 civic si weight??????
- Crower cams...
- type R rear seat in 7thgen?
- turbo exhausts...... whats the best performance wise?
- !!!frustration is consuming me!!!!
- GSR gauge cluster in EG?
- pics of red civic si's
- anyone else think the grey and polished lip slipstreams are pimp?
- need some help on deciding what to do..........please help
- Pics of my BaBy (these are B4 pics some after pics later)
- I Need A Carfax Done ASAP
- the mugen twin loop........how does it perform/sound, ????????????????
- help on specs of a honda crv si engine
- Question about transmission mounts on an 1.6 SOHC automatic ?
- s2000 wheel on 7th gen civic?
- I though I was gettin away from Hondas, Well guess what I just bought!?>
- exhaust vibration and resonator hanging excessively low
- Z racing wheels?
- How can you tell the difference between rota's and spoon wheels?
- new to this.. looking for a cheap car (ish)
- $200??????
- Finally sprayed my car at the track
- I just did a custom engine ground installation...
- getting alignment, just wanted to double check
- Airbags? Life saver or not?
- Si-R front brakes, same as US GS-R??
- 16" Tires
- Skunk 2 tie bar install
- halp
- newbie
- 2002 Dashboard Question
- motor feedback- i need to order it, where can I go?!
- Grrrr I hate traffic school!
- tach wire at distributor
- 5 Lug Conversion
- ek hatch
- HOTSHOT Header!!!!!!!!!!!!!! Look if you havent seen this...
- ATTN B18C5-EH2!!!!!
- OT: Looking for a dope EG/EK to model in 3D! =)
- KYB AGX with Tein S tech springs ?
- Comptech Full Race Header
- Video of My Car Beating on My Beater!
- how does this work?
- Where to get ready tuned engine?
- EG6 & SRR Rear Lower Control Arms...
- brake and suspension swap
- Wheel stud replacement
- Dyno Day in Tallahassee (NO 56k)
- Exhausting possibilities...
- ITR AEM CAI on B16, Can it be modded to fit?
- reseting the ecu
- ecu advise, please help
- how to swat a h23 to a 95 civic coupe DX
- DelSol SIR swap
- Question about the civic
- best shocks for neuspeed race springs?
- mugen twin loop exhaust
- 92 Hatchback Rear Window - dumb question.
- Strut Bar
- tbi
- Bribing the car inspector
- Anyone with an aluminum spoiler on their EK hatchback....
- blew the clutch
- Motor Vendors
- Best Tire For The Money
- Should i get the jdm final drive???
- Please take note of new number =)
- Iceman cold air intake
- How do you install a GSR Strut Bar on an EG?
- dc2R ITR air box on EG civic ...
- i need help on my front camber kit on my eg civic !!!!
- usdm vs. jdm.....type-r vs. GSR.....
- Racing Seats
- installing 7gen civic seats into EG... HELP!
- how hard is it to remove gas and temp needles
- Is It Worth It???
- does anyone remember a post about....
- 92-95 hatch what muffler you runnin post sum pixs
- Anyone know this?
- itr springs/shox
- User name icon
- Hidden Radar Detectors??
- zc engine
- advan rg's
- NE1 running the BORLA catback ??????
- What's a good wheel paint brand?
- First Pics and Now a Video of My Car?
- need motor help
- anyone very put 90-93 teg mirrors on 5th gen hatch?
- how much hp from a skunk2 megapower?
- PIC REQUEST: Night time shots of Gauges. ( Boost, A/F, Oil Press.)
- Exhaust question???
- B16A N/A 200 whp engine
- Doing a brake swap from a 2k Civic Si to a 94 Ex
- Are these springs compatible?
- Do you guys think this is totaled? Check it...
- black EG's...post your car!!!
- Seatbelt/Airbag vs. Harness/No Airbag - What's safe?
- like my LS VTECset up??i need more feed back
- Should I buy this GSR motor? 70k miles for $4,000!
- upgrading D16Y8 NA for street/daily driver
- does anyone have any ls/vtec sounds or videos
- 98 CX HB dropping in a 98 ITR motor...
- Fuel System Help???
- EK coupe or EG Coupe and why?
- wiring sidemarkers to 97 ek civic hatchback
