View Full Version : Honda Civic / Del Sol (1992 - 2000)
- head gasket
- WTB looking for b18c edelbrock manifold and rmf,hytech,anr,smsp headers
- h22 swapautomatic
- 2000 Honda Civic Si Parts, Stock Cluster, ECU, Headers, RS Type Exhaust, JDM Honda Radio Block Off P
- NEED HELP WITH EK4 REAR SEAT
- how to set d16z6 timing
- '92 Integra GS parts car. I need the rear discs.
- Honda del Sol power door locks
- how do i install a fan switch?
- A/C Question. been to a shop. searched. FULL RECHARGE AND NO COLD AIR
- Optimum rpm level for most economical fuel economy.
- Lug Nut Wrench and other wheel issues...
- are there any ek hatchback group forums only?
- Del Sol dedicated sites?...
- 5 lug help guys...
- ek with sunroof?
- NEED HELP?
- HELP SOHC
- Window Switch
- y8 oil pumps
- Spun bearing ????
- Hello Guys.!
- Z6 Only 3 cyl fireing.....
- 95 civic si coupe stock, what to do?
- tweeter pods question,
- East coast Ej1 build: MR '95 Ex coupe LS/Vtec project...LOTS of pics! slow modems beware
- Shift linkage issue in 94 Del Sol HELP!!
- NEED 93 CIVIC EX FUSE DIAGRAM
- VTEC engaging sparatically in/out?.... (VTEC stupid)
- Fuel Pumps
- will this tranny work?
- VX engine almost starts but wont?
- ls vtec vs. b16
- dash and a/c lights
- d15 timing belt?
- Just did swap and the car doesn't crank over...
- what trannies will fit a d16y8
- 95 ex to 99 si gauges
- 2000 Civic Si issue w/ pass. window switch.
- mini me dizzy
- door stuck shut need helppppp!!!
- what size injectors???
- wtf??? please help
- idle issues?
- D16Y8, best choice for increasing performance? Turbo or swap?
- 2000 Civic SiR???
- Help 4 my budy
- no start after engine swap
- Hondata S300 Launch Control Engine Damage? n00b's need not apply...
- CTR into EG hatch questions!!!! HELP
- 1994 Honda Civic EX Defroser
- NEED B SERIES SHIFT LINKAGE ASAP. HAVE MONEY. LOCATED JOHNSON CITY, TN
- Custome race style cluster idea's brainstorming here.
- Noob Question about changing tranny fluid
- Anyone Know where to get Plugs and Sockets for Gauge Clusters?
- FULL DRY KIT FOR 50 BUCKS. ZEX
- speedo not working properly
- when should i change spark plugs?
- Weird surging problem (Maybe ECU?)
- head lights dim when on gas??
- Coilovers...?
- building d16y8 need help
- Check engine light throws code 45: Fuel System Too rich or Too lean
- need help to get swap running.
- b16 turbo throwing codeh
- EK9 cluster and reading the odometer in the U.S.
- 2000 civic dx did integra disc all around and brakes wont bleed pedal goes to the floor!
- Is my alternator on the way out??
- oil in my turbo!!!
- need help.
- problem with Cat.
- help wanted....ek9 master cylinder and servo
- Need help identifying something on this crimper please *PICS*
- Check engine light shows IACV! plz help!!!
- Can you run a spare tire on a front wheel?
- BISIMOTO CAMSHAFTS
- d15b7/d16y8 mini me swap questions
- It took me a long time but my EJ1 fired for the first time today
- Can I use self wire tap splices for headlight wiring?
- HONDA GURU"S- PLEASE HELP! 93 Civic Coup Turbo
- Slight Electrical Problem (heated seat switch LED)
- Civic 4 door sedan/ gsr auto swap? front bumper swap few questions help me out guys
- ob2 1 wire o2 sensor
- Checking compression on a gsr engine
- k, looked all over this site and cant find thread !!!!
- mini me swap?
- 97 up Prelude seats in EG
- Changed timing belt/water pump/fuel filter and now idles bad?
- Which civic is this?
- Honda guru's.. I need your wisdom. -93 civic coupe turbo
- Help with 1996 Civic LX Sedan Power Windows & Locks
- Installed ITR suspension and no i have no brakes?
- 1992 Civic VX Stalls / Dies During Acceleration / Load / Quick Throttle Opening
- Window came off track on my EK
- B Series Vs. D Series - Dizzy Coil/Igniter
- type r shift boot
- pcv valve replacement on D16Y7
- Got a 99 Civic VP - Suggested Maintenance?
- LSD install?
- CFK and CYP sensor trouble
- Civic VX Axle ratio vs DX/LX Sedan?
- Selling my trans. need some help
- EK side skirts on EG coupe Whats involved?
- Leaving
- how hard is it to git trany bolts out dam i think mine have lock tight on thim help
- back in the game just moved to nashville
- sway bar
- head gasket
- HELP ME PLEASE!!!!!
- ITR Smogging question
- Help With 1996 EX Power Steering
- Painting Spoon Mirrors
- 4th cilynder wont start
- removing intake
- autometer tach not working...
- 95 interior questions
- B16 TROUBLE HELP
- charging system problems
- Searched for 2 Days....ELD...with a twist! NEED HELP
- experience with aftermarket radiator supports
- where are the HT brains at? need help
- Need quick help please
- Need a little help here guys!
- broken glove box handle :(
- GSR......b18c1
- Mashimoto ZX tires
- ?question about seats?
- EG ac into an EK
- new here just showing my ride
- LS SWAP NOT STARTING PLEASE HELP!! SEARCHED!
- s2k wheel on 00 em1..cruise control?
- need help with ek power doors conversion..
- My Swap
- quick question.. dash shakes.
- SPRINGS QUESTION?!?!?
- Vtec Wiring d16z6
- b16 intake manifold ???
- Where to get replacement rear quarter panel?
- vibration noise problem ...helppppp
- Rod Knock... Motor Options.
- Engine Hoist/Cherry Picker Question
- Question about rear brake swap onto EK and bushing set
- STOLEN: 2000 Si San Jose, CA.
- 99-00 si dash and door panels into four door ek?
- New Car Forum
- civic will not crack over need some help
- venom cam gear
- Some new pictures.
- ek coupe door fit on ek hatch?
- Are civic front abs sensors same as integra front abs sensors?
- anyone selling a rhd civic????
- What parts are good upgrades for Civics that come off of STOCK integras...??
- D15B7 cam and TDC balancer digital pics of correct line up
- Need to take out my shocks
- hatch or coupe fenders on sedan eg
- in a bind... b16 or b18?
- DIY: EG Cluster and Dash Lighting Modifications
- DC2 Integra Rack is Identical to the EG Civic???
- water leaking inside car
- B16
- Gas Gauge Needle Unsteady
- JDM ZC
- b16a2 manifold
- b16 setup help
- Snapped bolt that holds engine to transmission - HELP ASAP
- Low fuel light not working in cluster
- radio problem
- D16Y8 Cam lobe height... mid???
- Carbing 3pt strut bar form EG fit EK?
- Anyone have pix of . . . . .
- Vision/NRG Mirrors?
- haveing y7 mini me swap probloms need to know how to find out what head i got!!!asap plz help
- my car has parkinsons disease....
- 95 Civic Ex Faster
- 2008 s2000 seats in eg
- is 94-95 civic a/c receiver drier the same as 94-2001 integra?
- i need to if i need to drop my cv s to git my old Tranny out and a new one in
- 97 ex b16
- y8 swap into 99ek dizzy help
- should i take precautions?? *pic*
- motul gear oil question?
- 97 HX really wierd!!!
- will h22 fit in a ek or eg civic
- cable trans in hydro car....
- Is my car wired for fog lights?
- hasport v6 mounts available
- Engine swap question
- need some info going form a d16y8 to a d16z6
- Wiring Help for OBD1 loom.
- Burn hole
- Whats the best oil filter?!?!
- Trying to figure out what sensor this is
- Does this look like a legit buy?
- Downgrading 93 EX brakes to LX brakes?
- WTB 97 EL front clip, And ?'s on front end conversion
- Strange power loss?
- car wont start/hellp
- Will a coupe door fit a hatchback??
- Replacing catalytic converter 1998 Honda Civic DX MT
- d16z6 head on d15 bottom end
- crank position sensor help
- Buying a Shop Press, 12T or 20T...??
- Saloon EG b16 to hatch EG, easiest swop ever??
- HELP me out guys.....Eg auto tranny in ek??
- Radiator/Coolant Issue
- Exedy Stage 2 pressure plate combined with CC Stage 5 clutch disk?
- AEM EMS swap type computer
- dissy pin outs
- NEED help ...Puzzled!!!
- EK 2dr power window wiring...
- Will 18 inch rims fit on a 00 EX? pics of rims inside, coming from wrecked car...
- Driver side EK mount replacement.. no longer on ebay.. where??
- VX hesitation
- need help on misfire
- D15b/p08, installed new 4-2-1 header= intermitant ECL code 1, tried 2 O2 sensors, no fix
- hoses on 99 d16y8
- NGk plug wires
- Comments on K2 Motor's head light
- dumb vtec ?
- Couple question I need help on!
- Overheating help!!!
- breaks not working help
- start my car PLEASE
- i need transmission for my 00 civic d16y7 in it asap !!! have 500$
- S40 Tranny question
- Difference between 1992 Si and 1995 Ex Shock fork?
- A/C Changeover for 94eg?
- del sol engine swap b18
- tranny help
- Current sale price of 98' Civic HX?
- GC collar upside down
- New Honda pads, Rears drag bad
- B16B which hasport mounts???
- Just bought EH2 ?'s
- p06 to p28 help.
- Where can i find windshield weatherstrip?
- wierd vtec problem
- Location of temp sending unit on 95 Civ?
- obd1 gsr into 99 civic si
- Need Help FAST!!
- non-vtec to vtec
- need to know....
- Electrical Cylinder Switch screws?
- No power to main relay/ fuel pump
- Question About Switching Corner Lights on 2/3 Door and 4 Doors
- p06 conversion
- Automotive grade bolts from Autozone strong enough for holding motor mounts?
- Chipped P08 ECU
- 2000 civic si
