View Full Version : Honda Civic / Del Sol (1992 - 2000)
- diy oil catch can
- Fuel Pump For Swap
- Weird sound coming from engine bay?
- 92-95 coupe exhaust on a 96-98?
- Good deal on a turbo?
- Melting Wires, need advice
- CODE 20 PLEASE HELP!!!!!!!!
- What color should I paint my 00 Civic SI?
- Wheel stud removal
- d16 intake manifold....
- Smog...Please read..Located in SoCal
- 02 sensor
- got b18b in car only thing needed done is shift linkage
- Brake Swap fitting size
- overheating problem
- turbo civic white and blue smoke
- which brake pad? not your typical question
- civic vx 5wire o2 to 4 wire d16z6 o2 wiring help
- -- Question about JDM piece on my hatchy --
- Vacuum leak....
- co2 spray for the intakemainfold
- EK Brakes question:
- Another Surging idle thread
- Spray on stock motor
- Bomex Mirrors for EG civic .
- Camshaft for D15B?
- Auto Meter 5" Sport Comp Tach (3911) Install problem? HELP
- will this fit on my sohc?
- Brake lines?? Difference between DelSol and Civic??
- smog??
- New here... looking forward to learn more
- ST rear sway+tie bar combo w/ stock lca's?
- IACV question
- Turn Signal Fuse????
- gauge pod questions
- I need help with SMOG!!!Please help, in SoCal...
- What's with my brakes?!
- stripped allen hole in strut tower : /
- painting OEM civic fogs
- B series axles fit into civic ex hub assembly?
- Cooling Fan prob
- What are the best bolt ons you can do for HP?
- boost hungry and the forced induction people wont help :(
- firing order problem wtih dizzy on b16
- Tranny Poblem?
- H22A/D16Y8 Help
- compression number
- Stripped Rear Upper Control Arm Colt
- QUick QUestion inner fender
- shift linkage from a 94 integra to a 93 civic
- any exterior modifications for a 05 civic?
- RFL BOV or AUTOMETER TACH
- HELP! Sister's EK running bad with swap
- 95 dx transmission mount
- Z6 v.s. B7 Tranny ?
- Timing belt noises?
- were can i buy rod bearings for my b20 block
- B18bLS "0bd2" Swap in a 00 EK
- how to wire an apexi S-AFCII to my p72
- question for a current H22a swap owner.
- puttin the pig a diet
- O2 simulator
- 96 to 98 OEM fog lights.
- 99 Civic Ex Turbo D16y8
- Will a dx hatch exhaust fit a Si hatch?
- got a quote again... a more useful one with parts
- my civic sucks
- MSD 6 BTM
- Sounds like a helicopter ???SUSPENTION???
- Question: P05 work on d15b7 motor?
- new guy / a few questions
- different fuel pump, runs rich???
- del sol front seats what rears?
- ground wire diagram for 00 civic si???
- compression is low in #1 cylinder, should i get a new motor
- Anyone got a Top Fuel exhaust?
- Timing With New Cam
- gauge ?
- Question: HKS Carbon-Ti Exhaust
- Hondata Q&A for D16
- dash lights
- My car has hella lots of miles on it.....
- No Start.
- Problems HELP!
- How would I fix this?
- civic 4dr weighs
- AEM part number 2-603
- 40-point inspection results
- I need help......ASAP....
- jdm b16a with obd2 ecu?
- cutting torque mount(HELP)
- Need INFO!!!!!!!
- sway bar endlinks
- What Would A Muffler Sound On Stock Piping?
- my 2000 civic ex wants your help
- Greddy EVO Good for Turbo?
- What is the best quick release?
- Whats the redline
- H22a Question
- Speed cut?
- brake bleeding help!
- k20 4rm 04 accord into 97 ek
- Normal Idle
- a newb question on suspension install
- my srs light is on and so is my check engine light. How do i turn them off?
- Compression test for an EG6 and BB4....opinion please
- GSR Brakes...gettin noises
- 2 Questions. Need help bad
- 95 black honda del sol stolen in NY
- FAST HELP NEEDED!!! CIVIC BACKFIRED AND NOW IT WONT START!!! please help!!!
- installing RC injectors
- my motor
- cell code error
- H22 swap question
- timing on a d15b
- Strut bar/sway bar?
- Check engine light
- B18 into civic
- b16a2 expert help please
- blinking Oil and check engine light
- turbo question
- Jdm Pro
- about to do fuel light in EG
- Ek seats direct fit in Eg???
- del sol dies when it starts real fast
- JDM healights with corner
- Starting Problems
- help with cruise control?
- DX civic w/ d16y8 help!
- ca smog in arizona?
- Skunk 2 Coilovers Question
- removing head unit from 97 civic?
- wastegate question for my turbo setup
- CLUTCHMASTERS SLIPPAGE!!!! STAGE 3 W/ D-SERIES.....
- suspension for a 95 civic coupe
- OBD1 GSR INTO 96 CIVIC 2DR??????????
- Part number for eg si input shaft bearing?
- HELP...quick question (searched)
- Alternator killed my car? Need troubleshooting help.
- Del Sol and CRX springs compatible?
- Rattles
- Suspension Technique COMPETITION Sway??
- Civic Si shifter/linkage vs. ITR shifter/linkage - The Truth
- Ignition problem No Spark please help.
- Chipped p28 on d16y8, running weird.
- PasswordJDM or Memoryfab Intake?
- Interchangeable MC and PB?
- CTR Steering Wheel Wiring + Ghetto Rigging of CC
- Reuse?
- Please help me.. CHeck engine light is on
- HELP: swapability of Civic Suspension
- High quality pads
- Idle Probs. with D15B Vtec, O2 Sensor Wiring ??
- Rattling noise when I go over any bumps
- Replacing rear brake shoes.
- My Friends turbo hatch got stolen
- greddy turbo kit users?
- Which brake pads are good for daily drive and where can I buy them?
- B16a2 Hot idle problem.
- questions on a oil pressure plug
- ac problem
- LCA bolt question
- Vinyl for interior
- Same FuelRail between different D16 Engines??
- Mid-pipe compatiability. (92-95 Hatch)
- Rotor screws
- Injectors for Y8
- I NEED CLUTCH FOR 97 civic CX
- side molding removal on ej1
- Honda Bearings
- LOOKING FOR EK FENDER!
- 195/50/15 VS. 205/50/15 on my hatch
- How do you bypass heater core?
- 92 cx to vx swap, egr wiring help please?
- Bad TPS???
- EK problems. lights pulsing
- need help wiring a 95 cx hatch w/ a 97 gsr.
- HELP?!? My EK Just Died While Driving.....
- Things to check when ticking/clicking in engine
- 99 lights on a 98?
- D16Y8 ignition timing...
- Where is the wire that tells the car the clutch is pushed in to start it???
- maintenance required light
- For Those Of You With Magnaflow Mufflers, Please Read This Thread!
- b20 harness question 1 or 2 peice...
- D15B ECU Question....
- wtb civic 01-04 rear bumper 2 door
- Ripping apart a SOHC
- pinout diagram for ZC (D16A8)
- can any one help bogging
- S2000 license plugs fit 2000 civic?
- V TEC ISSUES ..PLEASE HELP!!!!
- question about jdm itr big 4 lug.
- Where are the screws to install Intake?
- How much oil does a mini me civic take with a d16y8 head d16y7 block
- Squeeky bushings?
- Identfiy this part...
- Main Relay?! Is there a difference in..
- tsuedo exhaust??? anyone have one??
- install question
- Help with ECU
- Tach doesnt read right...help
- d16y8 head into d16z6 short block
- h22a coupe times?
- WTB: 96-98 EK INTERIOR HARNESS
- Interferance motors?
- 97-01 prelude gauge cluster into 1995 civic coupe???
- got a z6 prob????
- Yoko avs es100 --VS-- Falken Azenis rt615?? for EG
- Long island NY
- new seats for EG, help w/sliders
- 5 speed cluster install????
- i'll buy your 99-00 Si Rims please...
- JDM Gauge Cluster
- rsr exmag any body gots...
- electronic vss on cable trans
- Using RSX Endlinks?
- Emerg. Brake light on during acceleration
- DIY oil catch can
- tachometer problem, idle shown as 3000RPM
- What's tha diff between ls and gs integra..??
- Speedometer stop working - HELP*****
- Weird Stalling
- 60k mile maintance?
- Power Lock Module
- need help on engine wiring harness
- 92-95 civic 4 door hood the same as 3 door?
- Muffler Options????
- need help with ecu code
- ek power steering
- anyone know how to convert obd2 alternator plug to obd1 alt plug
- question about the EK fuel pump?
- braking/suspension problem
- ignition timing questions
- Long Block into 96 EX How hard to go SOHC to DOHC
- FREE TUNE-UP FROM HONDA DEALERS FOR SOME CIVICS!!!
- increasing z6 hp
- Does Cruise Control effect Vtec?
- EK thermal exhaust on EG
- Distributor rotor stuck, any tips?
- Installing j's style intake
- wich suspension setup should i get?
- Just got a rebuild and.......
- Putting a ABS System in a non abs EG SI .... ?'s
- Radar Detector setup................
- delsol windshield wiper arms
- bore b20 to 85+??
- del sol starter problem
