- Any help?
- License Plate 'Y' Bracket
- LS Vtec?? Who reccomends IT??
- swaping hx tranny for ex help
- p2p Ecu pinout needed... Already Searched
- Weight Reduction Potential - Coupe and Hatch
- What's a good turbo to run on a B16A?
- pic request......
- y7 throttle body on a y8 intake
- help!!!!!!!!!!!!!!!!!
- 99-00 Civic fog questions
- fujitsubo ??????????
- will a 96 4 wire o2 work in 95 si?
- NRG battery... where to get it????
- Mr.Clean
- Power window switch question....
- need help identifying 95 ls ecu in ls civic
- Z6 HEAD ON Y8 BLOCK
- can i use my stock CX mounts when im installing a b16a2
- Integra springs on a EK
- Bracket Compressor which to use...?
- GSR into eg
- Yellow'd Headlights in 97 coupe; need help
- b16 stock compression #?
- How to disassemble a 92 Honda Accord Dash apart.
- what is ZC engine?
- new exhaust...(magnaflow)...75% satisfied
- just got my car!
- OBD I b18b1 ECU plug in to OBD I d15b7 harness?
- Just got my coupe!
- Is a lcd good for a civic Si (all Motor)?
- New tire ?
- Just came back from Fun Runs at local track. Fastest street import i have ever seen.
- EASY MONEY – THIS REALLY WORKS, I HAVE DONE IT!!!!!!
- just bought 94 dx auto for GF. . . needs exhaust, will this Work? see inside
- Does apexi offer catback for del sol?
- ? ? ? Tokico Illumina Settings ? ? ?
- si rims and tires for sell.
- ZC motor
- Want to use 4-point harnesses and retain rear seats. HOW???
- obdII jdm d15b please help!!!!
- Check signal codes detected were P0304 and p1399, How to go about it ?
- My suspension dilemma... anyone know?
- ok to run +40mm offset on one side and +42 on other?
- gas prices ??
- NEED HELP. EG9 IS THROWING A CODE AND CAR WONT START......
- Idle question...low to high?
- 98 Civic Blow Motor
- Proposed Del Sol Plans. Anyone knowledgeable, please look over and provide insight...
- Reminder - ARP wheel studs for hondas
- Parts for mini me swap on d16y7
- O2 problem in a swaped car.... have a pic!
- Just installed my oil pressure gauge and i have a few questions.
- what code is this
- What options came with the different trim levels?
- APEX N1 RUSTING
- The Little SOHC that Could.....Finally Dyno'd my Z6 at 12psi!!!!
- spent a whole weekend on 1 problem to another
- pm6 vtec?
- STUPID QUESTION
- Whats the best way to go...
- 2 philips screw under the handbrake
- Radiator Question
- Question about rear seats? (somewhat tech)
- What kind of Exhaust do you guys have on your EG?
- funny noise after valve adjustment
- Curiousity Question about putting OEM springs back on..
- gsr swap eg tach problems
- well this just sucks
- need help changing seat rails
- Exhaust question
- driver door interior light switch
- iacv question on my mini me
- Firewall
- Honda Bond for Intake Manifold Gasket
- check engine light when slowing down?
- Can someone school me on the distributor?
- JL Audio Stealth Box for sale - need help
- Radio turns off
- o2 and speed o'meter..lol
- EG frontbumper problems
- Engine ideas
- IS HI REVVING GOOD
- Bleeding?!?!?!?!?!?!?!?!?!?!?!
- Majestic Honda for Acura?
- good place to get a B16a2
- *** Is my motor knocking?..... rod going out?
- Power window in EG wiring help. Yes I have searched.
- Front Brake Swap
- B18B Exhaust manifold - Civic chassis - what catback ?
- Grinding in the front end...
- Blower/Fan for 96 civic ex
- why do the runners look the way they do . . .
- EG coupe vs. EG sedan catback exhaust?
- Need to know which wire for dash lights
- how do i fix code 16 - defective fuel injection system
- Turbo SOHC or go DOHC?
- Crate motor?
- 94 civic pistons not firing correctly?
- Rubber hanger for exhaust...
- 92-95 Coupe Weather stripping ?'s
- 2000 Civic DX Idle problem
- trying to tweek my suspension a bit.. looking for something like this..
- Question about lugnuts
- Defroster--Fuse shortage...now what?
- 99/00 Si shocks the same as 99/00 coupe shocks?
- The Tornado gas thing
- Help OEM Power window and door lock?
- plugs dripping with oil..?
- Ctr side skirts?
- getting new car this week
- Using a bigger header & downpipe to smaller mid-exhast good?
- orange county body shops
- Question: what kind of Carbon Fiber lip is that is 92-95 Civics??
- Need help with autometer monster tach.
- how to become a member??????
- exhaust fire balls???
- Lowering my car...
- hood pins on cf hood?
- LS throttle body on d15b vtec good idea?
- dc2 sideskirt on eg
- leakdown on k20a2
- Help out a fellow honda enthusiast
- JDM B16
- Complete EG6 suspension swap questions...
- whos fixed a wrecked civic?
- Fender liner keeps poping out
- Tips for Shifting faster 1997 Civic EX coupe
- 89 si seats in a ek
- Carbon fiber trunklid
- Need Thoughts On Tein's
- How Much Brake Fluid?
- HONDA ECU QUESTIONS
- ground control distributors
- Might have to re-wire the o2...any dangers?
- ek hatch stock?
- EG bumper to EJ1?
- DEL SOL OIL LIGHT QUESTION
- del sol meets 93 hatch.
- d16y7 AEM SRI inlet size
- Problem starting my EG hatch...
- 99-00 head lamps in 96-98
- Wilwood Brake Fluid
- what fuel pressure gauge do you guys own?
- worming up problem
- 2000 si exhaust question
- wheel dent
- help help turnin lights
- Jdm itr into 00 EX
- 4dr DX
- What makes the wheight difference between VX/CX and Si HB?
- Rota size question...15x6.5 or 15x7
- can i just swap an adjustable steering column into my VX hatch?
- DEL sol headlight HELPPPP
- Civic Suspension Question....
- does a CAT have weld on? or can I just put it in to a place
- jdm d15 engine bolt up to USDMd16 trans?
- 90-93 turbo piping fit EG?
- what have you done to your D16y7?
- what is the weight of b16 complete motor asap
- Idle problem.....
- which brakes for 16's?
- Dynoed the New Single Cam today
- bottleneck...? you decide please
- DEAD CIVIC...NEED HELP WHERE TO START!
- B16 Clutch and Flywheel
- fuel
- clutch slave cylinder problem- B hydro tranny slaves all the same?
- Question on Re-apholstering Seats
- I need help!ive searched
- Race results for my 92 dx hb.....
- I need HELP!
- just wrecked my 00'si will interior fit in eg?
- Buying a Civic HB
- d16z6 spark plug order!!
- 97 honda civic ecu
- DIY CAI
- does anyone have camo paint ?
- how to get front right spindel off?
- important header question..
- auto to manual conversion(ek)
- help me with this timing issue.
- Air Filter Size
- dash harness help!!
- Racinskittles new IC.
- searched and still no answer (timing belt)
- clutch help request
- vafc install...
- what should i do for more power on 99 civic si?
- DIY aluminum intake box's
- a tiny bog when i hit the ggas?
- camber and Toe
- I just got an EG!!!WOOHOO!!!!!
- that wire peice on the headlight
- my little del sol needs some work
- Strut disassembly help
- Jdm Sh!T Hood Fitment**update** with pics...56k no no
- Secondary o2 wiring (EK hatch)
- Need HELP with taillights
- Weight Savings
- need help
- Is this gonna suck
- SRS codes?
- Will 91 integra rear disc work on a 95 civic hatch cx
- Indiana Team Sol Meet Ideas 2004
- Would Ek Seat brackets fit in a del sol?
- ground wire locations on 99 EX SOHC VTEC?
- Denso O2 Sensors??? Any Good??
- dx manifold
- hx exhaust ?s
- how to adjust timing???????
- EK with Vtech
- Will a 94 civic 4 door gas tank fit a 93 CX hatch?
- wiring directly into ECU question.
- Throtte Messed cant get emissons!
- Alarm
- Are 5g civic and Integra disc brakes equal?
- should i put v-tec controller on my 1999 civic si?
- skunk 2 coilovers what are you opinions?
- Apexi N1 rubbing and hanging low, help if you can please.
- Problems with upper control hitting fender well?
- ls/vtec or ls build up
- Help.. CEL 132.. Primary Heated O2 Sensor High Voltage????
- Turbo d16Y8
- How can I tell if my distributor is bad?
- CRX or del Sol?
- b16a2 swap
- b18b with b16 ECU work ?
- B16 tranny with Quaife LSD
- HMotorsOnline
- diy turbo ?
- D16 Overheating
- JDM 1.5 civic and engine swap Ma.
- Why does my car sound like poop? *VIDEO*
- 5G civic with GSR swap and N20 on the spike TV
- Exhaust Flanges for a tanabe exhaust
- GIRL needs help with mod's on CX motor..
- opinions please, any experience with this setup?
- EK skirts on EG !?!
- OT: TireRack.com Road Hazard Program?
- gauge cluster problems....
- 1995 gsr motor into 1996 civic hatch ek little help???
- ABS Code
- Some nice vocab...I'm sorry I'm such a noob
- *Will 96-00 Shocks fit in a 92-95 civic?*
- Spoon Tie bars EK, DC lower tie bar fit?
- harness question
- drag suspension
- clutch fork ek, dc, eg.....the same?
- swapping parts from EJ/K to EG
