View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 97 civic depo side markers help
- Does an eg hatch exhaust fit the ek hatch?
- Headlights flicker/SRS light flashes on and off while driving
- Transmission issue
- Reputable source to buy gsr shortblock?
- B20B octane?
- 5 lug disc swap, ep3 calipers
- B16A eg intermittent starting prob!!!
- 00 D16Y8 into 97 Civic EX - What's needed for this swap?
- 96 ek hatch obd1 b16 swap wiring issue!
- 2000 SI power steering
- overheat and hard to start
- torque specs for a d16zc harmon. bal.
- crankshaft not going in with new bearings!
- cant calibrate TPS properly, help!
- Engine options for 2000 honda civic ex
- Tansmission Swap
- ek rear disc conversion
- 99 si sputtering problem
- What motor mounts can i use?
- question on Dash Harness Wire for 96-00 civic
- Oil in plugs?
- 1992 honda civic dx overheating ..HELP
- transmission oil question???
- new to hondas, 92 civic lx cam timing question
- o2 sensor Primary & Secondary question.
- 93 Civic - Drum brake job question
- Heat wrapping headers good?
- Car is jerking, HELP ASAP Please
- How do I swap an 01 Civic EX engine (auto) into an 00 Civic EX (auto)?
- Timing issue?
- Rattle Sounds Only Accelerating.
- Honda Orthia '99 with Civic '99/00 Facelift Nose
- something making noise in my gas tank?
- Intermittent hard starting 99 Civic.
- Looks like i may have a short, but where to start trouble shooting? SRS, Radio, Issue
- EM1 Electrical issue! Radiator fan won't run and AC compressor clutch won't engage
- Blue smoke problem!!
- need motor mount bolts
- How difficult is it to replace rack-n-pinion on an EJ1?
- 92 civic si hatch fuel pump not priming
- 97 Civic D16y8 with fluctuating and low Idle
- B18b with YS1 Trans Axle Question
- Bent Valve Need help ...
- Name Of Front Lip! HELP PLZ!!!
- Vss help
- EM1 blue smoke
- will b20 pulley fit on Ls?
- Changes for better gas mileage?
- Skunk 2 manifold gsr with d series throttle pulley?
- 93 civic ex 4dr door problem - do i need the plastic cover
- Cruise Control Vacuum Help / 99 Civic Si
- Will an HX cvt auto trans fit into a auto lx?
- b16a1
- 2000 ex runs rough on cold start
- Availability of Apexi WS2?
- 3 Groove Alternator Pulley for D15B Honda Civic Engine
- Automatic Transmission- HARD to get into Reverse.
- 2000 civic hx check engine light/new exhaust, help plz!
- repair or engine swap... what to do?
- Recharging freon in a 2000 Civic.. What to get???
- 93 ej1 w/GSR swap wont start
- Help identify electrical connector in door
- Spacer behind lower timing gear?
- Oil Temp Sensor on b16a2?
- 1999 civic dash problems
- transmission issue
- Rack and pinion boot
- possible clutch problems??
- B16a2 Civic EK Hatch Swap - Mounts!?
- Y8 b7 mini not starting
- CEL 43 tried almost everything
- 2000 stock civic dx hb, coolant slowly disappearing from overflow reservoir
- headlights and taillights not working
- Is there a DIY for EG retrofits?
- Cluster Lights
- Lack of power in the upper end
- Front lower control arm bolt issue 93 EJ1
- 93 Civic Ex Coupe PROBLEMS
- 97 Civic DX hesitation - possible blown head gasket
- turbo D16z6 or turbo B18b ls?
- Car Starts but wont move, wierd idle
- D15B7 IDLE ISSUE
- Transmission question?
- Help
- 98 Ek Coupe D16Y7 spitting & sputtering? Opert. Temp no heat!? :((
- is my sir cluster with 42,xxx miles worth a trade for these items?
- White smoke /steam out the tail pipe
- sir trade for yakima help
- Quick Question
- Head Gasket Help!!
- Will spoon tow hook clear oem sir lip ?
- "92 Civic not running
- EK Fender Flares...
- 96 to 98 civic cd player install help
- 1994 Honda Civic DX Coupe - Problems accelerating PLEASE READ
- 95 del sol si: Car sputters at high rpms and engine light comes on.
- Quick shock tower plug Wire Question
- injector CEL after clip splicing
- A/c Question
- 99 civic gsr swap bogs in low rpms
- purchased an ek with a b16a swap, lots of plugs not connected, what goes where?
- 95 civic dx d15b7 swap to 96-99 ZC SOHC Long Block (Non Vtec)???
- no spark problem on 94 civic.
- Old gas now missfiring
- Replaced '00 Civic DX injectors, has no power
- Car starts then dies ? ?
- 93 Del Sol Si - suspension, body, A/C, and other problems
- 97 jdm civic quick release steering wheel help
- Anyone experienced with fixing key scratch with touch up paint?(Midori color)
- Thought you guys would like this...
- question on intake swap d16z6 intake to a d16y7head on a d15b
- 00 Ex : wiring an extra slim rad fan
- need help on exhaust setup
- de-power steering civic, no results ?
- 1992 Civic engine ticking / tapping sounds ? ? Video
- Honda Civic d14a4 - d16z6 headswap problem!
- Convert EG CX to Power Steering or Not?
- Unresolved Del Sol bogging and idling Issues
- EM1 with B18C1 Cruise Control Woes
- 99 civic si gas problem
- 99 Civic Coupe Dx suspension\ brakes problem ?
- Burning oil...what to fix?
- obd2 jdm d15b arp head studs?
- is this a genuine greddy axleback exhaust?
- 97 civic aftermarket quick release steering wheel help
- Integra rear trailing arms tool req
- what is this part called 96-00 Civic Front lower control arm
- 1993 1.5 delsol broken timming belt help
- 93 Civic Sound System NEEDED
- Stressing! B16a2 timing...
- 95 Civic head gasket replacement and other issues, please HELP!
- 97 civic front end + back bumper trading help :(
- 2000 Civic d1678 parts
- Obd1 gsr into obd2b em1...can't pass smog
- MadCoder Del Sol Build Thread (no 56k... if they even exist anymore)
- 97 Honda Del Sol Wont Start Or Crank Over PLEASE HELP!
- Vitara or B Series
- Installing A/C into my 1998 Honda Civic HX - HELP!
- del sol knuckle help
- 93 Civic 1.6 - No Start No Fuel Pressure No Spark
- TRANNY PROBLEMS PLEASE HELP!!!
- 93 Civic Hatch (Si motor swapped in) idle issues
- 93 Sol w/ Very Intermittent Start Problem (Not Main Relay)
- Eg hatch si , need help installing new sunroof
- Door Mirror Paint
- 95 civic EX wont start after spark plug change
- Where is trunk light switch?
- Adjust rear drum brks at star wheel or at hand lever?
- 92 civic will crank but not start
- 97 civic shaking bad
- 97 civic ex - WEAK SPARK!! HELP
- civic starts and dies a second later.
- AC cause harder pull out?
- 1993 honda civic ex power door lock issue
- Highway rpm
- Failed CA smog 92 Civic VX, high HC at idle
- d15b7 Harmonic balancer
- Thermostat question?
- Electrical issue - turning on blinkers blows fuse 19
- Looking for amber leds for my cluster
- Brake booster and master cylinder install?? Bench bleed needed?
- Can a cracked header cause idling issues?
- Idle surge after warm up if press the gas (no fitv)
- Oil then water on top of the spark plugs...cant find a solution.real techs help!
- 97 Civic - speedo and charging problems
- Best streetable brake pads?
- 92 eg hatch dx ls swap rpm problem
- B18C Not wanting to stay running.
- trans fluid on clutch causing slipping?
- jdm d15b Vs. d16z6 difference?
- engine harness tuck
- CEL flashing on my 98 civic
- 93 DX hatch -- where do i start?
- civic springs or coilovers
- civic bogging,jerking,slowing down?
- 2000 si engine swap
- Power Steering Loop help...
- looking for obd1 or obd2 engine wire harness for 2000 civic si
- 1993 Civic, 94 GSR swap. No spark
- stock 92 civic rear (firewall) motor mount on ls engine?
- help with harness =(
- gsr into ek dx , o2 question
- 97 HX VTEC-E controller
- helppp plzzz!!! anyone!!
- 95 DX D15B7 Won't Start After HG Change
- Snapped oxygen sensor
- Best suspension setup for the money?
- What oil weight are you guys using?
- Engine dies when plug iacv hole (good-bad)
- why isnt the vtec pressure switch bypass trick working for me??
- Snapped rear strut mounting bolt. Replacement?
- 1995 CX starting related fuses and wiring
- The tiny piece of rubber that makes your car not start
- A/C Turns off randomly
- B18c Gsr turbo built?
- Under hood fuse box question
- 98 civic b16 swap starter question
- Newby booby from the 740
- OEM Rubber Bump Stop
- oem mud flap splash guard question
- del sol colors
- CKP code on JDM B20 swap HELP!!!!!!
- 00 si whistle noise at start up..
- brake help please! - pedal hardness increases until dragging
- Helppp! Type R swap into 93 EG. No spark or anything.
- B20b rough idle and drive
- Can I fit 2001-2005 Civic seats in a '96 Civic?
- 96 Hatch, 99 SI motor, speedo/tach won't work on cluster, HELP!
- cheap B series swap?
- problem mounting 15x8 0 offset, please help!!
- Misc Swap Questions
- ebay vtec controller
- Blown Head Gasket??? HELP!!!!!
- d16 y7 starting issues
- ek d-series build???
- wont start in hot weather
- brake booster help
- buy a delsol and swap b18 or prelude? help!!
- Code p0420 No Cat Need Help!
- CODE 41 HELP!!
- spoon n1 exhaust replica
- po325 civic 96 DX
- Wideband install on 2000 SIR.
- First post on honda tech/ exhaust question on ej7
- D Series build??
- D-Series Build?
- po133??
- Fuel gauge working sometimes.....
- ls/vtec surge problem again!!!
- 98 Civic DX alternator pulley WEIGHT
- energy shift bushings for GSR swap and B16 linkage
- B18c1 IAT HELP!!!
- 97 ek cluster not lighting :(
- Wheel Spacers
- del sol - vent blower motor not working
- a lil help on wiring diagram plz. thxs
- Spark Plug Gap
- 94 EJ1 D16Z6 Where do these lines go?
- 2000 Honda Civic Fuel Problem, will not start
- A/C System Flush - which fluid to use?
- 97 civic front to 99 front conversion help!
- lowering springs on ej6
- Carbon Fiber Hood Restoration
- brake light issue
- obd2a hx into my 99 civic questions
- after swapping engine, problems
- Proper way of using seafoam in my D16Z6
- no reving up (dead spot)
- mini me swap
