View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Fuse 15 keeps blowing after I bottomed out
- Adjuster nut?????
- Almost took a 20lb Sledge Hammer to my del sol Today
- B4RA A/T issues
- DC front LCA on an EK?
- 95 Del Sol S surging idle after manual swap
- 1.75k for ek civic 1998 with 300k reasonable
- Clunk noise when coming off a stop/light
- D16Y8 - Water out of exhaust
- Need Help b16a2
- Correct engine manual
- Alternator/Charging System Help
- replacing hatchback upper brake light
- reconsiderat - mini-me track car
- Transmission Type From Vin?
- Civic fuel injector paint dots
- Starter: "turn-turn, pause, turn-turn, pause..."
- No spark
- Worn plugs, occasional hard starts...
- 96 Civic stock fuel pump pipe sizing..
- 95 del sol Power Window Modulator Replacement
- Pulling SRS codes
- WipersWon't Shut Off * Power Windows Quit Working
- Del sol vti 97 flashing green key problem
- 95 Honda Civic feels like I have a flat tire but I don't
- Power windows/lock/mirror issues.
- opinions,... Tien springs with .......
- Swap issues
- D16y8
- Head bolts/studs
- 99 Civic ex no power to fuel pump
- 2000 ek coupe with h2b swap help
- Newbie
- No voltage going to constant wire
- D16 obd2 (crank fluctuation sensor) pinout/diagram
- 93 del sol starting problems
- Need help diagnosing Catalytic Converter P0420
- Aftermarket stereo not working
- CEL on and runs in limp mode at random times??
- 97 Del Sol engine humming noise
- Im baaaaaaaaaaaack!!!!
- ecu help
- Obd1 b20b swap 40k miles intermittent ICM CEL 15 temperature dependent hard hot start
- I need some serious help here on what to do…need all Honda Civic experts
- Starter problem
- Idle keeps going up and down
- What engine harness is this?
- Front Lower Control Arm Bushing
- Third brake light problem, wiring issue?
- Reaching 250whp with D14 block?
- Budget kswap harness for 97 civic
- Does anyone offer complete K24 swap kits for EG hatch chassis?
- Windshield replacement 1998 hatchback dx
- 1995 Honda Civic Ex misfire
- Lights flickering inside & out, Bad idle
- reconsiderit - mini-me track car
- Honda Civic Eg4 rebuild
- Lug pattern
- ABS Wheel speed sensor interchangability Help needed
- ‘97 Civic Lx
- Harness/Wiring
- Obd2a H2b swap in 1997 civic lx Obd2a(While remaining Obd2a)
- Ek1 disc conversion from a ek4
- YELLOW SPEED RDPS OR BC BR RACING OR BUDDY CLUB SPORT
- B18c1 swap won't stay running in eg (video)
- Will a full CRX exhaust fit a del sol?
- What is the Canadian Civic Trim "SE"
- Questions about steering column on a 1999 Honda civic
- POWER STEERING TO MANUAL RACK CONVERSION
- NEED HELP REWIRING INTERIOR DASH WIRES
- Hey is there a way to switch my radio bezel?
- Running NOS on. Stock d16y7
- O2 sensor help, need smog
- Rad fan not working after swap
- Brake fluid leaks to minimum line and stops there
- 2000 civic lx automatic 269k trams issue
- Color wires
- Cheapest way to reach 300 whp?
- IAT issues
- Temperature gauge wacko...
- Evap purge pump - fuel rail.. black cover removal..?
- 96-00 Gas caps the same?
- Need help installing back up camera
- Starting problem (Solved)
- 92 Civic VX (cruise control not working)
- Ecu question.
- B16a2 rattling noise
- EK K Swap Steering U-Joint doesn't fit.
- Need help 2000 Honda Civic lx sedan
- Stock d15b7, had ecu troubles, trying to decide to sell or not. Advice?
- Finding square fog lights for 96 civic
- antenna
- Tuners In Michigan
- honda civic 2000
- zc sohc timing
- [EK] In-Manifold EVAP solenoid stripped screw advice
- rear right wheel is bent, not sure which part
- P1399 and p1456 codes
- Spoon / Vision Rear strut bar install with interior installed
- B16b intake and cams?
- Trouble Removing Rocker Arms (b16a)
- Can someone point me to Europe specific trims/models for gen 6 civics?
- Headlight help!!
- Civic grinding when pressing clutch after installing clutch kit
- 1997 civic hatchback clutch safety switch rubber bumper replacement - HOW?!?!?!?
- NEED HELP OBD1 ENGINE OBD2B CHASIS
- CEL code reading problems
- 1992 civic hatch wet seat belt (diver side), only in retractor?
- Civic starting issues
- GSR Seats into 95 Honda EG
- Help
- mugen gen 1 wing
- Cruising at 70MPH, car loses power
- Attempted Break In of My 92 Civic VX HB
- My 00 EX is being weird
- DelSol Automatic Transmission Fluid. What non OEM alternatives??
- Ek hatch rear bumper conversion?
- Mini-me horsepower?
- Passenger door lock being weird
- B16a obd1 swapped civic won’t rev past 3500 until CEL comes on
- Heeelp :( 94 eg civic
- Too much air?
- 01 LS Integra Motor into 00 Hatch
- P72 ecu ridiculously expensive
- Brake fluid leakage from master cylinder
- D16Z6 Manual/Automatice Engine Swap
- Do I need to change headgasket if I put arp headstuds in?
- Help please. No injector pulse
- Starter electrical issues -1997 hatchback
- Coolant Issue :: 1997 Civic
- Radiator cooling fan not working but car doesn’t over heat
- 2000 Civic EX weird jerking and surging
- My Honda Civic 1997 Automatic with 2002-4 D17A2 swapped Engine
- No power to fuel pump . I’ve checked everything
- What oil pick up tube work with what pan?
- Fuel pump problem
- Questions about my B18C1 swap into eg
- Searching for an ECM for a 94 Honda Del Sol
- Please help
- Pinout
- P28 pinout info
- 94 hatch limp mode fix?
- D15b non-vtec black smoke help required
- D16y8 into 96-97 Civic DX evap help please.
- Mystery D16z6 Head Plug
- 92-95 civic knuckle/spindle assembly interchangeable?
- Whatever happened to DPR Racing Heads?
- 1992 Civic Hatchback Back Glass
- Mugen Strut Bar Genuine?
- Power Window Problems
- Power steering hoses
- [D15] ECT gauge removal
- 96 Del Sol Si - Low comp after rebuild.
- Starter only works outside the car.
- del sol seatbelts
- Please help
- + oil pressure wire?
- Skunk2 Intake manifold & oil catch can on d series
- Holy cow my fuel pump looks bad.
- Wiring in fueltech ecu/guage on 1997 civic ek
- EJ1 3k budget build
- j32 swap tips
- Face-lift ek
- Sputtering on Acceleration issues
- Vtec gasket replacement to Random tick to possible blown head gasket
- d16y7 stock basemap
- 92 civic wont crank & wont prime fuel pump
- [EK] Engine Hoist brackets
- Wheel fitment
- Temp gauge pegs out
- P3Y to P28 swap
- New Zealand P2M ECU for D16y8 swap???
- D16 Issue after manual swap.
- Fun Engine Noises
- manual swap del sol S won't start
- Lug holes on mini cooper 280mm rotors too big?
- At a loss for no spark diagnosis.
- Rims/wheels slightly damaged. Causes steering wheel to vibrate/shimmy highway speeds
- Cheap EK turned expensive, low miles though!
- Need help
- engine wire harness?shock tower connector
- Brake proportioning valve discontinued
- Engine Bay Measurements
- Is my brake stock?
- Preventing Fuse 15 issues regarding TSB
- Broken lock assembly on EK4, need help
- 1996 civic b20 swap won’t start
- Are civic and del sol radiator hoses cross compatible?
- Floor mats fit in a EG?
- Antifreeze in sparkplug well
- Casting Marks of Cracks on S40 Transmission
- Good compression for boost?
- Help with headlight conversion 94 Del Sol VTEC
- 4 wire lambda conversion, which part# to get?
- Front Right Brake Hose
- Trouble with smoking brakes!
- Engine Swap Recommendations?
- 1999 civic sound from transmission
- 95 CRX (Del Sol) EG 1.6L DOHC VTEC Australia
- DelSol Automatic Transmission Fluid. What Type?
- No battery power to ignition
- Coolant Reservoir Question
- Oil in radiator
- 1996 Honda Civic B20B EFI / ECU fuse keeps blowing
- 1998 Civic Dx No POWER
- 1992 VX Hatch Low Idle
- Obd2b ecu constant power
- Exhaust Manifold - Right or Left hand drive car?
- Metal shavings in Distributor
- 2000 Honda Civic EX ticking/ knocking noise help
- Are EG coupes and EK coupe roof the same
- Does this motor have a knock?
- 00 civic dx cylinder head or gasket
- 99 Civic HX no start, scanner won't connect
- B20 w/ B18 head OBD1 ecu… STAYS O. HIGH REV… HELP!
- Password JDM Rear Trunk 2pt Bar / Brace
- Civic EG electric mirror conversion help
- 2000 civic d16y8 intermittent no star (cranks good)
- K20c1
- A/C leak
- 94 Honda Civic Del Sol S crank no start
- em1 transmission oil seals
- Stock Temperature gauge is a tick above half
- Which Civic 6gen had the center arm rest as standard ? Only 1.6 VTi ?
- Changed plans from boosted b16a to Frankenstein
- 94 honda civic
- CKP code is being thrown and idk why
- HELP Problem calibrating tps. Missing volts
- After swap from automatic machines to mechanics, check P0700 and P1768 are lit, P2P a
- Help..I'm stumped.
- USDM Itr knuckle problems!! Please help!!
- Misfire from HELL
- 96 civic lx
- Please help, idle surge.
- 1995 Del Sol S Manual Swapped Can't Go Into 5th or Reverse
- rocker arm
- Radiator fan position?
- 2000 Honda Civic type R swap bogging at WOT during vtec
- Doorboard extra - is this oem?
- 97 CIVIC CEL OBD2 LINKING ERROR
- Lsvtec no vtec
- H23a will crank but won't start
- New here! What condition is my VX in?
- Squeaking clutch thrust bearing
- What suspension parts for 99 dx hatch?
- Car can't run in hot temperatures?
- Overheating during idling, parking
- Misfire codes
- B series - 1 pin/stud water temp sensor plug
- Rear LCA bushings and bolts
