View Full Version : Honda Civic / Del Sol (1992 - 2000)
- converted to stick help..
- are the mounts on a car with a hydraulic clutch different from one with cable
- header bolt is loose!!
- Type R Steering Wheel
- Always running cold?
- need help w/ swap im getting
- what is v-tec e?
- Shocks from a 98 civic to a 95 civic?
- header air leak affect ref'd
- How could I modify my 99 civic dx (D16Y7)?
- Help Identifying Head Passage
- Whats the cause of this?
- jdm b18c in 92 vx with ls harness.
- Posting Videos
- 1994 Del Sol Si (stock)- Low RPM's & stalling
- Stupid ricers and their loud music
- Loosing my will to keep going on my project. Advice?
- What to do: Odometer not reading correctly
- jdm non srs itr wheel + quick release?
- NEED HELP! with my Secondary o2 sensor no 00 civic
- hey dc2typer01
- EM1 feeling sluggish (searched)
- nsx calipers, 5 lugs, lowered on Teins springs stock shocks. What sire tires?
- Alright HT's here's a question for you
- Window off track again
- can i reuse drained oil?
- how much $ to install A/C in a 1994 Civic Si? thanks!
- My First Honda!!
- EK Hatchback DX strange noises help please!
- need pigtail for turn signal
- which air intake should i get
- Smog Check Time (Kill me please)
- 99-00 OEM CTR/JDM Style/SI Fogs (Debate & Discussion)
- Y8 Block and Z6 Head question
- Vaccume hose disconnected.. Where does it go?
- Negative effects of a salvage title?
- need code help vedio attached
- Main cap help for D-series
- Fuse for cluster lights keeps blowing out
- Flange gasket HELP PLEASE ASAP
- D15B, D15Z7 Different? Same? (Confused)
- 4g63 in a 97'' H/B
- driver door won't open, outside or inside
- Ek Top Fuel Bars With Ek4 Seats
- Vibrant Muffler
- Help choosing EK Civic. First Honda.
- Will all the AC stuff from a 99 SI work on a 96 CX hatch?
- D-series manifold for 2 DCOE webbers
- AC blowing intermittently
- 92 Civic...No Spark
- Car wont start..... Help!!!
- b16 head question
- hawk pads opertaing temps ?
- Bigger Brakes
- head swap problems?
- Fuel problem.
- h22 to f22 swap?
- Crankshaft damper
- a/c question
- WHAT do you prefer.
- Running GSR turbo, with no turbo..
- review!
- F*in Hondas. Different Cel codes for different ECU's on Hx
- Integra Dash into EG coupe wiring question
- can i use same camshafts for d15b and d16z6
- 92 si brake light problem
- A/C not working-no signal from ECM to relay
- Need help to find a black set of SiR floor mats....!!!!
- engine sputter
- b7/y8 mini me swap, need help
- Drinking Coolant
- Odd suspension/wheel hop issue... HELP!!!
- check engine code?
- Sway bars?
- Will 94-00 Integra mirrors fit 96-00 Civic
- Best or Proper way to close the hood on our Civics?
- d15 wiring help
- what colour is this? whats the colour code?
- How to Take off front door panels on Civic 97 LX
- solenoid gasket
- Where's the SRS light on a CTR gauge cluster?
- h22a head gasket
- OBD0 EK swap help!
- will civic EK 99-01 seats fit in my 1995 Del Sol?
- del sol makes loud rattling noise inside cabin.
- d15b7 with a d16y7 head? HOW MUCH GAIN??
- B16A EJ1
- NGK spark plug wires
- Needle bounces
- Del sol Wiring harness!!???
- EK Front Lower Control Arm Problem ... please help
- After changing head gasket car is shooting code 9
- D16Z6 intake manifold coolant line issue need expert help
- DASH SWAP>>>..... >>> WIRING TROUBLE!!!
- Drove through almost two feet of water, WWTHD?
- b18c vs k20a
- Something NOT Good WTF?
- thumping noise on rear tire
- EG clear projector headlights...
- Throttle Cable? 1992 Civic with B18B motor.
- if is low on oil, is it ok to fill it up with new oil instead of the whole new oil change process?
- 99-00 front end conversion on a 96 civic
- 97 HONDA CIVIC HX! QUICK, DUMB QUESTION!
- Crank pulley keeps coming loose
- Help with EP3 steering wheel asap
- Ls wire tuck!!!
- ODB2 LS in a 95 Civic ..please help
- Fix for: Civic door won't open from inside or outside.
- offset question - 5 lug on ek/em1 - is this normal???
- STOLEN: 1994 EJ1 Teal
- What will happen if your primary o2 sensor doesnt work?
- Window help!!!
- 97 hatch window tint question
- Any stock civics with alarms and kill switches stolen?
- ecu codes help code 10 and 41!!!!!!!!!!!!
- probably not the right place to post this but......
- single cam
- 96-00 Hatch/Coupe door fit
- ej interior
- Shocks + Srpings or Shocks + Coilovers
- cam gear breaking
- Best Turbo
- Car feels like its bogging?
- 92 Honda Ferio w/h22a for sale or trade
- Ignition switch problem?
- name this exhaust
- 94 del sol project
- all civic shift linkage the same?
- Need Help with 92 Civic
- Question about windows..
- Does anyone know if the EK oem side skirts will fit the coupe?
- 92 hatch exhaust fit on a 96 to 00? Help.
- A/C system on 94 Honda Civic ex
- Spring suggestions
- power window wiring
- Distributor Timing
- Finally Boosted w/ A/C got a little carried and overcharged????
- Installing Air Conditioning (A/C) on an EG
- clutch seems to slip....
- A/C Issues
- What harness will work with 01 gsr swap?
- Looking for the guy who owns 360 Imports in Vancouver WA
- ECU causing A/C not to work ???
- !!!WHERE DO I CUT!!!! FOG LIGHTS
- Removing 1997 civic centre console
- 93 Civic H22A A/C questions
- no pwer to my car
- Does anyone sell gauge pods around the cluster area?
- HELP PLEASE! Stutter in 3rd Gear
- proportioning valve civic 97, which is which
- 2gauge or 4 gauge wire for battery relocation?
- getting no spark, she wont turn over
- Civic 92-95 H22A electronic speed sensor issue
- Car dieing after reaching operation temp
- Question about upgrading 240mm brakes.
- hatchback spoiler removal
- 98 civic si engine into 93 civic ex 4dr
- hey need a awanser
- looking for a b
- When is the radiator fan supposed to turn on?
- a/c belt help?
- Weird sound??
- What temp. thermostat should my car be using.
- coolant gone?!? no leak no overheat!?
- SI hatch brake noise
- swapping 2nd gen b16a into 97 hatch
- b16a head gasket and rings
- EG overheating/hot restart problem
- POST Videos of your cars!
- Keyless Entry 97 HX
- Has anyone ever seen or done this setup?
- No cat converter on a 93 VX?
- interior water leak.
- random single cam question....
- HELP!! SOHC HEADER .. WILL IT FIT!??!?
- 98 Civic Short Shifter/Shift Knob question.
- NEED HELP ASAP!!!!!! PLEASE
- Stripped adjustment nut SPC upper control arm
- CV Joint...Odd Noise...Help???
- p0700 and p0730
- Compatability between 92-95 hatch/coupe/sedan
- Hit a big rock in the road, now steering wheels is crooked..
- yoparts?
- build questions
- 1993 Del Sol 1.6l SI - Starting issue
- lock control box
- B-series A/C Compressor in EG (or EK even)?
- w00t! - New EK sedan that I purchased - 1999 Honda Civic EX Sedan 5-speed
- O2 sensor signal wire
- 13" wheels on eg si rotors?
- brake ?
- Can some one please help me!!!
- VTEC sputtering
- Throtle Body Question?
- Spoon style power mirrors replacing manual mirrors
- Car overheating after Water pump change?
- EG shell B series engine/trans swap
- idle goin down then up?
- jdm headlights?
- A simple throttle cable question.
- '00 B16 sWAP INTO A 97 CIVIC CX. ENCOUTERED PROBLEMS!!
- b18b1 into ek ????
- Importing cars from Canada?
- k20 eg, need help
- cv boot replacement?
- WTB!! EK's INTEG's
- CIVIC Parking Problem (Automatic)
- Can your downpipe from your headers go bad?
- Annoying sound eliminated
- timing / cam gear / valvetrain weird problem
- Need help on adjusting valves..asap
- 92 hatch help
- how to change a timing belt on a 2000 civic ex 1.6L V-Tech D16y8
- turbo? super? or pro? charger for my 2000 civic si b16a
- Mirrors
- Random CEL in a '92 Si (d16z6) ... WTF?!
- Which car is a better deal?
- B16 Related: Vtec and Cam seals
- Whats the proper gapping of my spark plugs for a 92 civic dx?
- temp gauge
- What causes detination issues?
- What Altenator belt for H22 SWAP with NO AC/POWERSTEERING
- Metal to Metal sound (sounds like a pully)
- head bolts
- Idle bobing
- BRAKE DUST
- gsr swap...with a p28 ecu.?
- Air intakes: Benefit in changing?
- question about acceleration issue
- New owner
- greddy injectors?
- speedo issue
- A/C
- two stereos?
- short shifter short question
- trying to ref'd h2b
- Help with swap
- compression test
- Location of AC Clutch Relay in 97 Civic DX.
- rpm's cut out at 3500. NEED HELP!!!
- Overheating and steam from radiator
- high emissions smell from exaust
- Weird Problem 97 civic jdm b16a
- timing cover melted d16 vtec
- lighting problem :(
- Problems with my EK with H22A
- where do people find these pictures
- New guy with some questions about a 93 civic with a gsr swap, What hp can this swap handle?
- rs badge on grill
- Is this a SI cluster ?!?!?
