View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Exhaust question
- What IACV for OBD1 JDM b16
- 5 lug question.
- D4 light are flashing???????
- 93 hatch h22 swap questions
- Ed
- Broken Front Wheel Stud...
- axle stuck into intermediate
- s2000 cluster question
- Should I Paint my Steelies Chrome??
- P08 ecu?
- Help plz. bad ignition key lock...........
- wierd idle
- Hmm... help identify noise coming from engine after swap?
- b16 stuck in gear
- Anyone know?
- AC failing
- Failed Emissions in NJ, High NOX
- built b16
- Blown Engine Del Sol 93 s
- Spring Question?
- civic 96 ex motor confusion
- b16 on a d16 block?????
- IAT SENSOR
- GSR cams
- obd0 to obd2!?!?
- wiring up vtec
- wireing vtec on obd1 gsr motor on obd2 car w/ obd2 ecu...help
- Oil Pressure Gauge Question/problem
- TURBO B16A EG
- obd1 gsr into dx??
- NO SPARK!! how can i diagnose the problem??
- ? on vtec on a d16z6 built
- Sealing spoiler
- o2 sensor wiring help
- Emergency brake or Slide Pin Problem
- 97 Civic HX
- Refresh My Motor
- super wiring mystery! see if you can solve it
- Eg hatch wont start
- all 99-00 si had lsd??
- EX coupe weight loss ideas.. sunroof/sideskirts
- My motor...
- b16a clutch problem
- GSR help again please and thank you!
- JDM B16a with an ITR ecu
- 99' Civic EK power window door switch
- so what about these pedals?
- leaking grommets may have caused stall..?
- B18C swap into a 97 EK 2dr Coupe?
- Need Engine Help fast....
- Sway bar install
- No spark .... how to diagnose??
- Rust a common problem for EG hatches?
- paiting headers and valve cover
- Ek, Eg rear suspension question.
- headers for a b16sir2??
- 99' Civic EK door glasses
- wtf, car won't start
- Looking for the legality info of the k20 swap in california
- i need help asap wiring.. i think & jerking
- 99' Civic EK fuses
- Lower ball joint trick.
- >>**pROJECt d15b-T**<<
- Console button/switch blanks? What goes here
- anyone knoes the spoon yellow color's name?
- 99/00 SI owners (ASR kit)?
- Fuel rail leaking...... Whats wrong?
- ovvver reVV from hell (tranny problem)
- hey
- Ecu options?
- really fast question.....
- b18b only 145 hp??
- Best way to restore...
- need ur answer
- Car wont start!
- knock sensor
- Hard wiring Vtec Solenoid?
- fuel blockage...
- cusco os strut bar for ek
- My automatic transmission
- should i be worried?
- headers?
- Is eg stock exhaust pipe not high flow enough?
- Do i need to reset ECU after i replaced a chipped one?
- Go Turbo or all Motor????
- Questions about trading my car
- anyone got a dc5 muffler on an EG hatch? post pics
- Intake squeak?
- smog check failure,,,help!
- what AXLES for B18C into EG swap
- Help with K Swap
- cable hydro trans???
- Y7 redline
- Need help about A/C
- ECU
- question is legIT but no help. why?
- For Sale: Speed Pro Bank to Bank $550
- CEL while driving, solid CEL, tried different ecu's, car drives fine but solid CEL stays
- motor help
- Heater Issues in 97 Cx Hatchback
- valve lash on a d15b7 ????
- b16a1 into ek?!?!?!?
- Replaced ECU and distributor/ignitor, still no spark (D15)
- d16z6= 1 plug from harness has nowhere to go!!!! help.
- My brakes gave out
- B18C Troubles/Sob Story
- quick question
- Quieting a Skunk2 Exhaust
- question regarding shocks/springs installation..
- headlight harness problem
- Help, Front Wheel Shakes, Noise When Driving
- clutch kit
- Squad Rear Tow Hooks...
- Idle Issues in stock 97 cx
- any1 know brakes????? 00' si
- auto to manual conversion
- lowered 95 Del Sol, now what?
- Does anyone have a REALLLY good FAQ for DIY engine swaps. First time & very confused
- Mini me redline
- 93 del sol Automatic trans side button locked up
- Lightweight Flywheel
- 1999 civic ex automatic motor and tranny swap
- 00 Civic Si B18C HELP TURBO PLEASE!!!!
- Interior Carpets
- lowering springs/rear LCA bolt help
- The Uber ECU.....
- which a/c compressor 4 b-series swap in eg
- Popping/backfiring after heavy throttle
- i need to know the weight of....
- Popping Noise
- Help with motor swap
- 99 civic radio/ a/c control area
- Exactly what bolts do I need to take off to remove the alternator (98 Civic EX)
- T bracket
- 1 wire oxygen sensor to 4 wire oxygen sensor on civic cx
- Zero1000
- need an alignment or wat???
- whats going on with my car!? please help me out!
- bullet riddled si restoration project any takers?
- need help
- what you guys think about my del sol jdm si conversion!!!!Lookkk
- Timing belt change with adjusted cam gears
- h22 into a EG thread?
- shift light in stock DX cluster?
- problems with my car!!
- ECU question
- Civic rails on s2000 seats - looking for a write up!
- 97 ek transmission question...!!!
- OBD l or OBDII 94 DX
- difference wings between models
- Civic towing a large tool box?
- clutch/tranny interchangeability question
- o6 si in a eg??
- is the front frame on a 95 civic one piece or a detachable sub frame?
- Climate control.
- Help Please!! Using a P7J/P54 A/C Bracket but lower P/S bracket has clearance issues... why?
- p28 identification
- Power Steering SOHC DOHC Question.
- 1999 Honda Civic DX
- is there a quality fuel filter or all they jus the same?
- Lower Control Arm Bolts
- gsr help please~!
- Check timming w/ aftermarket pulley
- rapid fire turning signal / overheat issues? 93 civic eg hb
- Lower radiator support bracket
- timing issue im confused
- New here, with question.
- d15 firing order??
- Speedometer/Odometer troubles.
- Feasible?
- Hard into 1st gear
- hatch raer seat
- JDM GSR (b18c1) q's
- 90 integra suspention to 92 civic?!
- HELP with fog lights
- lsd clunking
- GRINDING NOISE 98 civic
- EF si seats in a EK
- DIY polyurethane engine mount?
- Speed problem, car dies after 90 mph. Question?
- Turbo'd Mini Me... another one.
- bad axle? strange noise help plz!
- msohc motor mounts
- True ignition source
- sucking up gas.
- Lower Ball Joints?
- ej door handle question
- car wont go pass 2700RPM!!!!
- need help find a carbon fiber rear dash trunk cover
- Help... just swapped 2000 B16A2 into 1996 Civic EX; P/S bracket does not fit
- how do i know if i have a bad tps?
- How much play to your clutch?
- PCV valve?
- ek fog lights
- Battery & Alternator NEW, WHY IS THE CAR DYING!?!?!
- exhaust for d16y7
- eg glove box question
- DC Integra dash into an EG Hatch
- VTEC KICKS IN AND STARTS TO CUT OFF
- del sol
- tyc eg mirrors?
- Jazz Pro in Dallas texas.. TERRIBLE!!
- EG or 4door Teg
- looking for a 96 up ex coupe
- engine is DRINKING oil
- fuse and light problem
- Spoon Muffler
- shifting stabalizer help
- ground controls.. which ones are front and rear?
- RHD progress2
- climate control
- Clutch...Q
- who did a 98 ex swap into a 96 dx hatch?
- Car idles way too high
- halfshafts
- where to get a turbo charger installed
- all motor d16z6
- 96 ek configs..
- got bored so i painted my roll cage
- i need to know???? help is needed
- bored so i cleaned my engine bay up a bit
- Tail light question
- help PLS! rear seats on my ek hatchy
- 97 Ek Engine Problem
- what to buy 1st for performence
- high flow cat converter
- welded differentials so u have lsd?
- Need help on EG Dash.
- B18C swap - crank sensor problems
- Change clutch pedal angle ?
- stock compression
- Rust - Del Sol - Need advice
- Its a start...
- P72 on B16...need some info on driving the car.
- Bought some spoons but they need to be refinished-anyone know a black that is similar to the origina
- removing rear fender rust on my ek hatch...diy or body shop job?
- cel number on b18c ek
- New here
- please help!!!
- need help with rear seats
- help!
- Whats better a type r or a Gsr engine???
- How much to ask for my EM1
- Another Mini Me Question
- What is this thing? (sorry no pic)
- how long is stock civic cat?
- D15 SOHC distributor wiring
- si ?
- Gsr in a 94 Eg. Cel code Tps #7.? question. Front end vibrates and a Tierod/steering ?
