View Full Version : Honda Civic / Del Sol (1992 - 2000)
- eBay parts
- how do you install powersteering?
- D16y8
- ignition timing
- Will this transmission fit on my motor?
- 2000 ex power mirrors not working
- Charging Battery
- Have to give gas to start the car
- Suggestions for suspension set-up
- Is this a/c manifold ok to use?
- weird honking (?) noise in ek??
- Del Sol JDM Maplights pigtail
- HELP
- Normal Running temp?
- turbo problem
- ball joints... I've tried everything.
- need help on why my 00 gauge cluster gas gauge wont work
- d16y7 to d16y8 intake manifold swap problems
- eg b16a2 wont go into gear.
- These tails on a Sol? Need to be modded? What kind of paint.
- taking apart folding mirrors for EK
- o2 sensor? gsr into 95 cx swap....will i be in limp mode?
- wierd electrical problem
- Power Steering reservoir keep it or remove it?
- oh gawd, not another noob asking about engines
- Intake manifold.
- my altenator berring is squeeking
- HOW TO: USE A OBD2b 1999 2000 Civic EX harness with b16, b18 swap
- D15B turbo question
- HELP!! ECU Codes wierd?
- b16 transmission vs. b18 transmission
- Idling Situation HELP!!!
- Radiator flow tank for my coolant???????
- Please confirm this rear disc conversion question. *searched*
- radiator cap for d16z6 civic coupe 95
- would you trade a race header......for a carb legal one
- Exedy replacement Stage 1 Disc
- Will the 92-95 Civic HB/Coupe Mudflap fit onto a delsol?
- Which Alternator for poor man's type r
- 94-01 Integra LS rear lower control arms
- rywire chipped ecu's?
- Service schedule
- QUICK ECU QUESTION ?
- 2000 civic radio removal
- Problem with front st sway bar
- WILL A 99-00 SI CLIMATE CONTROL WORK ON A 96-98 CIVIC
- Headlight problem
- Main relay Problems, Getting power to relay with good relay but not going to fuel pump?
- is this swap worth it?
- motor runs.. but try to give it gas.. and it wants to die...
- CARFAX, PLEASE HELP???
- Help! Car throwing P0453 CEL and has a high idle
- how did the shock end up like this
- short shifters?
- homemade license plate relocator
- im sure this has been talked about but i cant find it.
- ***STOLEN 4DR EG8 in SACRAMENTO***
- PLEASE ANSWER! question about lug nuts...
- Dash lights are so dim?
- 92 honda civic problems
- how to change ebrake handle
- write up on reinstalling a/c system???
- injector/head question
- head light issues
- Speed sensor (VSS) for B-series same as d series?
- noob question
- Anyone seen this kind of trunk lid before?
- p28 + d16 (obd2) = F'd up timing???
- Parts of A/c
- help me!
- Shift light install problem
- BELT REPLACEMENT on 99 Civic HX sohc
- Window question
- 1995 GSR front brakes on 99 EK hatch?
- How to identify USDM ctr pistons vs. JDm?
- shift linkage
- Down pipe and high flow cat to stock exhuast
- coilovers
- engine harness
- how do i get beyond trial user?
- Spark plug wires? Which is best in ur opinion?
- overheating again!!!
- new here, FBP 99 Civic Hatch
- Help? Engine bogging?
- Muffler silencers - Does it really work?
- 96 dx, wanna swap 95 gsr; worth it???
- How to tell usdm from jdm ctr pistons?
- Safe to drive on 3 lugs?
- motor oil question?
- Densor Universal O2 Sensor
- Going on long trip - What to check/replace?
- b16.. engine light for code 16 .. need help
- NO FUEL - after LS Swap
- ls/vtec swap.. jerking prob.
- ah oh, upper rear control arm bolt popped out? or something broke... look
- To many axles to choose from. HELP
- Changing Outer CV Boot Without Removing Axle
- are these the same?
- b16 -> ls/vtec
- Clutch Safety Switch..
- I need help on a b18c1 swap into a 99 civic ex
- 94 gsr front disc conversions on my ek.
- !!!!CEL P0133 & P0420 Help!!!!
- wheres the main relay located on a 1999 civic ex? (yes i searched)
- zc motor is the best?
- 2000 Si squirting oil out the side of the block.
- crossmember fitment ?
- Where to buy axles?
- B16 in civic when hits vtec choke hesatates- Help!
- FS civic
- help w/intake setting...
- windshield squirters... squirting roof o.o
- CHECK ENGINE LIGHT!
- quick question
- EK jdm fog lights...measurments?
- MY DOORS ARE SAGGING =[ please help!
- A/C refill proecdure with vacuum pump, correct?
- carbon fiber
- People w/ aftermarket steering wheels in an ek
- Can u turn cross-drilled rotors??
- SEARCHED, What is this harness for? Front by Headlight, corner light.....
- B16A Swap into EG (Pics of engine)
- 2000 Civic Dash into a 1988 Civic
- a/c - kicks on and off... wtf
- ARP HUB?
- Type R in EG2 Over Heating AT IDLE
- Is the ignition control module linked to the starter somehow?
- what to check for before swap startup
- lost of power
- Blown Reverse
- Boring block vs/ sleeves
- EG6 front knuckle into EK civic will it fit?
- solid cel..... have a few question
- Hatch weight savings?
- where can i buy headgasket/rings ect. online?
- Picture Request: White EK's with any style and size of Red Rims
- h22 or b20/vtec
- Things to look for...?
- Driveshaft clearance in gearbox!?
- Civic Automatic to standard conversion help.
- sway bar endlinks...
- B16A2 JDM smog problems?
- obd2 to obd1 dizzy help
- HELP!!
- help... ELD,APS, ??? info needed Crome features...
- srs and cruise control light constantly on
- Stripped threads on tophat studs
- How powerful can a d16y8 be?
- problem with sir!!!
- will jdm fit
- No spark on my EG si
- low seat rails
- Powdercoat Calipers or Not?
- Si rear seats in a 4 door Ek...?
- Max offset for 17's (Stop-Tech releated)
- Turbo/Supercharger
- NEW!
- tsudo n1 style exhaust?? how do they sound?? fartcan-o-rama???
- Strange thing happens every once in a while.
- D15Z1 (vtec-e) wont start...
- selling full garrett turbo kit for b-series
- ls/vtec questions
- I need help in Atlanta. Crown bolt came off the UCA. Recommend a shop?
- LCA hitting brake dust shield???
- How do you remove the plastic pieces around del sol rear window??
- CEL 43 help plz
- Trunk leak+Trunk alignment
- For Sale: '93 Honda Civic Si Hatchback
- wtb HX rims
- wtb fenders 95coupe..
- what to look for when buying a 98 civic w/ 144,000 miles
- 99 civic ex suspension help
- Clutch slipping when warm.... HELP!!!
- EK Sun Visor keeps falling, driving me MAD!
- Reverse lights, license plate bulbs and 3rd brake light
- all motor non-vtec
- Effing shopping carts!
- y8 manifold.
- Quick Question -Searched : CF Power Chamber on Stock D series motor?
- More turbo qwestions...
- 1.5 CFM 1/6HP Vacuum pump enough?
- Timing belt question
- ef rack and pinion on eg?? possible??
- Pics of my 92 si
- upgrading cams
- short shifter question...
- 98-97 Del Sol Front Bar Part Number
- wiring problem...
- Got My Car Dynod Today.
- HELP! ! ! GReddy Turbo on an B16
- civic exhaust..
- Having trouble aligning strut with rotor
- blown headgasket....questions on damage....?
- HID fitment question
- de-badging-- does anyone know?
- clutch set up
- question for an intake fitting
- How to bleed the clutch?
- USDM EK tail light vs EK4 tail light
- 96 EK with 95 GSR motor. Engine harness woes
- Light question
- IS an AEM fuel Rail ILLEGAL....
- which bendix pads to get
- Clean Interior Metal??
- need help picking new engin mounts
- How do you use a d16y8 harness on a b16a2 if the dizzy plugs are different?
- civic dx fuse box diagram
- Would a oem 99-00 si oem exhaust + cat work on my JDM b16
- what goes between my axle and transmission?
- What is this piece called >???? NEED TO KNOW
- What Exhaust setup is best
- GSR brake swap, Integra Master cylinder/brakebooster necessary???
- How much spray is safe for my car
- hcp motor mounts???
- are the plugs different on a b16 obd2 dizzy and a 2000 civic ex d16y8 dizzy?
- 00 civic si
- cluster
- Help: 96-98 & 99-00 EX engine harness
- ball joints?
- What to look for when buying a used 1997 Civic w? 144,000 miles?
- Quick catalytic converter question.
- top speed for EG Si?
- So I used a d16y8 obd2b harness with a b16a2.... what do I do for the dizzy?
- throwing a code 21
- LOWERING Oil Pressure... What Oil To Run? Additives? Temporary Fix Need Help
- Del Sol wiring problems
- Need some help please.
- will a 92-95 power steering system fit a 96-98 Civic Model?
- UKDM rear fog light switch?
- best weight for a 95 ex tranny fluid?
- GM syncromesh friction modified..when does it kick in??
- new steering wheel horn install
- northern florida hatch owners!!!!!
- gauge cluster question...
- ecu trouble
- type r?
- i cant get the axel out to put new arp studs in.... help
- help ek hatch tail light stud broke off
- Whats Up! new to site
- 95 Civic no-start
- help! smashing now gear feels out of place
- HELP
- Help with b18c ( r ) swap into 92 civic dx hatchback
- DOES ANYBODY KNOW A WEBSITE THAT SHOWS VEHICLE WEIGHTS OF DIFFERENT CIVIC AND MODELS.
- rpm just drops
- 92-95 dx vs si
- K-Swap Questions
- Instrument Panel Dash Cluster
- d16a1!?
- how high is too high for turbo?
