View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 98 Civic OEM clutch
- Replacing entire rear 1/4 on an eg.
- ignition key switch problem...
- motor problem
- fog light installation guide EG/EJ1???
- del sol 325cc injectors question
- Need help with engine light code
- finally pics of my EM1 tell me whatya think!
- Timing marks for stock 1998 civic?
- just need some of your suggestions.
- Hmotors online engine...(d15)
- d15 turbo setups
- newb
- lookin for...
- broke front lip, fixable?
- fuel filter how to??
- eg headlights
- itr dash swap into eg
- cant get timining right "pics"
- advice to turbo 1999 civic si
- cel code 5 any suggestions?
- WTB Turbo Kit for 96hatch
- Weird clicking noise from the passenger side area NEED HELP!!!
- h-brace
- What is the proper way to bleed the clutch master cylinder?
- driveaxle/transmission problem - did i fuxor something up?
- Defective head?
- Highest section width?
- Rsx type s brakes on 1999si
- Is a 92 hatch main relay the same as a 91 CRX SI?
- Acura/Honda 17'' brand new rims for sale
- Squeaking
- PLEASE HELP!!! What clutch will work in my JDM b16a SiRII motor???
- front end changeover?
- 2000 Civic Si, What should i do?
- Brake question on my EJ1
- oMy motor is overheating! . please HELP
- 92 Civic Hatch Si Vibrating under throttle only
- Seafoam on a 250k mile engine...
- replacing headlights
- Bell housing back on tranny..
- whats a 93 del sol worth?
- WTB parts
- cruse control in a 93 eg
- Horn problems on MOMO detchable steering wheel
- b16 swap help
- GSR CLUSTER PROBLEMS INTO 96 EK NEED HELP
- fake skunk2 intake manifold?
- Air Conditioning Fuse Location
- Weird Noise - Video link enclosed
- Coolant lines for turbo
- grounding/earth kit really work?
- bogging on a sohc?
- Low beam bulb size?
- parts needed to install passwordjdm cf intake onto GSR motor?
- HELP! NOOB QUESTION!
- D15Z1 swap to D16Y5
- need help...rear disc swap
- Help needed in Orange County area
- vafc manual
- Websites for parts, all types of parts?
- brake noise... squealing
- HELP! Car Wont Start
- Will this build work?
- build question
- new to here and hondas
- timing
- Calling all Toronto Honda Heads...
- replacing window scissors?
- squeaky intake
- where to buy an ecu for this set up? n/a b16 i/h/e
- switching back to Si cluster from CTR (prob)
- Switched connection
- D16 turbo questions
- Skunk2 Intake Manifold on D16Y7.
- Bullfrog head package
- rack swap
- endyne oil system
- 2Dr/Hatch Fog Lights into 4DR POSSIBLE??
- b16a2 using thicker head gasket to reduce compression ratio for a turbo vs new pistons
- Need help H22 eg
- are these ebay sway bars good ???????
- An ecu to replace a p28 in 94 Civic EX
- MY CIVIC EG HORN DOESNT WORK HELP..!!!!!!!!!!!!!
- Poor radio reception
- bearing question
- Ek auto to manual swap
- Injectors
- Car is missing causing to stall out
- If you had $10,000 to spend
- LS/VTEC TURBO HELP!!
- motor mount? tranny mount? i need mounts but confused
- EG side skirts
- car wont start filled gas tank yesterday car died,did full tune up car still wont start
- Idle problems when cold........Help!!!!!!
- Header System For B16A
- thread locked?
- please help wqith JDM non vtec d15b
- A few Question regarding Exhausts
- PARTING OUT DEL SOL
- Help!! "Can't find a suitable baby car seat for my Civic 97"
- Need some help plz
- Car Dies sometimes + idle issue
- help with gas needle
- crvtec headers question
- swap in my 97 civic
- BOOSTED 99 SI 4 SALE
- e brake handal removal
- Need help with swap....half done.. HELP!!!!
- AEM Cold Air intake
- i need some help d series
- 98 HX, sputtering.... what are my distributor options with VTEC-E? Will nonvtec dizzy work?
- which size should i go ??? 2.25" or 2.5" exhaust (recommendations highly appreciated)
- 07 JDM B20B swap help
- Code 14
- Del Sol Experts!!! I NEED YOUR HELP!
- D16y8 Header ???
- jdm parking pole light not working....>_<
- fuel rail
- Mugen Twin Loop Exhaust
- I hate this car - only place it's driving me to is DRINK
- 99-00 civic bumper, 2door and 4door the same?
- DC5 momo steering wheel
- Headers hitting my oilpan??
- 92-95 Transmission bolts the same as 88-91 Transmission bolts?
- WTB PARTS
- 95 civic coupe icu into a 93 hatch
- Tumbler removal Help
- Puting On New Head
- DC2 Dash in 96 CIVIC EK...
- 2000 Em1 Vibration Under Acceleration (HELP)
- DISTRIBUTER
- ..Why dont i have valve cover mounts...
- 1993 civic missing
- CEL #6 (ECT sensor) - need to replace?
- power window regulator question
- WTF is this squealy sound? (Video clip)
- o2 sensor question?
- How do you replace your plugs?
- Fog Light Connector Location
- BEST HEADER FOR THE $$$$ ? (suggestions??)
- Gauge Light Problem
- what can cause engine to skip a cylindar?
- NEED ASAP!
- need help!!!!
- someone hacked my account... i have a question for a MOD
- B16A1 injectors fit on a B16A2 engine ?
- I dont know what kind of swap i should get for my 94 civic ex
- help with power steering reservoir
- motor question
- Please Help!!! Removing dash
- Throw out bearing
- 96-00 ex motor and 96-00 dx tranny
- 95 vx harness with 4 wire o2 sensor/ with a p07 ecu??
- Difference in vtec and non-vtec timing gears?
- Bolts for b16 head.
- chiping stock engine
- i want Bense's d15b crank
- Cams
- choosing between 2 b16 heads
- Ignition Tune-up = Car Dies
- radiators
- quick question
- engine assembly
- how to replace rear wheel bearing??
- jdm visors
- Indented footwell floor board fix? take a look!
- 97 GSR head, 95 GSR block(USDM), be able to BAR on 92 civic
- Need help asap on these UCA bolts
- trying to install suspension techniques front sway bar on a 1996 cx
- 97 del sol alarm help power lock wires
- B16a second gen in a 00 ek
- Skunk 2 mani and a gay whistle
- Slave cylinder or Clutch master cylinder or other?
- Tein S. tech or full coilovers
- stupid noob with camber kit in hand... plz help
- will a reset fix this?
- Air Bag sensors... Where are they???? Help
- how do i remove the front wheel hub unit bearing
- oem headlight question
- Need your opinion on this guys
- code 22 searched but nothing really fits
- Headers?!?!?!
- sohc injectors same as dohc injector s
- 92 coupe hitch on 92 hatch
- Weird Idle, sounds like a WRX or cammed car... 00 GSR in a EM1...
- Distributor differences????
- 98 civuc EX motor questions.
- ???? need some help
- will fog lamps fit with intercooler on 99-00 civic?
- Looking for seats for my EG6 recaro, sparco, spoon, mugen, etc
- I need a inspection sticker in MA...help
- Tein S Tech vs H&R?
- manifold
- code 17 + high idle ???
- y7 throttle body on y8 manifold??
- 1994 Del Sol D16 Vtec auto to manual swap
- OFFSET require for Brembo Caliper Brakes???
- Blox Camshafts or Skunk 2 Camshafts stg 1
- eld help
- keep blowing my fuel pump fuse
- 1.6 crank doea it fit?
- b16a2 vtec not making power- any ideas
- b-series midshaft clear up
- best color for ej1 or ej2?
- Overheating...
- ticket
- can someone please help me, manual trans gets stuck/wont go into gear
- chambers in b16 head
- **DIY** Dupicolor Interior dye how-to and review.
- need help with wire tuck...
- How to Install Del Sol Armrest Covers
- OBD2B to OBD1 blowing fuses
- putting da suspension on a eg/dc
- starter question 92-95 MT EG
- Main Fuel Relay
- d-series oil pans
- boosted del sol
- Help looked...but can't figure....suspension tech. Sway bar!!
- EJ coupe 95
- hasport mount problem
- A new untried method to flush water through the block of d15 civic engine prior to changing the radi
- y8 manifold on a y7 engine
- fuse problem
- Civic 96 LX power window donot open
- gsr throttle cable install
- D16z6 into 92 dx, axles too short? (yea I searched)
- valve chatter
- Si rears fit in hatch?
- eg and ek carpet
- Code 91 fix
- INSTALLED SKUNK2 MANI ON B18C - starts then dies please HELP!!! (video)
- fenders off of a 4dr fitting a hatch?
- Fog Light Harness Question
- Help with H2B kit.
- I have a good Question?
- axle combo for LS in EK?
- battery question
- Fluctuating Idle, getting annoying...
- Smoking intake manifold?? HELP QUICK!
- Help problem with interior electrical system?
- Calling all "Frankenstiners" :o What is the average life expactancey of a B20 vtec
- ENGINE OVER HEATING
- Starter/Solenoid for 94 del sol
- i would like to get an idea for future interior mod
- Foglight Plug ripped out by accident, how can I fix?
- Car won't start. Starter?
- LS swap?
- quick LS swap question
