View Full Version : Honda Civic / Del Sol (1992 - 2000)
- how much play should my timing belt have
- Throttle Cable
- Automatic shifting problems
- car wont go into gear!!!!!!
- 99-00 front end conversion
- 96 cx tune-up
- o2 sensors and performance
- 1999 Civic EX Question
- Battery light came on
- How to properly fix a paint chip?
- Need Clutch Install Help!!
- b-series swap in EG and still have A/C?
- Putting a 92 si head on my 97 hx, have questions
- overheating slowly...
- Swap troubles
- sizes of honda 1999 vti belt?
- Looking for EG Coupe EX Door Harness'
- Is there a site to get HONDA MTF?
- K series swap
- d16z6 turbo... compression?
- GSR strut bars in an EG?
- Sales Reciept Needed To BAR Swap????
- shock/strut ????
- what turbo do i NEED...?????????
- BAAAD Front end wobble!!!!please HELP!!!
- Lower control arm... where did it came out from.
- 1996 Civic Ex
- Code 21 .. Help.. CEL comes on when i hit vtec
- waddup
- Civic custom dash gauges?
- del sol valance panel
- having problems with stereo connector
- Help! Code 21 (vtec solenoid).. how to fix! comes on everytime i hit vtec 5700
- removal
- H22 EG Shifter Box
- H22 EG Half Shaft ???
- pics of the hatch
- Another civic down
- head question
- 1996 Civic EX for sale, body damage, 95k odometer, si rims w/ new yokos
- What LSD will bolt into a 00 si tranny??
- Fast brakes rear brake upgrade
- Tach AND Spedo "jump" around
- Will 94-01 integra armrest pad fit on a 96-00 armrest console?
- IAC high idle problem!
- Programming 99-00 keyless entry?
- tunning question
- 4 cel's (Help Please)
- motor mount compatibility question
- ls vtec done.......but
- 93 civic si front lip
- Rear seat belts
- Front Sway Bar for 93 Civic
- Which tranny should i get??
- HELP quick responses please
- NEED: an answer quick (ECU)
- Can I take out my D15B engine without removing the tranny?
- B16 coupes
- need help fast and badly about tranny
- Quick question
- Bore my block yes or no
- URGENT HELP: any oil is better than no oil at all right?
- DC2 mission with B16 engine?
- How To: Throttle Body and Intake Manifold Coolant By-Pass
- jdm b16
- sir ek bumpers or 99 ek9 front end? please help~~
- 98 EX sedan, cold air intake, yes or no?
- installing spark plugs in a 94 civic ex
- Car won't crank....PLEASE HELP
- civic 4 dr weighs less than a 2 dr??
- a6 head on z6 block. which timing belt?
- Car quits, will crank but not start
- Vtec troubleshooting
- Head stamped PR3-r??
- going to remove/install all mounts a little help.
- Fuel Filter
- vafc mounting and pic request
- radiator support question
- 1994 Honda Civic - Engine light on (yellow)
- moisture in headlights
- Does This Sound Like A Problem?
- z6/y8
- good suspension setup?
- b7 crank into a z6 block?
- Brake Upgrade Question
- vtec wiring?
- cams for b16?
- lookign for information on a FRONT END SWAP
- question
- ek civic d16 trans swap
- is engine bad or is it just an injector?
- Rims and tires f/s
- 98 civic dx--- OEM Struts and shocks question...Does anyone know?
- tps problem
- Biggest benefit of an aftermarket steering wheel that I found
- DPFI to MPFI in a 98 civic. HELP!
- Best way to stop leaks from the oil pan?
- Help with pretty loud "KNOCKING"
- 94 EG d16z7 vtec put into 97 EK d16y6
- Driver side inner outer tie rods is shot.
- Need Ball joint tool for 1993 Civic
- Anyone have any reviews on the Password JDM 3-point strut??
- best intake for a cx?
- removing dash
- need help in building custom zc hybrid hyrdo tranny ATTN: Mista Bone
- Rmf headers
- Are there any links on how to bleed coolant??
- my radiator hoses wont hook up to B16a2
- didnt know which forum to post this...*clutch* issue..
- Heater making a lot of noise in an 95 civic
- sound right?
- s2k seats in a civic
- 1.3L Carb (DX) EG to B18C?
- loss of oil pressure
- Spoon Axle Back Questions
- rhd in jersey
- radiator support
- HELP! Glovebox
- idling problem..
- WHat should i do
- Changing an alternator belt on a 93 civic cx?
- swap question
- exuast causing grime?
- still having wheel hop after traction bars =(
- how do i tell what tranny i have
- OBD 2 Engine Codes
- Enersys ODYSSEY PC680
- obd0 to obd1 conversion help
- quaife steering rack
- Question on Strut tower bar.
- vtAk controller
- how big of tires can you go in a civic?
- Does jdmcarboy sir ek bumpers fits?
- which springs/shocks on my 99 civic?
- Buddy Club or tein
- does ex doors fit on hatch???
- Tranny.... Help
- OBX Intake Manifold. How bad could it be?
- hatchback minor problems
- Leaky Vtec Solenoid
- 92-95 Hatch rear quarter panel?
- fuel line question?
- Vtech Question
- Ain't this some shit
- !!!!!SICK PROB NO VTEC HELP!!!
- rotors are rusted to the hub
- Civic Audio Harness Malfunction
- power steering
- Are my brake lines busted?
- JDM DC5 Parts
- torque question
- --D16Y8 Into Del Sol--??
- motor question
- Mount Inserts from Home depot, Lowes??
- Question, why does my engine keep dying???
- Y7/Y8 MINI ME baddest header for the $$$$
- Civic Exhaust
- Konig Rewinds on a Eg civic
- 1997 HONDA CIVIC HONDA CHALLENGE PROJECT FOR SALE
- Would someone help me find a part on Majestic's website?
- Help me to install a Rpm Tach
- My Civic Si
- Radiator swap?
- AN-R Intake spacer
- behind the firewall..
- Oil pressure wiring help
- What tranny do I have???
- Electrical problem
- tranny noise, need help!!!!!!!!!!!!!!!!!!!!!!!!!!!
- d-series
- powdercoating LS MESH rims???????????
- FAQ: How to Install New Intake Manifold
- Exaust question
- What happend to the K Series?
- 95 cx dash
- honda dealership adjusting mileage on cluster?
- whats the color code for this car
- oil pressure sender on D16Z6
- 92 civic vx Battery indicator light and engine Bogg Out problem????
- DX throttle body cable on EX
- Any place sales CTR headlights seperate?
- cam seals....
- Primary O2 sensor part number?
- Steering wheel and trunk probs?
- Please Help! 99 civic si w/ 92 civic si engine
- Suggestions on build direction....
- Hood won't fit right!
- pics ???
- boosting d15b?
- Installing a Turbokit
- whats this extension called?
- bleeding hybrid brake setup
- throtle body d16y7 question
- block identification
- How many quarts of synchromesh for a 98 gar tranny?
- header help
- 94-01 JDM ITR springs and shocks onto a 96 civic?
- Throttle bracket on y8 mani swap...
- when do u replace the clutch?
- twinloop mufflers
- could someone point me in the right direction?
- Changing ignition switch on a EG?
- The Steps For Engine Swaps..Tools...
- B18a1 into EG
- How to make the tire name brand white?? PIC INSIDE!!!
- surging at partial throttle
- Swap mount needed for b18b into a 96-98 ek
- is this really 99-00 rims?
- i'm new
- Anything special about bleeding brakes on '99 EX sedan with ABS?
- 2000 Civic B16 Wiring Harness Problem!
- I'm new here and I wanted to introduce myself
- d16zc head on a d16y5 block
- B16A2 weight
- BRAKE PROBLEM HELP PLEASE
- coolant, air/fuel question!!
- anyone on HT with a black 99-00 si w. JRSC,DE,MD??
- help identify this harness
- Need to pass inspection...
- Messing up distributor timing b16a2
- Need shift knob
- Amount of power AT can hold?
- help please b16a2
- what IM gasket is that.?
- will a 94 delsol fuel pump fit a 94 eg6
- Which axles are different? I need one for an EX
- IAT Wiring install
- How To: Change Spark Plugs
- Every winter my steering wheel squeaks
- Rustcheck ROCKS!!!
- Smoked Amber corners?
- Fitment of this front lip for EG Civic ?
- del-sol,b18a,turbo, start then stall?? help??????
- 1.5 L HEAD GASKET? First post, help?
- JDM Climate Control
- Majestic Honda is Starting to Suck
- del sol seats into eg hatch
- Taking My Car Down For Winter. What About Remaining Gas?
- WTB: Stock 99-00 blue civic si fenders/side mirrors
- 68mm throttle body with upgraded intake manifold...
- Koni yellows and stock springs?
- anyone have a k20a in 2000 ek?
- STOLEN : 93 CIVIC Si *black* BALTIMORE, MD
- 94+gsr gauges in 92 hatch
- 92-95 Civic Coupe exhaust... Will it fit on a 92-95 Civic 4 Door???? PLEASE HELP!!!
- anyone else own a civic ex-S/ex-A?
- heater core and all
- knock sensor for D16Y8
- Camber question!!
- Edelbrock Performer X Turbo kit
