View Full Version : Honda Civic / Del Sol (1992 - 2000)
- side markers on eg civic
- Honda Civic 1993 swap b series HELP!
- ek rack
- eg door panels?
- quick question
- rims and things.com?
- cabin air filter
- wheel cylinder help!!!
- engine doesnt start like it should be...
- not sure on how to do this...need help please
- I hate stupid people....
- electrical problem
- Recaro SRD brackets and rails?
- 2000 4 dr civic
- stock shift boot will not fit on my h22 swap
- how much LOOK
- shoft shifter install
- JDM doors on USDM. will the power windows be able to work look within anyone
- B16A in 95 ex problem...
- itr hub conversion?
- EK brake locked with gsr set up?
- Pic request JDM DEL SOL SEATS ALL BLACK
- civic starts but stalls right away
- Anyone interested in a Buddy Club Spec II for an EG6?
- anyone have racings seats in their del sol?
- exhaust help
- jb weld
- Qustions about Car performance parts.
- D16z6 head on a D16y7 block
- b16a2 no spark
- Bumper cutout for eg6 fog lights?
- need help wit ac compressor noise
- 92-95 cluster
- headlight problems plz help????
- New here, just saying whats up.
- HELP**D16y7 Swap into EG
- quick question
- chassy abreviations
- Quick GSR Spak Plug Q
- SOHC Mini ME Conversion HELP
- DELSOL TOKICO SHOCKS .................PLZ HELP
- *** ANOTHER GREAT DIY PAINTED HEADLIGHT WRITE-UP ***
- changing wheel studs
- HID lighting Issue
- 92-00 Civic Oil Pans
- DIY??? for civi cpillar gauges install ???
- Window/door question
- Clutch Losing Pressure?
- Is this the wire for my tach?
- dumbest questions my cousin asked, but got me curious
- Need help asap!!!
- problem with timing
- Just installed BRAND NEW clutch, Having problems!!!
- 92-95 Hood Question
- Code 9 CYP is haunting me
- Overheating 1994 Civic LSi auto hatchback
- where do i get the EG arm rest
- H22A in EG - possible to remove tranny alone?
- Does anyone know what these hatch moldings are? EK Hatch part....
- NO VTEC!!!!!
- Remote? 1992 Honda Civic LX with Keyless Remote?
- Gsr power steering question, please help
- shocks from a delsol
- bleeding brakes need help : [
- replaced axel still vibration? any ideas
- distibutor question??
- ref!!!
- rsx seat swap into a 93 dx hatch
- new engine
- No heat -
- fuel problem... i think? help please!
- Clutch squeek???
- act 6 puck clutch with stock integra pressure plate
- Price on 2000 Civic SiR??
- why does my car redline at 5000 rpm
- Questions about a B20 VTEC Project.
- HELP MY GSR NOT GOING TO 8200!!!
- 93 Civic DX distributor firing order
- gsr limp mode?
- B16 TROUBLE!!
- Torque Specs for 96 civic..
- Question
- key hole
- GSR lca on EK???
- Axles
- ECU Jumper Harness Question HELP PLEASE
- idle goes down when pressing the brakes
- Need Help. Brake Prob
- ls/vtec turbo
- Checking oil pressure, fuel pressure, and cleaning A/C system?
- Strange Problem when re-fueling
- help!!! engine sputters
- cleaning fogged up headlights
- best ecu
- screwed head light
- CARFAX
- tell me what u think please
- what to do to my car next help?
- Tach installation questions.
- new intake problems helppppp!!!!!!!!!!!!!
- Smells like oil burning, but it's not?
- which is right side of piston ring??
- windshield wipers dont work need help!
- Will Honda replace non-retracting seatbelt for free?
- Beeping after new ignition column install
- Civic throttle cable with ls motor?
- manual Steering Rack, better??
- price help
- 99 civic si shocks and springs on 97 civic hatchback ??
- h22 del sol how fast?
- I need help with my mini-me swap.
- need a little help
- D-serious EK question
- Bleading brake and weird bleeder valve????
- honda gurus! wtf is code 70?!
- help!!!! no heat
- Alternator Belt
- converting my 97 ek climate control to 2000 need help
- D16A
- d16z6 cost $$$$
- H4 bulbs in 93 sol?
- Where is a good place to find an engine
- NEED QUICK ANSWER - Lower control arm bolt
- leak location
- car starts REALLY hard, help
- CTR rear swaybar quick question.
- 94 Civic Ex - Lighting/Electrical Problem
- power steering belt?????
- How to hollow out cat?
- 92-95 civic front and rear lip
- EG civic W/ Sushi door panels (searched..)
- STEERING RATIO NEWS! Swapping Integra pinion assembly to the EK rack
- 95 civic ignition module
- Cost to fix drive axel?
- Oil Recomendations
- ek hatch w/ gsr swap FUEL ISSUE!!!?
- Need help installing hella supertones
- greddy exhaust
- How can I tell if I have a Non-Immobilizer equipped OBD2b ECU???
- OBD2 Engine harness for EK Civic
- no o2 sensor, what can I do.
- Swap Problems not a n00b! lol
- D16Y8 ECU
- Electrical/ignition switch issue
- wiper help
- Cheap and Effective way to install your eg front lip!
- I can't pull my codes on chipped and vtec'ed P75 ECU
- 92 EG 4dr build
- NEE HEPL CHANGING WATER PUMP
- D15b!!!
- EK EM fenders??
- Can i mismatch D series transmission gears???
- 95 auto civic conversion to 5 speed
- CD Player
- Emissions problem
- Hood won't latch closd - Cable release is loose.
- Mid Pipe broke off at the Cat converter Friday night
- 99-00 center console on 96-98 hatch....would it fit?
- D16Y8 turbo+msd hvc tuner question
- condinsation
- ctr headlight clensing.
- K-ignorance.. pls help or direct me to helpful forum w a possible K build
- Q: D16y8 swap using D16y7 ecu
- 1998 ex y8 motor with a 95 ex tranny question
- would a hatch eg rear bumper fit on ej6???
- Can't get alternator to fit into upper bracket.
- AT civic shell into MT?????
- Skunk2 lower control arms?
- downpipe sound?
- d series vtec
- b18b intake manifold~brake vacuum line taken out
- new delSol pic thred......FINALLY
- Timing change
- New hood will not latch, frame replacement or repair?
- Decisions
- broken bolt rear lca
- Can we make a proper brake bleeding / brake fluid flush guide?
- ECU question
- disributer module
- h22 in eg wont go into 5th gear
- Thermostat change help?
- looking for quiet exhaust
- Looking For Del Sol Parts Car PA/MD
- b16a2 into a 96-98 ex
- Test Pipe (for my B series swap)
- First Car.
- any help welcomed (93 hatch)
- how to check for bent valves
- copression ratio
- part out question
- gassy oil
- cranking problems
- about to buy a car 2 choices HELP please
- removed srs box will that cause a problem
- weird "thunk" noise
- 95 ex distributer module
- poss. power loss from exhaust leak????
- Evil Question
- All B series Crank pulleys the same?
- Wont Stop Accelerating?? B18 swap
- Jdm Itr momo steering wheel
- help with short shifter knob in 98 civic sedan
- 92 Civic OBD question
- seat swaps (searched but no luck)
- power window control module
- h22 del sol?
- throttle cable for gsr
- 95 del sol meets 92 civic vx
- strong smell of gas
- motor mount help!
- Does my car have a bad ECM?
- What are these wheels?
- why does my gas gauge only work till quarter tank?
- driverside door
- no injector pulse b18c1
- Heater Help
- EK Coupe Camber Kit Question
- interior questions
- sticky throttle
- need help with shockss..........
- problem
- cel code 6
- what spoon n1 exhaust fits em1
- Skunk2 Stage 1 Cam for D16Z6 in a D15B VTEC?
- tps help
- 93 honda civic dx crank pulley keeps come loose
- 92-95 z6 engine wire harness
- 92 civic dx, Idle Bounces.
- civic auto to stick problem
- help me!
- problem taking heatshield off of a d16z6
- wheel spacer removal?
- Brake Lights not working need HELP
- need help on code 1..
- Happy Sunday.....Recieved my K-Pro yesturday and have questions for the more intelligent
- vtec..problem.. help!
- 1992 Honda Civic: Overheat / HELP!
- Si AC Compressor + GSR Engine = happy?
- 99 conversion on a 96 hatch? pics on how to
- K20a2 head build advice/suggestions/ comments wanted
- 1999 Civic, Rear Hub/Bearing removal...Inside cap of hub stuck on axl...Tips for removal?
- someone help
- IS IT TIME FOR TUNE UP?
- P0505 code, Car idles high until i block off the IAC???
- Revved to 9300rpm and i think i broke sumthan...
- SiR Power Doors in 99 Civic DX
- Trade eg hatch for teg!? help
- Reliability question on a ls/vtec build for sale
- ls to b20 swap in eg hatch.
