View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Nagano Japanese: Has anyone dealt with them??
- Can anyone help ID this mystery distributor?
- will 90-93 integra rear disc brakes work on my '99 civic hatch?
- 97 COUPE ?'s
- 97 civic help please!!!!
- h22 type s
- intake manifold swap instructions ?
- AEM Cold Air Intake for 96 del Sol Si (D16Y8 OBD-II)
- silencer help
- Knocking noise near my bottom driver side
- Catalytic converter size?
- 99-00 SI power locks too weak to lock? And, remote locking standard on SI?
- does anyone know if the sell the rear wheel bearing without the hub?
- civic i swaped a d16z6
- lowering v-tec range?
- Wheel color and type on a ek
- dumb question
- b16 schematics
- CF hood for 99 civic conversion
- HOW TO: VX/CX owners with swaps. Can't get rid of code 1?
- ***** ANY ONE HAVE THE 99-00 JDM CARBOY FRONT END ON THERE 96-98 2/3DR *****
- QUESTION: 96-98 4dr side skirt on a 2dr coupe
- b16 in a ek, L bracket?
- 92 Hatch Fluctuating Idle, USDM GSR
- Carbon trunk from GroundedConceptz.com
- Fuel Pump
- How to put X brakes on your 96-00 EK civic (revised) upgrade chart
- Gs-r cluster in eg
- Gsr Suspension on a 94 EG
- vtec and thermostat
- *** HELP PLZZ****
- ek and 95+ teg's UCA's
- aiming headlights
- z6 and y8 tranny
- Ignition coil
- OEM LIPS
- car wont start...
- Does the 93 delsol base model come with a pre wire vtec..my motor right now doest have vtec???
- Possible different way to route the shifter cables on an H22 swap...(H22 gurus please help)
- It wont go into reverse!
- JDMCarBoy...
- Will the pedals from an 01 Integra fit a 97 Civic?
- z6 just died out on me!!!
- HELP, WANNA KNOW WAT SHIFT LINKAGE FOR TYPE OF TRANNY...
- o2 simulators
- obd ll
- What caliper can i use on a 93 civic coupe?
- p16 engine found possibly misread b16?
- Eg6 Fog Lights
- Need to know stock code for a d16Y8 cam.
- code 22 oil pressure switch
- car boggs in low rpm
- ek9 interior in ej8
- exhaust leak - Permatex RED good to use?
- Ebay... Bad place to buy a catback exhaust system?
- Thoughts on a 92 Civic dx HB
- skunk 2 pro series manifold + throttle body
- Swap to B18B and having some electrical problems.. Help!!!!
- exhaust gasket question
- help 95 civic cx swap d16z6 into it
- Just bought 96 civic lx, performance exhaust suggestions?
- Brake sensor comes on while driving
- Help with b16a2 swap into 94 vx hatch
- Help Wiring...!!
- Chatering noise from 75 and up.
- re-routing hood release cable?
- tapping/knocking sound @ 2k - 3k rpm
- EVERYTHING IS ON THE WAY!!!
- b16 question...
- 99 Civic Ex Compression
- LOOKING for people with bins from Mugen and Jun and all others
- Eibach vs. Ebay
- EK color code = duplicolor ??
- still not pulling right....
- HOW TO PUT PICS?????
- Need exhaust!!
- hondata s300????
- 92' d15b8: 4 valve reliefs or 2?
- confused on compatiblity
- Another car won't start thread....Need help!!!!!
- Difference between obd1 Alternators... mitsubishi vs nippon-denso, interchangeable?
- Can new Si seats and Steering Wheel fit in an EK HB?
- hamp oil filters....
- Quick question
- Fog Light Fuse
- Any one have any rims they would like to sell
- LEAKDOWN TEST NOT WORKING - why
- tie bars interchangable?
- 00 si gear grinding?
- SOHC Nitrous set ups
- Hey
- fixed O2 sensor and still pulling O2 sensor code.
- 1999 Ex suspension
- gettin smoked
- exhaust pipe mod for 1999 htckbk
- Help!..some advices in body work??
- stupid stupid! question, but a good one, about tach's!!!
- help with 95 civic cx..
- eh3 visors in my eh2
- Engine abruptly stops
- rsx seat question
- How much is a BB/MC usually?
- d16a6 into 92 - 95 civic
- HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE
- Cam?
- momo steering wheel in EG
- fake inspection sticker ticket in VA
- BRAKE PROBLEM HELP
- i just called all over the world...
- 98' civic-new radio and keyless entry
- Just Curious - D15B8 Redline discrepency
- wiring questions..
- Help: Why does my E-Brake not work for a expletive?
- checking codes: obd2 car, obd1 ecu
- K&N vs IGT
- Leakdown test - HOW DO I ROTATE THE CRANKSHAFT TO TDC
- check this out... does this part go bad?
- 92-95 JDM power folding mirrors...
- Issues with my z6
- 98' civic electrical problem
- Clutch Switch Kill Button for Security
- MY cd player, cigarette lighter, and coin tray light have no power!
- cooling fan help
- need help lookin for a lip for my civic
- i'm back (bought an eg)
- 98 civic i want to make the radio and climate control light up amber help please
- Civic 99-00 Si rims same as the 05?
- Headlights keeps tuning off while driving. Help
- del sol colors
- Eg rear compartment, anyone know what model comes with this?
- Whats the best trany for a D15 Turbo??
- honda hatchback eg igition remove.... need some help on swaping out one for another.
- 92-95 honda civic hatchback QUARTER PANEL removal?????? HOW TO REMOVE quarter panels??????
- Ok... WTF?
- Cars driving sluggish (99 Civic Si) !!!!!!!!!!!
- are all b16's the same piston rings????
- ep3 front seats in eg hatch???
- Gauge setup
- Suggestions for Detergent Use
- best spot for hood locks
- Pelude cluster in EG
- **Need Help** finding the correct bracket for this racing seat
- what color is this civic and what kinda head lights aare those
- spoon sports exahust, which b pipe can i use?
- Clutch problems HELP!!!
- Size of NSX-R steering whee
- Deciding on what headers to get..
- will a 96-00 civic coupe catback fit on a 96-00 civic hatchback?
- interior colors
- hey del sol frame flexing
- b16 piston rings
- HIDs with stock headlights?
- ls injectors in a b16
- Del Sol people
- generations
- what exhaust will fit Del Sol???
- Coefficient of drag for a 92-95 Hatch?????
- Anyone have any ideas?
- Go OEM? 2 different prices?
- motor swap?
- 95 civic ex wont run right
- what are these?
- where can i get another carpet for my hatch??
- ecu? please help
- JDM SiR foglights
- Transmission help needed
- Where to get the power->manual steering conversion kit?
- What have you paid for a rear disc conversion?
- 2 inch cat
- *HELP with a 98 Civic SI
- Surveillance
- where to get a tach needle for jdm cluster
- charcoal canister HELP
- will 99-00 si rear seats fit in my 93eg
- 00 Si front on 92 Si
- 96 civic w/ H22 what would be the best turbo kit set up? and for a resonable price?
- quick ecu ?
- START SWITCH tirck to start ignition HELPPPPPPP !!!!!!!!!
- will a 96-00 HB catback fit on a 92-95 HB?
- cd player question! help asap
- hondata
- HOw To-99-00 civic radio/AMBER LIT?
- MAP Sensor Code?Missing Link
- will an LS oil pan fit on my b16
- Constant high idle--Help me figure out what part(s) went bad??
- WTB: EG SHELL IN UPSTATE NY
- Moving my converter.
- My dyno on b-16
- Trade 97 tail lights for 99 or 2000 tail lights plus cash
- Dash interior wire harness 97 civic EX problem...help ASAP
- *** 96 Civic Door Handle Help!! =( ***
- trial period
- quick dizzy question
- R18 civic 8th gen engien specs?
- LS into a 92 hatch
- can someone help me out with the name of this part?
- ITR Sways on EG
- fuel problem gas is not going from the fuel pump to a fuel filter
- Going To Get Civic For First Car
- have a 93 dx hatch.will an ex moonroof fit or will i need the 92-95 si moonroof?
- cluster and climate control light problem
- Replacing Radiator Support
- d16y7 to d16y8 whats needed!!!
- Civic EX Wipers
- transmission problem..help please
- Randon Misfire, CEL 71 & 73
- CTR headlights for HID's?
- is my car obd1?
- What does a front lower strut bush bonded suspension look like?
- car runs like crap
- Question about aftermarket header collector sizes
- Emissions Help!
- How to bleed cooling system on D16Z6
- Will a Turbo kit for a 92 Si-Hatch....
- question about rear lights with carbon rear hatch.
- GSR seats in 99 hatch
- So I Keep Checking to See if There's a Dead Cat Under My Hood. Whats the Noise??
- my egs drivers side floor is wet......
- SIR sideskirts question
- f/s: Enkei RP01 16 x 6.5 wrapped in 205/45/16
- Starting problem
- 92 civic front end masurements please help asap
- Just finished the h23vtec swap on my EG
- SOHC VTEC head swap, need parts and help!!! please.
- buttons on the climate controls...
- I bought a car with a LEGIT six finger wheel gap!! ..spend my money!! help me fix
- eg dx to power windows
- who has mount inserts? read me...
- nice ass civic but no performance mods?
- Cheap Power
- Is this possible? eg owners
- Best Ecu for a B16a2 motor
- Vtec want engage on H22 in civic
- ecu wont reset
- del sol si rear discs on an ek?
- wtb beat up civic
- car idles eratically like a iacv already replace
- my indiglo's blinking....please help me this time!!!
- exhaust question (EK w/ B16A2)
- Bad Starter or Starter Wire?
- smoke comming out manifold
- 93 Civic Idle Issue
- advancing motor to high?
- A/C problem
- Any one need any parts??
- what is the name of the stock EM1 colors?
- B18C swap in EK Questions
- Ek CX owers enter here
- your suggestion
