View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Crank fluctuation sensor code 54???
- Urgent help
- Temperature gauge is inconsistent
- AC/HEATER Problems
- need autometer dual gauge pod!!
- Problem with headlights, tail lights, dash lights... What could it be?
- low idle help
- How can I find out what cars these engine and tranny parts are????
- HELP.... My idle is surging..
- Somewhat easy question. EG related *pic*
- Which aircon bracket for B16A2 into an EG?
- Loud TICKING Likea dam Diesel
- ride seems bumpy? help
- D16Z6 runnin a little bit rich.. anyone else?
- Adjustments on Apex N1 suspension?
- Next upgrade i should get?
- GOOD PRICE?? FOR 96 DX CPE?
- honda civic help...
- engine knocking from cam gear side!!!!! bent cam gear?? SEARCHED
- fuel pump not working ?
- GSR cloth seats
- 92 civic rear wiper install
- 2.38 inch exhaust gasket
- want to put hid kit in ek civic
- abs in a del sol
- will a y7 dizzy work on a y8??? (Ive searched but have not found a concrete answer)
- What motor comes in the the S2000?
- d16z6 tranny ?
- Guages.
- 96 cx into mini me...just a head swap?
- EX TRANNY
- DSM 450cc Injector into a SOHC Queston?
- 2 map sensors
- Will Coupe dashbard fit in the Hatchback?
- EX Power Window Conversion SEARCHed.
- lips for a del sol?
- vertical door kit?
- pricing for b16 swap...???
- del sol
- Side Skirt Question... And yes i searched
- Looking for a Honda civic hb 92-95
- EG6 Audio Console
- Need help
- Need help>>>>how do i put H I DS in tyc elegant back housing lights
- JDM Civic Audio Console Question
- Suspicious Black Civic in Charlotte, NC
- what tool can i use to adjust my illuminas shocks
- how do i become a member???
- Cold driveablility issues
- DIY HEAD LIGHT COMPLETE AND LINK TO HOW TO
- Swap my D6Z6 engine on a 94 Civic EX to a faster one?
- weird road noise in del sol
- Question about honda purchase
- what are some steps i need to know to register my b-series motor?
- A way to tell if my head is still good?
- clutch pedel pressure flucuates.
- Help me choose between the 2 combo.
- Can I pass smog with a cracked manifold?
- clutch slip problem
- Stock suspension help....
- Show me your 4 door civics
- anyone know about d16z6 motors???
- Finished my swap(d15b with p28 and si tranny)
- JDM EG6 Corners
- So whats up with my car?!
- Engine Swaps... Auto engns to manual engns have less power?
- Whats the best swap with the most potential?
- installing clutch and flywheel.....questions....
- suspension neuspeed/tein
- NEED HELP LIKE ASAP THANKS
- ek civic axle help
- New header's for my DX hatch 98
- civic ideling outta control
- Does Apexi make a 2.5" WS exhaust for an 00 hatch?
- B.A.R sticker need advice
- D16Y8
- ek to eg springs
- how much do stock eg seats way??
- wats a dizzy??
- Auto to Manual?
- Widest Wheel?
- Which front bumper is this?
- Where can I get a header for my 98?
- delEG
- help MY brake lights dont come on
- AZ people smog question
- del sol light
- how should i do this???? sell my b16a with tranny and buy gsr complete swap for del sol or??
- turbo'ing a 95 civ
- another night at atco 11-30-04
- 92-95 coilovers
- Question about Possible trade for 99 EK
- EK Power Door Lock Module?
- 00si w/ oversized ctr pistons - stock rods?
- Will Accord/Prelude coilovers fit a EK coupe?
- 2000 civic si radio in 98 civic
- yet another idle problem
- 96 coupe motor blown, what should I swap in?
- ECU code zero? turbo d15b hatch
- Skunk 2 Intake manifold
- Exhaust Opinion's
- Seats for a ek
- does this work with no problems?
- 2000 civic ex syntec or not?
- Headlight bulb? or Ground?
- Automatic Civic need help with gears.
- Uneven exhaust gas temperatures
- Will an Integra passenger seat fit in the drivers side EJ8?? (98 Ex)
- Help with blue wire on dizzy
- What is the stock bore of a SOHC?
- Valve Bolt broke :/
- Would you buy this civic or not?
- Engine Bogging?
- Exhaust question
- blown tranny.. can someone help me out ?
- What could be causing my random heating problems?
- help! i need good qaulity buddy club side skirts.
- steering column
- TYC one piece headlights
- 90 Civic SI - Brake Light won't go off
- 90 Civic SI - Door ajar light won't go off
- fule pressure
- opinion on my swap in progress
- springs for the sol!
- Valve and Timing cover gasket life span ?
- y8 tranny
- Ek lip
- 92-95 Manual
- Has anyone bought an engine from Soshinusa.com? Looking for opinions
- how to hook up autometer oil press. gauge on b16a?
- I´m searching for a del sol bumper
- fuel pump replacement quick question
- v-afc 2 for sale
- 02 civic ex swap
- ECU Chipping website that sold lots of programs on a CD?
- carb civic i have question??
- UNDER DRIVE PULLEY
- Building a car for daily driving
- manual swap in the 94 dx
- Washing the Engine Bay
- idle help
- D16Y8 upgrade or No?
- Tilted hatchback
- All EK owners w/ camber kits...
- Oil in exhaust tract??
- Ground control and koni yellow
- Bad VTEC Pressure Switch Cause Low Oil Pressure Reading?
- SOHC TURBO TROUBLE HELP!
- Civic Headlights
- DX intake manifold
- Fan problem
- D15 tranny upgrades, what models/years
- Short Shifter Opinion's
- TEIN SS, OMNIPOWER, OR APEXi N1
- jdm access visors - updated fitting kit
- IACV questions
- 93 CX wiring for b20/vtec swap, I need help!!!
- tokico strut problem?
- GROUND WIRE KIT
- will a F20B Accord SiR-T TypeR motor fit in my car?
- Rear seat swap, suggestions?
- 99-00 Center Console Conversion, Will it fit in a 96-98 hatchback?
- ek hatch rear disc conversion ???
- Tap Size !READ!
- Want to paint me ek head lights like CTR ones, What color should i use?
- Will manual 88 crx hf transmission fit a 97 civic ex
- ease of clutch/flywheel swap...
- Attempted Theft Failed!!!
- Need help with OBD2 Oem replacement cats for 00 SI
- Noise from Axle? (after repair)
- Problem with fuel system?
- Lookin for some RELIABILITY in Rochester
- JDM D15B
- Civic Exhaust Fitment Question
- High Compression d-series
- engine seperation
- throttle body size
- will 99-00 Si F&R brakes fit behind 14" stock steelies?
- Help!!! please for my 1.6 vtech honda
- Blow off valve piping
- alittle help
- Vis Bodykits
- i need help
- any pic of TE37 cup on EG or EK?
- Koni Red adjustment tool.
- Free Eibach suspention.
- EK conversion
- Shorten shocks?
- Repairing crack/bent aluminum wheels
- Handling upgrades for my 95 DX, need some advice
- 93 ex for sale in mesa AZ, need motor help
- s2k Steering Wheel in a del sol?
- Will this exhaust setup work???
- 3rd gear pops out
- Installing an aftermarket steering wheel??
- well got stopped!!!!!!!!!!!
- Owners of 92-95 civic foglights.. Post up!!1
- beaks lower rear tie bar-ground clearence
- dilemma...
- my friend is selling 310 injectors, will they fit my car??
- D-Series LSD trans for $995* gauging interest.
- Beared witness...
- General Motors Pride...
- Ravin Axleback
- code 41and 23 wont go away
- mini me swap help: dizzy/t-belt
- TRANNY HELP!
- 2000 Si exhaust...1992 hatchback - I've searched
- Will d16z6 head work on d16y7 block?
- jdm ITR 4 lug Knuckel and suspension for sale.
- my lx
- DIY Clear headlight help
- RSX CLUSTER IN A CIVIC???
- AC tensioner pulley removal
- exhaust: twin loop vs buddy club Spec IV
- Engine light came on need help!!!!!
- Compatibility of a Y8 into an EG?
- si cluster in ex....
- eg suspension
- d15b7 head swap w/ d16y8?
- anyone running ground control 380 front/320 rear spring rates?
- D16z6 with ZC pistons 1/4 mile time Blows
- Help needed For SI 2000
- CTR Console Installed:::::PICS:::::::
- turbo
- Vertical Headlight Adjustment?
- ***LINK***
- Coolant inside cylinder?
- car is hard to start after taking out furl cap need hellllpp
- zex/comp stage 2 cam
- strange random starting problem
- auto 2 standard swap
- car dies??
- new rotors?
- quick question: difference between d16y8's?
- need to knw what the code is for the 99+ si transmission or itr trans
- Coolant ??????
- Car Auctions
- Any one with a eg hatch that had a z6 with I/H/E only Whats your Best times?
- help me
- bay area junkyards
- LS gauges in a 92 EG?
- y8 IM on Z6 head
- Dead Battery woes
- skunk 2 camber kit help PLEASE
- cheap performance ?
- Will a DA rear disc brake fit on my eg?
- Installation? DIY or Professional?
- ARP Head Bolts on USDM d15b7
- How much torque on a civic flywheel/clutch? *torque wrench*
