View Full Version : Honda Civic / Del Sol (1992 - 2000)
- carbon fiber hood
- b series intake mani on d series?
- is there a "How To" thread about the VAFC Hack????
- DC Sports 4-1 exhaust header question !
- JDM engines?
- Need a website to order some windshield trim from.
- 15X6" steelies ? What car?
- car wont start
- exhaust//header questions
- damint couldnt edit it.. serious question.. please dont lock
- a sumwhat serious question....
- header question?
- Exhaust Question
- Would anyone like to trade exhausts?
- Does anyone know where i can get this?
- Is it better to STRUT or SWAY?
- dx tranny?
- Stolen 2000 red civic cx w/ S2000 seats in Los Angeles, HELP!!!!
- good cams for b16
- JDM gauge cluster going crazy
- HEAD STUDS...
- cold engine bogging/sputtering? jdm b16a in EK
- NEED FUEL PUMP HELP ASAP!
- having trans problems, help
- injectors wont fit???
- Car Overheating...not thermostat
- headlight bulb size.
- What is the lightest Hatch for 96-2000
- vtec head on d15b7
- oil and pan and inclines/declines question
- Toda or An R header on B18c5?
- Help with Engine Swap kinda Confused.....
- clutch problems PLEASE HELP!!!!
- Steering Column
- wat will a 95 EX coupe run with a GSR swap...aprox
- what to do w/ a box stock swapped b16 into an eg dx
- Intake Question?
- del Sol lips
- has anyone seen this car around nova?
- H22 ECT sensor
- Type R Rims Paint Code
- so i somewhat completed my 5 lug but there was a significant problem. need insight
- what is my b16a2 long block worth?
- b16 swap in 92 civic
- Si front conversion
- Question for the b16b engine owners
- bent valve
- pully squeeling
- stock hp on a 99 si b16
- JDMCARBOY.COM?
- ** How did you mount your J's RACING AIR DUCT????? **
- fog lights
- wiring help!!
- throwing codes
- anything to look for when buying an 96 EK with a 95 GSR Swapped engine?
- Help with PS on my d16y8 swap.
- JDM Carboy seat brackets
- need pics of eg hatch w/o rear wiper
- How to know how fast ur going??
- exhaust sound clip???????
- 99 Si spoiler on a 94 coupe...
- shunk upper control arms
- Clutch Pedal Pressure Problems
- D16 clutch and flywheel
- h22 question...
- 96 civic ex, "stock"
- pic request: obd1 D dizzy on a B or a
- oil leak HELP
- apexi n1 ???? 92-95 hatchback (search didnt help)
- OBD1 O2 Sim???
- swapping heads.......
- Running a rebuild on an old tune? (hondata)
- Exhaust Sputtering Droplets
- Fog light install ?
- Doing my Clutch and Flywheel, and can't get the tranny to separate
- WEIRD left side brake light wont come on, bulb is good, but right and center light works?!?!?!
- AEBS headstuds for LSVtec
- EG Wheel Bounce HELP!!!
- Road Noise!Help!!!!!!!!
- integra?
- How Do I actually take the Slave Cylinder off the the tranny ?
- Help I have some questions
- GSR Block + LS Crank = BIG TORQUE+mORE HP?
- 92-95 hatch carpet into 96-00 hatch
- hydro to cable tranny conversion
- Removing d16y8 Head
- SOHC vtec head question.
- how do i remove my rear seats?
- What intake/plugs/wires
- Honda and Acura engine Trouble codes explained!
- for your amusement..
- catalytic conv. question
- JDM eg fenders on 94 coupe
- Price?
- I can't get the Driver's side Axle out !?!? WTF!!!
- Head problems PLEASE HELP!
- Crank Pulley-JDM D15 Vtec & D16Y8
- help on making a engine pass on ca
- Fidanza Axles Good or Bad????????
- d16z6 bolts? on girdle under oil pickup.
- battery relocation
- lovley new england weather
- d15b head on a d16y8 block need help
- d15b del sol or b18 civc hatch?? HELP!
- si tranny/d16
- !!!! idle prob > i did the coolant bypass!!!!!
- AHHHH !!! Ball Joint video plz
- NEED HELP ASAP (dizzy related)
- * Autozone guys say to use 10w30 motor oil for MTF !????
- main relay help
- Which oil to use?
- Radiator cap is leaking
- question ?
- About screw size in distributor (1995 civic ex coupe)
- Comptech Icebox EX/Si
- STI Steering Wheel
- 00' civic hatch brakes to integra all disc
- Difference between OBDI and OBDII B18b1
- What brand header for usdm b16 del sol?
- Thermal Shield Intake Gasket (yes searched)
- Whats Wrong With my Speedo?
- pressure plate question?
- Clutch Problems
- Help: did the 96 Civic HB come with power steering?
- Help!!! Problems with b16 swap in EG
- Lower tie bar
- Gas tank capacity?
- y8 head setup in a y5 even better?..
- big time car troubles.
- blox manifold help!!
- ES oval dimensions
- d15b o2 sensor help
- Check Engine Light back (lots of pics)
- throwing code 16,fuel injector,cause???!!?
- what did you use to put a 95 ex lip on your del sol?
- Found out my idling problem myself
- APEXi V-AFC V-TEC Controller
- will ep3 si seats fit into dc2, ek's or eg's?
- integra door panels into civic
- What tranny is p2t4? (Yes I searched)
- vx harness and ex harness
- 96 coupe, replacing window regulators
- pics of blown d15
- piggy back ECU's? / Controllers?
- Clutch spongie and very close to the floor WTH?
- 93 ex CEL?
- D16z6 or Turbo
- Installed CTR SRS wheel and Reset SRS but SRS light still on
- another not in the right fourm post
- Cluster?
- FOR SALE: P75 ECU
- clutch pedal makes sqeaky noise
- how much is a new transmission for ek civic??
- DIY Cargo Cover
- gauge ?
- 96 civic strut problem please help!!!
- head swap?
- PLEASE URGENT HELP!!!!!STRUTS
- where to find si wheels?
- has anyone taken a d15 apart?
- how do i post pics
- EG civic Overheating HELP PLEASE!!!!!!
- Sorry but search didn't help-C problem.
- engine code?
- Is this a good Price or Not? Need some help
- if you're pretty knowledge of compatibility ...help me out for a bit.
- Overheating trouble
- b18c swap into my del sol
- Swapping to 5 lug, question about rear trailing arms
- ek wind deflectors
- d16y8 stock intake pipe diameter
- sunroof problem
- Car Wont Start! Help Please!
- looking for a wiring diagram for d16y8
- HELP I keep blowing my Alternator, VSS, ELD fuse
- Worth it to buy gsr cams($50)?
- tranny mount inserts
- D16Z6 turbo, or B16A2 swap?
- d16y8 base settings safc
- New clutch??? wich brand help please?
- help with my lip
- 5 lug conversion
- DelSol climate control.
- Do i need to primer my lip after sanding?
- guage cluster swap
- 92 Civic DX - Climate Controller Problems?
- Spun Rod Bearing!!!
- eg built motor from dh-racing.com feedback
- Front Speaker Mounting Depth
- Need help! How do you take OUT the heater and heater componentes From a EG civc?
- Anyone got time slip for Civic Vx with b16a2
- after what year can you not take out your airbags?
- intake question
- how do i get off trial status?
- Cancer Rust
- Do I have to drain the transmission before I install a new clutch and flywheel ?
- Wired VAFC problems with VTEC
- D16Y7 mini me???
- how a catalytic converter works
- how to mod the EP3 seats to fit in a civic?
- *** SUNROOF PLUG ***
- JUNCTION CONN C415
- Unusual 95 Honda Civic DX Oil Consumption
- best place to buy OEM exhaust for a 2000 si
- How do I remove the rear defroster button?? 96-98
- stupid question
- b16 Sir-2
- No Spark From Distributor.....
- ARe there any D-series OEM LSD tranny's?
- 97 DX Help with Misfire and
- b20 vtec help!
- Ebay Spoon Mirror wiring HELP!!!
- controller units?
- will a 2 door eg headliner fit a 4 door both w/ sunroof
- newb ?
- gas pedal prob...
- Need Help! Possible Blown motor. Need Input
- Re looming my car for b18 swap HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
- Bushings
- will four door TEG REAR DISC fit EG rears? are they the same as two door integras?
- idling problem
- My bonnet doesn't open!!
- Ray lug nuts on Motegi mr7 and rota slipstreams. HELP
- QUICK HELP PLEASE, STUCK!!!!!!
- D-Jac intake
- map sensor wiring
- Graraggddd..... more delete plates! What goes here?
- PLEASE!!! Help Me!!! Check Engine Light While Launching
- d16z6/d15b7 parts interchangeable?
- intake inlet diameter
- Anyone know anything bout JDMcarboy.com?
- How much is too much? Total cash investment to restore a Del Sol.
- synchro's from a d16z6 tranny fit the 90-91 si transmission?
- does the obd1 d16z6 have a knock sensor?
- Odd clicking noise while in moton. Don't think it's wheel bearing.
- Need a quick answer, about D series tranny
- sleeving?
- The Loathing I have for Honda of America
- Have a few questions, need a few links PLEASE THANKS.
- ST sway bar.....
- Megasquirt?
- JDM motor?
- integra type R muffler... welders... anybody.
- is this an oem product or replica?
- s2k seats in wpb and the cops???
- Help please...need some advice!!!
- shop to swap in torrance?!
- how can i make my lil d16y8 go?
- taillight fuse keeps blowing
- noise from clutch pedal
