View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Vibrant Mufflers
- need advice
- 98 civic instrument trim removal
- Which is engines are better 2 swap 4 a 93 civic
- pulling a b-series from a EG hatch
- Help with my 97ex
- Buddy Club P1 Wheel 16x7
- HOW MANY MILES ON A NEW MOTOR BE4 I SPRAY?
- has neone baRR'ed a 96-98 jdm itr ina 92-95 eg hatch ?
- speedometer problems
- 99 Si seats on a 94 civic
- 92 Hatch dies at 1/2 tank
- OBD-1 knock sensor
- Looking for San Diego North County JDM Shops
- Trade 2000 Yamaha R6 for 96-00 Civic Hatchback
- pcv valve for 1999 civic.
- D16Y7 Fram Fuel Filter (G7599) fitment issue!
- What collector pipe will fit a stock h22 exhaust manifold
- Big brake setup, Wilwoods and rimsize question
- HELP!! My brakelight doesnt work
- need help wit jdm five lug!!! 36mm
- Steering column question
- Anyone Ever transport an b18 in the back of their EG?
- Apexi N1 Exhaust system
- Suspension for my EG
- Weird clicking sound and hazards flashing?
- D16Y8 manifold differences
- Fried clutch line??
- del sol header and a/c
- NJ: JDM ENGINE DEPOT GOOD OR BAD?
- Don't buy those cheap ebay hub adapters for your steering wheel.
- del sol jdm fog lights
- FS: 2000 Honda Civic Si
- Sidemarkers
- Car starting problems
- EG Fog light fitment
- del sol omni coilovers
- HOW TO REMOVE SPINDLE
- brake rotor question
- sideskirt?
- OBD2 motor into OBD1 car
- obd-1 ecu code 1 will not go away
- suprise suprise.. Happy Marry christmas!?!
- Buying new car
- The D16Y5 / D16B5 Civic CX Project PART 2
- #74 lights, tried posting in appearance
- 2000 civic suspension
- 3 engines 2 d16z6 1 d16y7
- vtec or not?
- TD-46U 5511 dizzy (is it OBD1 for a b16a2???)
- touble P0141
- EK ITR HELP
- Brake/wheel noise? Wear indicator?
- going from an ek hatch to an eg hatch??
- EG6 Project
- damn vehicle speed sensor
- differing rear number plate styles on UK del sols
- How much is this worth?
- cold idle problem, tried EVERYTHING, please HELP!!!!
- Is this a somthing bad?
- will 4dr headlight fit on a 2dr couple or hatch ?
- what is the best train for a b20 vtech?
- 92 Integra Radiator vs 96 Integra
- 96-98 to a 99-00 front end conversion.....
- check engine light prob
- Car shuts off while driving.
- Rarest Color for Si HB??
- d15b8 mini-me
- engine light issue
- more Hp
- IS300/S2000 HID's into EG?!
- b20z, b16 head or my 14b turbo kit ?
- exhaust sizes
- JDM GSR OBD2 in 96 hatch.
- Honda civic 97 LX Exhaust mid-pipe leaking
- My Swap Won't Start!
- SPAL Fans
- CEL codes 1, 9, and 22 -----> Possible effects?
- All D16 piston rings created equal?
- Engine lights coming on???? HELP
- Throttle Body Torque Specs
- Guys with after market steering wheels?????
- s2000 Twin Loop Mufler
- what motor
- WHAT DOES FITV STAND FOR
- Pic request...92-95 hatch on rota c8's
- Overheating Issues
- what turbo setup
- Base Map for eg coupe
- How to bleed brake fluid on '99 Civic EX Sedan with ABS?
- Help!!!!
- pillar bar for my coupe!!
- WTB Si Climate Control Cluster
- what is the best radar detector?
- What cluster is this?
- brake caliper upgrade
- Front Disk (help)
- looking for 92-95 caliper bolt??
- S2000 cockpit into civic 5th gen
- anyone have pics of a EG6 OEM Strut Tower Bar?
- good/bad headers
- Cold Air Intake help
- HID kit into EG hatch?!?
- 99-00 front end conversion fitment issue?
- SRE camber kits ??
- Ebay Aluminum Radiator
- Quick question
- Who have Service Manual for Japan EK3 Civic with right steering wheel?
- STOLEN 99 SI CIVIC SACRAMENTO !
- wiring problem? help please.
- How to reset ecu in '97 Civic Lx?
- question
- How much shock travel?
- stolen but HOW???
- would an O2 sensor fix the problem?
- 98 civic coupe trunk emblem
- ECU for a B16A2
- SRS
- new tranny swap issues
- GSR dash and center console into an EG??
- question about tranny housing bseries
- swapping rear discs over???
- the orange/yellow light bulbs?
- need help wiring my IAT code 10 itr swap
- Noob shift question
- diy dash?
- is this 97 EK worth the money?
- Type r head questions?
- Mini-ME! in progress
- D16 parting out
- my Civic is GONE stupid female drivers
- Best brakes for ek
- EG Sidemarkers
- Headlight chime
- -- Wierd 3rd Gear Grindage! Need some advice :thumbsup: --
- hey tach ?
- I belive its carbon build up, not sure though.
- D.I.Y autolock
- please help, im soooo confused
- jdm gsr obd2?
- lower tie bar, and strut bars
- Muffler question
- d series tranny
- My dash is effed in my 98 honda civic EX
- put turbo on gsr motor
- b16a2 idle/limp mode problem??
- My research has led me to this as a future setup:
- help with tranny noise!!!!
- radio swap
- k20 eg question
- My idle is perfect but when i hold the revs at 1500rpms car starts to....
- will my 99-00 Si front lip fit a Ek4?
- Motor Mount Issues/Questions
- swap advice
- EK rotors fit w/ stock EG calipers?
- tire moves but steering wheel doesn't WTF??? tie rods maybe ??
- Flywheel
- Interior Lens
- Need help quick?
- Car will not stay warm
- D16 buildup Questions. Problems with Mains bearings.
- Need help with caps
- Need help with wiring harness.
- How do I hook up my shift light ?
- H22 into EG hatch questions...
- Car wont go into gear when started and moves without gas
- Passport 8500 does anyone think its a okay radar detector?
- CX and DX straight pipe??
- D16Z6... need suggestions for build up please...
- Hows your GAS MILEAGE???
- the easy way to install a auto meter?
- jdm bumper pole need help wiring up
- piston question
- Timing belt broke
- my civic hatch b16a2turbo
- please help: used gunk engine cleaner and now car stutters
- geting my first eg
- b16 tranny with LS 5th gear with b18b engine
- Rear bracket
- 92 Civic having trouble idling
- Cost of lowering
- hit thwater kills engines
- EG6 Exhaust
- EG suspension repair shops help?!?
- which second gear should i use?
- EG suspension problem help?!?
- Help!!!!
- custom driveshaft...
- 97dx hatch rear disc conversion
- Tires down to the wires
- 96 EK h22 info?
- H22a 92 HB Dx?
- tried cleaning my iacv but its still does that thing
- Del Sol : moding the drivers air vent to mount a 2 1/16 gauge
- Help me out, unusual noise from engine maybe?
- ruberized undercoating question
- Cheapest place for FAL radiator fans online?
- gsr cams vs. skunk2 turbo cams
- WTF HeadGasket?
- fuel filter????
- Del Sol VTEC catback..
- d16z6 vs d16y8 to turbo
- header fitment question
- lsvtec
- What RPM should VTEC be adjusted to hit at optimal result
- B16 swap info (already searched)
- HELP! Sound when i turn
- Manual to auto tranny conversion on a 97 civic
- Interesting: EDM 4WD 1993 civic 4 door ( 4x4 drive )
- Looking For Someone Selling a Swap for around 800 bucks
- Nitrous Express Kit For Sale!!!
- Cuts Out at 3500
- Awesome!!!
- turbo'n d15b7
- Will rear disk swap stamped DB with abs fit on 98-98 civic?
- j's racing cf intake vs. password jdm cf intake
- my shit is fucked up
- ticking noise
- n/a runs like turbo lol......
- b18 into ek and draggin ass
- JDM YELLOW BLINKER LIGHTS
- where's the car shops in vegas
- Axle Boot Seal / Ring Tool ????? Anyone ?????
- power increase by switching from odb2 to odb1
- no one ever responds to this question....
- D15B Replacement Parts(Sorry if I didn't find this in my searching)
- Diffrence between obd0 and obd1 fuel injectors
- swap sucks lmfao
- Turn Signals,Rpm,SpeedO,Temp,Gas, gauge dont work!
- 94 Del Sol NOx to high
- Spark plug wires
- Few ?'s about my 92 hatch and the B16.
- 96-00 Civic HB Interior Color
- o2 senors
- How to find out the year of JDM motor?
- HOW DO I DO A VACUUM LEAK TEST
- HOW TO REMOVE BACK TAIL LIGHT
- BAD GAS MILAGE, HELP
- engine light and possible vtec kickoff..
- You guys are gonna hate me
- Mileage Questions
- I finished my integra dash swap!
- Tach Inop after swap!!!
- what size tools do i need to change spark plugs?
- RC 270 injector trouble!!!
- 99 EK SI -> Loud Squeeking Noise When Starting up the Car. Help!?
- EK HATCH SHELL FOR SALE
- pink slip/car title
- B16B TYPE-R into a 1998 Civic LX
- Looking for a steel braided fuel line.
