View Full Version : Honda Civic / Del Sol (1992 - 2000)
- A/c Help needed
- Buy a car with a swap or buy a car then do your own swap?
- S2000 exhaust on EK Hatch?
- rasing rev limter
- o2 sensor wiring help
- Help :: Starting a newly installed Engine.
- Shops In Norcal For A Motor Swap?
- 95 civic ex+h22...need ac
- civic ex cat conversion
- Gas tank..
- Idling too long bad?
- hey guys airbagggs
- Starter Wiring, Need Help
- chip recommendations? b16a2
- Bumper guards
- opinios on BARing ur car @ Fullerton JC, BAR ref.. smog
- What do u guys think about ref's at Fullerton JC for smog BAR
- thinking about putting ITR shocks and springs
- Need help with JDM tailights?
- Where can i order a SI Axle back muffer?
- volts gauge?
- 1992 honca civic cx what do u think?
- B18a axles and linkage
- European Honda Parts
- constant vtec
- Passanger side airbag. on eg
- cam picture
- D16Y8 into D16Z6
- D15B VTEC fuel pump question
- Front Clip question on a civic/prelude
- Some problems with my car.
- Just GOT a B18c1
- Intro Post
- ek 4-door vs ctr carpet
- CTR in a eg coupe?
- Driveshaft/axle help...
- another interior light?
- --> DIY - Door panel fabric upholstery! 17 pics! GRAPHIC HOW-TO!11!!!one
- ok im ready !!!
- JDM d15b. Support SOHC
- Rounded thermostat housing bolt
- JDM headlights and HIDs
- Post me comments if you care too
- b20 needs shoe horn
- ? about Mugen Twinloop
- Breather for pcv
- just got back from the track ......
- Point of LS/Vtec?
- 94si hatch for sale Ls/vtec swap
- Changing "carbon filters" every 15k on a 2003 EX civic?
- motor ?
- another civic dies to theft...
- knock sensor..help me please
- ls/vtec.....which ecu?
- AEM V2 Intake?
- Painting the black exterior trim on a civic, (mine's a 1994 civic dx)
- ek dash in an eg
- Out of curiousity!!!
- Installing Type R Lip HELP!!
- Civic Coupe Project
- 96 ek front anti-sway bar
- Went to the track for the 1st time today. Quite disappointed at myself
- b18c1 eg hatch not too empressed
- got the cash need to make up my mind
- Suspension Help Tein Coilovers.
- HELP!!!!!...............WHat bulb is this?
- 93-95 del Sol optional jdm fog lights english instruction manual scanned (not aux lights)
- civic and short shift kits
- Hatch Open Indicator light
- Replaced timing belt and now odd idle.
- engine help
- Help on D16y7...
- 4dr question and d15b7 ecu question
- New guy...with CF hood for sale
- Question about putting sleeve coilovers onto aftermarket struts.
- is a 4door front end the same as a 2dr or hatch for 99? need answer ASAP
- Distributor Question
- need info about b16 please help techs!
- check engine light question?
- bov
- changing oil pan gasket...where do i put hondabond?
- P75 chipping questions
- broke head bolt. need help.
- del sol camber kit fit on 92-95 eg?
- sir ek4 bumpers
- Random-ass vtec question.
- Rotors
- HID help me identify these wires
- BOLT ON NOISE
- ek hatch
- What kind of mirrors are these? Civic EX
- Do shocks lower the ride height?
- wtb cold air intake in/around 626
- someone please let me barrow your jdm itr header!!!socal!!
- Salvage Title/Clean Title?
- code 41 heater wire How to remove?
- faze gauge not reading right..lighting problem
- difference of ctr grill and si grill
- FS: Buddy Club bodykit
- PLEASE ID this part for mE!!!
- swapping to a snap off s.wheel wat do i do about airbag oem ??
- signal problem
- 5-lug convo help......
- type R crank shaft pulley on a EG??
- fuel pressure ???
- need advice on type of b16 1gen,2gen
- my rear lights don't werk = /
- cluster illumination not working.
- swapping dizzy caps
- Controlling VTEC through a VAFC with DX ECU
- question about jg edelbrock manifold and throttle body location.
- FUEL DAMPENER ON THE EG??
- Brake Help....
- EG vs EK hatch exhaust question???
- Which of these setups would give the best possible gas mileage?
- how to reset CEL
- how much to change license plates?
- B16A swap
- Diff. btw d16y7 and d15b??
- hood pin location on 95 civic hatch
- Installed Zeitronix, now car won't start
- suggestions please: All Aluminum Exhausts for a 1998 Civic DX HB
- quick LS/Vtec question can u use the B18b headbolts... or what?
- 2006 civic Si concept
- NEED HELP WITH JDM CIVIC CLIMATE CONTROL.
- 93 ex with b18c5
- computer for a swap
- Reupholstering Del Sol seats
- .NEWW MOTOR.
- JDM d15b motor
- Power steering is kaput!
- oil leak!! need help!!
- new si
- NEED HELP/TIPS FOR EK9 JDM CLIMATE CONTROL.
- Does anyone know if a integra RS Master Cylinder would mount up to a stock Civic DX Brake Booster?
- Which LCA
- can anyone confirm?
- Inverted backwards readout from TPS sensor volt reading
- Question about 5Zigen Fireball???
- JDM Integra headlights on 1992 EG Honda Civic (hatchback)
- wich radiator cap for koyo radiator?
- paper filter or foam filter?
- B18C in a stock 93 hatch?
- ls dyno chart???
- slight ticking/ tapping sound.. the problem?
- Removed carpet, and i now see theres a spot for a foot rest, Would GSR One fit the holes?
- Axle Back From An EK Couple On To An EK Hatch, Possible?
- tranny question
- Best place to buy rota gt3's and front lip
- how long did it take to get swap?
- crank shaft pully bolt aaaaa!
- Which Rims for my 1995 4dr. Civic?
- automatic ls/vtec or b20/vtec into eg
- red/sliver tail lights where to order?
- am i right?
- Bezel Pod in EK w/Integra cluster?
- Least expensive place to get JDM d15 (east coast) , im in michigan
- lolz...kind of a noob question
- Exhaust repair question.
- Compression calculator
- Shock/spring install question
- Air/Fuel help! if true my motor is dead..
- b20 vtec???
- What to do with my D15
- Clutch discs and plates interchangeable?
- 96-98 ex engine harness needed HELP!, 00 b16a2 swap question, 97 cx hatch....
- obd1 alternators
- Jumped improper connector, now no dome, or back up lights.
- 93 civis Si cooling system problems
- cars jumpy at steady speed?
- Wheres the best place for smog ref in SO CAL?????
- Spare engine anyone?
- if your buying motor look hmotors and jhp
- which engine would be best?
- Another Stolen SI
- engine block repair
- Dealer price cheaper than online? why?
- Locals Wanted
- JDM Cluster for USDM
- Installed H&R sports - bleh
- Is 178whp standard on a dynopak equal to about 200whp SAE corrected on a dyno jet?
- Help! My gauges won't light up!
- Motor swap
- Will my Vtec Engage?
- Our latest project...
- Is the new "skinny" oil filter ok to use?
- Front Fork question
- D16y7 cam question
- My exhaust is TOO F'N LOUD! Should i get a resonator, or a new muffler???
- airbag eliminator tray
- Turbo on JDM d15b?
- ps pump doesn't fit my b18b swap
- Sorry guys i didnt do the write up. S2000 cluster coming soon.
- need work done???
- RSX EP3 rear disc brake upgrade
- Wiring up 4 wire O2 sensor...can it be easier!?
- 99ex- about to do a d15 mini-me ANY INFO
- GSR shifter in 97 HX???
- Question about feeling of Clutch pedal of 93 Honda Civic EX
- !!!!!!!!!!!WTB: A CLUSTER FOR MY 92 HATCH!!!!!!!!!!!!!!!!!!!!
- WHY WOULD THE COOLANT LOWER COOLANT HOSE BE COLD WHEN THE TOP IS HOT EVEN IF I CHANGE...?
- ****AWAITING THE B16A2 SWAP INTO MY HATCH****
- Brake rotor question.
- what the hey..
- rebuilding a 99 si what is the best exhaust i could buy?
- Hondata: need maped
- NO SPARK tried everything i read on posts. help
- Fuel leaking after engine is turned off
- EK amber gauge cluster + climate control question
- people with d16y8's into EG's
- which exhaust to buy???
- Please help! Climate Control lights not working
- Good Paint Shop in Brooklyn?
- VTEC pressure valve sensor
- Removing tail lights- Help!
- undecided k20 or h22
- can someone help me out?
- CTR pistons in a B18C5
- EG b16 tranny leaking fluid...help?
- ground control coilovers....are these for EK?
- Wiring Diagram for Swap in 96' EK
- Auto to manual wiring help
- EGR Valve on B16A?
- Steering Rack
- a/c problems with b18c1 swap in 99 ex
- Seriously... does it ever f**king stop??
- Back Too Basics on Swap ????
- d15b7 question
- Door Problem
- unclear on a d15b
- 6speed
- anyone know where to buy engine stripped 96-00 civics??
- wtf is this sound?
- Small Claims Help???
- 96 Civic HX engine swap questions
- hooking up apexi vafc vtec controller
- fan not coming on on my ek, where is the sensor?
- D-series Compression Calculator...
- 93 civic keyless entry trouble
- EX at
- Car feels wobbly/unstable/bouncy even driving on flat road.
- TPS Sensor
- Timing Belt question
- V-AFCII SI Q:
- whats a good selling price for d15z1 vtec-e
- Brake upgrade.. from 93 civic hatch cx.. to 96 GSr...
- Good set of cams for b16a1
- Is it possible to install s2k antenna on ek?
- Any one have pics of the Ultra Rare Spoon EG Cluster?
- Skunk2 throttle body, intake man.
