View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Can't post
- H&R sport/race and Tein S-Tech springs...
- Whats wrong with my car?
- What do you run with your b18b hatch?
- Stock Cat on 00 SI
- Sometimes, god hates you: LS motor + blue smoke
- Cam question
- catch can Q's Im confused!!
- Starting issue - please read
- Del Sol won't rev past 2500????
- What Engines came in what years of the Honda Oddyssey?
- car wont heat up!
- 96-98 CTR Lip Mounting Hardware
- LSD.........
- 90 integra donor into 92 dx
- stock or low comp. pistons. help?
- Rear Disc Conversion gone bad - need help really badly
- can u make 92-95 civic Tokico Illumina Adjustable Gas Shocks fit a 97 ek?
- What mounts to use?
- H22 Swap but which tranny?
- ITr rear sway
- installing JDM EG rear interrior
- dash swap, problems with defroster switch.
- will a 96-98 2dr/4dr rear lip fit a 96-98 hatch rear bumper
- z6 and y8....all parts interchangeable???
- how to install my new window regulator?? into my EG?
- B20 Vtec with JE pistons
- Who knows from experience which Apex Exhaust performs better w/ a B16 engine
- stuttering b18b.....
- Which upgrade do you prefer before the other? Intake Manifold or Pulleys?
- Will a b16 internal coil work....
- If I swap my D16Y7 head will I lose my IMMOBILIZER system
- how to black-house a 97 civic hatchback?
- D16Y8 cam VS. D16Z6
- d16 axel
- 03 SI or Type R 5 Lug wheels?
- si rims or 17's
- Hood Help !!
- d15 header
- Tranny Question
- Need Wiring Help For Si Radio Dimmer In An EG
- integra dash in a 93 4 door dx (it is possible)
- My EBP - five years later
- walbro 255 fuel pump prob
- just installed new kyb's with ground controls...HELP!!
- (Searched) D16Y7 stock camshaft specs
- Noob question..
- brake upgrade ???
- elDel Sol S convert to VTEC??
- !!!WHO HAS THE BEST VIS C/F HOOD PRICES IN LA!!!
- EK CTR tach into eg6 cluster(searched)?
- sedan interior question
- O2 Sensor Issues.
- LS Motors or long blocks
- What size tires do you guys have on Si wheels?
- Is this an exaust leak?
- 1989 honda civic fusebox
- TOKICO ILLUMINAS ADJUSTING KNOBS???
- Cheap dent removeable?
- my new toy
- ok I want to boost, where do I start
- NEED HELP FAST ELECTRIC PROBLEM
- Exhaust leak at header flange! Should I worry about it??
- Color of this hatchback?
- VIN Check help please :)
- 2000 Stock b16 cam adjust
- Trunk Width - anyone know it
- Just got my ES muffler from inlinefour!!!
- I got rear-ended yesterday, car is a total loss. PICS
- 99 Civic Carbon Fiber hood
- OEM radio Compatibility
- '92~'95 front rear weight distribution? (searched)
- any pics of integra rear swaybar into an eg
- cheap camber kit
- Height of 92-95 Civic radiator?
- Need a carfax asap please
- installing hood pins?
- skunk2 SPRINGS? anyone using them?
- THIS SITE FUCKING SUCKS
- 99 civic si tail-lamps
- Attn: Brian Wong
- correct offset and rim fitment for 96-98 civic?
- carpet swap....any thoughts?
- need help getting my tranny apart
- jdm d15b problem?
- jdm d15b ecu
- Tips to get shock fork lined up with lower control arm?
- ABS (anti locking brakes) PROBLEM!!!!!!
- D16 Exhuast manifolds all the same??
- Difference between EG coupe and EG hatchback Exhaust
- Is THIS the Helms manual everybody talks about?
- head Gasket whats good for d16
- Need to know: ARC Intake for Type R fit in GSR swapped hatch?
- what steering wheels fit eg
- gsr rear sway bar
- HELP FIND A GOOD PERFORMANCE SHOP IN COLORADO?
- Tranny Help!
- FALKEN ZIEX ZE-512 B or NITTO NT 450 EXTREME
- Need Distributor help before i put a clamp through my windshield :(
- Which comptech icebox will fit in EG with B16a2 motor?
- is there potential in the D16Z6 engine????
- Tail lights painting!!!
- Flushing the engine when exchanging coolant?
- Signal Auto Quick Release
- How do I become a member? and not just a guest.
- del sol question
- Greddy EVO exhaust?
- injector queshtion
- ek eg ef, im not sure what years and models all these codes are
- speedo probs
- Helms vs Haynes
- Help me Identify this Exhaust! Pics inside!
- Clutch Dilema
- egsick I want your turbo block please email me!
- EK6 difference?
- D16 tuning.
- axle question
- 96-00 color question
- idling speed on eg
- skirts n lips( no its not a girlll) lol
- CTR shifter vs. Stock SI or Teg shifter....
- d15b7 Head swap! need Help
- Honda still idles rough and loss of some power noticed.
- EX hatch
- please, need advice on swappin...... quick
- SOHC VTEC IGNITION UPGRADES
- factory Si wheeeels?????????
- Car stalled and now will not turn over???
- Driveable HP limit???
- RSX Steering Wheel on EK9?
- which intake are people using? stock air box w/ spoon filter?
- what do i clean headers with?
- Automatic B16 Cam duration/lift numbers ?
- how to adjust idle screw
- JDM B18c with JDM b16 tranny
- Just a question.
- PWR Radiator users
- New user!
- Long drain intervals and Oil Filter Question
- Falken Azenis ?
- Problem
- engine swap help
- auto to manual (eg)
- Cheapest Rotas?
- oem rear lip on EG?
- SunRoof in Ek Hatch
- VAFC RPM Monitor Question
- Auto to Manual Shift question.... post up ur comments
- Went to the dyno today
- Having a hard time putting into reverse!
- Rustproof ek's???
- starter and fuel pump wont turn on anymore....why!?
- Adding AC to a DX
- A Challenge for you all detailed info on the B16A2 engine
- Turbo-ing a high mileage car??
- will the transmission from a 96? accord F22B1 adapt to 93 SI 3dr stock engine
- Skunk2 Rear Lower Arm Bar on Civic 99/00
- I got a?
- Top Dead Center Sensor (Replacement)
- New to site
- OB2 distributor wires the same colors as OBD-1 ?
- obd1 jdm b16a in a EK.....
- Whats you choice of motor
- 99-00 B16 engine harness?
- 92 Civic DX auto -> engine is dead, what should I do?
- OT: I need a pic of an ACT HD PP clutch side..
- OT: My own oops coulda fuct me!
- h22 in a 96 civic
- HONDA-TECH'S BIGGEST IDIOT = ME, COUPE94EX. COME OWN ME!
- js racing carbon fiber duct
- Gains with itr airbox in a Del Sol Vtec?
- Front End Swaps?
- Best Engine Builder For Your Money?
- 1997 Civic EX Coupe Door Lock Removal..
- Some dash vids of my Si W/ Skunk2 cams!
- angle mount exhaust question
- itr stb in an ek?
- What would the be the best SLEEPeR set-up
- Shck Absorbers swap
- Hood Lever broken
- Clutch problems
- d-series axle?
- mini me swap
- BAR Legalization
- Rear suspension swap.
- h-t i need ur help??
- '00 Si B16A2 with GM Syncromesh FRICTION MODIFIED?
- Car is making "put put" noise... Fuel pump dead ??
- Please help car won't start!!
- 96-00 2DR DX Proportioning VS 4DR
- what engine is in your 92-00 civic
- what should it feel like
- fan hooked up to the ignition?
- d15z1... Boosting it maybe..
- Miata Wheels on a Civic
- what do you call this piece?
- Already Searched - brake line problem
- Is this information about ground controls correct?
- resurface flywheel?
- d16y8
- mounting tires? worth it?
- n00b: Intro and Cars and sh!t
- What exhaust should i get??
- Jimfab torque mounts
- upgrading my fuel pump on my 93 cx, would i need to change my fuel rail & injectors?
- stock connecting rod bolt---how do you remove it?
- 93 integra rear disc brakes on eg
- type r swap
- Clutch Problems
- shaved moldings?
- HELP: Throwing check motor light
- Need 92 civic hatch bumpers will trade body kit /Im NJ Based
- Need your help please!
- Tranny Codes...
- What prop valve came in the '97 Del Sol Si? Plus a few more questions...
- D17 out K20A in?
- O2 sensor
- price range for B18C5
- what coilovers are you running?
- Hatchback floor mats ---> coupe???
- D15B7 turbo?
- 1990 civic motor swap
- stock looking muffler for EJ1
- Yeah yeah, i know...a rear sway question for EK hatch...
- surging idle eg's, possible fixes.....bet you never heard these!!!!!
- where can u get HID bulbs..
- D Series motors at Hmotorsonline...
- coilover question
- What muffler is this?
- Couple of questions b16 related help (i will paypal $$3)
- Tire wear question
- smell gas inside the car.. what could it be and how can i fix it?
- quick question (2)
- why is this thing not starting
- Stock exhaust heat shield OR Thermal wrap stuff
- gsr fuel pump
- h center caps for sawblades
- obd0 b16 obd1 b16
- gab centercaps?
- Questions about DC2 dash into EG
- installing new dash
- '93 Civic CX HB O2 sensor - to emulate or not??? Or other suggestions...
- performance for my 2004 civic?
- Gsr Cluster Plugs in cluster into EG?
- will any B-series IM's fit on a D16y8
- my 1999 honda civic si.........?
- zc question
- ACT UK Suppliers / Good Garages ?
- Civic owner needs advice
- Will any VSS work from a 92-95 civic on my 1994 civic si?
