View Full Version : Honda Civic / Del Sol (1992 - 2000)
- quick and easy oil level question
- Bad Idling after few parts changed: Oil pump, crank pulley, and camshafts
- Honda Civic Corner Blub Light Wire... Disattached.. help ( pix included )
- 90 LS rear discs on 93 civic cx...Has anyone done it?? (Searched)
- Do i need a gsr PPV to complete my brake swap on my eg?
- JDM Fog lights 99-00 EK
- HELP!!! TRANNY PROBLEMS!!
- JDM D15B non v-tec ??
- Good RPM for V-tec
- need help badly
- NTB SILVER BUMPER
- How can you tell if your condenser is not working properly?
- Which part # for window trim
- New Stuff on Da Whip! 56k=no
- Northern VA, Does anyone know where I can find HID bulbs?
- Ek hatch + b18 all motor video
- How can you tell if you need a new AC condenser?
- Boring d16?
- ZC + Z6 Head???
- removing b series tranny *help*
- brake problem electrical
- help with signal lights
- SRS light keeps on turning on. Please help
- iS there a difference with and obd1 to obd2 alternator for b seri.
- Is this good
- Shipping....
- srs light
- Import Builders, and some other ?'s
- ebay engine mounts
- injetors ticking
- thread pitch on hard brakelines on an ek?
- Civic drive click
- rattle at 1500 rpms
- Anybody in California with a EG.......
- APEXi Super VAFC II setings
- Problems With LS/VTEC Swap...
- CF hoods
- Any special tools to remove front discs on a 1998 Civic?
- Smoke under hard acceleration
- oem ctr header
- Stuck moonroof?
- Most whp engine swap
- RS MACHINES?
- Help.. tanny code..
- Cheapest big brake kit for EG coupe?
- Blitz front (del sol) brand new blue class fib. in Minnesota? For sale to pick ups!! $150
- 5-Lug Conversion Question...
- brakes making sound...
- JDM ITR LSD
- ignition pinout?
- Quick Questions...Adjustable Shocks...
- rattel at 2500 rpm
- Black Smoke (Searched more info needed)
- HELP!!! Need wiring diagram for UKDM Del Sol VTi
- off topic but help plz
- Best lowering Springs for 96 civic?
- H22 Keeps Dying :( :(
- Teaching how to drive Manual
- catch can question
- Will my non airbag steering wheel fit on my girlfriends 92 SI hatch?
- Timming Belt Loose?
- Clutch Question for a 1999 Honda Civic SI
- Problem checking my CEL, check engine light, frustrated....
- Green Wire Tach Help ON EG-6!!!
- eg/ek video
- anyone keep their AC using the ITR AC bracket, ITR compressor, and del sol hoses?
- Helpppppppppp!!!!!!!!!!!!!!!! how to Come out of "Safe" Mode - Honda Navigation System????
- Rear hatch gate: How to remove?
- v-tec solenoid???
- Windshield Wiper Switch broken...Need help....
- Dies at idle when I turn the wheel??? HELP!!
- The Parts Channel, body parts etc.
- Short Shifter Help
- does the helms manual show you how to remove or install radiator support?
- Now the brakes don't work!
- shift linkage
- Trailing arm question
- Pulley and kits
- steel braided hosing?
- A/C recharge needed?... my A/C is weak.
- AC not cold during Idle.
- Turbo Civic Outside Philly(For Sale?)
- Cam Gears
- b16 problem
- GSR rear seats in an EG hatch????
- 1.5 Vtec-e running rich
- I94 civic ex w/b18a1 swap CEL 12 EGR why?
- Looking for place/site to buy parts for civic 99 coupe
- Is engine salvageable
- Help Please Vtec Pressure Switch
- just installed clutch loose pedal feel i have bled many times
- oem itr axleback fitment on a 99 si?
- exhaust header crack
- What size 15" tires should I get?
- control/trailing arms
- some help please.
- new invidia g200 exhaust
- 92-95 OEM Headlights - HIDs - How well are mine aimed?
- Weld or Screwed ???
- Good paint for my eg hatch
- Pic request, inside a stock/virgin p06 if you please
- Mr Top Fuel Hoses ?
- eg6 climate control?
- Arospeed tear drop muffler
- question about short shifter
- 3000GT VR-4 fuel pump install in my civic?
- ep grill onto ek?
- Clicking Noise in 1st
- New Del sol
- motor mount?????
- Bad shocks damaged my tires
- how do your del sol seats feel like.......
- 93 Civic LX
- Newbie here. Need help on suspension.
- GSR rear seats in EG coupe
- How do i seal my taillights
- Korbach Performance Frame Locks for 6th gen Civics - product review
- Fast Idle Valve Question
- mini me swap for d16y7 at engine?
- swap4my ek
- STD bore vs. oversize bore?
- Sheet metal
- Del Sol water temp gauge
- Question about D16 and B16 motor
- help...cant find it in search
- Integra Dash in Civic
- scared
- RPM drops to 200. Could be timing?
- Brake problem
- Spoon Midpipe
- hello, newbie here
- 2000 Civic EX Fuse Panel Layout/Diagram
- Are you happy with your H&R race spring's drop?
- How many quarts of ATF for a 99 EX?
- Anyone ever get an engine from JDM Engine Depot in Hoboken,NJ?
- Motor swope out
- AC related to idle?
- unreliable starting
- Gas/Temp guage is not working on cluster
- total loss of electricity?
- HELP-HOW TO INSTALL PIVOT DIGITAL TACH(NOT SHIFT UP INDICATOR)
- questions about 95 integra se front end on 94 civic coupe dx???
- axxis pads smoking
- im so sad wreak story
- Just sent Earl my motor
- GSR intake mani...
- EK door panel question
- Rant: my civic and possible setups
- Cutting stock shifter?
- Cures for Rough Idles ... Ideas?
- steering column removal for windshield wiper controll arm
- am i just unlucky or what?
- JDM SH!T CTR headlights VS DIY
- cleaning iacv?
- manual to auto swap??
- O2 $Sensors ?
- people with a stock VX motor
- Interior work. 1994 Honda Civic CX
- I can't post in any other board so don't get mad. How do I find my tire size?
- b16a1 in 92-95 civic how hard
- adjusting fuel pressure with stock FPR
- SOHC ZC oil pan??? D16y8 maifold??
- 2 QUESTION!!
- doing a b18c5 type r swap into 2000dx.... i have a ? bout cat
- Problems
- engine swap question
- where to buy EG dash gauge pod???????????
- Pod for Glovebox
- salvation story
- How much oil does a '02 Civic take?
- Bleeding clutch procedure...again
- i need advice
- VTECH questions
- Caliper sticking
- AC Dryer?? What does it do?
- ----NEED HELP WITH HOSE PROBLEM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!1
- Need some help on mods for 96 del sol
- Adjusting Clutch on 93 CIVIC HB DX
- need tires for EK & want toyo's - only size is 215/40/16. will I rub?
- Does unbolting the front rad. support mess with frame alignment?
- Speed limit removal on JDM B16a?
- 02 Si seats in my del sol
- i'm gonna buy an engine :-)
- How hard is it to change the rear crossmember on 00 si??
- Nitto 555s, comments?
- can i use an oil pressure sensor from a y8 on a z6?
- Trunk Window
- oil pan leak....quik question to ask...
- stock p28 vtec engage point?
- d16y8 manifold on Mini-Me: y8 head, b7 block, p28 ECU
- Best Way to Sup a B16a transmission
- ## B18C1 Difference Between OBD-1 / OBD-2 ##
- looking for a d16z6 complete head
- Catalytic Converter Size Predicament
- went to the track for the first time today
- Catback compatibility
- JDMSh!t obd2b-obd1 jumper harness question
- Want to get a CAI but..
- 99-00 si a/c lines hook up to sohc compressor off 92 civic?
- 97 gsr wiring harness for 96 hatch back
- Looking for a reputable shopw for buying a JDM motor
- Mini Me question: z6 head on a obd2 bottom end? (d16y7)
- Civic type R cams or Type R
- dO2 sensor
- Auto tranny question
- Vtec wont kick in,
- Parking brake light suddenly came on...WTF?
- Wieght reduction
- intake manifold cooler?
- reverse lights dont work :(
- motor question
- wuts wrong wit my b16
- tokico illumina? or Kyb Agx?
- Adrenaline Racing & Performance
- b20 turbo manifold???
- 92 Hatch suspension Q
- Tranny Problem
- cut spring the cheap way to lower ur ride
- Headlight fitment!
- Fields SFC-HYPER in a EK
- o2 sensor wiring question
- WHAT DO YOU GUYS THINK??
- VIDEO of EK HATCH With b18 + motor work
- VIDEO of e
- [FAQ] [DIY] How To De-Rice Your Honda (50 pics 56k Has A Wait)
- NEED STOCK 96 HARNESS FOR MANUAL HATCH ASAP!!!! got cash!!
- anyone have a h23 on a 95 civic?
- How to: JDM RHD conversion
- EG/DC-R suspension on EK HB
- help wit b16 engine check light
- JDM Fog lights
- Car feels a little slow now.
- tail light removal
- My gauge cluster is not working at all, K.O.. :( help please??
- How do you mount the shifter in a auto/5spd con
- RS*R exmag hangs low!
- 95 civic ex "Check Engine Light"
- Best and cheapst place kyb AGX shocks?
- ***DEI shock sensor Question in my EG Hatch
- Looking for all-motor upgrade ideas for 2k d16y8 w/ auto trans.
- what do i get axles for?
- HOW do i pu a CRX seat in my eg
- Engine sputtering?!?!?!?
- Help with ECU problem?
- Civic Drifting Video
- Is this a good deal for a CF lip???
- Emissions help
- Mass Air Flow Meter location
- Head Studs vs. Head bolts?
- 92 SI - Dash, Tail lights, and corners wont light up PLS HELP!!!!
