View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Excessive smoke. Del Sol SOHC Issues!
- Which engine is better? B-Series K-Series
- help me choose the right motor
- no start connector
- Round 2 with no spark
- Clutch slipping on 4k miles
- My 1995 EG Hatch Build
- Vacuum line Diagram
- Need help need this done the sun is killing me....
- 94 civic gsr swap tranny swap problem!!
- 2000 civic lx
- rough running civic NO CEL
- y8 with z6 dizzy?
- B18C1 wont start, cut off while idling
- manual window hard to crank?
- CEL 41, ox sensor heater , where does voltage come from...
- Need Help:B16a2 engine problem
- Real 99-00 civic si engine harness?
- HELP PLEASE high idle when AC and headlight are on
- AT to MT Driving style...Affected?
- 00 ek coupe... Needs some opinons on what to do to it....
- pull axles while lifting engine?
- RPM arent working
- fuse 32 keeps blowing in 2000 si
- si ecu on 97 spec type r swap
- Ek hatch vs ep3 hatch
- What rpm/speed are you running
- Flywheel bolts for b18
- 02-05 RSX Steering wheel on 96-00 Ek
- 1997 Honda Civic EX losing Radiator water
- Power door locks problem
- 97 honda civic with a 96 GSR harness question
- 1994 honda si del sol randomly dies now wont start
- how can i check my fuel line pressure in my eg
- 1994 civic steering column trim bezel
- need vtec diagram with pics of harness
- Difference between 1st gen ASR brace and their revised one?
- Battery gets REAL hot when both cables attached...
- Apexi WS2 Muffler-A word of advice
- Can i run a chipped p28 in a 2000 civic ex with a auto trans
- Upgrade Cam Questions...
- Where can I find a complete stock d16 motor LA area?
- map sensor CEL HELP
- No spark. Out of ideas
- 93 civic wont start after swap
- Zc motor rebuild/gasket
- Del Sol owners. Need some advice.
- eg bubble quarter glass
- 95 Civic CX - brights, wipers, and cluster lights dont work
- Individual head bolts
- quiet exhaust for my b20v?
- Bought 00 Civic EX - power mirror and clutch problems
- Z6/Y8 help and instruction is need asap!!
- Jdm B16a swap, wont hold steady idle...help.
- A shot in the dark.
- obd1 gsr swap in to Ek Question ??
- Replaced wheel bearing but still makes noise (vid inside)
- B16A2 Swap Question
- valve train noisy
- Can someone tell me what is supposed to go here?
- 21 VTEC spool solenoid valve [Easy Q]
- worth it? B18C5 engine...
- 93 dx d15b7 stock rev limiter???
- Help? 99 Civic Ex with an 99 HX harness.
- Si interior
- what oem rear sections fit a ek coupe?
- 93 EG shuts off when ishift into different gears
- Ek mudflaps help
- GSR swap exhaust question
- Will Civic fender liner fir Del Sol?
- Why do I have a p28 ecu? And a another question....
- Catalytic converter
- 2000 civic ex w/ b16 swap idle shakey
- em1 random hesitation under throttle
- Maintaining a JDM D15B. Quick Question
- NO CEL but code showing
- Car cuts out at >2000rpm
- Is it bad to use an exhaust silencer?
- Can drum brakes warp? general drum brake questions
- No BAR sticker with stock exhaust, cops??
- exhaust rattle
- AEM EMS FOR OBD1 HONDA/ACURA
- B16b into non vtec car questions???
- Anyone used the R12-R134a Honda conversion kit?
- Using Hatch to Transport a SWAP
- Del Sol shifting question
- CEL: code 91 help
- Need Help ASAP
- SI will not turn over: VERY SPECIFIC: HELP
- 94 Honda Civic - What Spark Plugs?
- motor rebuild or purchase dealer
- Clicking noise occassionally under load solved
- tranny mount q's
- Car dies at idle under load
- My car bogs, Need Help ASAP!
- B20vtec build planning help
- 93 Eg hatch cigarette lighter and antenna dont work!
- D16A9 Swap Axle question
- honda civic hx window
- brakes making hissing sound when braking
- 1996 Civic seat track
- 1994 Civic EX - b16a swap - CEL on - code 9
- Del Sol without A/c
- 97 Civic LX auto To manual ECU question
- Turbo LS? vs ZC sohc(v) turbo?
- A question for my Del Sol people
- New wheel bearings 93 Civic
- need help with specfic suspension part
- Stage 1 Cam with OEM Valves, Springs, and Retainers??
- ek problem plz daily driver helppp !!!!
- wires sparks blu/wht, and plugs spark orange..
- what do you think?
- 94 cx hatch CEL jump wire?? [location]
- evap canister plug location...?HELP!
- '99 EK6 overheating only on idle
- Alternator issues
- JDM ITR seats into EK Hatch.
- Cars not starting!!
- 1998 Manual Civic bucks/jerks in 3rd gear only at 2500rpm and 35mph
- 1994 Civic EX Swap Parts List
- valve cover breather
- Body work on '95 Civic
- 2000 Civic Si Breather Chamber Question???
- b18c-r runs like crap on chipped p28 but runs perfect on jdm p30
- Is a f22b2 tranny good for h22a4 engine
- What fogs to get?
- 92 Civic dx no spark
- Exhaust questions
- HID's with DRL's
- 93 civic si, what do you think its worth?
- Hawkman13's Ek Build
- Need help with steering wheel.
- What rear control arms do I need whith 94 integra rear disc on 99ek
- Vibrant Street Power ?
- Help with DIY Throw out bearing
- 00 SI clicking ecu HELP!!
- car smoking help!
- ek4 navi in usdm ek?
- 93 civic si misfiring issue
- Vtec Solenoid Valve on a B18B1 code thrown
- Cheapest fix for blown compression rings?
- Vtech Solenoid Valve on a B18B1??
- Axle CV Joint Replacement on 2000 Civic SI
- problem with 96 ek gas meter in cluster
- Rim thread
- help! cel is on and wont rev past 4k
- Clarification on installing distributor (TD-80U)
- Timing belt question...
- Which is the better civic to buy?
- ek a/c parts replacement?
- good deal but issue with the glove box.
- lost only key to my sol what to do?
- can i use a different ecu?
- Will a sohc compressor work on a b series motor help
- Are all 92-95 a/c compressors the same?
- ws2 replica?
- 99-00 civic:Blower motor only works on highest setting,changed transistor=nothin
- 99 civic suspension
- Improper axle installation?
- Sway bar question
- Fair trade? Tell me what you think...
- check engine light in 97 civic dx
- 97 Civic Hatch Crash bar
- Need help wiring power fold mirrors on my 92 civic sedan
- Injector junction harness problems
- Type of bearing in the ignition cap.
- 97 del Sol VTEC smooth running but still CEL
- 1995 Del Sol Si where to start??
- Em1 condenser fan problems! Help
- engine bay still squeaking, please help :-(
- Civic will crank but not start
- gsr integra center console into eg hatch?
- lowering spring question
- All four stainless lines leaking
- Car running rich, b18c
- Compression test help!!
- EG apply to "Putting X brakes on 96-00" ?
- Civic Maint suggestions
- help Honda code 43 fuel related
- b16a1 help please
- Tachometer flutters around, can BARELY accelerate without sputtering! HELP!!
- Need Help On Some ECU Settings For My H2B
- 97 cx power steering n ac system
- Si been sitting for few years, bad?
- Z6/s20 shift linkage help!
- k builders, where this go?
- 94 b18b1 swap into EG. LS harness install help. Pictures
- no underhood fuze box. help
- Sudden Slugish and poping LS/T
- mph gauge going crazy.
- overheating motor, please help!
- Loud clicking gone...quieter clicking noise left behind.
- Simple pwr steer question; did search
- Manual To Auto window conversion
- 98 Civic: hard jerk moving between accel/decel
- Carbon Fiber bits
- Is there any kind of "goop" i can use to repair torn bushings???
- What Aftermarket Intake Mani Will Fit In My H2B EG
- VX electrical issues? -- no spark
- my 99 civic Si doesn't start.
- 93 hatch - battery light comes on and car stalls. starts right back up
- OBD2 B18B1 into 92 Si Questions
- 1996 Honda Civic DX Coupe Brake light problems
- 96 civic wont fire... dizzy/Ignition Timing issue?
- Headgasket... Maybe?
- EG/D16a6 block/Z6 head/Y8 IM - idle fluctuation problem
- MOTOR SCREAMING when slowing or stopped
- Engine almost off at low RPM...Help!!
- Clutch hose leak - EG Hatch
- Brake caliper quality
- Any benifit to putting a D16Z6 Intake Manifold on my D15B7?
- gsr cluster on my 92 eg hb???help??
- 94 civic sedan - A/C doesn't work
- 92 del sol ls swap
- help my eg wont accelerate!!!!???
- winshield wiper int doesnt work
- vibrating shifter wont go away
- EG ACTUAL JDM CUP Holder exist?
- wiring after market gauge to stock sensor
- 96 Civic DX - Parking lights will not turn off even when the engine is off
- Del Sol with poors mans type-r plus + moar...
- Starting Issue
- z6 pistons
- Where to buy JDM Motors
- 93 civic. new ecu?
- Sol stutter
- lsvtec bogs down at high rpm falls on its face
- What is the best site to order rims??
- b series swap in a eg. rear mount problems.
- can someone help
- loosing coolant
- wiring harness question
- 1992 Civic brake pedal sometime goes to floor
- car is pulling all differnt directions on the road.
- 94 Civic EX - is my engine interference or non-interference?
- 97 Civic strut bar question
- blew a head gasket need info plz
- Possible engine swaps into 92 civic coupe
- 93 Civic; B16A Not wanting to stay running.
- Brake lights won't turn off
- 96 Civic EX - will not start
- Swapped B20 VTEC won't start
- Del sol build
- Tracking Device On My Civic???
- 93 Dx hatch blower just stopped, need help asap
- CEL: code 15
- Smog question
- Launching
- Relocated Battery, have a question about the Jumper Terminals...
