View Full Version : Honda Civic / Del Sol (1992 - 2000)
- jdm eg wing???
- SWAP B18B TO CIVIC SI 91
- Looking to buy a 92-95 hb
- any one got pics of jdm sols? or sites?
- 99-2000 civic front end on a 96 civic hatch
- Who to drive around?
- where to get those window vents at?any pics of civic with them?
- Stock Engine Swap
- 5 bolt conversion off ITR to 99 Civic Si..Question
- help on clutches
- Which Alternator\Starter. B18B w\ Y1 Cable Tranny into Hatchback
- Iam a new guy to the forum hoping to help people out
- 92-95 jdm amber corner lenses??????
- 1997 to 1999 Civic front end swaps
- Simple Request
- makin a stick shift chirp
- Tanabe or Tanabe Knowck-Off
- Camber Installation
- AEM Brake Pads
- motor swap in 2001 civic?
- crankshaft pulley bolt removal
- swapping in Si Brakes
- Will this setup Bone Out?
- wanted badly, 96 civic ex gage cluster
- GenVI Civic Neuspeed 19mm Rear Swaybar Hardware
- Wide-body kit for EG?
- 96-98 Civic Type R front lip in Carbon Fiber!!
- Side Moldings?
- will the hx rims fit over an eg6 SI-R front suspension?
- What to do next?
- I GoTs TwO ChoiCeS oF a MuFFleR I Am pUttIn On mY SI. Pick one for me!!
- Just Another Guy With a Honda
- Running Numbers on Motors
- i'm new to honda-tech
- deployed air bag can it be driven?
- test pipe or exhaust cutout???
- Volk Te-37's for sale for a civic or teg
- Civic Coupe 1994
- Ok here we go again
- Wanted: Clean 86-87 Civic Si...
- Weird Idle....????
- Anyone down to goto Sears Point this wednesday?
- who makes black lug nuts?
- Engine swap ?'s
- wanted
- B16a hybrids or Si's: What kinda gas milage you getting????
- ClutchMasters or ACT?
- Si Distributor
- torque specs on cylinder head
- MASS DYNO DAY CONFIRMATION!!!!!!
- whats up im a new member
- 5gen mufflers
- WidE body for a 92-95 hatchback
- removing Honda emblem on SI
- Tuner in Boston
- sub zero, grid racing, c8??
- 98 front end conversion on a 95 Civic!!help
- WANT TO BUY... COMPLETE A/C SYSTEM FOR A DEL SOL(twin cam)
- Website update (finally!)
- Most badass civic you've ever seen.
- just some new pics...
- what should i do..swap questions.
- engine swap question?
- Best Springs For EF (1991) Four Door?!
- For those of you that have H&R race springs, what shocks do you use?
- what r your thoughts on exhaust's for the 89-91 civic SI??
- CX hybird
- replacing windshield
- Acceleration Hesitation 1996 Civic Cx
- Exhaust for HB
- Hybrid or Turbo???
- DX and VTEC
- what kinda times for a 90 civic SI HB with a
- Hood Pins?
- 90 Civic Si For $2000???
- what r some nice bodykits for the 4th gen civic HB's
- Suspension set up on 99 civic vti
- got my vx wheels! yay!
- Where can i get a Custom turbo kit for a GSR motor or ITR motor?
- =( =( =( I keep gettin dicked over about my motor....
- tunein up
- Plz help me guyz...
- Help! "Looseness" in front end when turning corners at speed
- What are some good performance shocks you guys reccomend?
- greddy turbo owners, I need any help available
- Front Lip for 92-95 HB?? Pics??
- 2002 SI coupe?
- JDM b16A w/cable tranny into 92-95 hatch
- idle problem
- Will an APEXi W/S scrape on my lowered SiR?
- MASS DYNO DAY?????????
- Is anyone here from .....
- Camber Kits
- whats a oil cooler, and ? about motor oils
- anyone know how much the jdm eg cluster is?
- street glow and arospeed front mount intake.................................
- difference of gasoline in honda civic???.....................
- We got our autocross lot back.
- I'm Confused...Difference between U.S Si and Canadian SiR?
- 98 Hatch
- Kyb Agx installed
- Tanabe or APEXi
- Help with Suspension Dissasembly?
- Any info is good????
- Do I need to swap my engine?
- APEX'i N1 vs. Factory ITR installed on 95 Civic coupe. Graphic intensive....
- Best swap?
- Idle Control
- How do you make the guages red like the ones in the 99-00 Civic SIs? Not the guage cluster but the m
- Body Kits for an 86 CRX Si
- OBDI...OBDII, what is it???
- S2000 seats in a Civic
- need help with speeding violation
- Throttle Valve Cable-- A little help needed!
- Pinging in a 96 DX
- Where in MD , DC ,VA to find highest octane gas?
- Do you guys think this is worth it??
- 5g civic radiator fan thermoswitch location?
- Questions on Superchargers?
- Ek lip part# once again =P
- H22A Turbo or B16 Turbo
- LS vtec
- spoon engines swaps?????
- Civic AEM Intakes $175.00 Shipped
- ECU RESET
- 97 Civic EX fuel gauge problem
- Anyone have Tein HA on their Del Sol or Civic
- missing link = Lower boost??????
- ENDYN
- A/C Complete System for a 1995 Del Sol Twin Cam??? FOR SALE
- Diagnostic Software for my Laptop
- MIL codes??
- ? ? ? How much a carbon fiber hood cost and how much weight saved? ? ?
- Does anybody know how to disconnect or turn off the safety headlights on my new hatchback???
- Turbo for 97 Civic DX ??
- is it avail. to put a h22 in a hatch
- Ok Ive dropped in my LS
- Indexing washers for plugs...?
- need help with 99 civic o2 wiring ASAP please
- Hey whats the best front upper strut bar for a 92 civic hatch?
- Attention Members: Please Read
- Spark Plug Gap
- Power Windows????
- can anyone hook me up with a carfax report??
- here r some pics of my 94 civic hatch
- FS: 5Zigen 304 man
- NGK PLUGS
- What turbocharger can i use for my civic HB CX?
- Tubro Kits for 92-96 Civic Ex
- New Car??
- 92-95 Air conditioning???
- Gsr Rear Disc brake conversion DONE!
- Drove the new RSX Type-S (10 serious miles) last night...
- BEST TIRE?
- Shifter moves forward when accelerating heavily--NORMAL?
- where to get...
- Blended wheel???? Is it safe???
- Flange-Back Stainless Exhaust....which one?
- IDRC Summer Slam at Etown
- A/C for a Twim Cam Del Sol
- need ur opinion on turbo on ls!!!!
- Just got my Thermal on my civic, take a look!!
- Which of these wheels would look better on my Civic?
- compression question
- NEWBIE questions!
- Will I still retain the *sleeper* look with a carbon fiber hood?
- installing a tachometer
- Integra cluster in a G5 Hatch?
- whats a good throttle body cleaner
- question about valve breather filters
- Spoon Motors
- double clutch????
- Who here is from Sydney, Australia?
- i may be buying another civic,,90 civic hatch SI,,got some ?'s
- Anyone have a junk o2 sensor they wanna get rid of???
- ENGINE SWAP
- ? ? ? What will headers and exhaust do for my Si, besides make it louder? ? ?
- New 2001 Civic EX
- Vinyl Dye?
- '97 Civic overheating!
- 99-00 Si Front LCAs
- how do i remove the third brake light in the wing of the eg hatch?!? please help!!!!!
- Anyone have pics of a car with an F-max kit on it???
- Why don't you guys check out Qualcomm drags.
- 15" Rims on Hatches?
- A long time ago in a magazine far far away.
- Leejen, question for you.
- CRV gauges?
- Intake and Exhaust
- Birthday presents.. hmm what to get?
- projectors for 98 civic...u guys have the same problem??
- pin stripe removal question
- NX KIT
- What do you guys think about all these new, lower control arms?
- All these damn polls
- Height adjustable shocks?
- Just shut up about F&F!!!
- Short Shifter recommendations
- Honda-Tech.com stickers
- Skunk2 Shift knob?
- grill material?
- ITR rear sway bar installed.......initial thoughts
- trade Civic for Del Sol
- Updated JDM Gallery
- i-V-TEC?
- Wheel/Suspension question
- DC short shifter question--did a search--didn tfind what I was looking for...
- New Model Civic Motors
- Revised skunk2 front camber kits
- WHAT ELSE CAN I DO FOR CHEAP SAFE SPEED
- Hi
- NEW civic on the market
- What do you think is better (I dont care why you think one is better or not just which you perfer)
- Is there really a law that says....
- What do you think is a better deal ?
- Are the front disc brakes bigger on the new Si's than on a 98 EX? Also...
- Where to buy SKunk2 strut bars?
- i think i blew my shocks...
- How to get sticky stuff off my door?
- neuspeed or other premium brands?
- What is the best engine to put in my del sol.
- GSR rear brakes on a 96 4 door EX
- Anybody have pics of RH CP-35's on a 6th gen?
- What ecu programming is better????????
- Hello
- low idle and then stall EK
- PRM CAI's?
- In need of a race/street clutch...
- the opinion from the people
- does anyone know how to hook up the horn for a MOMO steering wheel?
- Anybody selling a Civic
- SOHC VTEC HP & Tq
- painted vx wheels!!!
- I think i figured out why light rain kills engines with CAI
- body kit question
- question about GSR AEM CAI fitting on my stock DX motor
- exhaust question
- My 97 Civic Gsr at Napierville Dragway in Montreal Canada
- FS: 2K ITR 5 LUG SUSPENSION WITH GUN METAL RIMS
- Anyone have a window handle?
- The Fast And The Furious
- automatic?
- info needed
- B18c swap on an SiR
- Danger of CAI
- 94+ integra dash in a 96+ civic?
- How much are Civic VX wheels worth?
- 92-95 hatchback with power window and door's
- has anyone orderd from K. Wantanabe??? Whats your expierence
- Any New Yorkers know of any good race prep shops???
