View Full Version : Honda Civic / Del Sol (1992 - 2000)
- need help asap about to pick up cams dont wanna get scammed
- How to get a smoother ride.
- Need help!
- 1999 Civic Dx: What is all thats needed for an Ex brake conversion?
- itr seats in eg?
- 95 Del Sol Auto trans replacement - Will 96 Civic trans work?
- rhd 94 coupe need help!!!????
- best cams for d16z6 help
- does anyone have the 96 ex power window troubleshooting flowchart
- JDM d15b Question?
- Randomly slips out of 5th gear on freeway?
- Rear hatch window plug?
- Smog failed and car runs poorly
- 99 Civic with 3 Fault Codes, P1298, P0135, P0141
- how to cancel p/s on my 95 civic?
- B16A 92-95 (SiR-II) into 00 ek
- Automatic B series swap
- GSr turbo compression and head build help
- CR-V Steering Rack?
- b16 low rpm help
- 09-11 honda fit rims on del sol.
- Just Bought an OBD2 gsr jdm need help
- CEL during wot.
- Coolant Leakage Problem
- irritated with oil leak.
- Honda brake pads vs EBC Redstuff
- Del sol fuel tank capacity
- H2b alternator question
- z6 TB on manual y8 IM (FITV hose help)
- d16 hg repair
- single cam zc soch engine? info plz specs.
- H22a MSD
- Slim radiator fan question
- 96 hatch. jensen vm9311 no sound at all
- struts
- 1993 Honda Civic: Bottom rad hose is cold, top rad hose is warm like normal
- want to run stock exhaust please help !
- D15B8 harmonic balancer special tool to install: where do I get one?
- How do you time a 98 civic?
- Tach not working need help
- Would a catalytic converter from a 92 ex sedan fit on a 93 lx sedan?
- Bsq kit with 22mm ITR S/B good enough for 92 Eh2?
- new tranny installed and speedometer not reading the correct speed
- D16Y8 code 70
- Jdm gsr swap into 97 civic dx cel 54
- 99 civic b16 idle problem
- Vin plate size
- Turn Signals
- A bird in the engine bay???
- d16z6 headers help
- right front lower a-arm doesn't fit
- trunk wont lock
- Mud guard with rear lip help
- Help window keeps fallin off track
- front end rattle over uneven roads
- 95 del sol si brake problem.
- K SWAP HELP!!!!!! HELP
- good Catback for EG hatch
- How to build my 94 civic**HELP NOOB!**
- Help with cel code 41. Honda civic 95
- help to identify ecu
- B18C1 swap into Del Sol
- ITR Swap
- del sol tweeter mounting
- real or fake te37??
- secondary 02 location: on cat or after?
- Completely removing rearview mirror??
- 93 EG Motor Swap Questions
- Del sol D15B7 engine replaced, overheating issue. lots of info
- 98 Civic Ex struggles to fire up. Any Ideas?
- EG/EK Axles help...
- 99 Civic DX started to over heat today...
- Start up after 1 year
- help! need advice is this woth 3k?
- civic dvd gps
- injector plugs confused
- B-series engine swap into '96 civic questions
- Where does this "drain tube" connect to?
- B16A2 headache
- White smoke coming out of intake manifold HELP
- 00 si power steering problem?
- del sol no power to window or mirror.
- 92 civic auto brake lights dont work, and shift lock as well
- del sol unstable ,bushings?
- new motor
- B16A6 into EG?
- Bolt-in Swaps -- 2000 Civic EX
- 2000 Civic EX with '95 D16Z6 Slow Idle Drop
- will these rims fit??
- k20 hb lose fuel pressure after prime help please
- 95 civic cutting off please help!
- Which Progress suspension to get?
- Running Rich? B16a2
- OBD2a to OBD1 swap
- exhaust headders?? gaskets w/ ading high temp silicone gasket????
- OVERHEATING!!! Upper radiator hose is hot, but lower is cold!
- headers question
- Jumping Idle, tried everything, HELP!
- No Start Question
- whats the best SUSPENSION parts?
- just sayin hi:)
- 96-00 CTR Rep Mirrors
- 98 civic reving issues
- Radiator fan not working and I hear what sounds like a bearing whine????
- oil pressure gauge necessary?
- B18b into 2000 hatch
- my swap
- 96 civic sedan engine code P1509
- relays? what are they for??
- Teg Cluster into EG
- Overheating problems
- 1993 honda civic o2 wiring help?
- ls valves in b16a?
- y8 mini me
- b16a2 -P1457
- D15b7 Crankshaft Postion sensor
- d16y8 trouble please help
- 94 Civic EX - no spark!
- VTEC in limp mode
- b16A2 Stock intake mani VS Skunk2
- D series engine swap question
- Oil filter question: 3593 and 7317 compatability
- Will Ek a-sport fender braces fit eg's?
- 92 hatch front end noise
- What tranny mount do I need...
- EVAP wiring connector? Where is it from
- 99 civic si rear seat problem
- Need help passing inspection
- Sunroof glass
- Number of things going on..Car losing power. D16Y8
- Fan not engaging on 1993 Civic hatch D15 engine
- Wheel bearings keep breaking & Cx master cylinder/ brake conversion question
- built gsr
- HELPP swapp obd1 engine into obd2 99 ek
- Honda del sol targa top latch buttons
- Lowering springs on stock schocks..it takes time to gradually drop???
- 92-95 Best stock setup for MPG
- 96 Civic Accelerator Cable
- p/l wont work and dont know what else to try
- heater not working...?
- whats wrong with my tranny?!?!
- 95 civic DX "distributor out of room for adjustment"
- H22 SWAP IN EK COUPE NEED HELP
- 2000 si cluster question help
- Just got a K... Where do I start?
- Del Sol Blinker problem...
- 98 D16Y7 auto non vtec and 92-95 D16Z6 man. vtec...
- Starter problem 2000em1
- Anyone know what throttle body this is?
- fuel pump question
- Y7/Y8
- how can I tell if i have LSD or not?
- Type R grill fitment
- white smoke
- integra dash in 94 coupe help plz!
- Help with tire size.
- Skunk 2 cams & JR Supercherger?
- Headlight Seal Condensation...
- Gas light does not work when low on fuel.
- 94 civic ex cooling fan problem
- the civic from crank 2 high voltage... dont flame.
- 98 Civic EX - Speedometer, tachometer, and odometer occasionally don't work
- That bolt securing the top of the clutch pedal bracket?
- knock sensor?
- Tachometer off? Gauge cluster swap.
- 2 quick audio questions 96-00 civic
- Would a Apexi WS2 full catback fit a sedan?
- High idle with BBK IM/TB
- 1993 Honda Civic DX Fuel Gauge
- 92-92 4dr hood fitting on a 2dr coupe?
- Major problems with b20 vtec
- Door handle - EK
- Civic/Estilo Parts in Indonesia
- TB for y7-> y8 IM swap
- my all motor build!!!!
- D16Y7: How to do a good mild n/a bulit on it?
- 97 civic EX power door lock issue!
- Starter diagram for delsol
- what the frak is this plug (under dash)
- Making my own Si Style Tail Lights? How?
- WTB: DC HEADER FOR D16
- 97 civic hx coolant leaking from thermostat housing
- 92 EG won't crank
- 95 civic oil control orifice
- inner tire wear on del sol
- 1993 Civic EG8 Speedometer problems
- 92 civic si bogging......helpppppp
- Blown head gasket - need advice
- Ek hatch with 99-00 Si seats????
- yonaka engine gasket kit??
- d15 motor and trans mounts
- no spark to the dizzy???
- Slight tapping sound in morning on cold start up
- what r those plugs?
- Sweet Ebay find
- Car not sitting even.
- B18b
- b18a1 obd1 to p75 obd2a wiring help
- What size upper pillow of Civic EG?
- Best recommend tranny fluid for type r trans?
- 1" MC and Booster question
- Car goes into gear - won't move/ drive
- b16a mods
- EJ2 problem HELP!!
- GROUND CONTROL
- Front bumper tab replacement
- iavc problem
- URGENT! I need a 93 del sol si (manual) wiring harness
- B18c
- B16 with GSR tranny
- Good deal or not?
- b18b into EG
- Mounting a front license plate
- civic clutch in ls swap?
- Could someone check out this VIN for me?
- p06 => p08 is it possible?
- Clogged Catalytic Converter affects IACV?
- D16Y5 into EG..
- Cutting Longer Distributor Slots as Alt to Adjustable Cam Gear?
- B16B Or GS-R Build?!
- prop valve?
- 93 civic-b18b1- Clutch issue, wont go in gear..
- 96 Civic cranks longer when low fuel
- Clutch Pressure Problem!!!
- B20B/vtec issues
- Timing Belt Replacement Trick
- Del Sol torque mounts???
- how to change your belts d16y8
- starting/ignition issues on a del sol
- HELP bought a ek shell that use to have a K want to go back to B series
- Bent rad supports?
- REAR Disc Brake Question?
- Is there a difference in D series and B series tranny torque mounts?
- 00 civic coupe/sedan, 98 spec itr header, what cat?
- EG coupe power door plug pin out
- Timing belt tension?
- Is this B18b worth rebuilding?
- JDM D15b swap into Eg hatch "VX" Your Help!!!
- 97 Honda Civic Radio
- auto trans slips to false neutral when warm--torque converter or sensor?
- Saggy driver door
- Anyone have any experience with remix customs?
- Need a Quiet Cat-Back exhaust
- EK Rear disc brake conversion / suspension question..
- Proper Ways to Clean & rebuild a Z6 head?
- D17 Valve Cover Swap on D16Y8
- 2000 Coupe D to B series swap power steering question
- Fuel Gauge Stuck after swap
- Timing Tensioner replacement
- b16 or itr head
