View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 95 Civic Type-r lip on 99 Acura 1.6EL ???
- Fuel leak! Need suggestions!
- 93 CIVIC HELP! My Stearing Seems To Have A Mind Of Its Own please read thank u....
- IAT on 95 GSR w/S2 IM
- Where to buy RED resevoir covers?
- 1.5 Vtec (JDM) engine Distributor
- cv boot inner/outer
- Estimated Cost: GSR Engine Swap + Tranny Swap
- Premium Gas VS Regular Gas (96 Honda Civic EX)
- 95 dx hatch with climate issues
- b18b into a ek swap problem
- 96-98 5 lug conversion
- Spring question NEED A QUICK ANSWER
- rear lug nut broke now its stuck!
- I need help with engine swap in a del sol
- Dealer option - "ADM" what is this???
- Weird idling?
- S2000 seats in a EG
- What exhaust/header b18b1 93 eg?
- Clearcoat chipping off of tailights?
- DOHC GARAGE
- DC5R front rotor replacement?
- Help needed Please, Purge canister/carbon canister problem.
- del sol owners help please
- window not goin up
- Air Fuel Guage Problem
- side markers?
- no o2 sensor = no cell + bad idle
- civic halogen to maxima HID
- traction on boosted Si
- Vtec controller....
- Proportioning valve installation
- std piston size
- They right way in Japan?
- idle jumping up and down
- Oil Filter
- Help
- LED Gauge CLuster? Possible?
- will i pass smog with z6 in eg?
- knocking/pinging sound in my b16 ek hatch! Help Please!
- rubbing on fender linings
- Trunk lock dont work
- Help with Axle replacement
- Cometic Head Gasket question?
- will the eg-civic airbag tray fit del sol?
- cluster bulb replacement?
- Looping power steering rack WITH 3 holes
- Hood latch relocation.
- who has the strongest body kits?
- is it possible for the air bags to deploy without having frame damage?
- Will 99 civic si intake mani. gakset fit a b17a1 head?
- water in cylinders. is it only the head gasket?
- ive got a question...greddy evo2 vs. apexi ws2
- Honda Civic Headlights
- help. intake side cam gear loosened
- what are these for my aem intake
- JDM B16 into EK... axles?
- gsr / turbo..gapping sparkplugs?
- 92-95 Stock Civic Si Colors
- fog light wiring question ( I Searched)
- Eg Rhd wiring harness??
- clutch keeps sticking
- Are Integra exhausts interchangeable with Civics?
- Parked my car for 5 months, now it surges at idle.
- Odd transmission problem - JDM GSR tranny
- Tips? 98 EK VTEC Head install
- how to remove stock intake
- U.T.I. NEW CAMPUS, PLEASE READ
- FIRST SWAP: DPFI TO MPFI
- .::Question: EG suspension onto a EK? Can it be done?::.
- Turbo which engine?
- if u ever had a soch , please help!!
- pr4
- once apon a time i had a cold air intake and drove through a puddle now i need help!!!
- throtle body?????
- 92 eg, buying 91 teg, all parts needed for swap??
- bulbs are flickering on delsol hvac controls
- i think starter problem
- /////////need help B18C1 in 97 civic hatch TDC problem\\\\\\\\\\
- [FAQ] Shock removal/install on EG!
- Can anyone identify this for me please D16y8
- I've had about enough, please help w/ climate control bulb
- FITV / Throttle Body Bypass + Additional Coolant Sensor - will this work?
- Relocating the radio in a ek
- head gasket
- main relay blew twice.
- SRS light
- Reseting My ECU
- b16a2 with ctr pistons
- Aiming Headlights
- CEL shift light.
- Password Thermal Intake Manifold Gasket, anyone try it?
- B16 question
- EG to EK civic conversion!
- Oxygen sensor bad?
- goin turbo--sellin the JRSC
- gsr crank vs b16 crank
- What size is the piping in the RSX-S Muffler?
- need rims?
- please help.. my car wont start
- i need a obd0-obd1 engine conversion harness.
- Helm's service manual for 1996-2000 civic
- spark plug covers oem b series?
- What rear lip is this?
- B18C GSR Strait up trade for D16Z6 need your tech knowledge
- H22 in civic question.
- Silly oem header fitment question. D16z6, D15B8 header...
- 93 del sol harness?
- z6 with y8 cam gear
- Clutch Seal
- Mugen M7 16x7 5-lug
- performance questions.please help
- gauges
- polyurethane vs. rubber aftermarket engine mounts
- Few questions, if anyone has the time
- car wont start
- Transmission troubles???
- 92-95 hatchback axleback on coupe?
- del Sol exhausts.....
- eg cluster plug / vss question
- d series alternator compatible??
- Does b16 exhaust manifold line up to stock exhaust.
- HELP Installing Apexi Rev Speed Meter and G Sensor *SEARCHED*
- Need some help with D16 head rebuilds
- need help car making horrible noice
- wiring for gsr in eg w/ skunk 2 mani
- gsr swap didnt start...
- More b18b swap questions
- Anyone ever seen these bars? looks like bumper support replacement.
- 1St Turbo Project
- Leaking from Heater Core, Coolant in cabin? Do i need a new heater core?
- jdm EG stanley corners need help?
- i know im in for it...
- b18c in eg?
- tire pressure
- problems after header install
- "rumbling" at 30mph - 97 civic
- I feel fat
- stabalizing bars?
- WTF: Can anyone go to www.passwordjdm.com??
- Power loss from 15's?
- help me on a situation about vehicle title
- Civic Keyless Remote Question
- trany proble need help please.
- transmission studs?
- JDM B16A DOHC Vtec
- askin ppl who know
- 92-95 civic 5 speed
- hondatech help me
- Anyone who has mounted rocker panels (stock sideskirts)
- AEM UEGO A/F ratio gauge vs. regular A/F guage???
- A/C compressor clicks like crazy
- Poor Acceleration
- PLX-M300 install Q
- Oil problems Leak
- anyone know if there is a DIY for integra Master cylinder upgrade?
- Plug wire keeps popping out
- Mold on Steering Wheel- what to do?
- Were do you buy valve cover paint
- A simple yes or no question...
- Which ECU to use for z6 swap
- 3rd gen itr suspension on an eg civic
- A bunch of del sol questions!
- Upgrading Suspension, what should i do? 96ex
- New Guy
- Low End HP?
- 1999 honda civic 4door auto, Engine wont start
- tranny replaced, no having problems
- quick release hub poll
- GReddy guage install
- Anyone Use DropZone Struts?? Thoughts
- what bar/brace is this called?
- Axle Halftshaft?,
- EM1 Owners: Whats the best exhaust?
- anyone using hasport 62a street mounts?
- finger prints on exhaust
- EM1 problems post here
- jerking during acceleration
- 93 Integra GS into 92-93 EG
- Trying to fique out how to put DA disc on a 93 hatch
- eibach sport-system kit reveiws???????
- Compression Test on Stock 97 EK AT
- last mini me thread ever!!
- d15b vtec with p07 head
- Review: Ebay oem clutch replacement kit from Gripforce
- FS d16zc motor and turbo setup
- how to install front lip
- Valve Adjustment
- tensioner bolt hole stripped. what can be done? help! fast...plz?
- b18c into ek throttle cable 2 short?
- omni valve train!!!!!!
- Is Civic 92~2000 model better than Del sol when Cornering?stock!
- b18b1 slight hesitiation in low-mid range
- What back seats will fit in my 96-98 EX coupe with little to no modification?
- AHHHH IGNITION HELP!
- no spark after i changed distributer, wires and plugs changed relay.....
- Integra door panels into EG?
- antena install? (i searched)
- More clutch problems....Need help
- motor
- Anybody kno the size of the 02-03 civic Si rotors?
- EG rear sway bar on EK ?
- for ecu?
- Installing trailing arm bushings
- what's this noise...? seriously... what the hell is this noise?
- injectors for sale
- Slow cranking
- what all feeds the speedometer
- bettery suggestion
- 90/91 Integra Axle vs. 92/93 Integra Axle in H22 EG hatch
- HELP-----94 civic ex/1.6 SOHC vtec ( pictures )
- any one used this suspension setup?
- new here to the boards!!
- MIR World Cup
- Speedo doesnt work all the time Please help
- im not getting ANY help in suspension forum so......
- wrecked integra, do you think it can be fixed?
- black housing taillights?
- Exhaust Help
- Accord powersteering problem
- ITR cluster in a EG6 hatch?!
- DC headers ?????
- noob compression question
- h22 or gsr?
- Torque specs for B-series dizzy?
- Give me some info on a 98 civic DX Motor
- exhaust side cam wont move /turn
- integra disc brake
- im tryin to figure out a place i can get some carbon fiber
- I got tranny problems! Grinding in reverse!
- Rear suspension?
- Oil question??
- sludge on one of my valves????
- Trunk Light?
- CTR Headlights and HID's?
- tranny help!!!!
- What should I do b16/b18c question?
- Question about the EG's
- what model is a EG4 ?
- Big Brake Conversion???
- Question about my 1/8 times...
- ahhh help
- B20/VTEC Almost finished... Where do I get oil from?
- what kind of ecu ?
- b16a2
- I melted the driver's side headlight wires running w/o a dp
- Timing issue???
- ARE ALL D SERIES PARTS COMPATIBLE?
- Attention: 99-00 SI owners
