View Full Version : Honda Civic / Del Sol (1992 - 2000)
- intake manifold differences d16y8
- Thought it was a simple map sensor
- 90-93 aaccord axles for a h22a eg swap
- VX to Ej1 swap help
- NEED HELP WITH SMOG
- K20A eg DTC help
- Cable Tranny Clutch Q?
- Deal Seems Really Good?
- adding a car to my garage??
- eg/gsr CAT and header combo for passing CA SMOG question
- ***official rsx type s muffler fitment thread***
- lagging acceleration/idle dropping
- good trade?
- INTEGRA DASH SWAP WITH AC
- E85..is it good
- 91 octane enough???
- Insane or genius...
- clutch problems
- speedometer and odometer question.
- 96 Hatch with b18b swap, what header?
- Need PRO answers! my 96 ek d16y8
- Won't enter in any gears when the clutch is engaged need help please
- Engine Swap - Need Help Pulling Axles
- Antifreeze
- loss of power......why?
- whats a d16y6???....anyone heard of it
- distributor problem
- headlight question
- HELP..bypassed coolant from heatercore...turned on car and it revs up to 4k ?!?!?
- b18 ls vtec sputtering help?
- does anyone know what bolt/screw this is??
- 97 civic coupe with SI b16a2 heating up
- p28 knock sensor?????
- Honda Manual Sport Pedals for FIT go into eg civic?
- 94 civic VX exhaust suggestions.
- axle poped out
- Hard Cold Start/Loses Power when HOT
- CTR B16B inspection help!!!!
- Antenna Delete Plate
- d16z6 tranny wont go in reverse
- torque spec for civic single cam oil pan?
- changing head gasket?
- 99 Si, Secondary O2 plug?
- d16y8 in limp mode please help!!!!!
- need help to fix CEL to pass emissions
- Should side markers be wired to turn signals or parking lights?
- power steering fluid bottle relocation?
- Car automatic shut-off when driving ...????
- O2 sensor problem...
- more gsr swap help
- Sunroof wont open any suggestions?
- Car starts and after warmed up.. it dies!! HELP!
- ECU swap problems
- 2000 high comp. mini me. Advice!!!
- 99 civic Sir exhaust
- New car need boost guru opinions
- Scratches on main bearings
- need some help with d16z6 swap issues
- went to the track for the first time heres the video
- 98 civic turn light questions.....so confused
- WTB crx cargo cover
- i need parts 95 civic 2dr
- Rear Mount Install Question?
- 98 Hatch B16A/B16tranny sir2 w GSR ECU I know nothing about hondas, need help!!
- CEL is on, quick question
- Power Windows and Power Locks.
- Need help to clear an EG6 spoiler question
- No O2 sensor cause erratic idle? B18c1
- b16a2 into 94 civic issues/ questions
- My Big SOHC
- Check engine light because of o2 censor?
- Need a pic please
- cluster options
- weird idleing in my gsr swaped ek help
- Honda Civic 4Door
- 93 ex hydro tranny issue
- anyone know where to get oem fabric
- 00 civic si barely moves no power help!
- 94 swap in a 97 ek.
- Headlights wont shut off!!!
- DAMN!!!
- Door panel install
- Need help on a type r shift linkage on a Gsr tranny
- Rear disc conversion for 98' EX coupe
- 99 EM1 losing power at freeway speeds....
- Why is life cheaper when you stay single? EK Build
- engine almost over heating?
- 92 4dr wont start no voltage at the fuel pump
- shifting problems in auto 95 civic
- Need help puttin my 97 Gsr swa. In my 98 civic dx
- Why is my car leaning?
- acceleration problem
- question about lsd h22 del sol
- Stronger trunk struts?
- alternator question
- I have to replace the passenger side axle AGAIN
- Please help!! Spark Plug won't come out
- Is a b18b rebuild worth it?
- HELP PLEASE!!!!! obd2 gsr swap in 93si hatch
- Help! Door is stuck on my '98 Civic coupe EX
- 95' civic ignition problem
- how much mpg does ur LS swaped civic does?
- Changing the tranny fluid on a eg civic
- Speedometer Problem
- Can anyone help a guy(amateur) out with his coupe
- ITR,CTR mufflers!!!
- Suspension ?
- Ek mirrors on EG- template
- Obd2 distributor, one wire left, HELP!
- 98 ek hatch swapping ls motor???
- Spnfedeg6 build finally Complete!! PICS INSIDE!!
- GSR swap into 92 4 door. Having issues!!
- b16 axel problem
- Rusty hood bleach or vinegar?
- Dumb question about sidemarkers
- Cluster question
- b7 head mill/shave
- what machine work is necessary
- Grease for hood latch.
- Will a fender off a 2-door fit a 4-door? 99-00
- civic problems HELP!
- turbo b16 problem
- 95 Civic Coupe (EX). VW 4x100 on Civic? Do P195/60R14 Fit Stock Civic Steelies? Help
- How do you remove car wax....
- how do i use a vacuum gauge?
- '92 Hatch B16A 98+ITR header (Flex Pipe or Bracket Options???)
- 1996 dx civic cluster need an exorcism?
- Help, car very low idle and run's rough!!!
- New Member Tampa Fl
- Limp mode code 16
- Swap budget
- Steering Rack bushing replacement
- Does anybody know were to sell/install lojack in chicago ?
- Engine swap help
- Fuel + Spark = No Start?!?!
- speaker wire debate
- KINDA NEW TO HT SO HERES MY BUILDS!!! (have others in different places!)
- will 92-95 civic clutch kit work for my 99 civic ex?
- ef ex brakes on a del sol si
- COOLING SYSTEM PROBLEMS!!!!!!!!!
- HeLp with DIZZY
- couple quick questions
- fuel pump not priming
- changing main bearings, opinion needed
- D16Z6 Oil Pump gasket & seal part #'s..?
- cleaning carbon build up
- CELs and Intake question EM1
- 93 hatch eBay fog wiring?
- dyno question true or false :?
- Temperature drop...
- ECU????????
- z6 or y8 .....setup for booooost
- Speedo Question
- Is there any way to tell if you need new valve guides on a head?
- auto trans shifting too high
- B series crank pulley interchangeable?
- Heater Core removal question Help almost done
- From rags to riches, b..ches
- removing ign lock cylinder
- 92 civic b18c1 swap what Injector?
- does any one know of a diy on installing an oem trunk light
- 99 EJ6 Rack and Pinion FAIL
- front sway bar question
- CEL help!!!
- Is it possible to pull the wiring harness with the engine still in the car?
- Replace expansion valve/remove blower motor box 93 Del Sol?
- help car wont crank over to start
- Vtec Solenoids
- What is a good budget swap to put in a eg sedan!!
- Bad oil pump????
- hid kit
- TPS...HELP very annoying
- Steering wheel
- Clutch kit
- a/f ratio problems
- NEED HELP WIT WIRE HARNESS
- Upgrading Axels For FI Setup
- What to do next?
- please help quick! will a EK hoodlatch fit my EG?
- Is MTF for a Honda just MO?
- Y7 to Y8 swap trouble
- 92-95 head light assembly upgrade?
- Del Sol Stalling Problem - Something Strange
- Power Folding Mirror help
- blockguard with honed block
- steering issue
- clutch problems on swapped hatch! help!
- what comp to run ls vtec
- Heater matrix loom difference between 99 ek9 and 99 ek9-race spec
- 951? Anyone?
- Car not running right
- Hook/handle for eg rear window
- Skunk2 Black Series throttle body and manifold?
- Compression for B Series
- where is the crank position sensor???
- EG Turbo Overheating Problem
- LS Swapped 93 Coupe Losing Power up top
- Save Rev Limit
- What car is this starter from?
- Roof Rack
- help!
- Civic makes odd noise when wheels are turned in parking lot....help
- Please HELP!!!
- piston rings shot, how long till motor goes?
- Installed a vented catch can and...
- D16 Distributor
- tranny problem??
- del sol overheating help
- D series cant get the timing belt to go on...
- 02 sensor question
- tune ecu
- Help I bought a car with a missing Part, What goes here?!
- Best black short / stubby antenna for Del Sols???
- 99-00 civic fron end on a 97 civic
- car keeps losing coolant..can smell coolant but cant see any leak???
- Passwordjdm carbon foglight covers! CHECK IT OUT!
- GSR turbo oil cooler in 92 eg6
- Replacement keyless entry remote programming - help please
- trani
- EG hatch brake problem
- newbie buying a turbo car Help..
- 00 Civic SI ac problem
- ECU HELPP!!
- B18B1 running rough
- i need advise/suggestions
- PLLLEASSSE HELP!!
- 94 eg auto to manual D16z swap problem
- help... Will a y8 map sensor work on a z6?
- D16y8 auto -> manual swap cost?
- '00 Civic Lights Pulsating
- Has anyone ever seen these JDM Civic magnetic autocross number plaques before?
- CIVIC Jerking / HIGH REVVING
- 92 del sol with 96 Ls doesnt run right!
- oil pressure switch
- Red light wont stop blinking
- OEM VX rear diffuser installation?
- ITB"S
- need a carfax on my car
- Do most b20 motors have valve adjustment problems?
- vacuum help
- i am looking to but a jdm civic type r head(engine head)
- D16z6 is really slow...Plz Help
- b18 question
- k20a eg help!!!plz
- How do remove distributor shaft???
- SiR spoiler question
- Australia DOHC ZC / D16A8 head bolt questions.
- power window conversion into 97 hatch question
- Windshield Weatherstrip
