View Full Version : Honda Civic / Del Sol (1992 - 2000)
- anyone put pwr door locks on ek hatch?
- 400hp goal, use high or low impedance injectors???HELP!
- brake rotors
- civic hatch wont start, not getting sparks
- Speedo and Odo. not working after lsv swap
- anyone one been in the steering column?
- 92 Cx hatch EG fuel injector question.
- cd player turns off when cig lighter plugged up
- air recirculation motor
- What is this connector? EM1
- Picking up a 95 si EG...
- just finished motor swap wont start just clicks
- smog.. I need help with a b20 into an eg smog in nor cal
- 95 Honda Civic. Inner Tie Rod. Now replacing the Steering boot. Where can I get them?
- 2000 civic si( em1 )..fuel pressure problem
- REALLY need some help on oil pump leak??
- OBD1 Jdm b16a in to 92 CX Hatch
- 2000 Si electrical problems
- converting my dd into my race car
- Windshield wipers stopped working
- d16y8 very high cold idle
- Help please! B16a problems
- Custom EM1 Radio Bezel NEED suggestions
- Need to pull codes on OBD1, no datalink anymore!
- b16a problems
- d16z6 or mini me???
- Clock options for 97
- 94 Honda Civic LX Cranks But Won't Start
- JDM d15b into 95 eg hatch VTEC wiring questions...
- Missing Lock Nut for Outer Tie Rod End
- B series camgear removal and reinstallation.
- clutch problem???
- ek h22 swap no fuel
- Idle problem
- Help 1996 itr B18c spec R misfire at cylinder 2
- B20, oil dipstick leaking.
- B18c1 help in eg/Running problems.
- Shocks busted through top hat!
- 2000 ex cambers
- 2000 Si Misfire problems... Help!!!
- gauge lights come on after ten minutes of driving
- 1st gear thud
- Light Weight Flywheel?
- 93 civic ex turbo build questions
- Hard morning start for D16Z6
- My 2000 si manual problem
- Car choking after Transmission Fluid change (solved)
- 92-95 VX with EX trans?
- Which donut gasket??
- Making a 99 Civic faster on the low end
- No crank issue!
- 1996-2000 coupe rear seats into 1992-1995 coupe direct bolt?
- no 5 cam holder d16y8, im missing a big dowel. how many should it have.
- NOOB questions... GSR cams vs Stock B16 cams in stock B16 engine??
- Different kinds of Head Bolts/studs
- start button?!?
- Accord suspension on a eg coupe? Can it be done?
- Just bought 98 civic lx...
- Any difference between the 00 SI front crossmember and the EX?
- 99 EX Coupe Racing Mods
- F23 TO 99 EK?
- D-Series valve adjustment
- A/C intermittent problem
- Advantages of a Y8 head on JDM D15B ODB2 block?
- help please main bearings
- 97 hondacivic lx d15b swap
- 2000 Honda Civic Si(EM1) Wire tucking
- updated head gasket?
- 94 Civic 1.5 DX crank no start
- Tranny Swap, Starter bolt wont line up..
- suppliers and info needed
- Clutch master/slave cylinder problem - EJ6
- Turbo D or B Swap???
- 95 Civic overheating. Please HELP
- 2000 Honda Civic DX heater issue
- Can the int manifold & throttle body be swapped?
- 00 Civic no-crank problem
- Rock hard spark plug tube seals
- Overhauling my D13B soon.. Which service manual should I use?
- Front strut tower bar question
- ticking noise from motor?
- Need help finding replacement part number
- 92 Civic CX running rough
- will my jg edelbrock tb off my 95 ls motor fit gsr
- h22a eg coolant problems
- what is a good 12v constant to tap into for my IAB's
- EH3 EDM 1 piece led spoiler questions
- NOOBish b series ?
- Cx dash conversion
- IAT 99-00 civic si
- 92 Si hatch Dash Lighting ??
- exhaust question
- Coolant leak - Photo Request
- d16y8 replacment
- eg b series swap
- Pulsing Idle on 95 Civic hatch. Please help
- can a distributor issue prevent starter from cranking?
- Dilemma! Ls or b16? Need help deciding
- outer tie rod issue
- B18B1 overheating, coolant every where
- EG won't start, got it fixed but won't start again
- ebay carbon fiber lower console..pics?
- '97 d16y7 vs '95 d15b
- Civic mileage
- 00 civic
- starting problems..fuel related?? idk?
- What is this part called?! Please Help!
- NEED HELP
- 96' CIVIC NO START
- Honda Civic Coupe and Hatchback roof
- 3 wires for gauge lighting which one!
- how to wire obd2 IAB's in eg civic
- code 54 crank fluctuation sensor?
- How to fix unwanted speedo warning lights
- Short in Turn signals
- del sol - weird noise coming from front
- need driver window!!!! immediately 95 civic hatch eg
- My Horn on my 97 honda civic isnt working?
- 96 Emissions help?
- SECONDARY o2 SENSOR HELP NEEDED
- B20 bored 40 over safe? With GSR Head?
- d15b check engine problem
- 95 coupe pulling to the right
- B16A3 BOGGING OUT PROBLEM! EVERYONE PLEASE HELP!!!!
- Hole in my sub-frame
- is this website reliable to buy honda parts from?
- 97 civic hatch obd2 wiring harness z6 head help
- IACV Questions - D16Z6 - 93 Del Sol SI
- (94 del sol obd1) with (obd2 gsr swap problems)
- 92 civic almost dies after warm
- B18b swap acceleration issues
- Is 245 c/r to high to boost on Gsr motor?
- CTR Parts
- 93 ex cranks and runs, then wont crank again
- CEL issue, goes off when car is turned off
- Should i keep my PRECISION SC44 60 TRIM?? ANSWER MY POLL, YES OR NO!!!!!NEED OPINIONS
- recently took off y8 head.. ive got questions with pics!!
- civic 99-00 sedan trunk wanted help
- Converting my drums to disc brakes..What do I need?
- 2000 civic EM1 convert to E85 corn gas?
- 2000 Si Misfire help
- need help about RPM.
- How to install ek9 civic type r mirrors?
- car not running right....
- Press lock button it unlocks doors?
- which O2 sensor to buy???? 95 civic ex with b18 LS swap... lol
- Car Won't Start/Getting Power to Fuse Box
- Girl Needs Help! 98 Civic LX Won't Pass Smog
- 95 del sol No start
- b16 need new clutch...Suggestions
- injector tap
- HELP 92 civic
- 1993 Honda Civic transmission mount help!
- alternator/sp sensor fuse keeps blowing
- Jdm 5 lug conversion on 97 ek coupe
- Emissions help:96 civic
- what to look for before buying? transmission?
- Head gasket replacment
- Reading CEL codes
- b18 ls swap whats it worth
- Coolant leaking from bolt
- 92 civic dx wont start
- Does this sound like a good deal for a 1995 del sol
- B18 TB going on D16...what are these, picture included.
- problem on old full-race.com car that has never happened before HELP
- Skunk2 intake manifold help!!!
- quick b16 timing question
- Obd2 diagonsis port location on an ek9
- Oil cooler placement issue?
- Trusted Performance shops???
- 92 Civic - Where is the main relay?
- Starting Problem
- obd2 engine and harness in obd1 car
- Blown Airbags replacement question
- 98 Civic Cruise Issue
- I need some help on a 1998 Honda Civic oil leak on front side
- d16z6 help?
- car dies when i give it gas?
- Where to buy body parts?
- help needed!!!45 mph impact on curb!!! right side wheel is 1/2 inch back
- 95 civic hatch rear suspension fit on 98 civic 4dr ex rear??
- mysterious hole in B18C that has me stumped
- Valve cover bolts snapped
- Lugs damaged..help
- clutch pedal problem
- "vti gauge cluster" fake??????? or real???????
- 94 dx starting issues
- California Engine Swap Laws
- HELP: Del Sol w/ AP1 cluster (How To)
- N/A D16Z6 BUILD
- ECU/Wire problem swapped b16a 98 civic ex Help please
- Help with auto to manual swap please
- Engine smokes when oil is at full level, stops when oil level gets low
- em1 wilwood bbk questions
- help with b18a1 swap in 94 lx sedan
- 04 DX SPEEDO INTO 97 DX
- Car sometimes hesitates while accelerating
- best stuff to stop an oil leak on my oil pan
- what is the name of this and what it does?
- Question about installing Honda Access window visors on 96-00
- b20 turbo not starting!!!
- DIY Replacement of Climate Controls and Bezel in 96-98 Civic
- 2000 dx speedo/odo problem
- Central NJ: 95 Honda Civic EX Lower Control Arms and Tie Rod?
- 2000 si, weird noise at high RPM
- D16y7 Fuel pressure Reg on B18b
- Fuel pressure problem - 20 psi prime
- 92 civic hatch, gsr head swap bog?
- cluster lights r out ?
- How did you install your front tower bar?
- Light in car and cluster
- external door handle on rear door -- please help me connect linkage
- Just bought a car with a CA Salvage Certificate.
- burns oil...sometimes? d16y8
- high compression z6
- Tranny help
- Need to know ITB's pros and cons
- Turbo B20 Bogs need help.
- Ignition Switch Problem
- Civic Upgrade Front Brakes Question
- Unknown Check Engine Light
- How To: Tuck the driver's side harness for EG/EJ
- Think this bone stock EK is worth $3000?
- 94 integra suspension to 98 ek
- Random Misfire Across All Cylinders. Truly Random or Cause For Concern?
- D16Y7 High idle/ running rich
- Air Coming from Valve Cover Breather???
- Clutch Wont Build Pressure???
- using Ibuilt or mr.alex brackets for ctr wing
- eibach sportline springs
- hytech rep/hytech original vs oem type r
- Need help!!
- 96 Civic Very Loud Engine Noise, Help diagnosing please!
- Do Del Sol needles glow?
- D16Y8 in Honda 1998 LX 'got some problems'
- b16a2 Not starting...
- HELP! Can't fit integra booster in.
- Integra mirror glass into an EX Coupe shell
- Megan racing mufflers? Any opinions on these?
- dc2 steering rack and subframe in 96 ek???
- Knocking
- **Suspension Bushing Change//Help**
- How to change an oil pan?
- timing belt wont go all the way up were up arrow is
- Gsr swapped ek, which power steering belt??
- No cold start with omni power 70mm TB
- Bisimoto replica ???
- Misfire problem
- Oil in overflow tank????
- Blue JDM interior?
