View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Water inside car
- GSR into EK - GSR Header Flange too big for EK Exhaust?
- Belt squell
- My bucket
- What steps should I take when replacing the alternator belt?
- pulled a CEL 9 today....confused???
- Clutch Pedal Travel/Freeplay all of a sudden changed!?
- where to put seafoam in on a gsr?
- Air bubbles on oil dipstick???
- REAL BAD IDLE ISSUES!!!!!!!!!!!!!!!!!
- D14 Help with new intake manifold
- I want to put an RSX type S muffler on my 2000 Civic Cx Supercharged. Need opinions on fitment. sear
- b18a1 swap in a 94 eg coupe!
- what mounts do i need for a b18a1 to civic swap
- Harness/ECU question?
- 97 civic ex cel code 91?
- What kind of HEADER is this ?? oem ?
- Rear brakes- drums to disks
- 94 civic dx with b18c1 problems
- Any good stories about weird things a previous owner did?
- OBD2A- OBD2B Need help
- EG/EK motor mounts?
- EG Hatch Rear Window hook/handle next by the wiper
- Can't find way to check engine light NEED HELP
- need some help with the check engine light
- cost effective solution b16a2
- Itr Fitment on eg?!
- JDM engines
- Car is burning oil suggestions on a rebuild
- D15 to D16 Swap
- Gutting my honda?
- Pillow mounts/Top Hats???
- 97 ek dx w/ d16y8 motor smog?
- Momo Horn..need it badly!!!
- PLEASE HELP! NEED TO DECIDE SOON!!
- Standalone on a d15
- Jb weld good enough for this?
- Eg radiator and EM1 radiator... are they interchangeable?
- Car won't start, please help
- keys
- EK B16 rear mount bracket
- Trouble with some possible A/C lines.
- Mounts help
- GSR into 99 EK Coupe, Exhaust Question!
- fuel injector Question ?
- b18c1 vs b18c5 vs k20a2?
- can anyone advise shop to rebuild b16a2 in nashville tn area...
- registration
- no knock sensor
- Will 96 prelude seats fit my 93 civic hatch cx??
- Knocking on b17a please help
- GSR seats in EK
- What would you say is the nicest exhaust?
- Charging problems
- My Do-It-Yourself D16Y7 swapped to D16Y8 in my EK
- h22 swap help (no fule, no power windows, no dome lights)
- This is the right side for the window switch right??? EM1
- car clicks fast but doesnt turn over, wiring problem : details inside
- 93 ej2 GSR redlines at 6500 RPM instead of 8200 RPM.
- Problems after GSR swap
- leaky rad after vtec
- SO look what happen today.....
- Anyone can help with timing parts list for 00 Si...?
- Automatic tranny question (might be a dumb one)
- questions about parts compatibility
- which gas to use on d16z6??
- Help: Broken Passenger Window (Theif) 99 Civic Ex 2 door
- dizzy?
- gsr swap into ej and having engine cut off problems
- got a hatch finally need advice
- 99 civic si suspension???
- D16y5 into a D16y8
- how do i get this @$#% off??
- any info please
- civic vVX EGR SWAP PROBLEM !! 5$ reward !!
- 92 stock civic, JDM ECU?
- 98 civic cabin filter? pollen filter?
- high idle with my swap (96 gsr in 94 coupe)
- AT to MT conversion question
- Help - California Si Catalytic Replacement
- what makes a car idle?
- ************ STOLEN WHITE EG 11/13/08 IN COSTA MESA ************
- Does anyone know where i can find one of these guage clusters?
- carbon fiber hood question
- Quick Distributor Q
- Fuel Pressure gauge on STOCK fuel rail
- OBX parts?
- 99 si going cams, what best itr or ctr
- Rear brake conversion
- Removing engine without removing tranny ???
- Difference in JDM B16A Cams - Manual vs. Auto?
- injector seals
- Times are changing.....finally accepting it
- Is it ok to take off ABS and if so how do you do it?
- how important is it to get flywheel resurfaced?
- strong gas smell
- 1999 Si-R civic w/ jdm k20 turbo
- NEED TOW HOOK Dimensions
- Rattling noise coming out of my rear passenger side suspension
- $10,000 question
- a/c compressor making chirping sound
- Brokrn lower control arm bolt
- should i buy cf hood?
- 2000 si have fuel no spark!!
- integra b16 swap issues
- h22 running on 3 cyl
- ej8 distributer problem
- LS Vtec Turbo help.....
- Coilovers on EJ1
- California emissions and engine swaps
- fuel pump wont stop primming!
- smog help
- vented valve covers
- B20 Vtec installed into bay, header is too short?
- B20 VTEC........
- issues during rear disc conversion
- lots of black smoke and water
- 93 honda civic b16 swap wont go past 3000 rpm hits a rev. limiter!
- hydro trans?
- suspension, whats good?
- Swaps for my 93 eg coupe
- short in the fuses
- b series vss are all the same?
- **Quick Help** 97 Civic Vacuum Question!
- foggey windows
- My 92 DX starts sometimes.... please help.
- help with CIVIC ex ..
- GSR rear sway on eg
- EK idle problems, trying to track this down.
- d16z6/y8 intake manifold swap
- D-Series A/C Compressor on an B-series Motor?
- type r rear sway bar on 99 civic
- Shifter Problems, when in gear -- still loose.
- Fuel Problems..
- FOR SALE! EK HATCH WITH TYPE-R!!!!
- rear disk question
- Honda Civic Type R - Christmas Gift Suggestions Needed
- VTEC problem?
- quick question on doors?
- NEED PARTS FOR A 92 EG
- ek4: side markers and h to b help please!
- b16 ek
- jdm ek3 non srs sterring wheel help
- Will Si springs work on a DX?
- smoke under valve cover
- d16a6 with d16y7 good combination????
- Help identifying transmission bracket.
- Civic VX, head question.
- Motor mount question?
- HELP!!!!!!! Me get me civic looking good........
- b18c1......anyone....
- Blower Motor Help
- Car turns off when I press the accelerator
- itr crank or ls crank!!!!
- Online 92-95 civic repair manual poor quality wiring scan
- obd0 d16 into a obd1 civic... will the harness and ecu work?
- kill switch
- What angle is the throttle plate supposed to be at?
- Squeaky clutch pedal - where to grease?
- 93 civic w/ b18 swap condesor line question
- alternator 4 wire plug question
- Y8 fuel rail and I.M. on a z6 head
- frontlights problems
- Limp Home Mode?
- Can I bypass a Hatch Vx manifold/cat, with an Ex manifold?
- Ej8 into a Ej1 Help!
- d16y7/w d16y8 wiarind diagram... is is possible to use the harness and put it in b16a2?
- Maintaining Turbo?
- clutch pedal help....
- 1993 ESi set up
- o2 sensor question
- greddy evo exhaust
- Could it Seriusly hurt the motor if i forced the crank clockwise?
- 2000 RED CIVIC SI TRUNK WANTED
- do i need this ECU wires???
- Wiring problem
- Couple questions about B18B1 in EG
- Brake locked what should i do?
- Port and polish question???
- 93 civic brake question
- civic hx o2 sensor problem
- Check Engine Light still on after changing exhaust mani to stock???
- Best oil grade?
- need help civic 96 hb idle problem
- o2 sensor wire question
- Anyone with a 92-95 coupe can you take a pic of the rear wheel arch a few pics of a oem non worked q
- cel:4 cpk
- Can idle be set through the ECU?
- h22 eg runs then dies
- coil or shock squeek?
- SPARK KNOCK? SOLUTIONS? HELP!!!
- EK4 Round fogs light on Del Sol.
- Dimmer switch?
- engine bogging
- OEM Si radio color?
- MINI ME Compression Test
- 97 DB integra seats in an EK
- D16y7 Tranny
- DEL SOL STOLEN IN SD
- 97 civic dx coupe windsheild fit 98 acura 1.6 el ?
- got some questions swaping manual doors for power in eg
- Any recently stolen white EGs in the bay area?
- Spurting/slight bucking at low RPM's?
- d16y8 mini me swap
- D series valve stem seal question
- ls swaped civic bogging
- 92 civic dx d15b7 problems
- 1992 Honda Civic Shift Interlock Solenoid
- a/c belt wtf?
- No knock sensor= no vtec?
- 93 civic fuel pump ?
- Looking for a d16z6 around my area for sale
- Rear Lips
- TPS sensor issue HELP
- Battery/Charging/Ground Problem After Jumping Car Off - Help?
- When three cylinders misfire...
- anyone know of anyone selling hatch for CHEAP wrecked i dont care near KY
- Just did a Compression test....
- t-belt and maintnence parts question for B16 ?????
- valve lash adjust help
- can anyone tell me about what it would take to do this swap?
- instrument lights fuse keeps blowing
- Gsr.....overheating or not? Fluctuating temp gauge.
- Axle Question
- Radiator cap not relieving pressure
- jdm d15b question
- test pipe!!
- 1998 civic dome/radio/ac/dash wiring help
- Oil leak coming from crank seal????
- Need A B-16 Tranny and Clutch
- 94 coupe mud flap hardware
- Will JDM DC2 Type-R rear lower control arms fit my 96' coupe?
- viper car alarm install
- Whats this battery looking thing in my 99 SI
- sol meet
- too much noise inside the car!!
- Tranny for SI?
- Modifying Distributor from D15B8 to work on D16Z6
- help with o2 sensor b18c1 into 97 civic
- did i blow my head gasket plz some one help !
- compression test
- low oil with no visible leaks?
- Cam Head Noise ?? Help
- jdmshit JDM CTR rear lip? 2 versions
- ECU Gurgle Sounds Please HELP
- didn't knew that the megan m.o.e muffler come with silencer?
- Honda del Sol foglights
- 00 Si Idle Check Engine Light
- need harness
