radiator fan issues
radiator fan issues
so today i swapped out my radiator for an aluminum one and when i put everything back together the fan wouldnt wanna turn on anymore. im pretty sure i put everything back the way i took it off, and i plugged in the plug for the fan. is there any way i can diagnose this? and i also will add that my vtec doesnt engage anymore if that has anything to do with it.
thanks in advance !
thanks in advance !
Technical Hero
Re: radiator fan issues
Check the fuse, relay, and jump the fan switch on the thermostat housing to see if the fan cuts on. If so the circuit is good. Did you bleed the cooling system?
and i drove the car to work and when i got there the fan still hadn't turned on, shouldnt it have turned on by then ?
The Grumpiest
How do you know that it didn't turn on while you were driving? Did you test to see if the fan was actually working? I don't see how changing out a radiator would cause your fan not to turn on.
well i dont see how it would turn on while driving and when i parked it would turn off ?
well i tested to see if it turns on with a paperclip and it didnt come on. and i dont see why it would cause that either thats why im lost lol
yes thanks for the help, the fan turns on now when i jumped the fan switch. so this means i need a new fan switch, correct ?
First try bleeding the cooling system. This may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
dont jump ahead and start thinking your headgasket is blown, first change out that fan switch which could and most likley is the problem, if your still paranoid on the headgasket thing just keep an eye out on ur oil. most common symtom is milky oil. if anything u can do a compression test as well
one way to test the fan is just take off the fan plug and just ground it out with a paper clip and if it turns on then boom its good and if it doesnt its bad im sorry its this is too vague, its hard to describe in words then doing it in real life
adamrich33
04-02-2012 04:00 PM
