View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Honestly now.....(question regarding suspension setup)
- Mini me swap question
- 00 SI Sway rear sway bar on EG/ITR LCA?
- Need advice. b18c1 block was measured, exceeds service limits, have a few ?
- PAINTJOBS
- D15B7 LX going to D16Z6 engine, quick questions
- CEL Code 43 ??? What could be wrong?
- 96 civic hatch questions
- how to install stock tape player
- eg door hinges??
- 99 auto with boost ecu swapping / tunning
- Hi-Beam light on when high beams aren't?
- car go bye bye, pics of me civic hb*
- has any one ever painted there chrome mufflers??
- Del Sol Engine Swap
- Any info on how to install ek seat brackets/sliders to universal seat rails??
- help me out, want to bore out B18C1
- just bought some rotas what do you think ?
- aluminum wing
- pinch weld in wheel well.....
- My new Skunk2 Products!!!
- b16a2 header= b18c1 header
- brake pad "clips"
- will i loose hp if I...........
- Civic Radio Install Help!!
- Squeek noise...
- exhaust removal for front swaybar install??
- New Seats for my EG
- uh oh... attack of the unidentifiable noises!
- Tire Size Decision... with some dimensions
- :: where did everyone mount their vafc's ::
- Rough Idle...only when a/c turned on...
- Swaps in San Diego.
- doing a B16 swa in to an EK
- Quick question
- what causes this to happen???
- Wiring pic's of the Wires for B18C into my VX EG!!
- can so one get check this VIN
- heat shield rattle. can i take it off?
- Malfunction Light(kinda long post)
- Threw a cylnder sensor code...(#9)..please help
- help me decide!! b20/d16turbo/???
- OBD 1 Distributor needed
- exhaust questions
- which exedy clutch
- 1st gen VAFC? WTF?
- Brake trouble
- short shifter?
- This is what I like to see... More community involvement to get the racers off the street...
- problems after misshift/over rev
- has anyone seena a 92-95 civic w/ h22a turbo and ac?
- motor mounts for b18c gsr swap
- i need pics please.............
- Skunk 2 spring ?... what goes where?
- ok new clutch or tranny???
- who here has a late 90s HX civvy?
- Mini-me, finally on and running, need help with a few kinks
- ACT Clutch, makes funny noise. If you got one answer!
- how much for my car you think?
- d15z1 w/ d16z6 head
- del sol videos?
- Can I reuse my stock gasket between the Header and the mainfold?
- someone please help with h22a ac on civic.....
- Eagle Rods and JE pistons?
- Hit a bump very hard and the car shut off.
- head swap question
- ABS help!!???
- Help replaced the bolts that go up to spark plug!!!!
- 1.8 dohc vtec 2
- turbo or all motor
- right hand drive conversion!!
- Poor gas mileage...
- swaps
- Koni Yellow ?
- JDM GSR into EG instructions
- Question about control arms
- broken regulator in window
- please help
- 1/4 mile Times
- Where to mount Apexi vafc in Del Sol?
- Big Brakes upgrade for 92-95 civics with 9.5" oem brakes?
- Apex V-afc etc tach question
- Valve train noise on Honda Accord 1.8i Non Vtec
- mini me, d15b7 block with z6 head.. plz help me with wiring
- Connecting a/c in EK
- JDM GSR & B.A.R. in the same post??
- FYI: EK's wanting to run an ITR rear sway - FS: Beaks kit & end links
- hood pin alternatives...
- apexi vs akimoto {ram air intake}
- can someone tell me how to bleed slave cylinder? a short how-to?
- Changed my fuel filter and car wont start?!?
- Looking for a pick of 92-95 lips
- ATTN: ALL 99-00 hatches with b20 and A/C... help please.
- Ek Hatchback struts QUESTION..
- ITR swap in EG....members sign in!
- d16y8 fast idle + poor throttle ?
- Custom gauge panels?? Custom electronics panels!!! Look, Look!!!!!
- Anyone with a auto 97 civic ex?
- Pics of my Car
- CRX shock 1.5 inchs shorter than Civic shock?
- tires?
- Anyone know where i can buy a GSR/ITR block, NEW????
- help me install a rich/lean gauge in a CX
- AC Compressor
- Alignment.....
- Quaife fast raito steering rack update...
- Looking for race motor to buy?
- odometer stopped working...
- Tokiko Illumnas and Skunk 2 adjustables
- convert gsr to manual steering
- Code 67-1???Help...
- What size MOMO steering wheel???
- Cylinder 4 MISFIRE?? Mini-me
- b18c1 block with b16 head VS b18c1 block with b18c1 head
- Honda's Smallest Steering Wheel
- exhaust question
- Mini-me swap lets break it down.
- 94 civic si question?
- Question about cat fitment with my car
- What do you guys think of these headers!!
- ITR spring rate... best way to have it?
- Power window problems
- Permanently Engaged Clutch
- Repinning obd2 ditributor to obd1..(b18c1 into crx)
- High flow Convertor or not? - pros? cons? recommendations?
- Can anyone help with a y8 intake manifold on a b7 head? I need help with sensors.
- 99dx w/b18c5: need to remove the tranny...what's the min # of parts to remove?
- I want to know.....
- Anyone with a 99-00 motor in a 96-98 chassis....please read and reply
- ODB
- Bad Alternator?
- NEED HELP ASAP! Shift linkage question.. DEL SOL!
- itr intake in an eg?
- track pics..
- b16 vs b18
- EG Sloppy steering, unresponsive why ? ...
- Clutch install tips, tricks and headaches
- eg for sale or trade
- civic EG
- injectors? is there a difference?
- Best lip for a sol
- What oil should I use on a D16Z6 in summer??
- EK with JDM ITR front end
- Just won this D16Z6 head off of EBAY... what you guys think...
- Radiator fan won't run on '95 Civic
- $550 for GSR block or $500 for b16a block???
- HKS exhaust on a EK sedan,is a 120mm tip too big
- Body Shops in Bay Area (east bay)
- DAmn Hot out GSr ac lines Fit in eg???
- '98 d16y7 into a 5th gen coupe
- when does vtec engage 94 d16z6?
- gas gauge doesn't work
- Cam Gears
- how do you program a keyless entry remote?
- First gen b16 cutting off on me??? why...help a good b16
- Carbon Fiber Hood 1999 Civic
- starters: which will fit a 98 civic dx automatic?
- appraisal?
- HELP RYANE Motorsports lowering Steering Knuckle !!!!!
- Any running a aftermarket cam in their D16 (SOHC CAM)
- when at the track do you........
- How to wire horn for Ek JDM Non-SRS steering wheel
- Honda Accessories Side Skirts: How are they different from OEM?
- JDM Engines comes w. goodies?
- B18b into hatch
- Honda part number for CTR N1 crank pulley?
- B18c into eg problems...need help asap!!
- Considering...
- Auto to 5 speed swap completed!! Do's and Don'ts! 56K go do an oil change and come back ....... seri
- prelude shift linkage help needed!
- Fuel Pump Cut Off, Stop your car from getting STOLEN in about 5 Mins
- exhaust q(swap related)...
- my daily driver
- radiator caps
- There is some hope out there...
- NEED Del Sol Gas Tank ASAP PLEASE HELP
- Group Buys
- FYI ---> JDM Power Folding Mirrors
- my hb
- Question about Superchanger kits
- d16z6 pulley marks. need to know wich 1 is wich..
- Question on Replica mugen/type R ABS front and rear lips
- Valve adjustment...
- CTR exhaust?
- Fun with oil! and lights!
- Exhaust question
- Center Caps and such
- SI Wheels
- where is cruise module located at?
- ELD Malfunction?
- roll a Posche...
- '99 cd player fit in a '96 ????
- CTR Gauges in EK9 DX
- newbie needs input!!!
- weight of del sol seat
- anyone else's rear defrost not work for shit?
- ls/vtec with b20 sleeves
- How much are the a/c vents in a honda delsol
- Code 9999999. Error unknown???
- converting R12 to R134
- Prop valve install 99 EX
- B20 Swap
- quick question about a b16 swap
- suspension tech springs w/ tokico illuminas
- How much does a window cost?
- how do i gt off a smoke finish???
- Removing door panels...
- transmission question
- Tein Basic Coilovers
- Is the 96-00 DX Bottom End The Same As The 96-00 EX Bottom End
- dynomax exhaust?
- my motor is running lean
- Suggestions for exhaust on hatchback
- Headlight problem..need answer fast.
- GSR shifter in a civic?
- my eg's debut...
- Carbing 3pt. bar in Canadian SiR
- Weatherstripping???
- Radiators in 96+ coupe...
- Have an EK, what car can I use the HID lighting sys.
- muffler too loud
- 92 teg intermediate axle into a B16a2..
- D16y8 with p2e?
- gsr mounts
- Engine Restorer
- ctr and itr interior peices.....fit into an EK??
- ac compressor question !!! need help with swap and want to keep my ac
- 93 Civic Si without ABS which AEM big brake kit?
- 99 Ek Coupe w/Rota RnR's????
- quick question
- attempting the impossible:......s2k into ej
- used coilovers
- mounts
- I am throwing a code 16 and code 43....please help!!
- I have an EG, w/ an H22 what kind of bracket for A/C
- whats a good allmotor cam for my set-up (z6)
- turbo kit for a 99 dx hatch?
- Anyone know where i can find KENJI?
- what motor oil do you use? (10w30, 5w30, etc)
- car is throwing a code. need help
- Odd outcome of a race... question for my friend
- HELP!HELP!HELP! Can anybody tell me how to install the Mugen front lip! please...
- stripped a bolt
- Color codes... need some.
- Can anyone tell me the measurements for a jdm EG sidemarkers?
- h22 turbo or b18b turbo
- B18-C1 TDC Sensor cost / difficulty
- Looking To Buy Mirrors???
- gas smell
- 2.5vs.2.25 exhaust
