View Full Version : Honda Civic / Del Sol (1992 - 2000)
- which Exhaust on my car is better?
- painting my hood and trunk black
- Compatible windshields EG2
- B20 swap into my 98 civic!
- Help Crack the Case, 99 Civic, No CEL, No Fuel, No Spark
- ITR swap into EJ6
- Brake Noise & Out Of Ideas!
- the new ej6 fotos :)
- power steering pressure?
- Help!
- tips on fixing random rattling in cabin
- Fuel light not coming on, 95 del sol d16z6
- swaped two engines and they will no start!!!!!why not!!!
- What's the extra hole for on the '94 Teg ABS Master Cylinder?
- Tranny oil on the clutch. damit.
- h2b feedback
- what is the name of these lips on this ek?
- P73 iacv help!!!
- Question about a B16 tranny??
- I need an SRS / horn cable ? Help me out
- Anybody using the pulstar pulseplugs?
- Low voltage in '99 Civic
- Integra Coupe Seats Into EG Sedan...
- Will EK9 Shocks and springs fit?
- Year the block was manufacured
- ls vtec overheating
- Still getting 12-16mpg w/ b16a2 swap, looking for some advice what to do next
- D15B into 97 EK... What engine harness?
- questions about replacing all front bushings on an eg
- porblem with civic door wiring
- whats a good racing seat....?
- 1994 civic hatchback
- Automatic shift boot..
- Built GSR head on LS block?
- crx rear disc brakes
- Check Engine Light Going Off
- nitrous install
- code 17 - vss problem
- need help finding thread/website
- CEL code: O2S (HO2S) S1 Voltage High
- timing
- crank pulley acting up**HELP**
- Will an Integra Type R oem Axle-Back exhaust fit on to Civic?
- integra type-r spoiler
- D15b7 PROBLEMS!! NEED HELP ASAP!!
- po8 giving auto cel codes
- Dimmer switch on Ebay
- Carbing 3-point front strut bar with master cylinder brace
- D15B Head Code. Is This JDM?
- Fitting a D-series Exhaust on an LS swap
- what exhaust for my 97 ex coupe with gsr swap ?
- P75 or PR4 ECU???
- Tranny Question
- engine block number?
- B16B iacv replacement
- Swap B18b1 in 99 civic sensors question
- h22 swap possible axle issue
- vtec or not
- You can search all craigslist cities at one time - great for parts
- exhaust manifold quick question
- 1993 Del Sol Quarter Panels
- Help my eg wont start
- Engine tick/tap/knock only during idle in 2000 D16Y8
- b16a2 clutch and LW flywheel info,help on choosing the brand
- how do you remove paint from a side skirt?
- b16a2 97 civic hb swap help!?!?!?
- D15 plug gap question
- Axle Issues. Need Some HELP!
- D15B2 in 1993 Hatch
- starter problem
- Problem With My 92 Si Hatchback
- Car not turning over
- Code 7 TPS--car runs great, though
- EG seats need help PLEASEEEEEE
- Stripped crank pulley bolt
- swapped out da6y8 for y7
- Heater won't blow
- D15b spuddering
- '94-01 Integra v. '99-00 Civic SI Control Arms for Sway Bar Install?
- 92-95 civic dashboard HELP!
- skipping from drum brakes ?
- Vtec Solenoid Question
- head gaskets?
- 2000 Civic EX brake rotors size??!
- eg/ek/del sol pic thread?
- Manual steering rack
- Removing Ignition Lock Cylinder
- del sol/civic shift linkages- are they different?
- can i plug this?
- Need opinion on build
- white smoke
- E85 Safe or Not Safe?
- help with Lighting situation
- jdm DC sir-g cluster
- 00 EM1 Civic MOMO hub question
- requesting help !!!! spoiler issue !!!
- safe mode
- New Around Here
- anyone know why my car sits uneven?
- ek 1996 hatch speaker problems?!
- EK Sedan A-Pillar Pod
- 171 code
- timing woe's
- HOW TO: Install New Lost Motion Assemblies in a Vtec head (LMA)
- car bogs when vtec HELP!!!
- Starting Problems / 93 Del Sol SI HELP!!
- obd2 special edition into ej1
- where is the drl module in 92 lx
- ls vtec serious coolant leak help please
- Head problems/questions on a 99' SI
- my first honda
- Ferio rear wiper wiring?!
- Si cluster too dim...tried searching
- ignition switch and push start help please
- help 96 ek hatch speedometer issue
- engine swap
- what mods next
- S2K seats
- no thermostat?
- New civic hatchback PROBLEM with shaking.
- delete
- Honda B series Nut & Bolt Spec's or Part #'s
- b18a1 build question
- help A/C
- 99-00 Si Cluster Issues
- D and B motor mounts
- Painting a d16 valve cover
- z6/y8 conversion..wont go over 3.5k rpm
- 95 civic with b17 gsr boging down?
- ls/vtec on stock p28?
- B16 Del Sol. Need help.
- Radio and clock stopped working?
- CEL stays on & isnt throwing a code
- gsr swap on a ek
- removing back seats- help
- OBD2 to obd1 distributor adaptor...
- Turbo PSI q's
- 93 cx with 94 ex and need to get CA/OC smog
- Emission Specs
- Help:car wont start after testing battery!
- D15B Engine w/Block-Off Plate: Stock or Swapped?
- A/C doesn't work when weather is hot
- california state reff, what should i do?
- please help! im sitting in my car waiting for any response
- rear lights problems
- no tail lights, dash lights, or cluster lights help please
- wtf sounds like running on 3 cylinders
- 92-95 b16a swap ?
- Obd2 ek gsr swap
- Civic problems part 2: Tach all over the place.
- can I? obd1 coil in obd2 distributor
- distributor rotor screw???
- new horn
- NEED HELP will a 99 civic si pass smog if...
- oem vs replica. how to tell?
- Catco catalytic converter question
- Still no working Vtec in my Civic
- A/C not working need help!!!!
- whats the easiest way to change alternator?
- D15z1 vtec-e into 1996 civic ek ?? Help wiring ??
- d15b8 timing issues.Need help
- gas guzzeler need help plz
- Bad PCV Valve...??
- new ctr lip
- B16A CEL code 20 (ELD) + speedometer not working
- 96 civic wiring
- Somking issues
- Is the 0bd2a and 0bd2b EK Dash harnesses the same?
- power steering question
- 92 eg wont start
- Ignition Switch
- Hasport rear mount in EG
- hx help
- iacv wiring
- suspention problem....
- radiator fan not kicking on...troubleshooted and...
- trouble with eg
- 96 Civic mini me swap
- b20 swap cluster??
- butchered flywheel bolt thread
- Help: Retaining air conditioning swapping a B-series into my 2000 EX.
- I changed HEAD GASKET, i think im still getting preasure ?
- obd0 or obd1 ecu
- what u know about this
- spark plug ?'s
- did my transmission go?
- need p/s help, any feedback at all
- What would be a better camshaft?
- Torque Mounts
- 23mm itr rear sway bar
- running rich looking for ideas.
- Headlight fitting
- E-brake problem
- yakima roof rack
- My 92-95 Civic EG/EJ "one off" speedo gauge cluster.......tell me what you think
- AEM Big Rotor Kit?
- K24a????
- sir vs 00 ctr
- b20 swap in a eg and ek cx modles
- jdm cluster problems
- b20 injectors
- Can i put a manual engine into automatic car?
- CTR center console delete 99-00
- rear quarter rubbing my tire.
- WOT BOX 2-step
- clutch from d15 to d16? cable or hydro?
- Fuel Pumps
- B16A Question
- what ALL do i need to intstall a rear sway bar?
- No Speedo or temp
- swapped y7 into ex, idle issue and bogging
- So...Coolant Temp Sensor (Not Sender)
- Knock Sensor
- Electrical Problem
- Crankshaft interchange?
- GSR with B16 cams?
- Armrest in 97 dx civic
- Rain drips onto driver's feet - '93 DX 4dr
- erratic idle
- HELP: drivability issue!
- Radiator Top Seal Leaking When I engage gas
- need help with compression ratio
- J-Series ?
- C/E Light Code #86
- ek auto tranny experts needed
- Civic Type R Fuel Pump question
- i need d16z6 help badly please someone
- Changed some parts on turbo d15b runs bad and stalls??help??
- Crank Pulley Bolt
- CEL for a faulty A/F sensor 1. (wtf is that)
- SRS question
- B20B Bogging!
- smog question
- ECU went up in smoke
- What Torque Wrench...??
- lookin for moulding at bottom of windows...92-95 hatch
- Explain Suspension mods?
- Cant find msd install...searched! help!
- 99 si rear sway on 96 dx.. quick question.
- VTEC solenoid gasket changover
- Another one,STOLEN,2000 Honda Civic Ex
- Car Temp isn't Working.
- Lip fitment: 96-98 rear OEM lip on 99-00?
- ITR seats in eg coupe...DB8? DC2?
- Removing EK steering column
- Need Opinions With My EK Project
- Cleaning Engine Question...
- 1992 eg6
- need wiring help please
