View Full Version : Honda Civic / Del Sol (1992 - 2000)
- b18c
- GSR ROD BEARING
- Modified Exhaust Violation - Spoon N1 w/ silencer - is it less than 95db???
- when buying the manifold/cat all in one oem used....
- Torgue full coilover kit???
- Boost?
- 1995 Civic Hatch w/ aftermarket cup holder question...
- How To: Install A/C air conditioning in a 92-95 Civic
- guage cluster questions. please help
- a/c question
- what is that bar called that goes across the back window in eg hatches?
- A/C question 1994 civic dx coupe please dont overlook thanks
- top radiator hose hot
- 97 del sol O2 code and FITV bad!! HELP PLEASE LOOK
- b series vtec sylonoids
- b18c1 into 96-00 civic
- A/C Compressor Not Engaging on 94 EG Hatch
- MAP sensor
- Need help: How to change my bezel on the cluster
- tired searching. Battery relocation help..
- Compression issue, help NEEDED >.<
- eg6 jdm boot
- cracked radiator
- D16 low compresion parts
- Should i sell it or no?
- Help from a Moderator?
- 96ek need help please!!!!!!!!!! obd2 to obd1
- rc 550's fitment
- civic eg cooling systen please help fast
- boost opinions
- Coolant Temp Sensor Question
- my new project (Del Slow )
- Quick question. 96-98 lip on 99-00 civic. Will it work
- Wheel Problem...
- Transmission Seating Problems
- EJ8 And Dent Repair
- B series and Torque mounts. Do i need em?
- halfshaft keeps sliding out and idk why...
- 97 Del Sol code 41...Again
- air in brake lines....
- Need help with buying a delsol...
- Need some help here
- how to convert a p28 ecu auto, to a manual tranny ecu
- car dies if i dont step on the gas
- eg stock engine harness or gsr
- tranny starting to grind in 3rd
- eg h22 turbo
- This car is giving me hell...
- Header issue...
- Stumped: Changed timing belt, now doesn't run.
- **NEED TPS HELP** TPS always reading 26%
- What TB should i get?
- header suggestions
- Help me diagnose this.
- rod bearing question help
- D16Z6 rebuild question!!! Need help asap please!!!
- BackYard Special EK Rear Bumper?
- Cost of dent removal. Opinions needed!!
- VTEC/ sensors?
- Ebay Carbon Kevlar/Silver hoods
- Using ABS master cylinder w/o ABS...
- Brake booster hose
- skunk2
- rubbing issue
- Newbie to Honda's
- adding cruise control Q's
- del sol headlight adjustment tool ???????????? what is it ?
- CARBON FIBER HOOD?!!!
- H22A 2 Step.
- didnt want to resort to this but....
- what motor is this
- Del sol leg room
- Need help..tranny or clutch???
- Civic eg with dr20
- whats the name of these headlights?
- EK Vs. EG LCA's
- Please Help(Check engine light)
- Hmotorsonline leakdown test results need advice.
- honda eg vtec-e
- What catback will fit ek hatch?
- 215/45 r17 tires rubbing
- Tranny experts, help please. (d-series)
- where did you get your 15/16's 91 ex 4 dr master cylinder?
- head gasket problem
- wanna buy an ex
- EG Catalytic Converter Length
- civic swap
- replacement bulb?
- Tac Speedo Gas Temp Clock and Turn signals doesnt work
- How much to ask???
- Door lock "C" clip
- torque specs?
- interior wiring problem
- Need Help Identifying Errors
- Question for moderator.
- black box in 96-00 civic
- Question regarding seatbelt interchangability
- sunroof dont work
- obd0 A/C compressor fit a 0bd1 Bseries?
- JDM cluster help, what is it??
- vtec????
- Seatbelt harness bar, part of roll cage for del Sol
- DEL SOL engine, when was the twincam introduced in a del sol ?
- I need Help from a Moderator
- what happened to ej1 owners club
- leaking headgasket
- I need to check resistance on all my TPS wires. Need diagram.
- Need help With my EH!
- how much are GSR BLADES worth??
- Ek driver's door cannot be locked from inside by pushing in switch?
- JDM one piece del sol headlights from Ebay.
- help me decide wich is the best Spring/struts setup for 92 hatch (my budget 650)
- 1993 Del Sol SI front brake rotor/caliper fitment question.
- kind of dumb q but oh well......
- power window help
- Axle Question
- Where to get power for power window wiring
- Harness question..........
- Update to Vafc hack,
- better gas milege
- Noob question
- Midori dx EK for 94 del sol si
- EK throttle cable bracket / direction
- Defroster Question.
- Factory Sunroof install question
- Disable immobiliser ?
- CEL Code 9 with CKF Bypass Trick
- building a mini-me
- Need to find out what type of halftshaft to use on the right side of h22a swap in eg hatch asap?
- MY FIRST BUILD!!!
- CEL Issue Random
- mini me swap question?
- Need Alternator: Which one?
- rotted brake line
- heater hose
- OEM cd changer with aftermarket head unit
- Can anyone tell me if these are good?
- Civic save story
- stupid question.. help please
- engines?
- Cant start my 94 civic
- My lights turned off then turned back on while driving??
- transmission question
- Plastic gauage check need advice
- swap in h22 into ek now car throws (no rpm signal) and runs like sh$$
- b16 header fit a gsr
- car jacked
- When replacing your oil pan gasket Do you guys use silicon
- just seeing what you think
- machine shop with milling machine
- Ek9 Steering wheel hub problem
- lowering
- got a CEL
- car dies when cold
- HOW DO I TAKE THE SHIFT LICKAGE OFF THE TRANNY???SOHC
- Really weird blinker/hazzard problem
- y7/y8 mini me manifold help????? bad idle!!!!!
- Bottom fuel filter line nut stripped
- does an EM2 steering wheel fit on an EK?searched... nothing found
- Need help with engine swap lads.....lsi to SiR
- bring a civic back to stock height
- How do I install a car alarm?
- 92 Civic Overheating
- Radio Codes?
- I need Help!!!
- 96-98 b series dizzy?
- d15b8 with an Si/EX tranny
- hi im a boob.. opps i ment noob
- i need to no
- 4DR FRONT END CONVERSION
- pressure on civic stock injectors help
- Vafc hack?
- Integra Type R Wheels - Tires (15'' wheels)
- CARBON FIBER HOODS!!!
- Aftermarket steering wheel = SRS light for life?
- Bumper fitment 93 civic hatch
- are eg sohc and ek soch rear tranny L-brackrts the same?
- HELP!!!!!!!!!!!!!
- Removing ctr headlight clear lense???????please help
- batterey light ?
- H22 Del Sol radiator Help
- exhaust header swap
- Please Help!! Rear Caliper Replacement...99 EM1
- Help With 93 Civic Ex. Clutch Not Working. Goes all the way to floor, stuck in first gear.
- Towing options for my EG CX Hatch (stock 8v D15)?
- ATTN: ej1times
- Halo Projectors!!
- stock muffler.
- Finally fixed the water leak on my drivers side!!!!
- Dumb Q (Resistor Box)
- Installed Blox front camber kit... now I get a grinding noise? (EM1)
- 1990 crx wanting to swap
- The difference between the del sols?
- What parts can I use to build up my D16Y7/8
- JDM D15B vs. USDM D15B rod
- Whats seat swaps are available for EG hatch?
- Compatibility Question - 99 Civic SI
- swap info?
- Need Help B16A2 Into My 92 CX Hatchback
- 99 front end conversion question...
- Master cylinder issue?
- will CSX type S steering wheel fit 2000 civic EM1?
- need advice on passing smog
- question about ref ticket $483
- holy shit, my brakes GSR brakes suck ass!
- idle problems
- where can i find parts online to order...and sohc vtec questions...
- DA front conversion help.....
- Civic EX to DX. Cluster Swap.....HELP Please!!!
- skunk 2 camber kits???????????
- Anyone have a list of factory dealer option's for 92-95 Civic's?? USDM OPTION'S
- side skirt help
- 2000 si CLuster problem
- Prior Rex owner,soon to be 2000 civic owner
- BBS WHEELS!
- Civic newb, few questions to be answered.
- Is reprogramming an OBD2 ECU possible?
- What ECU comes in the 94 civic ex ( d16z6)??
- motor, or turbo???
- 97 honda civic o2 sensor
- -=Squeaking noise from my clutch=-
- question about ctr suspension.
- my hatch keeps cutting out like its hitting fuel cut...
- WTF did I do wrong?
- Axle Nut correct size?
- B18c5 trany/ 92 hatchback
- Where do you guys buy your parts from?
- Car wont start without push start...
- Engine parts interchangeability within D-series-->Timing belts
- Strut help?
- ignition harness . . .
- need obd2 p72 pin out diagram *searched*
- Lost my password and had to create new account
- Hondata S200 question
- main rely
- What size slick will fit??? DEL SOL
- Wheel Hub Removal/Brake Splash Guard replacement
- '00 b18b Civic A/C hose problems
- Time for new motor
- cam gear question
- MOMO steering wheel/horn button question...
- 00 integra dash w/b18b1 and b16 cable trans swapped into 92 civic cx, which vss??
- installin a d15b into a 99 civic
- Trial status
- HELP! Want to swap GSR/w LSD tranny, in DX, non vtec auto coupe. Help!
- car jumps when i turn the wheel all the way!!!!!
- just installed hood dampers. VERY creaky....hard to close... ?
- Car start and dies!!!!!HELP
- DIY: 99-00 Climate Control Swap into 96-98 Civic *NEW* (lots of pics)
- HELP Water on drivers floor
