View Full Version : Honda Civic / Del Sol (1992 - 2000)
- D-16 tranny casing problem.
- radiator fan
- Need to find the right Donut Gasket for Yonaka motorsports ITR Header
- Sedan and coupe exhaust question.
- Which d15b?
- 1129 code on 2000 civic si
- are the pin outs on a p75 ECU the same for a SOHC p06 ecu?
- Is my brake F***** ?
- Noob
- z6 intake manifold on y7
- loss of pwer at 5500 rpm
- crashed!
- Is this better than a mini me swap
- Loss of power at5500
- will a p75 ecu work with a stock 92 dx with a 94 dx motor.
- Mugen Si not even safe on the lot...
- help with interior ek
- newby question about rear door-98 civic
- new
- trial user
- I need to know which computer my cars needs...
- 98 dx ecu
- Ek Basic Info "Cluster Light" help
- ***question***
- Sound
- Looking for photos and install advice for 4 point harnesses.
- Correct ECU - B20z swap?
- b18c teg r or a stock b20vtec
- EG EXHAUST ON EK/DC
- where can i get this.
- Engine swap
- PLEASE HELP!!
- 1999 Civic Dx vs. 1999 Civic Si (O2 Sensor Wiring Clash)
- Q: about 96-98 EK dash vents....
- exhaust/no front license plate citationn ISSUE PLEASE HELP
- Engine won't start!!!
- Can someone gimme a picture of their coolant lines on their DX/LX/SI Intake manifold?
- Shifter Linkage
- Go Boost Or Go Home!
- RSR exhaust
- Faster Power Steering Rack Ratio For a 99 Hatch
- NEED HELP: Mounting Volk Racing Group C onto 93-95 civic coupe
- B18 Swap?
- IACV cleaned, idle dropped??
- New to HT!
- 96 dx hatch, tail light fuse keeps blowing
- Bad vibration coming from left front??
- No More Cruising 4 me
- eg samco hoses, will they fit an ek with a b16 swap???
- In Progress: GSR steering rack into a Del Sol S
- Lambo Door Kits And Air Ride Kits
- please answer me
- distributor question
- D16y8 Engine Manual NEED!!!
- Laggy and check engine light...
- Mini me swap
- Exhaust on EK 2dr & hatch.............
- Help with wire harness for DEPO fog lights
- idle problem
- 1994 honda del sol axle removal
- belt noise while parking....??
- Help me find my horn relay and rear defroster relay, 94 DX Sedan...
- vacuum for b16
- help me please!!!!
- bouncy idle
- kseries owners help any info will be appreciated!!!!!!
- Questions about Civic SI
- 205 on a 7" wheel?????? will it work? pixs?
- what motors have a balance shaft?
- CTR Trans Vs. ITR Trans
- Question on RHD laws in CA.
- ECU QUESTION!!!
- b18c VS. b18c1
- alright I searched and can't seem to figure this out......
- CLUSTER HELP
- My Eg will do nothing when the key is turned over! WTF
- wire
- serious question..
- does ne1 now what will interchange from 92-95 to 96-00
- just pick up a 2000 civic si...project
- FS: 4 rota group-N/AZENIS ny $525 pick up !NEW!
- need help on Type R swap..
- Transmission Swap
- quik question that i havent found insearch yet !
- d16y5 vtec-e head on d15b7? which ecu??
- JDM meet @ Ranch Market
- Tranny Problem
- brake system question??
- b16a
- jdm b16a swap question
- 96-00 civic front shocks fit on a 97 dc?
- need help on camshaft set up for my b16a 2nd gen
- B16 Vs D16
- For those of you running no fender splashes
- B16 LSD Cable Tranny - Which clutch disk?
- e85 conversion with a b18 and boost
- mugen exhaust 95 ex civic coupe GSR Swap?
- where is the fuel pump relay located 92-95 civics??
- my buddys car is running like total $H!T help!
- cams
- rear disc brake conversion
- help Plz!! need to know engine type.
- More power without a swap
- wolf's head
- I want to learn...
- any ideas?????
- Hey guys, a little help PLZ! :)
- help
- B16B swap info, HELP PLLEASE!!!
- Help with Diagnosis?
- 94 integra exhaust in an eg coupe
- Pictures and a Video of my y7 to y8 conversion...need feedback!
- Help Overheating!
- Rmp gauge/engine "yaws" at idle...god help me
- Big Problem, Need help
- help knock sensor
- cam questions?
- OBD2 Harness in EG?
- What are the best cams for d16y8 without changing valve springs???
- 92dx ls swap problem
- my muffler finally arrived...REVIEWS???
- plz help slippage on new clutch
- trick to getting out pcv valve
- Installing JDM EG6 white face cluster
- what centercaps can fit 15" rota gt3/drag dr16?
- cel 41 question
- p30 ecu
- flooding rain gets into car, ecu ruined?
- mugen spark plug cover for B
- Spoon mirrors power?
- Itb's
- 96 DX question
- Any interest in a D15B8 Mini Me VTEC conversion write up?
- Post Pics of a/c hooked up on a b-series block
- Best cams for 2000 si, without valvesprings or retainers upgrade??
- EG hatchie on s2000 16's/ RSX-s 17'' OEM WHEELS< WHAT CHA THINK ????????
- Front end damage. Question?
- NEED HELP
- emission help
- Car cranks and sounds like it wants to start, but doesn't. help!
- oil jet on h22a?
- High CO2 Emissions Issues
- Where can I buy Honda OEM parts online?
- K24A2 OR K20Z1 FOR EK9
- Y8 head, Y7 block. quick question. (tried searching)
- aebs manifold stripped hole wwhtd?
- what do these pinouts do
- VSS = No Vtec right?
- Need Timing Belt Help, did search! -- this is a new one
- b16 Power Loss
- front lowercontrol arm
- B20 VTEC
- THe most important THIng??
- What should I do with my 98 Coupe
- Hatch Raer Wiper?
- New to HT, tell me what you think.
- Simple question about b18b1 into 96 civic
- Limited Slip in On D15
- compression for stock usdm b16
- newb questions
- b20 turbo?
- HMOTORSONLINE????
- B20 -> Del sol, clutch ecu ??
- My Ride
- Issues after a swap (B18B1 into 93 civic si hatch)
- ROOF molding/weather strip
- "story" funny noise but it sounds cool
- this car of mine
- new to H-T, heres what i got
- p07 ecu hurting me or not
- Problem with my heater on my EG
- New 2 honda Tech here iz a pic of my eg
- removing side skirts
- Help needed for power window conversion
- GSR seats
- question
- Question about side markers!
- Front tie bar
- cluster lights dim
- small NA build
- c pillar bar in a coupe?
- Are these the tweeter interior panels that i need?
- about the accord motor?
- Lug Nut
- Hey need help with foglights for a 97 couple
- Civic Won't Start Up
- when you step on the brakes the speedo goes like 100 something mph
- eg dash lights
- hey why was i "user auto ban" ed?... cant use IM's yet
- Skunk2 LCAs
- 2002 wrx
- cable transmission
- removal of A/C compressor!!!
- manual rack and pinon for 95 civic
- Help with Wiring. Gsr motor into an EG.
- 93 civic hatch noob question
- stolen
- K20Z1 Transmisson into Ek Civic
- engine swap
- What is the stock ride height on an EG Hatch?????
- oem gauge clusters?
- nj emissions
- 99 Honda Civic SI Problem
- car wont grab!!
- Ok answer me this one.......
- rack-n-pinion swap
- Valve tick
- Ahhh...!!!
- 93 hatch bumper/hood/fender question
- fan is not working
- balance shaft?
- Cyl. No. 2 Rich to Lean to Rich...
- Clutch seems like it has no return/pressure while letting up
- Trailing arm Bushing shot
- skunk2 Vs. performer x boosted D IM
- EK H22A Swap -- Questions
- DelSol seat in a EK
- please help with some questions! lol
- redline d16y7
- 92 civic w/jdm gsr poor performance under load/cold idle
- Help building z6 head
- b16a2 into 96 ex.....
- eg coin pocket
- Check engine light on when i change the transmission...
- CALLING ALL OWNERS OF SKUNK2 PRO-S 1 Piece Coilovers
- Car shuts off wtf?
- Motor mout insert question
- TPS woes.
- QUICK Question
- 99 hatch with h22 vibrations when turning right..
- Trouble install exhaust...
- What rings and bearing brands do you guys recommend?
- nitrous?
- confusion w/ chassis codes
- Quick Help! Engine Harness I.D. (EK Civic)
- Tool to install oil seals while engine is in the car...
- anyone know of a thread about pulling a tranny off?>
- b18b1 w/b16a tranny??
- honda type r question
- unfortunate full gsr swap into EG6 question
- Newbie Brake Replacement question...
- 94 dx engine swap
- putting coilovers on!
- Noob to the forum but not the game!
- need help installing h-brace!
- my story, new H-T user
- Help, Oil markings coming out of exhaust
- Wierd reverse whine noise... 00 Si
- Soft Rev Limit help
- Whoosh of Air When I Loosen My Gas Cap?
