View Full Version : Honda Civic / Del Sol (1992 - 2000)
- New Member 94 civic 1.5 l mil dtc 8 HELP
- thank you's for everyones help!
- Good switched power source?
- Problems getting ignition key out
- d16y8 i/h/e p28
- Exhaust setup help
- Cruise control not working
- B16a Fuel rail bolts for skunk 2 intake manifold
- My Bro's B16...
- P0113 Trouble code OBD2 Please Help
- ignition control module
- Intermittant A/C Operation
- B16b swap, keeping ac/ps which crank pulley?
- harmonic balance
- 99-00 Honda Civic Em1 Will Not Start !!!! (Halp)!!!!.
- Failed Smog Gross Polluter
- can cv axles cause my car not to move ?
- looking usdm climate control diagram
- b18b1 swap completed p28, misfire limp mode?? read codes?
- civic ek4 - B16a2 project - high flow cat questions
- 95 Civic SRS & C.E.L. constant flashing. Need help!!
- 1995 Honda Del sol 5 spd- Idle issue (yes I searched but it's a unique situation)
- Honda Del Sol 1994 b16a3 (chipped p28) throwing me a code 30 !?!?!?!?!?!?
- 96 ek, b18b1 swap, crv p.s bracket belt info
- fuel pump issues. please help
- No Power Issue
- New engine needed for 1999 sedan. Rebuilt?
- Speedometer and reverse lights not working.
- H22 Low RPM Misfire When Warm
- 97 civic dx flooding no start
- honda pedal stucking
- No start Problem d16y7
- Another secondary o2 sensor motor swap problem...
- Radiator support bent upward.
- need help fixing the body
- Passenger side door stuck.
- B16B Crank behind Cam TDC after timing belt replacement
- B20 EG8 new distributor no spark.
- D16y8 headgasket replacement
- 2000 Honda Civic si problems
- 99 spec b18c engine,
- 1999 civic ex failed smog running too lean
- No engage in my transmission 94 honda civic
- Half shaft issue
- 99 EK Civic Window Trim Help
- auto trans will not shift into 4th gear
- Curious.. what kind of lip is this..
- What is this/how to?
- Running rich at idle, low idle.
- Help!! I cant fit my cv axle into my hub.
- 94 DEL SOL ,WHEN WET/RAIN SOLID CEL WONT START FOR 30 MINTS
- Car won’t stay on
- Simple battery question!
- 99 civic
- 99 civic si help.
- Ringing sound at a certain rpm
- p28 ecu questions.
- transmissions
- F20B Axles?
- non y-tec d16y7 with a v-tec head d16y8
- What could be draining my battery civic 93?
- Honda civic 97
- How do I set timing after head swap?
- 92 Civic SI won't start after wire tucked
- Premature wear on piston rings
- All 5v references on 2000 Civic LX?
- Tachometer not reading correctly
- 3 wire IACV
- EJ1 Restoration/Resto-modification?
- 1993 Civic No crank, but will occasionally start
- Cover for front passenger side blinker
- D16y7 buring serious oil
- A/C pressure switch
- Just bought a 95 Del Sol, mpg not good?
- no injector pulse
- Manual swapped 97 ek won't crank!
- b18b1 into 96 civic iac wiring
- Rough Idle (Did my research...still no luck)
- FUEL PUMP WORKS WHEN IT WANTS TO!!!
- Need recommendations on a 2100+ cfm 14” fan
- Head Studs
- no crank no start
- Ignition Issues?
- Y7 y8 swap
- DIY: RSX steering wheel into 96-00 Civic
- 1996 1.4i honda civic
- Coolant Leak d16y7
- Clutch/ flywheel setup
- Looking for a full build
- Brake line flaring kit recommendations
- B series swap power steering hose id
- RPM METER SHOOTING UP?
- How to replace head 2000 Civic?
- Difference between 96-98 & 99-00 civic floor harness
- 1999 CX Grinding Noise Help Needed
- Got some transmission questions
- Del Sol Fuse Box Label (Downloadable)
- ABS delete need help!
- About P2J-5 different Vtec-E?
- Advice on wheels
- What do I NEED to turbo?
- D15B7 WITH PR-4 INTAKE
- 1994 HONDA CIVIC EX D15B7 engine
- 94 Civic Hatchback front bumper to Sedan Swap help.
- Can't find a stereo mount for 95 del sol anyone?
- cooling fan problem
- Fuel meter shows full
- GSR & SI Exhaust Manifold Heat Shield Compatibility
- Del sol logo on dash
- B18C5 Swap Issues
- Iat issues
- FSM does not detail replacing front fenders or front splash shield
- Idle issues
- 17 inch rims will they fit on 2000 civic
- Flooded Engine?
- Need help
- Preventive maintenance tips
- Brake, turn signal and flasher on L/H side only inop
- Boosted stock internal d16z6 will it handle 220hp?
- Stuttering/surging help ... goes away with acceleration
- 2000 Civic Sedan LX broken wires in passenger door jambs
- Removed transmission questions.
- Y7 to Y8 Intake mani swap.
- GSR to EK swap...some questions
- Engine mounts
- 97 Ls no start.
- New Jersey inspection sticker
- started my b series swap this weekend. need a little help
- A little help plz, thank u
- My em1 build thread
- 95 and 98 civic front subframe compatibility
- 95 del sol dohc need air conditioning badly
- no spark
- I’m stuck
- running lean ?
- Recommended exhaust that doesn’t drone too much
- Head gasket help
- Are there any good engine rebuild kits?
- Crankshaft key
- Ej1 manual swap help
- Vibrant Muffler too loud?
- Civic JDM D15 engine distributor rotation firing order
- JDM ITR / Mugen EK4 Header Fitment on Stock 99-2000 Si
- air filter box
- How to hook up sway bars to hardrace front Tubular control arms
- 97 D16y7 into 99 Civic Ex Wiring Questions Please Help
- B16 ex swap please help
- 95 Civic Ecu Reset Mpg
- 92 civic with D15B7 engine won't start... Please Help.
- Removing axle without popping lbj
- k24a swap??
- EM1 rear suspension setup
- need help finding engine for 95 cx hatch
- WHAT AXLE B16 Del Sol Swap? TROUBLE
- wink mirror vibration
- 1992 Civic VX Hatchback Build (Thread)
- GSR head exhaust valve springs with inner intake springs inserted
- Automatic delsol body harness in manual civic
- Just a really quick question about my engine harness
- NO START...BUMP START?
- EJ6 Front Lip Spoiler options
- B15z1 block w/ b16z6 head
- OBDI or OBDII
- Another EG VS EK thread
- Windshield Seals Replacement
- CEL P0505
- What sun visors fit 2000 civic sedan?
- HELPPPP!!! 95 civic EX no spark
- HELP MY CIVIC WONT CRANK OR START
- After head gasket swap car wont idle
- Adding a knock sensor on z6 block
- no crank but i can jump the starter solenoid and it fires right up
- ECU - ECM - 37820-P28 -modulo de injeção, modelos - diferenças
- Help! Fender Problem
- Help with my fender fitting
- Miikka85´s Civic EJ1.
- Why is this info so hard to find? (B16 C131 pinout)
- Pressure in cooling system
- Do i need rear camber adjuster, alignment ok?
- No power headlights work
- 1995 Honda Civic LX gas gauge reading full after swap
- 1993 SI D16Z6 Idle HELP
- Eg coils in an ef
- 2000 civic weird issue
- EK 3 piece Front ends
- Del Sol Custom altezza taillight DIY write-up
- PLEASE HELP HONDA BOYS!!
- Wiring up fog lights on 96-98 civic with 99-00 front end conversion
- Sputtering and gauges spazzing at high rpm
- 1998 LX Crank No Fuel Pump
- b16 swap popping/running poorly
- D15z8 distributor
- D13B2 problem
- 99 EX 5 SPD Trans Rebuild Kit PN BK386WS
- Crank no start
- EK Tie Rod Lengths
- 95 Civic Intermittent Temp reading
- VMS steering wheels and hubs??
- 94 del sol swap.
- Is it the right MTF? EK 2000
- Issues with Idle in Warm Weather
- AC Electrical Problem 95 Civic EX
- Electrical connector identification?
- no start, no fuel
- Need help with swap
- valve job need help choosing new valves
- I'm out of things to look at
- Speedo not working
- 1996 Honda Civic turbo kit question
- Persistent Brake issue
- Driver Door Wiring Harness Connector Issues
- valve cover bolts
- Intermittent fast blinking turn signal
- F22 swap into ek
- car mssing
- B16a2 low afr at idle
- 97 Acura 1.6 EL - electrical issue?
- Is the d16z6 the original motor for a 93 eg hatch
- Transmission/Engine noise ID
- Obd2 port not communicating with scantool
- Front bumper screws
- What main relay do I need civic 2000 EK
- civic/Integra interchangeable parts
- Short Whistling Sound at Start up. 1996 Honda Civic EX
- New 5 lug swap questions
- 1998 civic b16a2 swap
- No spark on 2000 civic lx (1.6L)
- hello
- 1998 Dx Hatch Swap Help
- Issues with d16z6 Swapped 1997 EK
- S40 transmission question 2000 honda civic
- D16Z6 worth building?
- My Car stopped driving last week and we towed it home, after a whole day, It started
- Limp mode?
- oil in old ac compresser
- Where is voltage regulator located on Civic 92-93?
- Ignition Timing Change Not "Sticking" ('92 Civic VX)
- Harsh Ride Over Bumps and Holes
- Honda b16b starter help
- 98 Civic rear disc brake conversion
- 1999 dx sedan turbo?
- Code problems
- what engines bolt up to the s40 transmission
- 1998 Honda Civic ex fans not working
- B20 short block
- 1994 Honda Civic Dx Hatchback
- Brake Spongy, all new parts Bled proper, at a loss, help!
- Evap LEAK help
- 2000 Honda civic LX, crank no start.
- Help!! Identify This Plugs Location
