View Full Version : Honda Civic / Del Sol (1992 - 2000)
- distributor ?
- jdm or usdm motors
- finally fixed the original problem.!!!!!
- jdm b18c5 axle question
- I need a wiring diagram for a 97 Del Sol...
- engine bearings help!!!
- tokico coil over kit for ek???
- Thanks for all the help guys, but i must go now...
- VX b16 harness!!!
- Audio Console Accesories?
- stupid tires
- idle problem
- EG ex rotors bigger than cx? fit?
- Picture of Civic Si/EX 1993 Header
- will this work?? need answers bout swaping motor parts..
- Anyone?
- Greddy turbo serial numbers...
- SI Muffler on a 97 hatch
- 02 Sensor Simulator
- AEM V2 - Pros, Cons, and how APC saved the day
- IAC Valve question
- p72 ECU
- some dumb g-tech questions..but if u know anything, please help me out =D
- ls or h22
- Jay Smith?
- Lugnut tightness effect ride?
- removing Valve Cover. Just 4 bolts??
- clock colors? mine is white
- p28 pinouts the same as p30?
- Best Place to buy 92-95 Projectors
- speedo problem
- H22a Or H23a
- obd0 motor in 94 civic
- GSR seats in EG hatch..?
- Are there any street-legal/emissions-legal high flo cats out there?
- anyone know where to find skunks works sway bars?
- Weird occurence with a 93 hatch im about to buy
- Where can i find some good Motor Mounts?
- Alignment help
- Put in Aftermarket dual core from O'Reily's
- Car doesnt turn on sometimes.
- '92 civic SI shell w/ integra engine
- AC Compressor bracket question..
- TWM ITB's on ebay any racers interested
- roll call for meet in san diego 05-03
- Questions
- Will 16"x8" wheels fit on my 92 civic hatch?
- need help with ps pump install
- what parts should i use ??
- Intake for HX civic
- new rear sway bar
- EG Guage cluster, corners and tails are out. Need help
- Cat/ Idle Problem...
- How much do the 16 inch rota grids weigh?
- check up ...real dumb.. but i 4got
- Need help, bleeder broke off!!
- Intake for eg hatch w/b18c1???
- H22 in gen 5 hatchback?
- HEadlight problem!!!
- B16A vs. B18B
- whiich cam for a sohc mini me?
- concerns about micro relay method of wiring JDM mirrors.
- Pulsating Idle?
- Help! All Techs and Swap Installers! JDM vs USDM Wiring Harness!
- theieves try to steal my ek.
- ITR sway bars do they fit EK ???
- what is an oil catch can and what is its purpose?
- Pics of Bronze Volk TE-37's on Milano Red EG?
- my car wont pass smog..
- Problem w/ GSR in EG Hatch (ECU Probs)
- intake inatall and what filter to use
- Illumina Install *Help*
- cv joints bad
- Z10 Bar on Ebay!!!
- Supercharger or turbocharger?
- Civic Supercharger?
- header for d16y7 or.....
- time to change oil
- Intermadiate shaft Interchange
- steering wheel hub question
- Springs
- pivot shift light help
- help with oem style fog lights
- H22 VTEC - prelude.........
- changing oil pump
- new pads with new rotors?
- -=STOCK EG in Australia ! Help me tune ! =-
- Ticking on startup and from 3-4k until fully warmed up...?
- fresh out the paint booth
- burning oil
- Friends Clean EG got hit!
- Houdini CEL...
- Bought Rear Disc conversion, and having removal problem. Plz help.
- My Car got stolen WHY!!!!!!!
- cluster plastic face
- Yet another OBD2 Motor to OBD1
- Help... wodling noise...
- Alignment for 96-00 Civic w/ 5 lug conversion
- I HATE rear drums. Disks for EK Sedan?
- d15b vtec vs. d15b vtec-e?
- What car did the D16Y5 come out of.
- Question...
- What happened here to my KYB AGX?
- WTB: Stock civic parts - please dont delete
- Hawk performance brake pads?
- AUDIO - I need to know the sizes! QUICK HELP!
- putting pistons in yourself, how hard
- Question??? about 03'CTR wheeels.
- b18c5 swap OBD1 OBD2 question
- D-series owners that want to start junkyard turbo build....
- j's racing front lip for a 00 civic
- axels for my b16b
- HELP PLEASE!!!!! pinging/knocking in a B18B1!!!!!!!!!!
- Pix of my 98 coupe (new rims)....
- coilovers fit?
- ABS Plastic?
- Can I Hook up The Engine Oil to an "Automatic" Radiator(the oil coolant thing)
- what do you think of these rims on an EG hatch?
- pic request EG hatch
- good oem brakes on a eg
- VTEC ALLSTARS, what a joke.
- can you take off the knock sensor and still run your motor ok?
- switching speedo's. HELP FAST!!!!!
- I got $1,000... what should I do to my stock del Sol S??!!
- how to remove springs?
- Some random pics of my hatch..Got my Skunk2 Mega Power on :-)
- where to find lsd tranny
- UPS man comes up big in the clutch again!!!
- EG/EK spring fitment question.... should be easy for you guru's
- shock pictures please asap
- Passed California Smog Today w/b16 in 92 hatch.
- crank pulley question
- Weight of the EM1 chasis
- Supercharger, or Turbo
- input on year/make of hatch too buy 4 auto-x and daily drive
- h22 mount kits for 99 civic ex
- Clutch Vacum
- Help!!!! please asap...
- Rasp of an exhaust
- that damn trim around the windows
- need shock help
- Any performance shops in Charleston, SC?
- Cruise control from 92 si into a 92 dx
- Please ... I need some help!!
- crx w/b16 and other stuff
- Car runs like crap after using 93 octane?!?!
- OEM style yellow foglights
- no injector pulse
- SiR tail lights
- 94 eg compression test #'s
- H&R Race, Skunk 2, Tanabe DF210, which spring will get me this low??(pic)
- J's Engine dampner kit
- GRRR...kinda peeved at IAS
- turbo applications
- New here, pics of my new 00 Civic EX *Stock* for now...
- Camber kit question!
- dc header question??
- what would win DEL SOL SI b16a or integra GSR?b18c?
- Does going to VTEC require sottering ECU?
- Help Quick Please... (Help with fix it ticket in California)
- How much would a paint shop charge for.....
- ok to run CRX hf injectors on turbo b18b?
- I need a pic of a rear motor mount from a 99-00 Si asap!!!
- repairing or replacing stainless steel braided lines
- LSD For JDM Second Gen B16A ???
- Selling 92 Civic w/ B18C, curious..
- i need help with a paint code asap!!!
- Fender Flares
- a d16z6 if you have please let me know what you thinkexternal coil
- teg conversion on a ek6?
- since im lookin into purchsing an ek????
- Tachometer Installation
- 95 teg RS exhasut on a 92 hatch
- Mud Flaps yea or nay?
- code 9 (cyl position sensor) is there anyway to fix the sensor with out replacing the distrubtor
- Need a Honda dealership that has good prices for their parts.
- dead car..
- swap questions...
- Tire pressure???
- B16A Throttle Body/Intake Manifold Fitment To D16Z6..
- how to mount a Benen tow hook (94 Civic EX Coupe)
- 99-00 CAI for DX/CX/LX will fit a 92-95 DX?
- fuel injectors
- cam info
- dumb question!!!
- 2001 Civic "HOW TO" Question...front speaker replacement
- Engine clicking?
- quick stereo help!! ASAP!!!
- Finished swapping the teg dash into my hatch
- yay my turbo kits in!! lots of pics 56k beware
- what aem CAI in a 93 civic hatch with b18c
- recomended lug nuts?
- b18 civic or b20 teg?
- 96 civic ex short shifter question
- Zenki forged lug nuts?
- How long does it take for a shop to complete a 5 lug conversion for a Civic EX w/ factory drum brake
- Help with rim offset.
- which ek hatch best for track?
- brake pedal is soft after new install....need help asap
- need help on what size wheels
- Oxygen sensor-b18b in 5th gen hatch??
- 93 civic cx
- WHere Can i get black ek interior???
- my car almost got jacked!!!!!!
- Del roll cage...Anyone know where I can buy one ??
- New tires... wtf is up?
- help on sturt bar
- throttle position sensor question
- any one have a del sol vtec swap for sale
- N1 or GT-Spec for EK?
- EG hatch cover
- rear disc question
- Is the rear strut bar standard
- type r cable bracket with skunk 2 manifold?
- Does Ground Control have Email account?
- Camera Mounts?
- knock sensor price?
- ES Oval or Magnaflow muffler?!
- Coilovers are stuck....
- lil help here.......
- need help removing dash piece
- cx diet!
- A quiet Skunk2 muffler... rivaling the quietness of a Mugen Twin Loop?
- 1 Year Anniversary....Thieves Give Me A Present!!!
- CAI Hissing Sound?
- what size tires to run on a 96-00 civic .. 16" rota circuit 8's
- what does knowck sensor do???
- Cam for SOHC
- Peoples with h22a swap!
- I got friggen rearended today
- Need advice, oh mighty HTer's...
- Car wont start after electircal work, what am I missing? symptoms w/in...
- i give up i dont know what to do now
- wtb: 14" del sol SI wheels 5 spokes
- down falls of individual throttle body?
- Boosted LS/VTEC
- Upgraded Rotors!!!?!???
- bumber off?
- Hi everyone, new member here!
- Honda Tranny ?
- Good mods for a d15b motor?
- Question About Taking Out Carpet And Using The Bed Liner Stuff
- toda b's or jun 3's in b16?
- how to get 2 wheel burnout from non LSD trans?
- it just won't start
- whats krakn...HT...im new
- decent hp for $300?
- Speedometer Question y0!
- Could someone get me a carfax report for a hatch im interested in???
