View Full Version : Honda Civic / Del Sol (1992 - 2000)
- car only running on 3 injectors
- Anyone know where I can get this?
- Final Gear Question..
- Coilovers on 99 civic dx
- 2000 Civic CX Headlight Wiring Harness
- Civic EK weatherstrips?
- 96 Del Sol won't start
- b18c1 swap in 00 civic si
- y7/y8 mini me planning head ?
- b18 turbo is blowing white smoke
- 98 Civic Horn Issue
- 1999 Civic SI Vibration
- My DD is broken! Please Help!
- VSS Voltage readings, someone test yours for me?
- Brake Master Cylinder - New aftermarket OR used OEM ?
- wat can i get for my bar'd ej1 shell?
- help... b16a2 into eg body
- Help! obd2a distributer on obd2b y8 head
- B20b leak down test results question
- What B-series motor will bolt in directly to a 96 Civic hatch?
- Any easy cheap ways to hook up a 95 Civic EX?
- D15B7 REV LIMIT ??
- no vtec engagement problem need help..
- Whirring sound while driving
- 92 civic, motor mount question
- Add secondary o2 sensor to gsr swapped 98 dx
- Identify cam
- Rear wheel making a buzzing noise, steering wheel swerves by itself? NEED HELP PLEASE
- Looking to refresh suspension, what should I replace?
- is the serial number from the vin the same number on the eng/trans?
- 97 Hatch drivers side lower engine mount
- ek4 retro fit
- b18c swap - What tensioner and water pump to buy?
- Where do I find firewall grommets?
- Comptech Intake? 00 Civic em1
- Clutch help 96 ek
- 00 ex idle problem!!!
- my 1993 civic cranks but won't start after shorting the battery
- idle and easy acceleration problems
- car wont start
- 1997 civic hbrear disc conversion from 1991 integra
- Parts help-sideskirt screws
- Quick Question: 02 Civic Automatic Transmission into a 96 Civic?
- HYDROLOCKED! :(
- Crv Cluster in 99 Civic Dx
- Did I order the right clutch?
- New EM1 owner: Pass smog with ITR intake manifold?
- b16b type r green plug question
- eg ls swap questions (electrical)
- how much is a b16a complete swap worth?
- Y7 to y8 intake manifold
- Muscle guy with a Civic question
- How can I tell a real legit Si?
- Electric Supercharger ?
- 96 hatch stalls out while coasting in neutral
- Problem removing front lower control arms - bolt spins
- changed spark plugs and wires, now car won't start
- Greddy td04 turbo kit
- B20B swap into 00 SiR - runs but throwing many codes
- What wire harness for b16a swap into 92 civic cx?
- changing cable reel... no red cap
- Suggestions on 6K HID kit for my 99 LX
- B16a2 Swap into 1998 Civic Coupe Ex (Wiring)
- Are d15b7 and d16z6 distributer's internal coils interchangeable?
- what wires need to be ran for hx harness to work with a b16a in 98 civic ex?
- Hks hi-power
- No VTEC and No Idea Why
- engine code P0113 IAT sensor...?
- Wiper cowl and accessories parts numbers?
- 97 Civic Hatch AC belt removal
- OEM Side Mirror Rubber Gasket
- 95 EG hatch with B18B1 w/ I/H/E - Please help me decide on my next mods - A few pics!
- d16y8 chucked a rod through the block - what block replacement?
- Authentic Skunk 2 Eg Camber Kit?
- Pressure in fuel return line
- Question on ST suspension
- D16y8 valve adjustment gap?
- Bay shaving questions!
- Del Sol Suspension
- speedometer not working, loose ground? idk what this cable is, pics inside
- Sputtering on startup on my 96 ex?
- Wiper Problem
- D16y8 swap - How do I wire VTEC using a DX ECU?
- car wont start, battery wiring?
- lca bushings
- Civic LX Header and Catback
- Will tein full coilovers from ef work on ek?
- 93 del sol new exhaust question.
- NEED HELP!!!! (CV JOINT)
- auto to manual? how does it effect mileage
- need help bad wit a 96 jdm b20b swapped into 98 hx
- Could someone post pictures of your stock headlight harness?
- Paperclip with radiator worked,but thermo..
- Dimmer switch circuit - Power through my ground wires?????
- What T Bracket Fits a B18C1 in a 93 Hatch
- Pics of completed vtec OBD1 P72 ECU wiring
- Squatting hatch
- Hesitation on first acceleration?
- New to the forum - planning GSR swap into 96 hatch
- d16y8 turbo rod bearings. what color?
- Rattling noise when shifting up Help?
- Best Cam Gears? Any actual proof?
- Connected new battery, no dash lights/radio doesn't work.
- high idle
- strange fuel economy on my '00
- 1993 Honda Civic: Code #14, sputtering at 1200 RPM when accellerating.
- 2000 cx hatch with 2000 obd2b b18c1 tach question
- High idle b18c-r...
- werid noise with video.
- Need help with Car idling at 2k-3k. Out of ideas
- Hidden Hitch Install on my 99 LX (3hrs later)...*!!
- How to lock vtec a vtec pin in place.
- Need help what alternator do I need?
- Whats this H22 worth?
- Car sputters, jerk, and acts weird
- B18c block help
- red out tail lights del sol
- 95 del sol w/ distributor problems
- anyone know where to get em1 fenders
- Engine iac valve questions
- Is this an OEM paint color?
- The end-all be-all thread for wiring questions
- Engine restorer??
- b16a2 swap in 95 civic dx - throttle issue
- Recommend where to buy Greddy td04h-15g?
- dome lights/ trunk light/ headlight/ beep em1
- abs delete: pros, cons, and how to?
- Mini me question?
- Broke Off Valve Cover Bolt off.......need advice
- Cam Seal Replacement Question???
- Swap newb?! B18a1 & cable tranny swap into 93 hatch
- non vtec to vtec, need help
- How to get Recaro seats in EM1 ?
- JDM DC2s in a delsol
- d16y8 distributer wont line up help
- Looking for Main relay wiring diagram.
- EK Fog lights.
- Radiator fan isn't turning on! how to do paperclip tech?
- Need immediate help. urgent!!! (pcv valve)
- CD player memory help!
- B18c swapping into ek best transmittion need help..
- 99 si a/c woes....
- 1992 Civic LX Thermostat Gauge MAXED OUT
- aftermarket water gauge wiring
- Alternator wont fit please help
- WIRING HELP!
- Fuel pump wont prime
- where to find hog rings for 94 del sol factory seats
- looking for your option on which motor is better to turbo
- 1995 civic throwing code 8 tdc sensor
- 94' Civic EX - Alternator fit problem
- b18b or d16y8 on boost ?
- Exhaust correct choice
- Front end shake after state inspection
- paint strippng whells and valve cover
- Adjusting coilovers
- 1992 Civic Engine Surge on New Head Gasket
- Diagnose this noise? Wheel bearing? Brakes?
- has anyone ever donw 3 stage vtec swap with upgradesc or something to no the outcome
- Subframe swap, now positive camber? Help!
- CRX Springs on 92-95 civic
- Ls-Vtec Setup in Ej1.
- 94 Del Sol Si with Very Poor MPG
- Stock 93 Si cat length?
- Can not fix this cut out problem! Please help (b16a)
- Leaking passenger side axle
- New/Old member...couple questions
- Taking sticker off the paint???
- ek h2B SWAPP
- Weird Electrical Problem 98 civic LX
- engine buy
- reverse light switch
- d16z6 in ej8?
- k swap help
- bolt question on suspension
- Resonator
- strange idle no cels
- Cold Start
- Locating the Bleed Nut
- Valve cover paint color
- Best swap choice for a broke student....
- Tune Up now FI relay not working
- injector power source pin on p28?
- Bad Gas Mileage on eg si, need help
- Walboro 255 - bad fuel pump-b16
- Built LSVTEC Del sol
- need to pull my b20, anyone in sac got a cherry picker i can use or rent...
- Need help removing door connector pin:
- How do u check the oil on h22 tranny?
- car started shuddering...
- roll centre adjusters: buddy club vs mfactory vs hardrace
- Brake M/C buzzes pedal on start-up
- another main relay/fuel pump issue please help
- White smoke, losing oil, and oil in coolant reservoir
- What else do I need help please with my build!!!!!!!
- d16z6 VAFC 2 diagram????
- d16y8 vtec solenoid...??????
- Golden eagle lsvtec line leaking problem?
- EG climate control light bulb
- Bigger AC condenser in a 96-00 Civic for those 110+ degree days
- Ek Body Harness
- 99 ej8 with b18c not pulling right
- online stores to purchase parts
- EM1's main relay chatters/buzzes. Push start car and everything is good. WTF?!
- B16 header on b20b
- CEL jumper doesn't work. Need help
- something knocing/clicking tranny related
- Boosted B18b -- knocking sound and metal in the oil pan
- Spoon N1 vs. Replica N1
- A simple tune up and it wont run!!!
- auto tranny works only by shifting manually
- Square Foglights install
- First swap - b16a (si) to D16y5 (hx)...any tips?
- 95 Civic air condition not blowing cold
- Mishimoto Radiator question
- Acura EL Front end?
- My Friends car is stuck on the side of the road!
- The dreaded po505 cel code. Need help to fix it
- 2000 Civic Ex ignition issues
- What Gauge Wire size do i need
- Want to drop my 17's for 16's... need advice.
- Vtec sometimes works...
- 2 Door EK Spoiler on a 4 door EK Civic??
- HELP! car idles fast and whistles too HELP!
- DC2 seats into EG sedan-- odd seat position.
- Projector fogs, What do you think?
- 18 and starting my del sol...
- Finding CEL jumper friends car
- power locks
- car surges after swap
- I'm back to the forum with a new build
- Help finding a positive wire in engine bay ....>
- GSR Swap in EG Hatch
- b20 timing question
- JDM p72 ECU vtec doesn't engage(NO CEL)
- timing off and vtec solenoid wire ripped off
- Car won't start when warm!!! NOT MAIN RELAY please help!!
- compression test results 90 psi ? any thoughts
- Are there any ways of passing emissions... or at least lowering HCs?
- Certi-fit fender price?
- 2000 honda civic sedan driver door window slowww
- Audio system in 97 del sol
- Figuring out what rear disk brakes are on my Eg?
- manual transmission fluid, oil, oil filter questions...
- Back after 7 years! Need help with idle problem.
- d16y8 chipped ecu problem plz help!!
- injector size
- Searched: econoline o2 sensor for honda
- will d16z6 start on a non-vtec dizzy
