View Full Version : Honda Civic / Del Sol (1992 - 2000)
- camshaft seal..cannot install, please help me.
- Fuel Line Help
- Edelbrock Performer IAS Shocks
- power window off track 96 ex any suggestions>?
- need help picking a motor
- NEEDS!!! an apexi v-afc II wiring diagram....!!! Please....!!!
- Looking for Si stock parts
- problem with my B16A
- fan relay keeps going
- Question about Integra dash swap
- missing dowel pin in flywheel
- Hmotors online
- KYB AGX installation problem...help asap
- lowering question
- HELP!!!! auto to manual conversion mount
- HX VTEC problems help
- GSR Calipers
- valve adjustment ??
- URGENT!!!!
- o2 sensor?
- Help!! Stereo problem
- dohc zc into an ek
- best sway bar set up for the street
- d15 crankshaft interchangeable??!?!?!?
- Avon Tech M500 Tires?
- please check out my ignition timing alignment
- DC5 seats into EM2?
- Exedy or Act
- Ep3 Cluster in a 92-95 Civic.....?
- A swap from an Autonmatic to a Manual in a 95 CIVIC DX
- DENSO Iridium spark plugs ????
- The Mini Me swap for a 95 CIVIC DX
- The slowest car in the world
- srr 4.7 or 4.9 final drive for d series s20 tranny?
- jdmshit Mugen V2 and type r rear lip... PICs inside and review
- Motor Mount Inserts for EG/B16
- JDM civic sedan?
- loose timing belt (y7/z6 hybrid)
- d16z6 head+d16y7 block equals what comp ratio?
- sway bars setup...?
- tearing down a 94 civic dx 4 door sedan...
- Going to make DIY obd1 to obd1 harness for vafc or fields.
- noob here
- help please d15b8 to d15b7 engine conversion
- Anyone ever POPPED a Goodridge S.S. Brakeline??????????
- carbon fiber hood fitment
- ORLANDO THIEFS STRIKE AGAIN!!!!!!!!!!!!!!!!!!!!!
- Cylinder 71 72 and 74 misfire? wtf?
- Broke a chunk off my tranny.
- Can someone run a carfax please.
- My Del Slow
- l00se belts..help!
- EX Doors...?
- ::92-95 EX front brakes into a DX hatch????::
- I need help with NOS wet kit....
- y8 swap-hoses?
- Civic HeadLight Tail Light Conver
- car died after timing belt alignment...help!!!!!
- SAFCII On a D16Y7 need help!!
- Glove compartment?
- www.efituningforless.com
- wide body kits for 93 civic
- V-tec engagement (searched)
- Wide Body Del Sole in Need of Help!!
- battery relocation???
- bore size?
- Switched to OBDI - car limping?
- OBX sucks, heres my experience. (56k get cable and view this)
- Need some Help with Bearing Clearences
- Whats an over all great exaust Exust???
- ECU help...auto p75
- hids from bmw x5 in an ek, stoped working, help
- Celica seats into a 6G Civic
- my cluster seizures, help!
- Installing amber corners tomorrow, need advice.
- 1998 civic lx HO2S
- Throttle Body options on a y7
- Changing to an aftermarket radiator
- Comptech Ice Box with a dry shot?
- bought WS coilovers, neccessary for the nut/washer in between strut and LCA?
- Cant find service connector
- Civic HB Rear Speaker Kit Question
- my 99 si's idle?
- ex cluster in my 96 ek
- sohc cam gear question
- Did not cut bump stops.....
- Keyless Entry Help Needed
- JDM ITR Cluster in a 96 civic.. 2 yellow wires?
- Neutral Safety Switch
- Need Help w/ Smog...
- BUMP STOPS?
- 96 bomex civic from sinful stolen (so CA)
- zc sohc block and a d16z6 head will it work ?
- Passing Smog in Ca. with B18C
- bit off topic but is anyone from the central florida area?
- Acronyms
- Swapping out d16z6 for d15z1 how wll it run?
- gsr ecu (obd2)on a b16a2(obd2) motor
- Car not starting help please...
- Fuel Pump Relay
- Question about my car battery...
- Ground Wire Kit
- HURRY, Timming marks.
- Type-R Steering Wheel
- Problem Starting 1995 Civic
- I Have a Question???....
- engine will not start
- How much HX wheels worth
- what center caps fit mortgei mr7 knockoffs?
- A bit off topic: A 240sx brake question?
- regestered RHD...what else is needed for CA??
- Coilovers
- loud vibrating noise CLUNKING n clicking coming from passenger side??
- question
- Rear Lower Control Arms: How Tight?
- exhaust hitting endlinks
- 1.4 honda civic
- how much for my sol?
- 98 Civic getting codes PO300, PO301, PO302, PO303, PO304
- will these fit on a 00 civic ex????
- b18 type r motor, with a 1.6 sohc ecu, throwing code 21 (vtec spool)
- EbAy hEaDeR y0!
- what is needed to swap an H22 into an EK?
- main and rod bearings question
- What engine is throwing code 21 and 15, what can I do to fix it?
- VSS question
- Car won't start....Help
- Hayame Exhuast?
- best price to get the greddy evo2
- eg-5 pads where can i get them
- putting ac back in the ride need some good help
- Basic EG Civic Question
- For Sale Help!!!
- 99-00 Civic GunMetal Headlights
- scoop for my CAI
- Will a 92-95 Civic alternator fit a 87 CRX?
- Head Gasket Oil Leak
- Delsol Antenna!! HOW DO YOU GET IT OFF!!!!!
- Hi flo cat question?????
- del sol gas tamk
- Boost controllers
- Spring compressor for coilover
- tie rod boot install?
- PIC'S OF MY d14a4
- p28 idleing funny?
- rack and pinion???
- question on axels
- Cold start
- Brace yourself!!!
- question about apexi n1 suspension
- Looking for 99-00 CTR conversion info, please help
- 96 dx brakes are that bad?
- WTB Pass Side Rear Quarter Panel off a Sol
- Brake indicator light on my instrument cluster, what?
- ?JDM HEADER?
- How do I get my alternator off???
- B18C1 in EK...Which shift linkage you are using?
- Cigarette lighter wont work, 02 civic.
- new forum for only va,nj,ny,pa
- ABS type r lip kit on an EG?
- whats the stock motor in an 01 civic
- radiator fan not working...help!!!
- Swapped a Ported head on my d16z6... won't start.. bad timing maybe
- quick question.
- Noob intake question
- Looking for a turbo kit
- low speed clicking from wheels
- SWAP inFo???
- might be the starter
- Flywheel for d16z6
- is a Y8 im better for turbo then a z6
- Revs go up very slowly in my B16a
- high pitched whining??
- TURBP QUESTION
- moter swap
- AEM wide band A/F gauge?
- car won't start.....why?
- tein flex...pillow ball mounts??
- Intake???????
- Tow hitch
- knock sensor
- low comp pistons for 1.5 liter
- compression test
- wierd problem with either tranny or just shifter....
- Jic Magic FLT A1 Feedback??
- 4wd civic!!! check out the motor.WTF
- new springs?
- ?for those who have swapped or gone turbo?
- 92 si hatch is it worth 1500?
- spoon lower tie bar
- stock p05 to run jdm d15b
- What Type Of Suspension????
- 5 Lug Question.
- Master cylinder is bad
- Is it dangerous?: Running a Vtec motor WITHOUT Vtec.
- honda centercaps on rota c-8's
- P28 CEL
- J's Racing
- Need HELP w/ d16z6 into '92 CX swap!
- Stock p28 ECU fuel cutoff?
- question about blitz blow off valve
- b16a2 redline?
- please help. occasional no start problem
- Please HELP!! AC problems!!!! i'm a newbie
- Idle below 1k..?
- ZC DOHC In A 92 Civic DX??? Would It Work???
- 4 wire o2 sensor
- Replacing rubber seals on a 98 DX
- will 4th gen prelude seats fit in an eg hatch with no modification?
- will it fit in 96 2 dr. civic?
- problem with ignition or who knows
- What Shoulld i do Hatch B18c1
- a lil vtec help!
- Angel Eye Fog lamps on a Sol
- Problem initial starting engine, or re-start after shutdown, please help.....
- Mods that you regret on your civic?
- cold air intake
- LS/Vtec piston questions
- exhaust
- any info any one?
- RPM Guage problem
- Loud header?
- Oil Change question
- a question about VX cluster...
- Intake..
- engine rubbing on the hood
- Ok I have a 97 Civic LX and a Wrecked 96 Integra LS what can i make?
- 00 Prelude Brakes on an EG?
- piston and head combination cr chart????
- LOOK.. tranny Question... :|
- Integra Rear disc conversion for '97 Civic
- So I got my frame locks today........
- which ecu is best for a b16sirII the p30 or a chipped p28
- ok swapping yet another motor
- konig mozart exhaust
- Front Lower U BAR Questions for EK/EG/DC
- axel help!
- pulled spark plug wire and nothing happens...why??
- wiring help dx on gsr
- H22 swap for a 94 honda civic ex
- Ok guys need some fast help!!! Friends car broke down out of state
- Right Side Wheel noise
- wiring IAB. i need a 100% confirmation before i go and do this
- scraping noise from drivers side
- A/C Thermal Switch Replacement - HELP!
- MOMO hub
- h-t dyno day august 21 wilming ton delaware
- power window Q
- 4 SPD Automatic Transmission 97 Civic ?
