View Full Version : Honda Civic / Del Sol (1992 - 2000)
- can someon tell me how to wire up a 97 ls engine with 96 civic harness
- quick axle question...need quick response please
- post pics of rear lips for sedans
- will eg coupe/hatch front end fit on sedan?
- honda intermediate shaft
- Distributor??? What OBD??
- FIA Control Valve
- Brake lights
- Brakes making a clunking noise
- What p/s pump for gsr'd civic?
- Can I CLEAN my O2 Sensor?
- MISSING MY EVILSIDE EK!
- obd0 or obd1 for a 94 civic 4door
- hid ballast help.......
- Will a Virgin p28 run a B16a2?
- vibration at 65+
- B18C1 torque spec verification... and order?
- Clinking sound from suspension
- 98 Civic radiator
- S2k Wheel in a EK?
- Springs
- EK power window mech parts crossover list...
- 94 civic centre audio console
- Hood latch problems
- exhaust fitment question
- Wiring Harness D15 to JDM B16
- help with a carfax
- b-series dizzy sizes?
- Insufficient voltage
- anyone can get pigtails?
- P61 Intake manifold better than P30 Intake manifold? SEARCHED
- Phearble.net ECU Idle Problem
- help! wiring jdm honda navigation system
- Anyone have H&R Limited Edition springs?
- extended shifter
- what brand o2 sensor to buy?
- nos on sleeved block
- qwick question time warner cable suckx
- CLutch probelms Need help Asap
- underdrive pulley and timing question
- KNOCK SENSOR, replacing it... what type of sealent do I use? the stuff that new ones come with, what
- got 3 asc certifieds stumped. need help.
- LOOKING FOR A STOCK EK!!!!
- Need pictures of stock DX/CX and EX motors
- JDM GSR in 92 DX hatch VS. JDM GSR in 95 DX coupe.
- wire tuck advice/info needed
- tranny removal problems
- z6 and y8 vtec solenoid difference?
- 00 Civic ex windows are struggling...suggestions..?
- EG FOGLIGHTS? JDM OR NOT?
- How to: Fuel cutoff switch...
- trans hittin pp??
- What exhaust should i go with??
- My Big Build Thread - D Series Hybrid
- FITV
- HEADLIGHTS AND turn signal blew out in the rain..WHAT!
- FOR SALE -97 civic with 1.8 ls
- B18b1 into EG Hatch
- what does this do exactly???
- how do i know if my car is v-tec?
- my setup
- ignition?
- h22 question
- Car won't start after stalling.
- need help asap!!!
- Fabricated exhaust system v.s. name-brand cat-back
- High Beam?
- del sol dash into EG (90% done)... need wiring help
- Turbo Kit question
- Q about taking off rotors on a 95 civic ex
- Heat Sensor Problem shown on diagnostic WTF 97 civic
- EK Interior Coin Pocket Question
- Air Tank, good?
- help ideal question
- Is it true...?
- help axel nut striped.
- Rear Speakers...Electrical problem
- Legal Odometer rollback?
- dry ice, what do you know?
- where can i get a good used honda 15b motor in so-cal
- EK Tweeter Question
- 92-95 civic sir steering wheel on 96-98 hatch?
- ECU chipping ?'s (searched)
- motor stand
- Help! Test pipe...
- 94 del sol S brake problems...
- cant rev past 3500K RPM
- A/C belt question...
- jdm and usdm!!!!!!!!!!!!
- JDM climate control.
- Abrupt Timing Change - CamGear Retarded Itself 10 Degrees!! Easiest Fix? Whyd It Happen?
- Turboing my Civic
- injector question
- Cometic HG marked "UP" on one side... only that side MUST face down???
- CA smog check...
- CEL:Water Temp Sensor?
- car wont start, pump not priming.
- civic climate control.. need answers help!
- What are some good shocks for H&R Race springs?
- Sparco seats
- Cluster Lights Not Working
- Emissions short ram intake question...SEARCHED..
- CTR Rear Upper Strut Bar
- Auto EK hatches vs Manual EK hatches
- EG/EJ Armrest cup holder.....
- Getting No Fuel!!! Help!!!
- helms/hanes?
- radio blcok off plate #
- Vibrant muffler or Tsudo cat back?
- EG power folding mirrors help
- 93' ex 4door suspension probs
- Guys who have changed mufflers of the same brand but different size.
- speakers
- Carfax needed.....
- 93 civic ex coupe ECU question
- Wiring Diagram for Ek9 Power Folding mirrors
- OBDII vtec solenoid....interchangable?
- what was your approach?
- Am I getting ripped off?
- Ek power Windows help
- Help with 00 Si no spark dizzy problem
- MY (@ CIVIC HATCH KEEPS TURNING OFF! HELPPPPP!
- trans problem
- d16z6 oil jet??
- 06 rsx wheels on a ek?
- My R-Powered Coupe
- Headers
- ek headlight
- integra brake booster and mc on eg
- b7/y8 mini me
- were can i get some turbo gaskets??
- need help with tach
- Question for anyone who has an autopower roll cage with a harness bar pls help
- injectors
- wut is best comp pistons for ls on boost??
- High compressed LS question
- 2nd gear pops out when shift @ high rpms, but ok when shift @ low.
- golden eagle?
- need tech info 5 wire convert to 4 wire.
- im not allowed in general disscussion, so i have to post here
- WTB: EG mid-wing and ROTA center cap or caps
- jdm ground strap, static reducer
- i have a question about alarms...help please!
- EK9 SiR front bumper??!?! help 96-98 hatch
- Is it possible....?
- RWD EG Civic!
- airbag installation woes
- Weird start
- dual bend vs single bend
- Cruise contol speed slowly drops off over any speeds above 75mph
- Long Trip help
- Need help with my manual 99 dx civic
- trouble after a tune up (yes, lame i know)
- IDLE IS WIERD
- can u swap the head and intake manifold of the d16y7 to a d15b7?
- quick vtec question b18c Iab and Evap
- GSR Brake Swap.....
- d15b7
- is this the timing.
- cluster
- 92 civic vx with obdo b16 need help with wiring
- New rad and check engine light is on!
- i have a 95 vx with a d16z6 motor in it if i use a z6 harness will it b plug n play for vtec??
- Laf cel... and wideband sensor question
- WTF is this thing on my buddy's ECU 94 dx hatch
- Knocking noise while braking at slow speeds. Help
- Del sol deal is 2 good to be true????? What can I do to see if its stolen?
- CEL light because of header. Help
- car is running lean..
- knock an v-tec questions
- h23 problem
- Anyone heard of this car
- question about stock color and title?
- 2 door ---> 4 door catback exhaust question
- EG6 brakes, which pads to buy?
- ecu plugs help
- will o2 sensor throw code
- Short ram?
- will the o2 sensor throw a code
- different feel
- eg rear discs on ek?b
- Boost Question
- Help im a trial user still
- paint
- Interchangable Parts with DC2 Question
- ek sir amber clock into a usdm ek help findng the hidden plug in the ek
- Cable or Hydro
- knock / v-tec wiring i need help
- Is my Brake Master Cylinder still good???
- Del Sol Radio
- can't get my car inspected!
- New parts from GReddy
- HID problems, help needed soon.
- light problem. HELP!
- having problems with the brakes
- Integra 94-01 spindle direct swap to 96-00 civics???
- Suspension Forum doesnt move...check this out please..
- help 1 1/2 years not started eg
- CTR Power windows install into 96 CX hatch Need help and Info please
- smoke
- trying to find a diagram of the 28 pins.
- ABS delete?? Use Steel Brane lines & an fittings?
- 92-95 eg main relay
- 95 civic died .... Please help
- CVT question
- V-TECH problem need some help
- any one?
- Question plz...
- NEED HELP ON SOHC
- d15a3 block and d16z6 head worth $$250??
- just did swap, i got a question
- Del Sol fuel pump issue?
- Stupid ECU Question
- is this legit?
- Cars for Sale
- help me diagnose this problem :/
- o2 sensor help!
- FOR SALE CHEAP!!!!!!!!!!!!
- s20 tranny making noise
- ERATIC TACH QUESTION
- rear bumper 98
- Indiglo Gauges - HELP!
- 94del sol S A/C question...
- sohc zex cam
- Vx & Ex.. Need Help ASAP
- difference in ecus??
- Question about Cvic and jdm b18c1
- Car starts, then dies, tachometer reads when car is off..?!
- Pic Request - color-matched foglight shrouds?
- Mini me wont start, no spark.......PLEASE HELP
- Dizzy Problem!!!!! Help!!!!
- GSR to EK Civic Ebrake cable question
- Apexi - WS2 Catback
- Clutch and brake upgrade help
- retrofit A/C? r12 and r134a compressor the same?
- would these tires fit?
- +35mm offset without rolling/flaring?
- HELP 92-95 civic dx help for proper engine upgrade
- Tail light swap
- New motor & mounts = Rattle?
- valve cover stud... question on tightness
- Slip over EK exhaust hangers? Buddy Club style?
- 95 integra cluster in to a 97 civic dirgram?????????????????
- Are 92-95 coupe sideskirts the same for a eg hatch
- help...
- OverHeating Issue due to a water leak?
- would a faulty ignitor throw a CEL???
- Quick Question
- valves???...wut brand to choose??
- clutch noise
