View Full Version : Honda Civic / Del Sol (1992 - 2000)
- CTR Cam Shafts and Valvetrain for my gsr - good deal?
- Can I still use my crank shaft gear? It has 3 slightly damaged teeth.
- heater hose leakin....can I use regular 5/8" heater hose to replace this ...pic inside
- proper cat for 99-00 Si W/DC JDM 4-1 header
- Greddy Exhaust
- Will 99-00 front civic seats bolt into my 92 hatch?
- Wrecked front end - no speedometer or gauges... why?
- CAI HELP!!!!!!!!!!!!!!
- How come my vtech doesn't kick in ??? 92 hb si
- Brothers civic wont start
- HELP: 92-95 EX exhaust same as 2000 Si?
- Hondata Intake Manifold Gasket - is this a good deal?
- REAR DISK CONVERSION
- are these worth the price?
- Will 98 integra mirrors fit....
- bypass vavle
- Where to buy OEM spark plug wires?
- Are all OBD2 crank angle sensors the same? IE: SI, GSR, ITR
- which mount???
- They found my car
- 00' ITR Bar fit on a 97' EX Civic?
- vtec question
- Weird rough idle problem! Help plz!
- civic exhaust help
- low comp pistons for gsr motor
- racing seat/seatbelts install??
- Depo foglight kit install problem. Or, I'm an idiot. please help.
- need help 92 civic si hb jdm b18c itr swap
- Clutch engagement point on '00 Si
- b16 sir just installed and vtec kicks "in" and "out" did all the normal checks
- ek "jerks"/hestitate
- where is ECU located?
- Battery light flashing
- where to buy interior parts
- side moldings
- SAFC II Help Initial SETUP NUMBERS?
- Oil pressure when hot
- makeover ??
- looking for civic hatch parts for an eg ('92) -don't have a clue where to find half the stuff
- can i slam my APEXi N1s?
- Car not starting
- motor mount question
- ECU Chipping Experience's
- 93 Civic EX 2 dr rear bumper cover question
- Car wont start. *hybrid EG*
- air/fuel ratio gauge which wire on the ecu i tap into
- Bad problem with my hybrid engine...undriveable...please help!
- what are the possible ways that car is not turning on?
- Where is fuel filter on my frankenstein? (b16a2 head on b17a1 block)????
- Del Sol Gearbox
- b18c1 swap question.
- D16y8 head gasket???
- Heeeelp! My B16 swap is getting worse by the day.
- Which lugs won't fade on me??
- Throwing CEL 21 and 22 still.
- tire and rim question
- what is this plug? pic inside
- Del Sol: Boosting Performance
- Bought a socketed computer from hyperduck, how do I change chips?
- Put too much oil in...only drove 30miles though!
- Stolen Car - Help if you can
- del sol for sale
- just wrecked my del sol. =(
- VIS = GARBAGE!!!!!!!!
- my 4th honda... what to do this time??
- aem bypass
- First time at the track today
- Need some Help about tune up
- Looking for a motor
- inline resister install question
- bald in the front, tread in the back??
- help
- safc 2 plug & play harness
- supercharger on sohc
- How to tell if ecu is manual or auto???
- 96-98 camber/caster kit question
- Is this possible; Pwr window conversion question!!!
- quick question.
- help with a TD05 turbo and a civic 01
- drop in electrical power effecting performance?
- how will an unchipped p07 run on a stock gsr motor?
- 99 Civic Si haveing starting probs!
- whats v tec and redline of a p07 ecu?
- Trans coming off, and I have plans.....
- **Buddy Club Pro-Spec or HKS Hi-Power cat back for Eg**
- Want to get bar sticker but dont have any paperwork..Help......
- Emission Question ???
- Replacing Power steering rack with manual steering rack question...
- D15b7 in my sol
- Just Completed Swap.. 3 weeks ago.
- Will SSR Type C 4x100 15"x7.5 +43 fit on a 6th gen?
- apexi v-afc 2
- Steering rack joint issue.
- will p72 rings fit p73 pistons and what good would it make a dual exaust header
- running an auto ecu on a manual car, how bad is it?
- just installed new headlights AND?
- Center caps
- poor mans type R and turbo
- quick release wheel
- Transmission Help
- need help with my setup!!
- can u use a big c clap to press your caliper piston
- WTB 92-94 HB
- do 2003 Si wheels fit EG bolt pattern
- Changing redline in EX Cluster?
- quick help needed: strut question
- How do you test your thermostat?
- BLUE EG w black RNRs STOLEN IN GARDENA SO CAL!
- What ECU in 93 Del Sol (S) base model?
- Differencec between GSR front brakes and stock civic brakes?
- SOHC Vtec Wiring
- idle problem
- Exhaust questions for 98 hybrid civic...
- need to pass smog
- installed Fastbrakes 11" upgrade w/2pc directional vein rotors
- car alarm problems with kill switch to starter
- how to: rsx keyless entry remote on k20 ek
- passing smog
- Bosch ceramic brake pads. "Dustless?"
- Sport Compact Pro Sponsorship
- I Got B.A.R'd!
- Del sol seats
- Any 1 know where i can get a good guild for putting a h22 in a 96-00 hatch ?
- Moonroof needs a push to open, solutions?
- 99 Civic Ex Help??????
- cornering with traction bar
- integra dash into EG door panel problem solver!!
- how do YOU get rid of the fender to bumper gap?
- what code is this?
- Suspension parts...
- Apexi N1 EG/EK coupe question
- h22 swap won't start
- noise from lowering springs?
- 10hp for 10 dollar continues...
- calculating max speeds in each gear...need some help
- Need to borrow or buy"cheap" Engine hoist in DFW area ASAP!
- jdm tail light
- Axle/Tranny questions
- ferio cluster wiring
- the EG+ Civic weight thread
- issues w/ recaro seats in my ej1
- 92 civic dx wont start
- will a teg type r swaybar fit on 95 civic coupe?
- help with excessive tire rubbing need advice
- what should i do next?
- choosing topic which camshaft is better Crower or Skunk2 for a sohc???
- (Searched)Question: Power steering to manual steering EG?
- Hondata s200 or Apexi Power FC
- Do you have to torque spark plugs
- Vtec solenoid compatibility
- 1.6 head onto 1.5?
- Bad throw out ball bearing or arm?
- Fuse layout for EG
- code 15: ignition output signal
- NEED HELP ASAP !!
- Does anyone have a greyish/gunmetal turbo del sol in the arlington area?
- Looking for a IMPORT FRIENDLY exhaust shop in ATL....
- Transmission swap guide(searched and searched)
- obd swap need help
- do ALL obd1 ecu's eliminate knock sensor?
- What all tools do I need to swap out for new struts and springs?
- 4 lug to 5 lug
- other than check engine light, what symptoms exist in having a bad oxygen O2 sensor?
- building a civic from ground up
- Whats the easiest way to change the passenger side parking light on a 99 si?
- Taillights Out...
- d17 (anyone know anything about the turbo kits for them)
- omnipower coilovers vs. H&R Cup Kit: opinions, experience?
- OBD0 b16a swap into 96 Civic SOHC VTEC ?'s
- What do you set your AGX at?1-4?
- EX/SI headers the same?
- AXLES for HONDA CIVIC 2000
- B16A Direct From JAPAN to a 2000 CIVIC needs help ASAP!!!
- EG springs?
- DriveSHaft stage 2 axles for a Integra, will they fit a civic with a B series swap??
- motor prep???
- NEED HELP WIT GSR INTERIOR INTO A 92 CX EG
- !!!!10HP for $10!!!!
- Blown motor???
- how big is the exhaust from a 99-00 si?
- dohc or sohc?
- Anyone make custom fuel kits?
- will this work?
- window visors / rain guards recommendation
- Paint for Valve Cover
- spindles?
- Need some help please.......
- Long Ass Service for just a damn tranny swap!
- b16 '00 or gsr?
- help ! My Isuzu Amigo is getting bad gas mileage and sluggish horsepower
- Having 4th gear trouble
- Need a little help
- Newb seeks accurate technical manual for 93 Civic LX sedan
- I need help with my engine swap
- Fuel Pressure Question
- CEL 54
- What company actually produces those H braces?
- Need help with my hydraulic tranny.... Clutch wont engage.
- how to remove weather strip?
- where to buy new starter/dizzy/alt for cheap?
- nice keyless entry trick for k20 ek's
- catalytic converter is HOLLOW upon inspection!?
- no need to push down clutch to shift
- Will stock 04 stereo fit a 98 ex?
- Aem V2
- Torque dampeneer installation ?????????????????????????????
- d16a6 throwout bearing in a d16z6 tanny?
- NSX Calipers on EG?
- Cant get my hood to close properly??
- horn doesnt honk!!!!
- Gunk on the rims will not come off!
- tranny pops out of gear, but goes back in all by itself?
- I feel that JDM parts/supplies are better --->than American DM equiv.
- Whats louder? Tanabe Hyper Medallion or Greddy SP?
- *DIY* tilt wheel (non adjustable) for dx civics with out tilt wheel feature...
- A link to some pics
- gsr suspension on 92 civic cx hb
- You know what sucks? WRECKING!
- p28 with d15z1?
- Driving lights
- Help a brotha out! (i know squat about cars)
- delsol with jdm b16a gsr tranny grinds in 3, 4, 5 ??
- TPS
- 2000 honda civic type rs grill???
- defi vsd 2 opionions ?
- Troubleshooting The Check Engine Light
- RSR Exmag II wont fit VX eg?
- Just did a b18c1 into a vx questions on clutch?????and linkage
- "Where Can I Find A Good Price On APR Strut Bar?"
- Canadian 92 SI vs. North American Version
- Replacing steering box
- Smoke coming from under dash
- Will these wheels work on a Si with CTR 5-lug conversion?
- BodykitsNW Customer service Sucks!!!!!
- 00 Civic Suspension Question!
- Civic SI Hatch--can anyone figure this out?
- axle, quick help
- where to find 1999 Civic Si shift stabilizer bushings?
- Integra Cluster in an EG
- Need ZC DOHC distributor cap and TPS.
- Yay vtec problems for everyone!
- Where to find this.......
- can i get some opinions?
- p30 ecu question?
- DASH COLOR CODE HELP!
- Yellow Fog Light Application
- WTF to mount my smic....? LOOK! $@$@#%^$YEGWE$R@#
- H22 Swap on a EG
- Question about my SPC RLCA's
- need help asap.........
