View Full Version : Honda Civic / Del Sol (1992 - 2000)
- EX vs HX
- Radio Code - Way to get around the hour delay for wrong code?
- Trunk Drain Plug
- changed clutch and now i have clerance issues
- d16y7 jdm swap
- Gauge Cluster/AC Control Unit Electircal Problems
- vtec trouble
- Question about aftermarket exhaust system fitting B-series swap ek!
- shifter probs
- where to find a tranny
- Custom 95 civic exhaust bends???????????????
- Cig lighter wont work...
- Taking out power steering
- What Brake Set-up?
- Civic HX owners, wiring question, 5-wire o2 sensor
- Need New Door Handles...
- Quick Question About turbos
- my sunroof glass flew off!!
- Instrement Panel light problem...
- do too many people hate on hondas. or is it just me
- Inpection Time! Dimmer Switch Problem... Help!!
- Inspection Time! Horn Trouble... Help!!
- Door Freezing?
- Engine Stalls then won't start???
- boost again or N/A
- Somethings wrong curious if anyone could help!!!!
- Best & Cheapest Axles?
- does carbon fiber lip crack easy?
- Rear License Plate Light and Turn Signal fuse
- 1992-95 civic cx models?
- mugen headers
- Trans code for VX D15Z1
- What are good decents shocks that go with the skunk 2 springs?
- my new hatch
- b16 Trannys
- EM1 Grille?
- Sound denseners
- LS/Turbo vs. all motor LS, which can make decent power while holding reliability??
- turbo help
- Tranny going bad?
- About to buy car, need expert info on owner's swap!!
- newbie
- d15b2 question
- All motor vs. turbo?
- bind in Throttle cable
- Si gauge cluster plug and play?
- fog lights???
- Del Sol Door
- 2000 ex front brakes on eg need help
- ROTA SLIPSTREAMS
- Dumb Question....EG Sidemolding..
- hid's in my fog lights
- How much....?
- brake line help!!!! needed asap!
- JDM / USDM release bearrings
- b16 + type R water pump
- What available ecus 4 99-00 ex(d16y8)
- D16Z6 Valve Cover
- Newb questions about Del sols
- DIZZY QUESTIONS!!!!! PLEASE HELP!!!!
- need help with my speed sensor, reverse, and coolant
- Heater cable help
- HKB hub in 95 coupe
- 00 EX with a mushy clutch, won't go into gear.
- single cam internals??
- jdm headlight help?
- going from b16/b20b to b16/b18(a/b)?
- 5lug convertion ( ek) nsx clamps
- civic > me (need help)
- Interior Fuse Box Diagram
- wiring up the reverse lights -ive searched
- dc2 catback fit on eg coupe???need help!!!
- how do you test a intake air temp sensor to see if it is working?
- DC rear strut bar on EK??
- my tranny just died i need help
- how do you change the chip in a ecu without messin it up
- Anyone wire RSX seats with airbags to work on their civic srs system?
- Drive By Wire?
- 04 Civic Si Seats in a 92 EG
- need help on swap b16
- b20
- I just purchased a 96 coupe
- what kind of rotors
- Trouble with my B16 swap in my 92 hatch.
- HOW TO SLAM MY CAR WITH SLEEVES?
- What can I expect?
- Name Of Paint For 92-95 4-Door Dark Bluish Green !RARE COLOR!(G-71P)
- cel code prob....
- Opinions Greatly Appreciated
- Ebay Rotors
- left turn signal
- turning car on
- Removing Heater Core from EK
- What would it take for me to...
- will 96 civic struts fit 95 civic struts?
- 95 Civic Question
- greddy muffler?
- f'd speedometer
- integra axleback on 98 civic coupe??
- cruise control removal
- turbo fittings
- B16 or B18
- EG vs DC stock spring rates
- New belt, same squeel
- Civette - Honda Civic with Corvette engine
- Car wont start after compression test
- does this oil pan look dented to you
- fuel tank pressure sensor
- valve lash
- Some help with brakes ..eg hatch
- want to borrow : d16z6 clutch alignment tool
- alright i have a problem with my h22 swap into my 99 ek hatch the shift cable problem please help
- Finally a Honda Owner : Doing Tune-Up this weekend...help if you can?
- Manual fuel pump cut-off switch
- hard as hell to get into 5th & reverse sometimes b16a3, matching tranny
- help with CEL problem
- Numbers?
- OFF SUBJECT BUT NEED HELP!!!
- d15b, no v-tec . help?
- stupid question
- EF suspension on EK platform searched
- Best OTC Brake Pads
- Gauge panel
- Civic SiR and Civic Si
- Brian Crower vs. IPS k2 in ek chassis.
- b18c swap into auto chassis 95 dx
- gsr in a 97 civic help
- Car cuts off then comes back on...
- How long it will take?
- Difference between DC2 rear Sway Bar and CTR
- high flow
- harness conversion?
- honda civic hatchback engine conversion
- AEM Adjustable FPR LEAK!
- CAT length?
- Problem with Head Gasket...Or Cracked Block?
- quick ??, i've searched
- ITR cross member brace on 96-00
- Need Clutch switch
- EGK..???
- dc2 itr sway bars
- hi
- Shifting knobs
- what ecu is the best?
- D series tranny bearing
- Camber kit, yes or no?
- DID I BEND A VALVE
- quick EG power door swap question
- Who makes an OBD II carb legal catalytic converter for a 2000 civic?
- I NEED This:
- Map Sensor for B18B in a EG Hatch
- Start-UP + Clutch problem?
- Whats my civic worth?
- 1995 civic ex
- I'm have a mini swap but i still dont have the p28...
- Vtec controller
- First code 8, bought new Distributor King dizzy, now code 9, HELP....
- idle issues
- Broken Clip on headlight
- Oil Pan Compatability Question
- how to identify JDM B20B??
- 95 v-tech dies after warms up HELP
- few questions about dseries builds and otherss
- Pro's & Con's of Ethanol?
- info would help me out tons!!
- can you put ctr pistons in a gsr or would you use type r?
- 4 door taillights
- help, domani ecu, d15b, 92LX, auto to manual
- b20 vteck cams?
- Skunk2 What can i expect?
- weird sound coming from motor
- car heats up then gets cold **searched can't narrow it down**
- Clutch Question
- High idle?
- D15B Vtec Q
- Mudgards?
- Tools
- civic headlights 00 to 98
- clutch bleeding
- D16y8 help
- GSR help
- radio block off plate part #
- getting db tested for modified exhaust ticket
- stg 2 clutch too hard for stock d16??
- clicking noise after new clutch?
- bolt-ons for b16a2
- are these 15's or 16's??
- need to run my vtec wires..first time doing it
- tuner shops?
- Upgrades
- vtec head or bigger cams and turbo?
- 3 line power steering loop?
- jdm d15b vtec swap troubles please help
- mudguards. do they fit or do you need to drill holes?
- Radiator W/ no Fan
- SIR tranny problem...
- Help whit seat
- Valves?
- 92 Civic - Replace Timing Belt?
- Engine swap Questions, need a little help
- HELP!! MORE PROBLEMS! car redlines at 4700 WTF?!
- k20 swap in a 98 civic hatch
- OVERHEATING COOLANT ISSUE
- Suspension Upgrade, suggestions?
- Help with swap please
- What are these plugs?!?
- what do you call those front lip protector?
- OBX LSD overview
- engine mount
- wiring question
- *****IGNITION PROBLEM????? 92 HATCH B18C1***********HELP!
- y7 and z6 timing belt
- del sol seats into ek
- wipers and windows no longe work wtf?
- anyone has this
- Freshly Built Ls Vtec oil prob
- skunk2 springs and gr2s? real quick
- Can anyone help me with my shift linkage?
- will 5dr edm civic rear disc brakes fit a 97 hatch?
- Overheating at Idle
- How do I know if my catalytic converter is bad or ok?
- questions about putting an engine together
- y7 crank pulley
- Si Brakes & Suspension into DX
- CHECK ENGINE LIGHT ON; I GOT THE CODE
- CHECK ENGINE BULB ON:HONDA CIVIC 96
- eg9 rear seat???
- humming noise after vtec or slight WOT?? --->B18C/ Anyone ever ran into this?
- Hood Latch Stuck - Help!
- fuel pressure regulator
- Swapping a SOHC for a ZC DOHC
- IAT sensor trouble
- screeching noises
- y8 over heating and spitting coolant, someone plz help!!
- obd2 b series distributor problem
- Emissions help
- Airbag ?'s
- idle's weird and bogs HELP!!
- JDM ZC non-vtec timing belt issues...(yes, I searched)
- swap
- Yes yet another stolen hatch :(
- what do the P numbers mean regarding the ecu's?
- ecu question
- cruise control
- whatb ecu is this?
- Never thought it would happen
- just got my springs installed.
- v-tec controller
- Engine Swap for my honda civic ex 1997
- Could somone identify these motor mounts?
