View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Problem with My EG w/ SI swap
- 1997 Civic EX 2dr Coupe
- z6 head on y8 block.....which head studs do i use?
- Wicked IM
- help with ac after swap
- exhaust reasonator on 2.5'' piping
- d16z6-T vs d15b vtec-T
- turbo civic?
- EDIT: Anyone know where to get the downloadable helms for the civic?
- Anyone know where to get the downloadable helms for the civic?
- [FAQ] What parts are interchangeable for all 92-00 Civics?
- hood switch
- EG Hidden Exhaust?
- mist a shift wont start now. now code 10
- dealer says tranny trouble what now?
- I Have Three Minor Problems With My 96 Civic Hatch. Help Please
- 5Speed Racing
- dash trim
- Swaybar grease?
- Headlamp problems..
- *LOOK* Please indentify this screw
- keyless remotes
- PLEASE HELP Search by license plate history
- Timing Belt Brand Quality?
- Rust dilemma need your input QUICK!# pictures
- AEM V2 Question
- will a lightweight crank pulley make any diff?
- VTEC not working. Redlines @ 6500 now
- STD BORE VS OVER SIZED BORE
- Some of those basic Questions...
- NEED HELP!
- Odometer swap
- Universal mufflers?
- b16 idling rough
- lowering help on 01+ civic
- Yet Another Seafoam...
- ebay headers..
- HELP Will they fit?
- b16a dyno results
- Falken Azenis
- 92-95 driver side door window glass???
- Weather Stripping
- TOP SPEED 4-1 HEADER
- 4dr vs. 2dr front end
- SO MAD NEED help.!!!!!!!!!!!!!!!
- tail light question
- Is the inside of an intake manifold supposed to be completely dry?
- Are there any replacement guages for my 94 ex?
- WTB EG hatch SO CAL within 1 WEEK
- Just ran a compression test...
- rims
- where to buy ARP head studs/bolts for d15b7 non-vtec
- what wires control the fuel pump?
- HowTo: Leakdown Test / Compression Check
- 6th generation Civic automatic trans shift points / speeds
- looking for high HP d series turbo setups on pump gas, please post here
- Will a 99-00 Si armrest fit in a 96 ek hatch???
- EG Vision Amber corners
- hollow out a cat?
- bought new main relay still no Fuel Press?
- TPS sensor location
- Ls 4 door eg
- Greddy SP style or Apex N1
- 92-95 doors interchangable?
- rip off?
- Question for Del Sol owners, please help!
- location of main relay on 99 civic?
- 99 Civic taillight/plate fuse keeps blowing need help big time!!!!!!!!!!!!!
- Crazy '99 Si
- Stock Looking Exhaust for EG...?
- JDM parts
- B16A Hmm... gotta love em...
- Apex'i N1 Pro Dampers
- JDM d15B still burning oil. Possibilities?
- How do you 6th gen guys fill your cooling system
- what are those bars that connect between your seat belt mounting points???
- how do u tell the differene between gsr and si tranny?
- Salt Flats Civic...?
- EG/DC....SHOCKS..WILL IT FIT EK..HELP??
- MAPS sensor problem?
- Is This Normal For An Engine?
- 94 Del Sol B16A S-AFCII pinout
- civic 97 idling high
- over heating?
- vtec question
- 92 civic ex alternator seize???
- car shows and get-togethers???
- My Oil Catch Tank...can someone give me a little more info on this??
- Vtec Hook up Help
- CTR rear seats in 99-00 civic coupe?
- Just got a Fart Can off eBay, anyone familier with it??
- electrical buzzing
- 215/45/16's on EK
- pulley question
- Battery keeps on needing a jump
- to boost or not to boost.....
- Learning da Manual Car
- d17 in 94?
- HELP. I'm the machine shop pressing bushings, and i do not rember which way the large front LCA - to
- smog wont pass need new registration.....
- 1998 honda civic dl
- recomended cam upgrade
- Burnt/Singed 02 sensor
- Things to check when you're running lean?
- Any1 selling a Del Sol ?
- engine pinging
- Air Pressure in these Tires!1
- HELP!!!!! whole car shorted out!!!!!!!!
- Bulk oil filters?
- weird blinker problem since my car came back from the bodyshop
- What are some good radiators?
- cam gear
- 185/50/15
- Are cold air intakes bad?
- How to make my corner lights blink faster.
- 00 civic No HEAT
- Any tips on buying used car?
- How do you change a cluch on a del sol or any other manual car?
- Seat belts
- Keyless Entry System
- Radio and clock fuse
- help in what i should do with my civic ?
- removable steering wheel
- Clutch or tranny?
- cure for inaccurate oem tach..
- Will gsr/310 rc injectors work on my obd-1 b20 setup?
- Cold Air Intake
- EG6 Question
- Does anyone have pics of some lowered civics?
- Plz help me find a single pulley for my 97 gsr
- Interior or exterior first?
- Clutch Question?
- help needed ls/eg
- eg 4 sale (la area)
- fitting a turbo to my civic 1.6 lsi coupe 1997!! need help!
- hmmm....i got a question for all you hatchback genius's
- i got a 97 civic hx auto tanny went bad, can i use a 96 auto dx trannt HELP!
- Radiator Fan
- 4-2 - 2-1 header question
- where also can i get a b16 offline?
- EK JDM multimatic diagnostic
- Power Window?
- STRUT BAR & INTAKE FITMENT
- any reliable shop to do swap?
- Where to buy obx LSD's
- The Impossible Mission?
- Brake Bleeding Problems with GS-R disc conversion? People Possessing knowledge or intelligence pleas
- I dont know what the problem is...
- HELP ASAP STUCK HERE
- gsr rear seats into 96 dx civic hatch
- turbo rebuild
- wheel diameter
- Getting a B16 into a car
- gsr with a b16a2 head feedback on the setup
- How much over heating does it take to cause damage?
- needs help!! turbo problem
- 220HP Vs 170HP
- b16 head
- car stolen need donation
- B16a top speed?
- What do you guys use to flush out you engine...
- Intake manifold help? Need answers??
- what are the steps of putting in a short shifter?
- Radiator Question
- purchasing a new motor.. help please
- Help with short throw shifter - '97 Civic DX
- wiring my city lights..
- Installing cold air intake on my '97 civic dx
- Brakes are firm then soft?
- noobie coolant question
- suspension on an ek hacthie
- Parking Brake Lite
- Will a 97 Del Sol AC compressor work on a 93 Del Sol??
- quick turbo questions... civic related
- b16a
- How do ya remove the rain gutter trimming from an EH (EG)?
- Sound Clip....AND YES I HAVE SEARCHED YESTERDAY AND TODAY
- Are rear spindles Interchangable? Disc and Drum?
- 96+ AT gauge cluster w/ tach
- Stolen C/F duckbill!!
- b16 a-1 help
- 92 civic si front brakes Interchangeablility???
- Motor Mount install with a swapped EG and with the motor in the car
- Blue smoke...
- best d-series swap
- are all honda main relay's the same?
- Type R
- Car overheating?
- where to buy main relay?
- I got a friend that has a 97 civic ex 2 door thats been lowered and its likes to eat tires
- What kind Oil
- Go for airmass thundermuff exhuast for 150$ or es oval with custom piping?
- miss shift from 2nd to 1st at 5k
- Rear Seats
- If you are from Minnesota, please read this
- I got a friend that has a 97 civic ex 2 door thats been lowered and its likes to eat tires would lik
- Searched already: OBD0 b18a into 92 Civic?
- rite
- loud tick when i start the car
- b16a head
- CAR THEIVES
- Is this a good buy?
- Scratched wheel
- both civics have b18b how much does weight effect accelaration?
- 97 civic ex aem big brake kit big rotor stock caliper
- securing you ecu idea
- fs ctr crank pistons and rods
- d15b swap.. need mad help
- would you trade if you were me?
- wierd noise when i accelerate, bad wheel bearing?
- need some feedback guys...
- vtec point question????????//
- Steelies Are Bent...Got A Quick Question
- Quick question about starter
- 02 sensor 4 wire (wiring)
- How to Height Adjust Tein Basics
- Shifter Problems.......Need help.
- 2 wires comioff of knock sensor in obd0 jdm b16a
- 8 or 16 valve
- cryo + autolock = stronger???
- obd2 itr swap into obd1 hatch.... what harness?
- Leather or Vinyl Seats in 5th gen
- NEED GUAGE CLUSTER HELP!!!!
- sorry for the n00b question but not sure what to search for.
- !!!!!!!!!!DAMN THEIVES!!!!!!!!!!! They jacked my Stereo and my ECU!!!!!!!!!
- Hawk pads
- Details on ITR motor in a 95 civic
- AC Compressor Clutch
- Anyone rockin ctr red caroet in there em1
- GSR and 00 Si radios
- Hondata anybody?
- d16z6
- /// Perpetual Concepts Archive \\\
- Toda individual throtle bodies....
- Need help looping ps after b16 swap
- Small black antenna
- 99 civic wont start
- broadway wide view mirrors
- HID's on Civic
- Will resetting ECU affect after-market alarm system????
- phasenine f0cked up service!!! no love from me
- Wheels
- Fuel Pump wont turn on
- Car stolen, October 14th, 2004...
- best clutch
- valve adjustment problem
- coolant bypass, searched
- car was put in 2nd gear on highway and wont come out of limp mode
