View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 94 coupe carpet in 92 sedan
- surging idle
- Brake upgrade and 15" wheels
- my friend just told me he bought a TYPE R
- ***Shift Light Help QandA
- has anyone have any experience w/ an ebay distributor?
- help with engine serial #
- 93 civic with 99 seats
- Transmission or Clutch Problem?
- 90-93 teg back seats in 92 hatch (searched)
- vtec controller on single cam? ya? na?
- sleeving?
- high rpm miss
- my temp gauge stays on cold
- HELP!!!! gauge cluster/turn signal/clock problem.....
- anyone eliminated abs on Si hatch?
- Help looking for d16y7/y8 conversion HOW TO?
- anyone know about this???
- lookin for engine harness...obd2a ex
- B16 swap into EG hatch
- "Spoon" VIS CF Lip Install EK
- CLUSTER QUESTIONS!!!
- Turbo how to?????
- were can i find a del sol lip?
- vtec not engaging/ low oil?
- EK '96-'00 Civic Password:JDM Aluminum Cooling Plate
- main fuse box diagram
- hot start problem + random stalling = bad main relay??? help pls.
- Break in period?
- Losing a lot of gas
- Turbo d series question
- Engine Mounts!
- need help
- a/c in 93hb with b16 questions
- Crome tuners in San Diego?
- z6 question
- DEL SOL front and rear bump
- Reupholstering Del Sol Seats ?
- FAST HELP PLZ!!
- Too Stiff
- do u know where is it??
- car got slower?
- Turboing a 95 Civic
- weather guards for 90 4dr
- upgrading brakes on del sol
- fuel system specs?
- 99-00 headlights- help!
- Car dies once warm
- LSVTEC Hesitation
- turning problem on 92 vx
- Leather Si seats?!
- swapping out my z6 tranny for a y7 got a few ?
- Reputable jdm websites
- i have a civic 95 si and i cut my spring
- who makes nice aftermarket carpet for eg with perfect fit.....
- Magnaflow or Apexi? (exhaust)
- Can anyone in Sacramento help me out? Disstributor test, OBD1 DOHC Vtec, will reward with beer!
- is god speed racing co. and good?? is xsracing company any good??thx for any help
- type r brake lines
- EG sidemarker template..?
- Exhaust Manifold Tempurature?
- Help please !!
- *********S2k Seats*********
- hey guys, will a d16y8 bolt up to a y7 5spd transmission?
- Jdm D15b vtec motor swap question
- d16 head swap?
- what seats have rails that fit a del sol
- 99-00 si rear rotor minimum thickness ?
- what size valve stems do i need?
- Boring/honing sleeves.
- BAR question..
- 99 seats into 93 civic?
- is it necessary to change your axles when doing an engine swap
- resistor box help
- 92 si with a cx motor smogable ?
- quick question..
- electrical problem
- Reccommended shocks
- Car gets fuel, spark, but no start!!!
- Ebay Yellow Fog lights.... already searched Yellow or standard color?
- Del Sol Body Kit?
- Help!!! Tranny is making a whinding noise when driving, almost like a supercharger.
- Where can I find a D16Y8?
- Exhaust + Header question...
- Help- having problem after v-tec engages in my d16z6..
- QUCIK QUESTION!!!!!>inside,click here to open!!!!
- H22A Del Sol, what upgrades can i do?
- HONDATA?! Super noob question!
- Jdm Headlights?
- 99-00 Si lip...help...
- one of my sockets / wire clips is not plugged in... help
- sqeaking noise while releasing clutch.
- knock sensor help me...
- IS there some fluid left?
- Tranny question: checking condition before install
- ZEX 59300 cam.....stock ecu?
- a/c bezel lights fuse?
- b16 b20
- My axel is stuck... wtf
- What color Interior???
- Civic hx
- How much does my car weigh?
- Legality
- Car starting problems
- A belt is making noise on my gf's EK hatch.
- AUTO TO MANUAL CONV. MANUAL GSR INTO EG HATCH
- Head buildup question NEED HELP!!!
- Looking for engine weights 92-95 VX (D15Z1) & 96-00 HX (D16Y5)
- fuel pump fro b16a2 need help ! ! !
- Help i cant log into my old account?
- P0172 Engine Code - What to check?
- cruise control?
- valve train ls vtec
- stock exhaust with b series swap
- D-Series to D-Series
- car tires rub on fender.. HELP!!!!
- 2000 si donut gasket!!!
- Quick-eee
- 2000 Civic EX Projector Headlights
- anyone looking for DAILY DRIVER?
- Motor/tranny mounts
- High Idle
- H22a In 93 Coupe
- Would the a/c from a del sol work on a 93 civic si?
- Difference in SOHC tranny's?
- Possibly a bad caliper?
- removing rear caliper on 92 Si hatch
- How much HP would port and polishing give me?
- Removing Speedlimiter from CRX del sol SiR?
- 93 hatch help please
- Help please
- ::DIY:: Cleaning Fender/ Rust Prevention
- Skunk2 camber kit pin
- 96-98 Hatch Carbon/Glass Body parts suppliers???????????????Help
- EK hatch glass replacement
- a/c system
- any comments on buddy club exhausts
- Del Sol Lip. What the hell fits?
- Civic shocks on a del sol...
- 92 civic vx... d15b tranny will fit?
- EX vs. Si front brakes?
- B16a into 92 cx...wont start!!!!HELP!!!
- Headlight Problem, high beams work, low beams don't
- switching seats
- Fender Cleaning
- help! 94 del sol LOST SECURITY CHIP
- Loud Fuel Pump
- WTB: honda del sol
- JDM EG(92-95Civic) Center Console, has anyone found a decent deal on this part? Or even a copy?
- help: does em1 vti-r caliper/disc brake fit eg vti
- y8 build
- swap help.......mounts ????
- Lean or Rich
- auto to manual trans swap 93 civic ex measurement request clutch hardlines
- What do you think I should do?
- Putting on SIR Lip Help!
- f20b eg dyno
- NEED HELP..... VSS/ SPEEDO NOT WORKING!!!!!!!!!!!!!@###@$@#!@!@!@#
- how well do del sols handel
- Bypass 94 civic dimmer switch
- Stupid question about oil changes on my car...
- fuel pump not kicking on
- Ebay power spoon mirrors WIRING NEED HELP!!
- when to replace your catalytic convertor
- Quick Question....
- stalling, no cel
- Upgraded to 90-93 rear disc breaks on the 92-95 HB. Tires are rubbing real bad. Any sugestions??
- Bigger intake tubing?
- Tranny
- Main Seal on D16Y8?
- Dry icing the interior
- help needed picture would help....
- what brand makes carbon trunk for my EG8 4door and if so il buy it...
- HELP need 2 get the car inspected but its leakin oil (95 gsr)
- B16 sirII shift linkage question!
- help
- how to clean intake mani while on car
- Home made turbo kit?
- Police Radar scrambler and DETECTOR?!?!
- How do u elimanate Emissions?
- memory wire on obd2b
- idle problem on a 93 civic dx
- my civic.... any suggestions?
- Stock 2000 EX +30hp?
- EG to EK Front end conversion
- engine swap question
- Another HID question (SORRY)
- 95 EG6 HATCH hood install help !?!
- quick brake question.
- auto tranny trouble
- demand for del sols?
- quick swap question ECU
- NEED HELP With SELLING ITEM!!!!
- seafoam problem!!!! HELP ME PLEASE!! (humming noise from intake)
- HELP type r 4 lug
- JDM CLEAR/RED REAR LIGHTS I NEED UR HELP
- zex cam
- i am looking for some parts for my eg6
- tan ferio interior
- stock d16y8....broken input shaft....wtf????
- DOHC del sol radiatior help...
- What Engine
- Weird Noise
- desperate
- Trying to make my D15 B8 fast
- what steering rack
- FAULTY CRANKSHAFT SENSOR...NEED HELP ASAP
- Idle Issues, again....
- rsx cluster in a 00 civi hatch
- What Should A Stock H22 In An "EK" Run In The 1/4 Mile?
- *Update* Keeping my del Sol front end!! woot!
- How can i find out what kind of engine i have in my H/B?
- is my timing off? (vid)
- will this wheel offset fit on a civic 4x100 hub without scrapping?
- help on my dohc zc
- Suggestions in fixing a hit front end!!!!?
- 92-95 Master Cyl on a 93 Del Sol???
- Looking 4 M3 style wing for civic
- Can I Remove the Door Panels with the Doors Closed?
- do ihave to change my o2 wiring?
- 93 hatch chasis
- GREDDY FRONT LIP ON EG? POSSIBLE OR NOT?
- 98 honda civic
- D15b8 wants turbo?
- B16 tranny ?
- LS?
- clip on del sol window switch?
- Thermostat problem that I think I have narrowed down. Need opinions.
- Best ECU for a B18B???????
- Heater problem??
- vaccum line problems in a swapped 95 hatch
- Wire tuck question
- Skunk2 manifold
- EK Cluster Panting??
- Car runs WIDE OPEN!
- CEL 6, 7, 9, 10
- Replacing motor mount inserts
- what types of rear brake calipers wil fit a 94 b16 delsol (with abs)
- ek cluster into eg...
- Axel replacement question?
- WHICH FREAKING A/C BRACKET
- del sol Question
- Weird wiring issue...HELP!
- Question on JDM 92-95 Coupe
- im sry im asking this question but how can i get started on a turbo kit
- throwing code 1,o2 sensor?
- High Pitched Squeal/Grinding During Acceleration?
- Starting Soon with new build of blown motor
- B18C1 obd1 sensor W/ Obd2B harness PLEASE HELP.
- just done with swap....NO CLUTCH.NEED HELP ASAP
