View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Eg's with H22's
- Wreck my ek
- Clutch problems..
- Who Lives in Orang County? post where ya live and what car
- NAXOS Bulbs Reliability?
- New Toys !!!!!!
- just got my EG.....
- right hand drive
- my Si gas mileage ! ! !
- projector tail lights
- vtec solenoid...
- sir & gsr
- Del Sol dash in EG?
- Widest practical, possible street tires?
- Junk or Treasure? D16 engine...
- lowering my hatchback
- brake upgrade...
- Car buying question????
- How much are EJs coupes selling in your city/state?
- guage cluster??
- G6 Civic dash fuse
- Should I? Yes, No?
- putting a teg dash in need help?!?!
- Are aftermarket crank pulley's bad for the crank???
- 92-95 coupe exhaust
- Hondata or PowerFC
- Hello, I'm new here, bash away :D
- how to: remove front dash
- 15" OR 16" is the ???
- 92 Civic VX w/ 157k miles........how much $$$
- 92-95 Hatch or Coupe WANTED!!!!!!
- Motor Building ?s
- shock question
- Stupid Questions from a Teg owner!!!
- right hand drive setup
- color desision
- Need opinion. I'm buying wheels. What color for a tahitian green hatch?
- Sad news From NOVA
- Traded the 00 FBP beast for an 02 yesterday.
- I hate this...I can't decide!
- Need Rear Control arm set up...
- wut car is this cluster for?
- Opinions on this Del Sol?
- import show??
- Rear brake question
- Need some purchasing advice.
- Gran Turismo Spoon Civics
- CRX seats...
- suspension setups/h22 swaps
- goin hybrid with EG what motor?
- airbags?
- How hard is it to install a cam gear?
- Interior Colors?
- Got My 99 Si Yesterday!!!
- new user
- HELP identify tranny
- C's Short shifter, easy to install it yourself?
- Throttle body !!!
- Buying a Civic with Damage?
- Dude, i'm lucky
- What to put in front license plate holes...?
- Five Lug conversion
- asdf
- quick question...
- Audio Center Consol
- Can I use......
- Brake pedal going to the floor slowly
- front sway bar removal
- Street Races in SOCAL....
- 92 dx hb 2178lbs vs. 92 dx sedan 2275lbs
- Steering wheel ??
- USDM shop in Japan!!!
- Too Hot? Apex'i Turbo 3psi... Revs at 2-3k after run
- fuel filter removal
- parts needed to swap an ITR engine in a Del Sol
- b16a1 in 93 dx hb(yes i tried the search and found nothin)g
- Type R Lsd
- what kind of exhaust???
- speed bleeder sizes....
- anyone delt with extremedimensions before good or bad
- 96-00 Hatch w/ eibach prokit.....Anyone have pics?
- MIR results
- URGENT!! Please help....
- anyone snap an axle with falken aziens???
- Del Sol bodywork question
- Skunk 2 Short Shifter Install
- HKS what the heck does HKS
- If you have 99-00 civic si....what would you replace it with?
- Goin turbo, what tranny!
- Weighed my car (approxamate though)
- will my ex rotors fit on my 92 hatch????
- Which B20 block ???
- jdm or usdm
- NGK wires?
- b20 blocks any problems????
- Type One Exhaust?
- Where to get swap done in VA?
- Skunk 2 tower bars
- Tires, Tires, Tires
- Injectors from a Prelude fit in a B16A3?
- WTF? JDM D15 Vtec and JDM SOHC ZC VTec
- Making a screensaver
- Can I get a lsd tranny for a sohc vtec???
- any good web sites?
- Cam Swaps
- What motor mounts ?
- Could someone do me a huge favor, please?
- b16a 1st and 2 gen b16a do you know the difference???
- My 1st time...
- what to do to a b20 for BASICS?
- is there any EG owner with ES motor mount inserts?
- EG with LS swap
- What is EK/EG?
- fitting probs with Apexi WS(2000 SI)?
- which hatchback is heavier?
- Swaybar question from downunder
- itr muffler in ek
- Timed my car today again.
- 99-00 si question
- LS/VTEC Conversion
- RH cp-10 in 15's ..weight?
- RICE??????
- Project CX gets love....
- B16 vs. B17 do you know the difference???
- Weight of 99-00 si wheels
- New xterra color, what is it called
- Speedometer
- act clutch experience
- smoking past 6500 rpm
- 96 hb and the 99 hb
- Stock air box washer/spacer & bolts
- B16a or B18b injectors
- Roll Cage Question !!
- whats wrong with body kits?--kinda long, sorry
- Painted valve cover, it's no B but still...
- My car is apart and I need a quick tip! Will a coupe Si spindle fit on my EG???
- Tint
- A/C Bracket for B motor???
- SOHC-DOHC conver.
- ITS alive again...my civic is alive...a few Q's on high compression motors
- EG6 Cluster
- need this piece its buggin me
- Looking for pics of a 96-01 two door civic coupe with autopower rolebar or cage.
- B18C swap in progress...which harness is which?
- Code 67 - how to fix? [Catalyst system Efficiency Below Threshold...]
- Modified Exhaust Ticket, check it..
- Who owns that 230whp camouflage EK? ? ?
- DOHC and SOHC same AEM cia?
- Turbo
- Ecu Error Code 23 Help
- del sol owner please help!!
- Going for BROKE!!!!!!
- does anyone else feel the same way...WTF?
- best of both worlds
- Engine scraping while idling
- what is needed to do a h22 in a ek?
- 4 point bolt in roll cage ?'sss
- Civic's sway bar / Anti roll bar kit -
- EG rear speaker panels
- mandrel bends
- eg and ek weight diffirences?
- LS IM or b16a IM???
- f-ed up engine(need help)
- mount
- 5G Hatchy weight....
- who sells rear disk conversion for eg's
- best engine swap for my 92 dx
- prefer LS or B16a2 in EK hatch?
- wat does blueprinting mean????
- Removing EG hb rear seats
- 2002 Si parts
- Starting problems!.....Please help!!
- Door indicator on EG9 Cluster panel
- Just got back from the Dragstrip..... :)
- what clutch is for sohc zc trans
- muffler options?
- 92 cx axles fit 90 civic?
- too all of you ex owners
- Hey guys I am looking for a turbo for a 2002 Civic EX
- Got my car back from Importbuilders today.....
- bad 02 sensor
- need brakes!!
- Does anybody(besides AEM) make rear big brake kits?
- What's Behind Here??? :)
- ignition system Q's...
- ARGHH, how the hell do u wire the horn with aftermarket steering wheel?
- b18c or ls/vtec in my hatch???
- guys that actually HAVE the H22 swap....questions for ya.
- Anyone have a pic/s of 00' red civic (Si) with Mugen RnR's??
- 00' Si vs. 01 GTI VR6...
- scraping issues with apexi n1 exhaust?
- Is a d16y7 a VTEC or not?????
- tire question...need help
- Better ignition wires? MSD or Magnecor? Need answer ASAP!
- Back Seats
- which is faster? 99 ex or 2001 ex?
- How much would you guys pay for a JDM
- B20 Turbo or CRVTEC
- Eh2 + new muffler
- hneed JDM side moldings for a 99 EK quick!
- stupid question about spark plug wires?
- SPOON mirrors......................
- B16 running on a p28 - question
- Debate this: Which motor will make more power....
- can some when send me the link of installing a 99 si cluster in a eg
- Idle problem, and then the CEL went on...
- what would u perfer?
- cusco oil catch can..... got a question
- My door wont lock!!!!
- Hatch strut broken?
- phantom grip or slip
- chipping P30 question
- ECU help!!!
- Coolant Problem???
- What's a good quiet stainless catback with a 2.5" dia?
- AEM Brake Pad ** Good ? ***
- What will I run??
- Brakes or struts?
- CTR City lights
- Civic hatch body conversion?
- someone analyze my 1/8 mile runs
- crvtec or h22 in eg?
- Do the real visions have " black" framing?
- FS: Racing Hart CP-8 and Brembo Big Brake Kit
- no flames needed: EG hatch, what year h22 should i be looking for? any year?
- Guys help me out here, I don't know Hondas....
- eaBack seat removal on a EJ
- what would you pay?
- ls/ teg
- New wheels!
- Any others make 4 point front strut tower bars other than Neuspeed?
- Installed my "Spoon" Clutch slave hose today!!! Verdict: ???
- Motor and Transmission mounts
- trickling sound when accelerating
- question for EK! JDM question?
- Should I buy it?
- How much boost
- should a 97 taurus beat a 95 or so civic
- Pedal Assembly Question
- brake problem on sol
- Stock Fuel Pressure
- What will i run?
- Shifting problems
- post your times
- Where can I buy Spark plug wires?
- newbie question: LCA's
- updates,
- Rear Drums
- Will '94 Civic EX exhaust fit '94 Civic 4 door??
