View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Running Rich
- Hondata Kpro V4 On Line Ignition Off
- Civic jerking at cruising speeds
- Hesitation/struggling on acceleration especially on hills
- Wiper stalk from '93 sedan --> '93 hatch with rear wiper OK ?
- TD-44U Distributor Rebuild
- Major screw up at first start..... Lost and need guidance
- Rear compensator arm and accessing the captive nut
- Distributor for 1.6 Vtec
- Civic Start and Stall After Swap???
- Car starts up then dies in a couple of seconds, NEED HELP PLEASE
- 00' Civic VP Sunroof?
- Civic 2000 Injector 3 short and flooding the engine
- OEM Part# Confirmation - Firewall Grommet
- Repaired blown head gasket, now throwing code P0420 (cat convert)
- Need help possible blown head gasked
- Replaced throttle body now boucning idle when engine cold
- Taillight gasket for Civic EG hatchback
- No crank/no start after engine swap
- 1996 civic radio questions
- Best fuel economy for d13b with vtec
- My new toy needs some serious help!
- Proportioning valve 98 honda civic EX
- No spark No Injector Pulse - B16A2
- 3D printer .stl file for an EK dash?
- P1166 code
- My country is introducing 10% ethanol to fuel. Safe to use?
- Stuck in 4th gear
- 97 honda civic d16y7 dies when warmed up
- 1999 honda civic ex sedan
- Obd1 engine in obd2 car
- Big brakes
- 1993 civic does not turn off with ignition until brake is pressed.
- P0420 1998 civic lx help!
- EM1 spluttering consistently - HELP!
- Looking for new headers
- 1998 honda civic ex to 2000 honda civic hx
- Bouncing idles.
- Auto to manual swap
- Which bushing do I need to replace?
- K24a2 turbo swap breaks up bad under load
- B18b1 heater core bypass
- Fitment on an EG Sedan
- Rear coil overs don't fit Civic HX?
- Collision Repair Shop NYC
- How to ECM communicates my fuel
- Underdash connector remove for rust repair
- b16 all motor build
- B16A into 99 civic swap. Bogg/lag issue!
- B16A2 transmission options
- Shaky and vibrating
- B20vtec injector sizing problem
- Freshly rebuilt d16z6 question...
- Need help with 93 1.6l si hatchback
- Small revs when idle.
- Broken fuel rail mounting bolt
- Car cranks but no start! Help please!!
- EK Coupe Fibreglass Trunk
- engine and transmission swap
- 97 civic No airbag light
- Brake Pad Wear
- Oil light and car died
- '97 DX, smoke coming from engine and exhaust after cylinder head replacement
- 93 Del Sol S cranks wont start
- 99 Civic hatch door molding clips
- replacing em1 alternator
- Which blue color for my Civic EG
- 1996 Civic hx distributor
- Eg6 hose kit
- Toe-in preference for a daily driver
- is alwaysjdm.com legit website?
- Could use some minor wiring help
- Minimal Stereo Setup?
- 92-95 EG
- Oil Leak. Possibly Rear Main Seal?
- Best Seats EK Hatch
- Rear Strut Brace Bar
- Number of steering turns from center position on EJ8 with power steering
- Starter won't turn over
- 1999 Civic EX Tach Reads Wrong
- Misfire on 1 cylinder
- Replacement rear wheel bearing hub doesn't fit. What's going on here?
- b16 timing belt
- Wiring EDM 1999
- Need help to identity check engine code
- Just bought a used 2000 civic EX sedan, a list of questions for you fine gentlemen.
- Rough start
- SKUNK2 INTAKE MANIFOLD ON B18B1
- Need to change ecu
- Constant ground at injectors flooding car!
- Fuel pump not priming
- The Cost of Golden Era Hondas
- 1992 EX Idle Issues (Hot / Cold Variance)
- Idle at 2500
- Throttle Body cable adjustment
- Hesitation and fuel consumption
- Power Steering fluid leak on 1999 Civic
- d15b no spark and no fuel problem
- EG Civic B16A Hunting IDLE and jerking. HELP PLEASE
- 2000 DX Hatchback Cluster Issue
- Question regarding pcv
- Looking to Figure out name of this part
- Having issues with brum brake slave cylinder breaking
- Battery relocation Wires
- Help with rough idle and CEL codes
- Cooling fan doesn't come on, engine overheats. Tried everything!
- B20 vtec head issues
- Wiring questions: OBD2b B20 engine into OBD2a EK Civic DX
- Transmission seals
- 95 VX AC blows hot
- Removing coolant expansion/overflow tank
- Spark plugs for b16a ?
- Idle issues with eg B16a motor
- Changed fuel pump/ relay is good
- 93 DX hatch, failed smog, would like suggestions
- Messed up phillips bolt that connects the rotor to the knuckle How should I fi this ?
- Honda Del Sol 1993 - Indicators Not Working
- 5th gen radiator hoses into 6th gen
- T-Bracket eg8 Swap B series
- HELP! i broke off the coolant temp sensor wire on my 95 eg kswap
- 1997 Civic door speakers...
- Car won’t start after stalling
- engine serial numbers
- Obd1 dizz on obd2 head
- My 3rd Civic EK
- Car won't go into gear
- 1996 Civic DX won’t start unless I wiggle the wiring harness
- Car slips in every gear
- 99 civic wont turn on sometimes unless green drive light is on.
- Side door trim clips
- Importing Honda CRX ESI?? To America
- Starter Engages But Whirs Doesn't Crank Engine
- vtak noise
- 2000 Civic coupe Ex help problem solving plz!!!
- 99-00 OEM installed Raybrig fog lights suddenly not working
- D16z6 Swap/Wiring harness
- Overheating D16Y8
- Front Passenger side suspension knock
- I need help with my honda
- '94 Del Sol w/interesting back story
- my Dad is getting old
- I need help with choosing wheels and tires for my 96 ek4 hatch
- 2000 Honda Civic changed radiator. Car started then shut off.Now cranks but no start
- B16A Aftermarket Rod Choice?
- 95 Honda Civic D15B7 (Timing Belt Question)
- Ecu swap
- Axles/hubs
- Honda idle surge has gotten worse!
- Acura Tl Type s Spindles on Ek Civic
- Broken slave cylinder bolts
- Swapping 99 EJ door interior and electronics to new exterior panel?
- Help with 97 hx auto to manual swap
- em1 dizzy
- Help O2 check engine
- What axles to use!?!? 32mm 5Lug with JDM GSR tranny
- Brake light comes on even tho handbrake is down
- What brand interior LED lights for cluster / interior?
- Seal that's behind the timing belt cogg what's the name off the seal .
- Replace 00 Enginge with Preface Enginge D16Y7
- Tps problems
- D16z6 on 96 Civic ex coupe
- HELP HELP HELP1999 Civic P1259
- Gauge sizes?
- 99 Honda Civic EX A/T ecu obd2a or obd2b
- 2000 honda civic ex 5 speed manual d16y8 idle problems
- 99 civic spoiler install problems
- EG SI rotors/brakes abs and non abs
- Front AND Rear Sway Bars
- 1998 civic DX no crank electrical issue
- electrical problem
- Civic 2000 How to confirm if the springs are bad or the struts itself?
- 99 civic ex with jdm B16A swap HELP!!
- Main relay/ Fuel Pump not priming car not starting
- Red Honda Emblems for del sol?
- power steering belt
- Dc2/Ek9 rear hub on mb6/mc2?
- No Interior Lights/Dimmer Switch Smoking
- Modifying my sons 96 hk front clip
- Starter grinding/stuck
- How many 96-00 civics were green?
- *sometimes* doesn’t crank 94 Del Sol b20b+GSR trans
- Intermitten Wiper Controls not working (HELP)
- Camgear setting. Need opinions
- d16/S40 Transmission rebuild
- 1995 Civic EG8 shuts off/no start bad ECU???
- 1996 Civic D15Z4 - Slight RPM fluctuation when pressing clutch, causing jerks/ buckin
- EK hood lock compatibility for EG
- 1997 civic dx hard start/very rich/backfiring/runs rough
- Kswap eg help
- P1509 on 99 civic hatch
- Kswap problems
- Need Help: Can’t Get My 2000 EX into programming mode
- B16 strange misfire and bog issue
- Crank no start, no cel 98 HX 5sp
- Very faint rattle when under load - D16Y7
- D15 mini me ecu questions
- D16A6 block D16Y8 head and intake mani mini me swap
- D16y7 to D16y8 help anyone??? At a loss
- Jdm B18c into ek
- Am I able to run my car with forks rotated 180 degrees?
- Overheating issue 99 civic ex
- K swap in 99 ek civic on ek subframe.
- 93 Del Sol door latch cable
- Car turns off when starting in the cold
- 1995 civic lx door hinge
- 1996 Civic LX no crank no start, headlights works.
- 1998 civic LX- sluggish acceleration
- 2000 honda civic si ringing noise
- How to attach Pistons to Rods?
- 97 Automatic Terminal Corrosion + Shifting Poorly
- Fuel Pump wont prime, no spark
- EJ9 96-98 D14A4 lambda sensor after cat
- Jackspania Racing Harness
- EJ8 Window Tension Breaking
- Y8 Timing Belt issues
- B18C 2000 Civic wont start when warm
- Beginners guide to a power window/mirror conversion on EK1
- 1999 civic lx swap help!
- 1997 Del Sol Fuel pump prime issue
- 96 swaped civic help
- Best handling Hondas
- B series obd1 harness and ex civic harness obd2
- Civic eg Service connector
- K24 vs K20 weight, physical height
- Most reliable K series variations
- OBD1 D15 Block y5 head in 96’ Ex
- 1992 EG build plan / looking for suggestions/advice
- What is this gray thing?
- Stuck Trying to figure this one out
- Any good shops in Maryland I have an AWD EK sedan project I'm trying to finish
- Automatic Transmission Install Woes
- 2000 Honda Civic LX Radiator Fan Wont Turn On In Time
- S40 Transmission CS Hex Nut 30mm
- Radio not getting power
- Refreshed JDM B20B Issue *photos attached*
- 99 Civic (lx) D16y8 swap HELP!
- Honda Bearing removal tools
- 1996 Civic EX Sedan Wheel hub
- Speedometer not working 95 VX Hatch
- possible clockspring issue?
- Please I need help! B swap 1992 - 2000 civic
- Rough start in park
- Car died while driving, then the fuel pump would not prime. Then worked later
- 95 civic dx b16a motor idle air control valve
- Random Misfires in 99 Civic DX
- Help with GSR throttle body
- B16A2 Dist rebuild parts question
- PCM code 0
- check engine light Obd1 engine in obd2 car
- FIA SEAT RECOMMENDATIONS EM1
