View Full Version : Honda Civic / Del Sol (1992 - 2000)
- B16 vs B18 for autocross
- anyone have or know of an H22 in a 96-00 CIVIC Sedan? preferebly 99-00....
- do 90-01 teg coilovers fit...
- Did alignment and.....
- ot: Tein HA replaced by the SS
- Does anyone know if the Del Sol and the eg are close enough to....
- the cost of beefing up a sohc engine?
- Changed my gauge cluster&climate control bulbs to amber/red...Pics
- removing rear calipers/ebrake cable.
- ***92-95 EG: power mirrors??***
- New civic 2003 SI.. whats the chassis code?
- rumors need to be cleared up...
- Header Question
- quick suspension question when swapping integra parts
- What is redline for a 5th GEN Civic EX?
- motor mouns on 96 civic
- Del Sol
- Could the si tranny fit a b18...
- Question about Spring installation
- Aluminum or steel for a short shifter....
- Where to buy Teins
- Skunk2 Intake Manifold: Worth the money? Advantages and disadvantages?
- arp head studs are they worth it
- i have a Vtech problem.please help
- is it worth it?
- Someone Buy My Hatch!!!!
- which one cost more?
- NEWBIE in the HOUSE, Just want to share my car to the world
- 310cc injectors cause car to run rich...?
- 97 hatch B20 vtec
- hit and run!!! arrrgghhh!
- Removing Airbag/Steering Wheel
- how MUCH do black GSR cloth seats go for nowadays? selling mine..need advice
- Intake?
- How to remove stock CD player? (99-00 Civic)
- Anything bad with too much tranny fluid?
- Toronto Used Parts
- Honda Civic SiR....Maybe
- Toda Individual Trottle Bodies
- front liscense plate trick?
- Someone sell me a Neuspeed Upper Rear Strut Tower Bar for a 92 civic hatch
- EK antenna
- awaiting mods - help needed
- Remove front bumper when changing headlight assemblies?
- why is it....................
- Newbie.
- which camber kit for eg???
- Sedan, hatch sideskirts same?
- Shifter question......
- Got a brake idea let me know what you think
- I like this body kit
- Tranny question
- what kind of springs?
- Synthetic or Regular
- my triangle exhaust flanges are stuck together! what do i do??
- 93 civic VX....doing swap and cant find MAP SENSOR???
- maco painting services, do they look good.
- anyone did any sound deadening on a 97 civic??????
- new here. Here is my car. not much to look at
- Pics from local import society event ***56k beware***
- Motor Swap or Turbo
- did swap today
- fastest civic for 3k
- Painting window trim
- what do you think??? new head lights
- Spark Plugs
- what rims should i get???
- go sohc.
- Cam Gear Degree
- vtec-afc is it just for show or will it help me go?
- should i get an ecu (jet-chip upgrade)?
- what lower and upper hoses for H22a in 93 HB
- a6 head on dx?
- Please Help Prove old Civics are better
- Tuner Showoff Oct 26th in Atlanta for charity
- what brand tire you guys running???
- SOHC VTEC turbo vs. jdm type r swap, which one and why?
- slave cylinder
- Engine Swaps...
- Smog Help!! How do you guys do it?!
- Why does my car die out after i turn off the ignition for about 5 mins...........
- B16A2 w/ JRSC in my EJ
- Does year of block really matter?
- gas question for 96-98 civic hatchback DX
- Which Engines have more torgue.. the Si Vtec or the Non-Vtec?
- Frustrated as hell...........Please help
- Does someone on here work at Motorola Schaumburg?
- cam gears settings?
- i want to attempt this swap myself. what's the difficulty rating of this swap.
- difference btwn 205s and 195
- Any1 Live In Virgina???!
- are the blue te37's impossible to find?
- $275 for wheel bearings?
- SPADE whats up d15y7
- si/gsr/el front rotors on 98 dx sedan?
- Integra LCA's on 92-95 civic
- WTF??? 15 sec 1320
- Anyone Got 92-95 Civic Hatchback Red/Clears Tailights?????
- Newbie here
- Anyone going to Import Eurasia NJ?
- JDM type r swap?
- Want to make your turn signal or blinker go faster?
- How do you change the gear oil!???
- need ideas for a new project..
- good place to purchase rims?
- I need a vouch fellers...
- How to?
- Climate Controls
- For my NA ppl that are runnin a B16......
- bleed screw size??
- what would you pay for my Civic?
- EK Shocks on EG?
- Can I use a 97 dx ecu with 2000 si engine to pass emissions?
- ITR rear sway bar with beaks kit on EK
- Aftermarket brake shoes?
- USDM B16 vs. JDM B16......
- What rims do you have?
- Exhaust: 2 1/4 or 2 1/2 for all motor D16
- question about vtec engagement
- Does anyone have or know someone who.......
- Cai off CRX?
- i have 94 eg civic si ecu for sale. other stock parts.
- SSR competitions weak??
- wtf? 200hp factory K24?
- Problem with my civic "Spade maybe you can help me"
- Front Bumper Plate
- Dome Light?
- All around performance...great handling, great 1/4mile times, everyday driver... what do i use?
- While getting the bugs out of my car, I found bugs in my car. Gross. JDM BUGS!
- General Questions about new setup in the works, kinda
- 02 si or rsx
- how much would my car sell for?
- rota slipstream
- civic si 2002
- Underdrive pulley??
- Fuel Pumps...
- Would a clutch off this teg fit on my hatch?
- what is this on the SI rear sway bar?
- Swaps are good but what about stocks!!
- Skunk2 SOHC lineup?
- pics of ur civic
- checking codes/timing on p28
- Pics of my ride finally
- More JGE triangulated strut bar pics...
- Group Buy on Greddy Boost & EGT gauges
- 94 si cams into a 94 ex?
- Simple silly brake question
- Post 1/4 times...Just curious what everyone is runnin
- Fitament on autodynamics amber corners?
- vx or hx wheels
- OT: I buy used cell phones
- Fixing up my 99 Civic
- Getting ready to do Brake job on 00 ex coupe soon
- brake question???
- What Should I do???
- Well guy....
- ? regarding front jdm gsr disc on 95 cx
- Blasted CEL 1!!!
- Fake ctr headlights??
- need brake bad for integra brake swap...which brake pads to use?
- stupid f'in bolts!!!!!!!
- Who makes engine mods for 02 EX's?
- New Titanium Strut Tower barce for 92-99 Civic
- gsr/itr radiator in EH hatch..
- GSR Motor Swaps
- whats up with this advan sticker?
- Check out my new site!!
- carfax this VIN for me .really need it..thanks
- who's blue/white itr rims eg hatch on espn?
- anyone have a dx chipped ecu?
- WTB: 96+ civic hatch
- Who is Dr. Kimbal??? I need SiR floor mats!
- Here's a pic of my car again, what do you guys think, which is better?
- lookin to trade 01 py itr for ek hatch with swap
- Is this compression ok?
- Integra carpet in a EH hatchcrap...
- strange noise
- Will Spoon bars that go on DC2/EGs fit a 99 Si?
- Factory fog lights
- I know I'm a noob..but still...I gotta know
- Installing 02 Si seats in 99 Si
- Is this a good deal on stock brakes ?
- how much is a 93 ex motor and trans worth?
- Proper way of mini-me
- i am sooooo pissed off at the honda dealership!!!!!!
- Voltage Regulator
- Manual Conversion
- 92 cx transmission
- 2kSi engine harness into a 97 hb dx body. Question about diatribe with Katman...
- Oxygen Sensor Simulator
- Need to change the suspension of my Civic 2001
- Got some new seats for the Si **PICS**
- Anyone know an easy way to take skunk2 coil sleeve off of strut?
- 92 CX Cheap Power options.
- Question about possible battery/alternator/charging problems
- Finally getting a 5th Gen Civic EX
- question????
- Differences/1.6 EL and 98 DX sedan?
- bad business
- oil leak somewhere
- Need help spoon n1/T1R b-pipe will it fit?
- Which brakes will fit under 15 inch Rota Slipstreams...
- Suicide Doors
- 15/16 Master Cylinder for an EG del Sol-did a search
- Question about a B-series swap....
- Anyone have Integra Type R spings in the 6th Gen?
- hidden nos???
- Place Racing mount question... part 2...
- Gas tank Problems with apex'i n1 , hks hiper and custom exhaust ...
- Eg's with b18 swaps ? any one using hasport billet mounts ?
- Another what to swap swap question
- Questions about polished lip on Rota Wheels
- What kind of bulbs does the 92-95 Civic Dash carry?
- I got 2 questions
- What is the best cam and nitrous setup for D16Y8 with bolt ons???Need your ops!!!
- Widebody fenders for 92-95 civic
- best sleeper civic on H-T? who's got it?
- WTB: CTR stuff for EK
- will 88-89ish teg dohc motor fit...
- Cheapie Exhaust Cutout
- need help
- whats the diff. from 9mm and 13mm oil catch can?
- srs light
- took a trip to the body shop today (56k... is that still around?)
- How come Spoon Never raced an NSX?
- OT: TODA Product...AWESOME prices...LOOK!!!
- which comptech airbox may fit in a Del Sol?
- integra and crx sway bars?
- 92 Honda civic Vtec swap!!! loaded leather seats etc etc CHEAP!!!
- Looking for a 99-00 Si Front Bumper
- Anyone heard of these?
- FAWKIN THIEVES (@*%&(@*$&@*($&
- Pic request...white EG, CF hood, white 17" Advan RG's
- Tryin to learn...Engine Q?
- JDM EG headlights
- Anyone have carfax? Need a vin run...
- Integra Ls Motor drop into 92 Civic hatch..
- **people who have tein type flex i have q's to ask.**or anyone thats knows about tein
- Apexi Groupbuy
- body squeaks and creaks
- HELP!: Installing camshaft on d16y8 engine
- Headlight problems!!!!!
- 96 CX hatch with B16A2 - Help???
- what kind of mugen rims are these? 17x8?
- Frustrated about my car a little bit.
- OEM D-series Head gasket???
- HELP:Rear disc conversion
- big smoke flume in vtec!!! wtf?
- Strange Idle Problem
- Part time job opportunity
