- Zc Head On D15b7 Block, 92 civic
- Pic Request. RHD CTR COUPE, official Honda
- Ticking sound coming from exhaust, I dont think its an exhaust leak though... help plz
- upgrades!?
- 98 civic si\ex steering wheel swap
- am having a tough time which civic to pick
- Civic Overheating...Electric Fan? help ....? thanks...
- 98 Civic Si\EX Knocking problem
- got motor repaired now having trouble with tranny shifting
- Door Panel Removal
- i have an obd2 gsr
- adding horsepower
- H22 or Gsr in a 99 civic
- QUESTION ABOUT IACV
- 94 ex.. wiring harness help.
- Important Safety Recall: Ignition Switch
- normal voltage?
- cigarette lighter and gauge
- Car wont start????
- turbo or motor swap? whats better?
- hole in the muffler
- FMIC mounting help...
- IcM-- Dyna Mod????
- Just swapped, throwing codes HELP! VIDEO inside
- 97 Civic Hx Brake Light problem.
- questions about b20...
- nopi mini nats?
- iacv question
- del sol front bumper
- k20 passing state ref - any other gas tank ideas?
- timing
- 41 - primary oxygen sensor heater....wtf?!? someone help
- What are lower control arms for? (SKUNK2)
- Quick Question about obd1 Engine codes..
- timing belt for d16a6 with z6 head
- If i solder my audio cables will the sound be better
- HELP! Feels like Misfire but on codes???
- CEL Code 41, Primary oxygen sensor heater
- Tires???????
- Power steering....it shakes...putting it back together...why? Is it supopsed to?
- Whats the little grey/black connecter for in a 1996 Honda civic DX im so lost! connecting wiring bac
- rear motor/tranny mount
- HONDA CIVIC SI EG6 MONEY IS NO PROBLEM
- Crate engine
- Lemme know what you think....
- tighten steering
- 92 civic si under hood fuse box
- dash headlight help
- TIRES
- need help ASAP, IACV question??????
- Intake Question
- CAT
- Illegal in NY???
- civic clutch slippage..
- what kind of paint should i use to paint motor?
- relay
- carbon fiber lip
- front end
- where to buy a fender for my 94 coupe???
- b16a v-tec wiring
- question about ecu and tranny?
- headers??
- starting trouble!!
- Oil filter leak, please help!!!
- starter issue
- cf lip
- turbo
- 96 spec itr bearing and brake pad questions
- Water pump??
- 96-00 Civeic Thin Moldings
- Basic Diagnostic Procedures!!!
- Help...miss firing
- pic request
- Code 41: Primary oxygen sensor heater
- 98 civic si cam adjustment
- Buying a swapped EG. Need info plz.
- Trade Eclipse for Del sol!
- keep the b16a2 or swap the h22 into it?
- Will 96 GSR Cold Air Intake fit an eg?
- ITR header...where to find knock offs
- Quick simple question
- Exedy Flywheel Q
- BAD BOGGING..WONT REV PAST 2.5K
- noobie ???
- Fuel gauge not working
- An actual Vtec question
- i got jacked and im looking for
- clutch slips when cruising?
- What size tires do i need for a 1996 honda civic dx 2dr coupe with 17s
- power door lock acutuators
- rear disk brake
- how to replace headlights?
- Rear 02 sensor removal? (wire disapears into body panel??)
- bad ringlands?? how to check..
- hondata S200 ?
- whats a good LCA (lower control arm)? skunk2 ssr function7
- Whaoo! My car got stolen last night in front of my house. -San Diego-
- KNOCK SENSOR
- radio problem help
- where do i go for here??
- what to do???
- mini me timing
- cleaning a vtec solenoid screen
- safe mode maybe?
- Looking Trade for P28,P71,P61 ECU
- DC2 seats
- swap question yOoOOooOoOOoOoOO
- Question about difficulty of swapping different engines...
- brake job
- eg oem lip
- dropping a b20b in a del sol and looking to see what I need
- eg oem foglight
- Rear seatbelts dont lock for a child seat... Are seatbelts guaranteed forever?
- n00b ?'s....
- need help!!!
- My current audio project
- UNDER DASH HARNESS QUESTION??????????????????????
- broken down
- Gauge Cluster no working...
- Good machine shops???
- d16z6 charging problem
- engine light..
- I have a 98 civic ex .. i would like some opinions please
- ecu ? for my 97 b16 hatch
- aftermarket header with stock b pipe from cx
- Would a 02 1.7L civic knock sensor work on a 97 d16y8??
- i want to turbo my D15B7. i need help!
- Looking to buy coilovers...will these lower car alot...?
- struts/shocks/coilovers ?
- Quick Help~!~!~~!~
- i wanna see some b18a/b swaps
- i used some throttle body cleaner and it did wonders. (idle issue problem)
- Loss In Power?? Why??
- vtec on at all times HOW??
- **HIGH RPM NOISE --- could use advice..might need help**
- please help with my rumbling front end
- Help!!! Where do I buy 99-00 Front End Conversion
- Tried Smogging my Hatchcrap today...
- sway bar EJ for EG -searched
- suspension upgrade
- Carbon tailgate weight savings. How much?
- Headlights
- installed a new stereo but it isn't holding its settings..
- EK Rear Motor Mount..
- o2 sensor???
- B18a and an EG...
- paniting hood
- Guys need some help check engine light is on w/hondata
- WTB: B-series hydro tranny casing (prefer in the Bay Area)
- where is the "beeper" in a 96 civic ?
- USDM_92-95 civic.pdf Civic manual
- b18b swap question about ac and ps
- gsr a/c?
- Quick OEM Lip Question
- head gasket
- 3 alternators in 2 months
- Will 96-98 Rear Hatch Fit on 99-00
- motor mounts and motor for a del sol
- Check engine code not in my Haynes manual
- ecu harness
- New ECU check engine code
- New distributor on but runs real funky.....
- Will 88 CRX / Civic Springs fit on a 00 Civic Si? PLEASE HELP
- axle removal part 2
- Hondata limp mode problem ---any help would be terrific
- cam plate bolts
- Gsr questions
- cel code 21 on obd1 civic
- to all EH2 owners...
- Headers?????
- knock sensor question
- just got A/C fixed ! just one problem !
- Lost my key!!
- GSR CLUSTER INTO EK
- EG/EK Pics ***No Comments***
- Pinched fuel line
- Ok to engage vtec with O2 code going on?
- What are your chances
- Oil Pressure gauge
- 99-00 front conversion
- Center Caps
- GSR Swap
- how to align the exhaust
- Cant Go Full Throttle
- h2b axle problems
- ENGINE JUST SHUT OFF!
- high rpm noise --- could use advice..might need help
- gutted or non-gutted cat?
- FUSE BOX DIAGRAM FOR A 99 CIVIC
- Civic lower control arms...LCA's
- 96 civic skunk 2 pro IM question need help asap
- HELP: removing rear 1/4 panel side moulding
- HELP!! engine stutters every now and then after shifting into gear and giving gas!! It sometimes ha
- skunk2 shocks
- 99 honda civic probelm....car shuts off wil driving
- 99 Civic VP CPU Location?
- Help me out with the design...Help me test.
- Black mesh
- Help with Swap(s)...EG to EK
- Cheap Turbo Build for EG9 4 door
- HELP!! battery fuse keeps popping
- Am I doing somthing wrong?
- v-tech workin intermitten
- nitrous on a b18b1
- Dizzy wire harness diagram or order????
- good deal done ?
- brake fluid......question
- Steering hub and steering wheel question?
- Speedometer needle all over the place!?
- DC5-EG6?
- Distributor on wrong? Help please....
- Brake question
- yellow mantenice light
- B16a engine trouble
- d series del sol linkage to b series LS motor
- what color paint
- B16a2 Tranny
- eg civic w/ front end conversions
- Would 88-91 front shocks fit an EG??
- 5 lug conversion
- Brake conversion question
- Looking for a good shop
- saab turbo into civic need input!?!?!?!?!?
- Taking Off Spoiler
- how to remove tree sap on my car?
- noises help
- TYPE-R?
- What can make a TPS go out?
- b16a2 distributor on b16a1 motor
- Questions after installing skunk2 proseries coilovers
- Welcome your new Mods
- which cams for a b16a2
- skunk2 springs eg to ej
- 92-95 eg coupe aerogear hood install.
- carbon fiber hoods
- 94 civic with apexi n1 question....
- disc brakes????
- Just got a hatch. Had a couple of questions.
- LS in ek what throttle cable
- signs of a clutch giving out??
- *My Ek Project* (SoCal)
- jdm b16 ecu
- 99 si code 65
- huge upper rpm power lost with hi flow cat
- Any way to fit s2k gauge in 92 civic si
- what a/c compressors work with my car?
- ebay find
- SOHC IM mods.
- 92-95 EG Si and EX Brake Prop Valve??
- engine harness??
