View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Peace out to everyone in the EG forum I backstabbed you guys....
- Swapping gauge clusters in a Civic
- Finding the year of a B18C1 Engine?
- Where to splice for Resistor box?
- where do you guys buy oem parts off the internet?
- is every single d series tranny interchangeable?
- tower bars
- Cheapest way to achieve 200 whp
- Fitting for overflow?
- Pulled over for too loud of exhaust
- d16z6 for b16a2
- Can i run my car without an o2 sensor?
- Does this sound like something loose?
- i cant get my hood open
- Midpipe question ek coupe to eg hatch
- RSX CONVERSION
- Ok i searched this: wiring vtec
- pivot aftermarket tach...detachable and portable?
- HEATER WILL NOT BLOW HOT AIR
- Is it VTEC?
- Manual trans service
- goin with a freind to look at buying a 2000 SI, what to look for??
- Suspension?
- how do i put my pics on here?
- D16Z6 backfires?
- CEL comes on when it's cold outside?
- 95 Cx with black interior. Stock?
- Where to shop?
- Horrible noise after Tein S-Tech install!
- Underdrive Pulley Question?!
- Eh Hatch rear gathers speakers question
- ATTN:: mods! how to upgrade account? EK hatch for sale
- need help
- if you had 4k to put into a 00 civic si what would it be...
- 92 eg stolen Seattle WA
- i need a chassis code...will take 2 seconds...please
- NEED HELP - HOW TO d16y8 auto harness to manual
- weird brake pad wearing
- purge cut off solenoid problems on b18b1
- Plastic piece under the car
- head question?
- d15b cams in d16z6
- werid trans noise
- h23 swap
- spring/shock fitment
- it works............
- need help
- Rear coilovers. Need how to
- Help i'm getting code 22 and 41! what do i do??
- Sway Bars
- B-series transmission indentification
- newaneed help:: my si's engine check light is on but i need to pass smog ASAP!!
- itr front end converion on an eg
- cell 20. help..
- Door Panels
- Can someone help me out with this?
- anyone have the clifford matrix 3.5 rsx?
- timing light
- Question about spoon calipers
- removal of stock stereo
- Skunk 2 intake manifold
- B20 block B16a1 head
- NEED HELP WITH VETC SEETINGS
- b16 in a eg oil problems and lack of power?
- Tranny Problems... Please help... My tranny really hates me!!!!!
- flare on 2-3 shift
- tried but no responses
- will this work
- people with PLX's.. where did you mount your display?
- ANTIFREEZE
- KYB Mounting Question
- Will ITR exhaust be too short for my ek coupe?
- H&R Race Fitment Question
- mini me distributor will i need one if i switch the head ?
- helms manual...
- LS swap in an EG
- Differences between CF and "CF"?
- eg with manul rack, High speed unstable
- Idle Stumbling please help...
- Electrical load detector HELP.
- motor is out of the car What necessities should be done before it goes in
- Need heat, its cold outside
- Anyone have pics of this...
- My attempt at a DIY manifold swap...Didnt work to well
- searched what if new ecu will not pass inspecion b/c it is a diff. VIN number
- DIY Headlights for Del Sol....i know, another post like this again....
- Ebay Scammers
- bolted engine wrong caused damage
- b16 with no/weak spark
- Check engine light on
- timing belt questions...
- eam big rotor install
- Seafoamed my car... now it runs like shit man!
- 96-98 Taillights fit on 92 95 ??
- fan switch --> fan doesn't turn on
- whats need for a b series swap in a del sol
- 2000 civic CEL Code
- Does anything bolt up here... d16y8 Head
- New to the forum. Need some input on where to start.
- auto to maunal swap help!
- ECu problem i don't know
- What came first: Chicken or the egg??
- Oil in coolant gallies....Help??
- Car won't start up..
- Need help diagnosing problem...suspension gurus, etc. needed!!!!!
- HELP QUICK!!!
- diy ctr headlights
- If i unplug VAFC2, do i lose my settings?
- short shifter..which 1?
- Vaccum question
- TPS testing and setting procedure?
- WHATS THE DEAL W/ THE FAKE MUGEN FORMAULA COVER TO THE REAL ON?
- I recieved a 2000 civic si front end for free and I want to coinvert my EG. Any advice?
- Anything else to replace besides broken axle??
- b16a2 problems all over the place please help me out guys
- ek???
- eg and ek head
- my new website with my turbo del sol
- Maintinance intervals?
- Need opinions on ls vtec fully built or ls fully built and turbo
- skunk2 short shifter question
- heater problems
- Need to help Juliana with donations
- Changing fuel filter on 1996 civic ex, first time newbie, do I need crows feet?
- Rad Fluid
- driver side motor mount question
- problem with the auto tranny
- SOHC ZC vs. D16Z6 (searched archives)
- vafc 2 wat are your thoughts
- Mounting Springs on KYB's
- Zc engine wiring???????????
- JDM B16 Hoses on Intake Manifold....
- ZC Head on D16z6 Bottom??
- Where the HX thread?
- any HowTo on how to remove instrument cluster from 98 civic? (new lights)
- 95 del Sol VTEC recurring idle/bucking problem - help?
- Best pistons for a turbo b16 setup?
- Header
- Dyno In Ny??
- question about 17's on civic
- Summer tires hold in light snow???
- Should i sell these rims? Not sure if they are rare honda rims.
- b18c1 or b20z
- Anyone have cluster and underdash plug pinouts for a '94 cx hatch?
- SS autochrome manifold turbo kit.. ANy good?????
- weenie heater
- civic 92-95 quarter panel skin
- will i need any more things for mini me ?
- my white 92 hatch was stolen on monday morning
- CAR SITTING FOR 3 MONTHS
- cut deadcoils..am i ghetto now?
- sohc with spray vs b16 hatch
- Anyone ever use a c-pillar bar?
- What's your favorite 14" or 15" stock wheel?
- Bad Idle WHy ???
- B16A auto / manual tranny
- Tranny not goin into 3rd Gear all the time, grinding, wont downshift into 3rd HELP !
- VIS products good or bad?
- ignition coil
- spoon radiator cap fitment
- Considering OBDIIb-OBD1 conversion but have questions!
- dang thieves..
- Overpriced Maybe?
- walbro 255lph?
- air compressor
- Riced Stock Civic = Thief Repellent?
- vacumm hose problem?!
- Ontario guys i need some help
- i need motor help
- radiator leak...NEED HELP!!
- wENT BACK TO THE TRACK TONIGHT...
- Steps for tdc?
- how to bypass main realy
- Automatic DOHC ZC 2nd GEN
- body kit
- B&M Short Shifter Question
- Someone please tell me why...
- What color primer to use with roma red???
- Oil cap question?
- cold start chattering..
- Frankenstein motor questions
- Is It Hard To Remove A Steering Wheel With An Airbag?
- motor swap, but axles do i use?!
- **L//CON Engineering Traction Bar Review**
- del sol trunk
- rear window question 92-95 hatch
- Need another gauge spot in your sol?
- Car sputtering and dying.
- Buddy Club exhausts?
- rear bumper support?
- Weight difference
- 93 Civic EX Car idels funny then acts like it wants to die HELP
- Where to download best motoring video's
- electrical
- Need help. 98 Civic no acceleration after 5000RPM
- just got dynoed
- timing for a b16
- Genesis Speak.
- Checked timing belt, now squealing goes on...?
- Stock civic vs Stock Integra springs
- code p0117
- Radiator Fluid..
- 94 si hatch
- can i make my d15 distributor work in my b18a
- is my ecu obd1 or obd2 please help
- What are the differences between a D16Y5 (VTEC E) & D16Y8 (VTEC)?
- Quick Question
- engine vibrates when I turn it on and wants to die
- Radio works, but not in my car...Help
- oxygen content CEL
- i need help
- are these ek side skirts??
- ZC transmission code
- 96-98 exhaust
- 92 Civic SI, CEL kicking kicking in ~5000rpm
- Good example of cheap "coil sleeves"
- fuse for fuel injoector
- C32A swap Question
- Mirrors for EG
- 92 Civic Si with GSR swap
- Door and Fender removal Del Sol.
- civic cx mileage
- 93 del sol
- PLEASE HELP!!! Could this be a thermostat problem?
- will a 94 accord trans work for a h22?
- engine ground?
- Car doesn't idle well after starting when it's butt crack cold...
- Fuel Rail Nut freespins
- Metal plate under drivers side dash
- Help with Esuse fog light electrical / wiring
- Help Identifying plug on intake manifold
- STRIPPED NUT...
- removing needles off of cluster..done it? I need some assistance
- CEL code 14, stumped me.. can't figure out how to fix it.. HELP!! *long*
- autometer boost gauge ignition wire?
- 96-98 head light
- 2 questions... (search is down)
- motor mounts on a del sol
- Civic taillight, one more try
- ECU chips on stock cars
- carfax needed will someone help
- b16 torque sequence for ARP head studs
- Need help installing o2 sim. in obdIIb car
- S2000 Tach Question
- Falken Azenis vs Yoko ES100's
- idiot ? about B16a2 from my EM1
- 92-95 back seat removal?
- Noob Question. How much power out of EG Si?
- Loose rotor in distributor
