View Full Version : Honda Civic / Del Sol (1992 - 2000)
- removing rota centercaps
- Integra muffler on civic
- resistor box: reverting back to stock injectors
- HELP! new headlights, only high beam and parking lights work Type-r fakes H7 bulbs
- That's it, I can't stand another archived topic on GSR/ITR dash into EG...my question is...
- GE 9003sb = GREAT!!
- car ran for about 5 miles just fine (after new engine installed) then died, what to do?
- Car Wont Start!
- Removing door panels on 00 SI
- I need some detailed information on putting a stereo in a 96 civic ex
- ABS Spoon lip
- What is the part number for the ECU I need? (New Car) (Did a search)
- EG and del sol body kit fit....quick answer!!!
- 96-00 driver side motor mount replacment
- Rear view mirror fell off, what kind of glue?
- Will Low Oil Make My CEL 23 come one
- Header question. Eg/H22
- H22 in a 98 ex?
- 2000 EX wiring harness on 98 CX motor
- exhaust problems
- 1997 Honda Civic DX motor?
- Anyone know someone or has an F22 in an EG coupe or hatch
- I need a pic of tanabe hyper cat on a EG ? anyone?
- Brake line size
- help-obd2-obd2b conversion harness.
- 99/00 Civic coupe rear lip
- eg with h22 and turbo questions??????
- heater hose pictures
- need help with distributor
- How long should it take for the ecu to regain emission codes
- Look yo. Took myB18b non-vtec DX coupe to the track.
- electrical problem with my 00 Civic Si
- 93 hatch a/c fit in 95 sedan?
- volk center caps
- Ok so Nice and slow vs Fast and ghetto
- anybody has ever seafoam their car??
- disable passenger airbag
- Lightweight wheels more prone to crack?
- 4door vs 2door harness?
- Doing swap, need help with transmission info!
- rear seats in a 92 hatch
- little door help.
- My abused but still bad-ass Honda Battery
- Best ECU
- rear washer trick...
- how to bleed the brake system??
- My Dream Honda (56K, I have about 37 pictures of parts)
- Strange behavior 98 SI
- 96-98 replica ctr lips?
- 93 ex bolt pattern???
- where is the main relay:94 civic lx 4dr
- OEM shocks/struts; mileage?
- well the car is dead
- Will ITR LCA's fit a Hatchback?
- How do you disconnect the secondary o2?
- the best place to purchase a carbon fiber hood/products?
- Wheres the knock sensor located?
- cat length???
- Does anyone on here knows whos car this is?
- eg jdm thin moldings?
- Post the " how to " threads you remember here
- EXHAUST GASKET HELP...
- WilWood Brakes
- info on ITR engined mini
- help! trouble removing my oil pan!
- Brake Experts: 99-00 Si Swap onto 93 EG
- SUSPENSION
- Smoke in the a/c vents?
- ok trying to post pics of my jdm sol in uk
- Swap order ... b18c1 + boost + ecu
- Performing an engine swap – how long does it usually take?
- Hi i am newish, how do i post pics?
- Auto Taser: the shock of your life
- Where to place lightweight battery in a Del Sol?
- Gunmetal paint?
- Intro, Yet Another Noob
- can 98 civic do the silverstar conversion?
- JDM ITR B18C, no VTEC pressure switch??
- ecu?
- manifold protection, car too low?
- Where can I find those o-rings for my Skunk2 coil overs?
- need help with odd electrical problem
- VAFC Wiring Diagrams
- Help with alarm/fuel cut off on Hatch
- B18c1 Civic Swap
- D-series IM: Skunk2 or keep the y8?
- Trying to learn about trannies and have a question.
- (new to civic) need help with brakes (my civic has no brakes at all)...please help...
- Weird noise coming from gas tank
- VTEC wiring HELP!
- Does Anyone konw what CEL 35 Is?
- STOLEN LIP!! north austin, tx
- wires going to brake master cylinder?? pics inside
- VIS CF hood
- Is the 96-00 WaterPump The Same As The 92-95 Waterpump?
- Handling problems after installing SPC rear lower control arms...
- Some new CTR lip picts for you "old skool" EK front end folks
- Intake manifold gasket
- Day 1 of my swap PICS
- New motor trouble
- Good Set-up or not?
- Racing seats?
- 98 EX headlight conversion help?
- Would Comptech's Integra Tie/Sway bar setup fit on 92-95 civic?
- powdercoating wheels
- b20b into del sol, hose problem
- anybody have vacuum diagram for clutch.. i need help..
- Finally got my 4.78 FD tranny in..............Thanks Brian
- Wadda ya think of Axis MagLites?
- aem v2: what do u guys think?
- Which seats for EG
- hi new member ^_^
- how many wires?
- REVIEW: ITR shocks, ITR LCA's, RS*R springs on EJ2
- I finally got my car!! 2000 Civic DX Hatch
- obd1 obd2 convertion legal?????????????
- stupid question
- custom exhaust sounds like crap...sounds like a frickin go-ped
- black clutch fluid? (doesn't stay clean..)
- Question Need help from tech guys
- Difference between JDM and USDM Eg headlights
- OT kinda......hilarous Japanese translation of del Sol product site.....
- weapon-R throttle cam
- B16A TB on a ZC
- Newbie here, just wana share pics of my ride and my friends rides.
- d16z6 vs d16y8
- Installed my JDMshit.com Carbon hood and duckbill
- Exhaust Question???
- Mail man visit today!
- civic header, rust...
- b16a throttle body
- Air/Fuel guage hookup
- B16 Dyno
- Choose one.....
- integra seats?
- 95 civic coupe body moldings
- swap price
- What're some engine options for a 94 Civic CX.
- Kyokugen lug nuts
- coil-over spring rates
- can anyone donate a minime turbo zdyne startup program
- How much to replace a 3rd gear synchro?
- ITR CAT FIT 99-00 SI OR SOHC EX??
- any1 know where to Buy Rots'a in S.Florida?
- knock sensor???????
- Wut 2 D0...........
- What is the best HID setup for an eg?
- a few questions on my swap
- Fuel pressure on GSR swap.
- can i achieve low 15's with a jdm d15b civic coupe?
- Greetings! I got an EK! yay!
- Build ideas : Powerplant?
- Edelbrock Y8 Performer X intake manifold, now available!
- auto -> manual swap done...need help
- ES OVAL?
- Will EG KYB AGX's fit my DC2?
- heater hoses
- TDC
- B18C1 overheating - 94 Si
- 00 si seats in 92 hatch
- getting civic hatch...is type r worth it?
- install Indiglo Gauges
- Doing alighment yourself???
- GSR swap with early redline problem! Can anyone help?
- Finally found a hatch...
- What we should do to prevent stealing...
- 2000 EK GSR Hatch
- Hayame coilovers - any experience?
- hypertech shogun questions for anyone who has one?
- '93 DelSol S rear speakers
- Honda crate motor!
- Del Sol Gauges question ?? 911 plz
- Why does my car make all these stupid noises?? Help!!
- Oil lubrification vs damage
- Sk2 Tie bar keeps hitting my exhaust? Help!
- What kind of shock/struts and springs are you using in your ek?
- header vs headers
- My ride is killing me...
- tranny swap cost?
- Anyway to Rollback mileage?
- thread pitch on master cylinder?
- 1994 Civic Cx Code 41 o2 primary heater.......... Reward inside, if helped
- Lowered? Issues w/ Rear Seatbelts?
- Distributor Cap Bolt
- I am THE luckiest man ALIVE * car theft attempt *
- Your methods to prevent vandalism??
- So I broke 70% of the clips...
- Updated my interior (EG), lost weight and added JDM goodness. pics.
- ??Legit Engines.....
- How can i lighten my Del Sol?
- who's SI is this?
- help with catalytic converter
- radiator choices??
- How to fix Exhaust?
- Parting out
- a/c
- Clicking noise & whine from transmission...
- couple of pics of my ride
- what do you do to lighten your eg hatches
- A nice and Clean Intake
- good deal on a type r swapped 97....? ebay link.
- 2000 SIR suspension setup
- brake question
- b16 headers
- if you could have a do over...
- 94 HB swap...what do yah think.
- D16Z6 Valve Cover Ground Wire, NEED PIC
- what should or can i do with 6,000??????
- ls boost or ls vtec
- Climate control Lights... 92 civic CX... I want it to light up
- Exhaust Question
- How much 4 `98Ex g.cluster
- Almost Done With Swap!
- anyone have the website or contact info for...
- CEL flashing, SRS light too...
- Like help or something!!! CF Hood question!
- where can I find exhaust transition flanges?
- motor question
- *GRIPE* Just another honda break in...
- alarm question...
- how hard is it to make an EG exhaust on EK
- how does the seatbelt operate??
- Disable key warning beeper? (Yes I searched)
- MY new coilovers (what do ya think)?
- 92-95 coupe w/ apexi N1 pics NEEDED!!
- Expected MPG increase with the AEM CAI on my 99EX?
- Ek with MoonRoof?
- type r rear section bolt onto a 95 civic dx coupe?
- Getting rid of the orange in the headlight. Somewhat...
- h22 swap
- Auto To Manual Swap? ? ?
- most f*cked up day ever help...
- Anyone with pics of 5" cf tach at night.
- Holy crap, look at all the metal!
- can someone please help post pix of my ride?
- problems with a vx..
- Good numbers?
- Help with oil pressure gauge1
- LS w/ gsr trans vs. LS w/ itr trans Turbo.?
- Where to get clear roof for 93 Delsol??
- For Sale: AEM short ram intake for $50!
- Tanabe Super Racing Medallion for sale
- d16y8 question
- Help QUICK can we use a 97 EX A/T harness on a B18C5 swap????
- 99-00 mirrors onto a 92-95 civic template.
- Need opinions on our new intro page. LOOK PLEASE
- New Clutch YEAH!!, but....
