View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Honda Tech Mems need help
- 92 civic 4 sale
- 99 Civic Si salvage title question!
- How many cans of R-134a would I use in my A/C system?
- thalternator going, what o do
- B18c gsr pistons?
- Just got a 96 coupe.. what to do?
- b16 intermediate shaft
- H&R OE Vs. H&R Sport??
- do any of you 92-95 civics have a "gangsta lean"!??!?!!?
- TYPHOON AEBS INTAKE ?
- Jun Complete Block
- Are these Jdm ?
- Del sol B16A...B18C1
- '95 Civic Hatchback... Is it worth it???
- Forum Question
- Axxis Metal Master brake pad question...
- gsr flywheel and 99 si flywheel question
- Honda Insight
- Am I Late Or Did I Find The Spoon Plastic Lip For 92-95 Civics!?!!?!?
- HELP!!! Is This Safe?????????
- MY car stolen =/
- Did 92 Si civic hatch come with rear disc brakes?
- Seibon carbon fiber wing
- More Problems...
- EIbach Sway Bar Kit? Opinions needed
- help meeee where is the ait
- Can you reuse stock ABS lines goin from Drum>>Disc??
- CAR STOLEN SAN JOSE AREA
- How do you remove the "reset" button on a EX cluster?
- b18c1 in EG...which radiator hoses do I use??? (civic or integra)
- 99-00 rear disc conversion
- Seat Question
- Minime idle problems
- Headgasket problems
- Cat size...
- swap done...PROBLEMS
- SCAMMMER ALERT WA STATE\\\\CALLING ALL WA GUYS
- WTF is a steering knuckle????
- Just got a 96 Coupe.. what to do?
- hondata?
- Another Civic Eg Wiring problem, sorry
- rsx door panels in an ek
- rear disc brake pad interchangability/compatibility
- Final answer...integra seats into an ej coupe...
- what turbo i should get....
- motor oil question
- Engine service light...
- Integra Steering Wheel Conversion Del Sol 56k no way
- how to match miles on new cluster
- Waterless radiator fluid
- body kit fitting 95 sedan?
- 99 b18c1 idling at 1500 rpms. what causes this???
- 04 tail light
- boring 1.8l to 2.0l
- hx offset?
- Minor Track Woe! Please Help
- Mugen question
- How much could I sell a EG with CTR swap for?
- Crazy problem with my b18c1
- HELP... HEADLIGHT PROBLEM =(
- how do i fix this part of my headlights?
- How much power does you B16 make???
- D17 block with Y8 head?
- is vtec working
- Power steering removal..problem !
- A/C Conversion
- Quick question about cluster.
- what a/c mount to use to keep A/c in 2000 ex going bseries civic and powersteering?
- what do you guys with h series swaps do about catalytic converters?
- which ecu chip is best(sohc plz)?
- car won't start plz help
- clutch suggestion
- idle problem
- Integra cluster swap harness...
- sohc header?
- 98+ civic stereo help
- Need some experienced advice, clutch/trannie problem
- GSR in a 02 Civic?
- 99 si power door into 97 cx hatch
- Starter Kill Switch
- PLEASE HELP!! HOW MANY 92 SI'S WERE MADE??????
- fuel injectors
- how HARd...
- neuspeed soft/race sprins og my sol?????????
- EG and EJ spring/strut question
- D16a1 pistons
- need exhuast oppinions- please help!
- ZC Clutch fit D-Series?
- Lights (searched)
- after fixing my Itr swap problems..now I have wiring problems ..PLEASE HELP!
- D17 turbo???
- Itr gauge cluster in EG
- Urgent, need uberdata help!!
- y8 manifold on a y7 block. Coolant lines go where?
- headlights
- bseries air conditioning
- Thanks to everyone that has helped me over the years
- Camber kits, does brand name matter?
- b16 sedan
- Jdm D15b or D16z6-z8-z7?????????
- 01+ Valve Cover Interchangability?
- Tranny?
- Will an overtightened timing belt cause major problems?
- 1992 civic engine swap
- 1992 Honda Civic Engine Mods.... NEED HELP!!!
- Best place to find exhaust gaskets and bolts?
- WILL IT WORK: 15" w/ 65 sidewall & H&R Sport springs?! HELP NEEDED
- exhaust question
- jdm civic sir rear sway
- please help my lights are dead head/dash
- '97 Cracked manifold under warranty?
- MSD IGNITION- who is running what?.. whats better for a turbo
- b16 or h22
- Help changing alternator belt on my b16
- What headunit are you using? (EG audio related topic)
- What should SHE get? 04 si or ex?
- d16z6 a 4 wire o2?
- Honda EG wheel base 92-95 civic
- ECU question...
- need help
- EK rear LCAs and JDM ITR suspension
- BARing a Skunk2 IM on GSR
- Cant remove civic crank pulley
- Good Price? B16A Engine and Hydro Tranny.
- CANT FIND THE RIGHT BULB 4 MY EG9
- Dry or Wet?
- Header Question ??
- Spark Plug Question??? About Heat Range????
- How would a b16a be wired to a 92 LX?
- Will EG6 front bumper fit a EG9
- window film with AC
- please help, i have a VTEC-E D15Z
- Bumper Screw Bolt
- srr rear tow adjustment kits - where to buy?!
- 94 hatch door panel
- gauge temp goin up???
- obd2>obd1 conversion ? (already searched)
- tps or not
- Coupe Front Bumper
- Replaced fuel filter, gas coming out of fuel line??? 93 del sol si
- 1.5 dx harness on gsr. help
- nitrous in hatch
- CLUTCH MASTER STAGE 3 OR SPOON CLUTCH?
- No CEL?
- All Motor D16y8 coupe times?
- Anyone need an OEM-style axleback/muffler section for a EG hatch?
- Suspension shop in so cal?
- Damn Theives
- any serious b16 build ups all motor
- Importing a CTR
- my little b16
- Front brake problem
- MINI ME, You Complete ME!!! (HUMBLE-TECH)
- jdm itr front end conversion on a del sol????
- ctr momo steering wheel question
- Need some help ???
- Cusco LSD what type of fluid
- 2004 Civic Si COUPE?!?!-not cool
- 1993 Civic DX caliper rebuild
- is this the right brack for ITR rear sway bar on my 99 Si Coupe?
- gsr swap with hydro tranny??
- RADIATOR SUPPORT REPLACEMENT
- HELP! Manual to power steering conversion
- Did everyone put there flywheels shield back on?
- 2001 Gsr Motor swap into my 2000 civic sohc non vtec help please
- Fast Hatch FS
- can is use b16 injectors in mini me swap.
- HOOK UPS RACE SHOP????? READ
- hood pin install on c/f hood
- tranny wont come off
- Anybody use the Fram quick oil change setup?
- Allright this is cracked in my car could this affect my cars vibartion?
- z6 head on y7 block
- brake question.
- MAP sensor on swap?
- Pinning Main Wire Harness in OBD2a
- Which sway bars for EK
- Help with question on setting cam gears????
- y7 and y8 head studs = same??
- What Brake Upgrade for Front EK (Did Search)
- ek hatch owners with power doors
- idle air control valve
- oil plug size
- hard to get the car in gear
- Bolt on rear LCA for removing strut. WONT BUDGE . what to do??
- sohc ac compressor on a b16?
- Which AEM intake for '99 Civic EX?
- sway bars??
- How low is toooooo low??????dc
- swap problems
- 97 civic bolt diagram
- wtb Correct Power Steering brackets for b18c1 into EK...
- Newbie! with some B18C4 questions....
- got bored pics for late night guys 56k no way
- ABS not kickin in on an ek...?
- Just installed the Type R motor today..but having some problems
- B20b w/ b16 tranny vs B20b w/ gsr tranny.
- ******PLEASE HELP ECU PROBLEMS, NEED HELP***********
- quick question?
- check if i have evrything for minime?
- Flywheel question plz help
- b16 speed sensor
- will a 2000 Civic SI AirConditiong system bolt rite into a 96 civic DX Hatch?
- HELP! JDM d15b .......
- new flywheel resurfacing?
- All around disc brakes on DX
- Cant tell if car is Overheating
- finally got on the scale
- hub issues, need help ASAP
- HOW to: Paint brakes.
- No oil light, car won't crank anymore...electrical problem? Help!! I give up..
- D15 VTEC swap info
- crossed hoses and fluids in wrong spots ?! what to do
- Insuring RHD EG?
- Urgent Help with dead Engine...
- Hondata Headgasket
- Are 92 cx injectors equivalent to jdm d15b vtec(or maybe z6?) injectors?
- Question about a part I saw
- Possible CV Joint/Axle problem...?
- O2 problems
- Finding a b16 engine
- ground control sleeves?
- Fiber Glass Bumper
- what does upgraded/aftermarket LCA do?
- post pics here!!
- 1995 white Civic Si
- where can i get crower rod bolts
- General civic SI questions.
- Need of stock muffler...
- Brake pads
- code 9 help please???
- B16A Injector Q...
- EK's and handling
- Problems with Idle/AC/Misfire codes
- No spark with MSD ignition, just started after like 5 months of working
- how to
- Three months later, CELs 63, 41, and 20 still remain
- which engine in 99 vti manufactured in pakistan
- How to fix EG cup holder???? Wont stay closed????
- help with axles
- Buddy Club Spec III Exhaust for Del Sol???
- Honda Civic with a ZC swap
- D16z6 mods
- Hydrolock scare tonight
- SOHC TURBO DYNO : BOOSTEDED9
- EG hatch/sedan taillight help needed
- HELP: New 02 sensor, still CEL 1 <== Steps to trouble shooting CEL 1 inside
- RPS street clutches?
- Need HELP on EK front conversion on del sol
